View Full Version : Beginners
- What is possible in this hobby ...
- U can do 3d 46
- What do you use to clean your monokote?
- SIG Mark II Engine ?
- Air Buble in my fuel lines
- SIG Accessory Kit ?
- Elevons backwards
- i have officially crossed over
- Super Tigre G 90 Muffler: Lost front baffle
- Learn to fly ASAP
- Four planes, one night, Awesome feeling
- Darn those hungry Corn fields!
- Which Fuel tank for Kadet Mark II?
- 28 years later I just flew ! I did it !
- HobbyZone Struts?
- Just bought a slow stix and a Spectrum Dx6i and having trouble
- need some 6
- CA Kicker ?
- repairing foam fuse??
- Define "Scale" for me?
- Choice - To much of a good thing!
- Build your own RX battery pack.
- Reciever Questions
- Just bought a 1.8m Cessna!
- The Return of the Avistar RTF - Now it's Elite!
- servos????
- Perhaps the dumbest question of the month
- Sig LT-40 control throws, cant find my build manual
- Evolution .52 Engine
- Good Starter Plane
- Help getting my OS 46ax up and running out of storage
- Good DHC-2 beaver float plans?
- New to e-power flying? Get the low down in here from experienced e-power RC pilots!
- Rudder servo
- RC Flying Clubs in NJ
- Volt spy question
- noob in boats with an electric plane question.
- engine/wing question
- Need Carbon Fiber 3-Bladed Props
- Help me get into rc airplanes!
- CG falcon foamie electric ?
- LT-40 vs. Kadet mk II
- Skyraider Mach 1 and FS52AR engine?
- Cox Wings WW2 Aircraft RTF
- How much downthrust is right?
- Foamie ID ? Got 3 for 40 with stuff.
- thrust weight ratio
- 60 size ARF
- AGAIN , aileron to flap ratio size
- brushless question
- Help with prop sizes and electric motors
- Maiden my Escapade...
- Some detailed RC Information!!!...(refer to 1st post)
- Hobbico Avistar a Performer?
- New Guy
- RX Battery wires
- RX antenna routing ?
- airtronics vg4r
- Spinner nut falls off
- First glider tow
- Non-OS engines
- going to fly again after 4-5 yr sabbitcal - help getting my planes airworthy again
- Transmitter/Receiver compatability question
- Disconect allerions on a trainer 40 ?
- Need help with a foamy
- Transmitter use
- Ultracote and Ultracote plus
- DX7 dual rate
- Suggest an electric engine for my r/c plane
- It`s alive Hobbico 40 , 40 LA.
- Help with something I have never seen
- Saito FA 56 no needle valve ?
- Can YOU tune a 4 stroke by ear?
- RCEXL OPTO KILLSWITCH ON ZENOAH G26EI
- To baffle or not to baffle
- Chip Hyde's tunnel vision
- Bought my first house AND bought/flew my first plane today
- New at the hobby! need lots of advice!
- Technique for changing pushrod connections
- engine/motor suggestions for a newb
- O.S .46LA Head Gasket Help
- Spinner prop nut
- Park Zone/Hobbyzonewhat's the difference?
- Scale Cessna 182 for Newb
- Transmitter for NEWB
- RX and battery mounting ? and push rods.
- Banana hoby/ blitzrcworks warning
- BIG HEAT!!!
- Different engines, Glow, Gas, please explain.
- Can you recommend a plane for me?
- lateral balance Question
- Metal spinners...Nose cones ?
- Hi Guys,Newb needs help !!!
- Question about servo noise
- next plane
- Are slow sticks god to start with?
- Rudder on takeoff help
- What goes up must come down, right?
- Converting Champ to 4 channel
- Help With A new Plane Choice
- Can Servo Handle 2 Rods on 1 Horn (same side)?
- I could not resist...
- smith mini plane balanced but still wants to climb
- Transmitter tray?
- Great flying today
- Futaba gold series FM
- dx5e Buddy box
- need a slimline gas fueling system
- Wings For Wishes Benefit Fun Fly
- Gene Gull Wing
- Newb in MD
- New to RC flying, and some questions for future builds.
- Mixing on a plane
- plans
- Avistar RX Batt and prop?
- Make that Trainer smoother at landing speeds
- Pine vs Basswood
- 4 Stroke Prop Nut
- Pictures of your engine test stand
- 1st U.S. RC Flight School
- plane engine
- Where in marine Bill
- How to handle the guys with flawed plans?
