PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Speakin' about fuel
  2. Spoilers????
  3. 4 stroke Break in and Castor Oil
  4. need help finding a trainer
  5. Need Help or Advice on beginner model
  6. got the kit
  7. Cleaning engine without removing?
  8. How do I cover a wing fillet
  9. Finally fired up the enigine
  10. Old Futaba radio and Hitec Eclipse 7 trainer cord?
  11. Plane in storage 2 yrs now carb stuck
  12. Engine Test Stand?
  13. morgans fuel
  14. Could use a little advice on next airplane choice
  15. Replacing Nylon pushrod with metal.
  16. Engine wont start?
  17. PLANE WIGGLES TAIL
  18. ME109: I want to change the motor to a brushless one!
  19. Help!!! What size engine???
  20. cutting out of tail servos
  21. Suer Tigre Dies in the air!!!
  22. Gotta recommend this plane...
  23. Is this a good deal or did I get hoodwinked
  24. can not believe it...
  25. Whats the rudder for!!! ?
  26. 1st weekend missed this year :(
  27. fuel inside the fuse...
  28. engine or 2.4?
  29. Replacing a 46 ax with 4 stroke
  30. Phoenix Dolphin, How are they?
  31. first time builder
  32. High tension poles
  33. wing mods for a next star
  34. head temps
  35. 11x5 or 11x6?
  36. Gas Engines!?
  37. Another prop safety tip
  38. Prop Safety, NEVER let your guard down. Warning: Bloody picture
  39. Radio fixed, now engine trouble...
  40. Big Day for My Daughter
  41. Macs tuned pipe for OS 46AX
  42. ng for the manualkondor models yak 54
  43. 4*60 manual???
  44. ESC choice???
  45. PLANE advise.......please lol
  46. weight range
  47. Carb leaking fuel
  48. My Futaba Set-Up
  49. CIRRUS Servos
  50. Mounting a 2.4 Ghz Faast Rx
  51. OS 75AX
  52. Beginner Dad training beginner son!
  53. proud of my Grandson
  54. Radio problems with mustang PTS...
  55. futaba 7c 2.4 ghz timer
  56. DX7 fuse replaced - now radio is always on.
  57. Building my first kit
  58. JT servo extensions
  59. rtf or building
  60. Super Cub LP Picture
  61. what reciever battery do need?
  62. Advice for teaching my son
  63. smook now !!!!
  64. SIG ARF glue failure's (Kadets etc)
  65. wont turn??
  66. Hobbico Superstar 40 CG
  67. 2.4 Mounting question
  68. Super Cub LP Jitter
  69. radio equipment
  70. kadet seniorita plans
  71. soldering antenna wire?
  72. What size prop for Saito 82a
  73. First Kit
  74. Buddy Box?
  75. is there a mod?
  76. Are we blogging?
  77. Pokenic's first rc airplane flight at Hamburg Flyers Club
  78. SOLO...I did it finally!
  79. Dead spot on high needle?
  80. Best 2nd Airplane?
  81. Do I need a brushless ESC for a brushless motor?
  82. Best field box?
  83. Balsa USA PHeaton II CG
  84. Reviews and recomendations pleae help
  85. aurora9
  86. Hey RCU,Wheres all the free stuff?
  87. How to convert metric servo specs to US standard?
  88. engine
  89. Maybe a silly question: side thrust - why we need it ?
  90. "Welding" Aluminum
  91. Whats a nice and cheap electric?
  92. Escapade antena...
  93. Some questions I want to ask.
  94. speed controllers
  95. difference between Futaba 6EXP and 6EXA
  96. what about these?
  97. tuned pipes
  98. almost ready
  99. Great Planes Extra 300SP Maiden Report
  100. Best airplane for beginning
  101. Engine thrust, Hobbistar 60 MK III
  102. static thrust
  103. Options for my first low wing
  104. info on air rpm
  105. larger prop
  106. Prop for SmoothE
  107. esc and battery
  108. recovering Cherokee Fuselage?
  109. weight VS stability
  110. Glow Powered Foam Flycat Build!
  111. How do you Turn Off an Airbleed Engine
  112. Cleaning engine on plane
  113. cleaning plastic part of Cherokee
  114. decathalon engine mounting
  115. Off my trainer and on to my 2nd plane
  116. Evolution .40 engine
  117. engine ranges
  118. Trying to make sense of crash on maiden?
  119. Voltwatch almost crashes my plane and then saves it!!!
  120. pylon racing
  121. HELP WITH MAKE AND MODEL
  122. futaba 7c 2.4 ghz questions
  123. thunder tiger 46
  124. Quick Fuel Question
  125. Tips?
  126. large or small prop?