- How to trim without subtrim
- Why this is the best hobby in the world
- Airtronics Receiver problem
- Best trainer plane for a Complete Beginner
- new to RCU and flying have some ?'s
- Lanyu Primary 100
- What kind of transmitter is good for beginner airplanes?
- Landing Gear Reinforcement
- Flaps going in opposite direction.
- Fuel hose routing on a 4 stroke?
- Engine Mount for a Test Stand
- Engin mount older nexstar 40 monocoat.
- Inherited Planes
- Interesting experience with Tower Hobbies
- Flaps-/Elevator Programing DX6i
- JR PCM10SX Stick Mode (s).
- RPM's in OS .40
- EasySky Mico Remote Control Sport Plane "Dolphin Glider" 2.4 G 4ch Brushless EPO RTF
- New design -Airplanes with Anti-crash Motor Mount
- Troy Built
- engine dying
- Questionj regarding the folding propellers
- recommendation for small trainer ARF
- Propeller-Motor extender adapter
- Another newbie with a Staggerwing!
- 20 yr old stuff- back into service
- which way is better
- Novice in Need
- first flight
- New T28 Trojan.. well replacement
- Easy Fly 40 Dimensions
- What Makes a Good Beginner Plane???-See Here (&download PDF in Post#1)
- Multiplex Elapor foam
- First Kit
- Painting a prop
- Love my Kadet LT40
- Bomb Door's
- Help building first plane
- Getting back into it . Motor quetions..alot.
- New to planes!
- LAUNCHING PVA MODELS WEBSITE IN INDIA
- Noob with a plane (kinda)
- Ideal trainer
- birthday party for Keith
- General Hobby or Hobby4less, experiences?
- Fuel Issues
- Hi Everyone
- Tactic 440
- Finally got a real plane
- A new rogue pilot with questions
- Guillows Cesna 150 with COX .020 Pee Wee RC
- rubber bands for wing hold
- where to put my battery pack? help
- Heli pilot - choosing a plane
- Any Mac users here?
- CG for SIGG Smith Mini Plane?
- right engine
- Need Remote Control Help for old Hobbico Sky Runner
- Nexstar Wing Help
- A Beginner - wanting to have a trainer plane + engine - please help
- 15CC Gas engine for Senior Kadet
- is this normal? Electric motor mounted to the right
- Plane Cleaning
- Unhinging a control surface
- Engine Mounting Problem
- What difference between Futaba FP-T8UHP and T8UHPS
- 7 year old flying
- Servos
- Join us for an electric fly-in
- Hobbico Starter
- RETRACTS
- Can you tell me what airplane this is...?
- CG Calculator
- servo actuated kill switch gas engine
- Spectrum receivers
- Next plane / First plane
- Steerable Tailwheel on GP Big Stik
- Noob question on c of g
- Real Flight G2
- What I don't like about the Apprentice 15E
- What I like about the Apprentice 15E
- i have an OS .40 la.
- De-greasing an engine
- chargers
- NOOB Needs HELP with electronics of electric flight
- aluminum wing tube
- Hanger 9 Alpha 40 trainer with a Saito 56?
- Park flying
- Help me identify a plane I inherited in 1997
- MOVED: Cobra Build Thread
- Great Trainer
- Battery Setup for 24 Volts
- Electric motors
- Advice before I fly a warbird with landing gear
- Engine mounting and pushrod setup
- HZ Champ floats? Added a question about motor swap
- Top Flite p 47, ok for a first plane?
- I DID IT!!First solo flight, well first flight period
- Parkzone Spitfire MK IX...beginner question
- On Off Switch connection
- Debbie's RC World
- Lost a screw on my dle-55
- electric motor
- Balsa and Temperature changes
- 56inch Yak 54
- Rocket powered glider
- Small tuning issue
- binding question
- new wire for the ignition control switch wire
- dle-55
- batteries and chargers?????
- Brand New
- Older planes upgrading to 2.4 tech. question?
- First flight today!
- Solo
- OS 75AX- Do I need to change the piston liner (or anything else)
- Flights per Day
- set timing on OS 61
- Need some wire
- Tunigy Accucell6 and 2 x AA nimh
- Tape type requirement
- does anyone know a good place to fly in NYC?
- Power supply question
- Airtronics RDS 8000 Radio
- Removing Aileron
- Looking for small, first 4 Ch plane