  127. Snap
  128. catch me up on R/C
  129. Futaba recever antennas
  130. Calmato trainer 40
  131. Glueing Leather
  132. Where to find rubber grommets and eyelets
  133. Do you think I will be able to fly an AT-40? EDIT: FINALLY MAIDENED! Video included!
  134. Field Fuel Pump slipping
  135. New Batteries?
  136. Saito experts wanted
  137. Which Manufacturer Has Trained The Most?
  138. receiver battery
  139. discharging a lipo
  140. Best prop for a O.S. 55AX
  141. JR PCM9X and Spektrum DX7 trainer
  142. 3 bladed props
  143. New Superstar 40 Daddy!
  144. I think I'm tail heavy...
  145. Engine piston wont cycle
  146. Is this to low a prop pitch?
  147. 2stroke vs 4stroke
  148. motor choice
  149. error check
  150. trainee etiquette
  151. Which servos would you go with for this plane?
  152. I need a decal and a pilot
  153. Just ordered my first electric!! Yea baby
  154. Phoenix Super Decathlon ARF
  155. sealing of motor
  156. Found the expiration date on my H9 Arrow
  157. new here :P
  158. after fatality
  159. Whats growing in my wing?
  160. binding trouble
  161. Kyosho Calmato with fourstroke?
  162. 2nd plane!
  163. Needed: needle valve extension
  164. Problem with aircraft fuelling system
  165. College RC Pilot
  166. Adding Flap Servos to H9 Mustang MKII PTS???
  167. Opinions please
  168. fatality
  169. Problems With My New Trainer Plane
  170. E-Flight apprentice receiver problem
  171. Wanting to get a mini plane.
  172. What is a Mousse can Muffler????
  173. what size battery pack
  174. Yay my first landning
  175. 10% to 5% Content
  176. Help a newb
  177. The Tiger 2 flies
  178. ENGINE TROUBLES
  179. speed module
  180. What age is appropriate for park flyers?
  181. Saito 100 too rich?
  182. tuning engine question
  183. Fair price to pay for building an ARF
  184. 14 channels?
  185. Alpha Trainer questions
  186. Parkzone Slo-V - 3 days in, losing power.
  187. My ultimate 120 pic not finnished (pic)
  188. prop recommendation
  189. The Maiden Voyage!!
  190. Beginners Luck
  191. Tiger 2 vs Super Sportster - Speed
  192. Four Star maiden set up suggestions for a rookie.
  193. Problems on buddy box with 2.4
  194. WHY??? no compression!!
  195. FINE TUNING A BUDDY BOX
  196. Gosh Darn Hanger rash! Need to fixed tailwheel mount.
  197. Formula for Dual rate expo transition???
  198. Servo accessories
  199. One or Two Aileron Servos
  200. Sig discontinues the Four Stars?
  201. clarity needed
  202. Does anyone know about the Mosquitomoth?
  203. Utilizing a 12V marine battery?
  204. Magnum xl 70 fs
  205. Fuel line ?
  206. On Rainy Days
  207. Rocker Covers Necessary?
  208. Best of the Best
  209. Help! Connecting Rod question
  210. Getting Stuff Together!!
  211. CG question
  212. bad delivery of my extra 300
  213. Question About Horizon Super Cub
  214. Help understanding ESC and batteries??
  215. GP Revolver servos
  216. What prop size for OS 55AX
  217. C of G...with or without fuel?
  218. need help building Extra 300s .45 size
  219. Futaba rx high/low band
  220. Dumb Question about Flutter
  221. Another Noob ?
  222. parallel question
  223. Hitec and Futaba
  224. can I put monokote (via windex) on plastic
  225. gas convert
  226. estimate
  227. How to make fuel?
  228. My First Plane
  229. progression from trainer to low wing
  230. Sukhoi Su-26m (Any Feedback?)
  231. Four Stroke breather
  232. what is a good beginner airplane
  233. Servo Repair.
  234. 4 channel radio 5 servoes
  235. Adding one more!!!
  236. Magnum XL 180 RFS Fourstroke.HELP????
  237. HELP!!
  238. Finding a new local club
  239. Need a Tx casing
  240. how tight should a pull pull system be?
  241. E-poxy use for firewall
  242. close call
  243. Eaglet or PT-20
  244. Saito 180 engine noise
  245. NITRO COMPARED TO GAS
  246. Question about power setup with fuel
  247. Heres a question for you pros
  248. lights!
  249. Fiberglassing tips and techniques?
  250. Almost done repairing alpha 40
