View Full Version : Beginners
- Need Flight Line Box Set Recommendations
- Sig Something Extra help!!!!
- Is there any one adhesive?
- Old Expy
- Help needed with a Kadet Senorita
- Applying fiberglass to the inside of cowl
- Storing plane nose down...
- buddy box ???
- Re-gluing old CA
- n00bie who wants a plane
- Build a ducted fan (idiot alert)
- Monokote application
- Trainer reccomendations
- My first and last computer radio?
- choice of prop for 46FX on a Trainer
- CG when going from 40LA to 46FX--Need some Info!
- Lost Plane Locator Beacons
- Thunder Tiger engine... Too much for trainer?
- Best Power Panel
- Saito 65 mounting question? HELP!!!!!
- Guess who soloed??????
- Flying Help
- Thunder Tiger engine tuning...
- Control Surfaces where to measure?
- Covering a wing
- Throttle linkage
- AIR LEAKS! Sealing engine and replacing o-rings
- Need Opinions Please
- Wing snapped in half... now what?
- Engine Break-in Questions
- n00b question!
- goldberg tiger, to taildragger
- Aircraft Proving Grounds
- maybe NOT engine vibration, but FLUTTER
- Rebuilding for a tail drager.
- SolarFilm Over SolarFilm
- Ca hinge?
- Propeller nut torque OS 46
- futaba dual conversion 127-df reciever
- Durable plane?
- Fuel filters
- Few screws loose
- crankcase hook up
- servo arms?
- First Taildragger-4 * 60
- engine vibration after prop strike?
- New 4*60 Question
- Flying Lessons Stamford, CT
- Slotting for CA Hinges
- Prop balancing
- solo
- Radio interference off of a building?
- Canopy /RTV questions
- Saito 100 / Ugly Stick
- props, reamers, shaft diameter, spinners?
- What will remove cured, thin CA glue?
- Sport stealth 1/2a
- Airmadillo fuel foaming?
- DuBro or Slimline?
- What's the best way to apply epoxy or fiberglass resin?
- Average training time until solo flight
- First gas flight coning soon
- 5 years since last fly
- Hanger and Learning curve
- Help with fuelproofing engine compartment.
- New at this info needed
- best trainer
- Real beginners question
- Range check ??..how far
- 4*60 Wing built upside down
- Am I crazy......Beginner/Heli/Aerial Photography?
- Multiplex Pico Cub HELP!
- LT-40 warped aileron
- Sig Kobra
- Another set of LT-40 warped ailerons
- 46 SF prop and manual, also LT-40 tail-dragger mod?
- Have trainer, now need to set up 2nd plane; Help!
- Rudder Control Horn Position LT-40
- Increasing throws?
- OS 46LA surging
- Paint coverite
- First post, First Maiden voyage w firebird ii
- need help
- A Few Radio and Servo Pushrod Questions
- center of gravity/balance????
- NewComer with a question on Fuel Tanks
- Non Warbird plane with Retracts?
- LT-40 Reciever/Antenna Mounting
- WHY discharge BATTERIES???
- Second hand Perry pump how does it work??
- cheapiest place to buy
- older stuff newer flyer
- Help Wanted
- Opinion Ibus 40 or Sig LT
- Which glow plug, and what % nitro for 46Fx
- koverall
- Willing to help,or chat about R/C
- Durastik VS US Aircore Colt
- Engine mounting?
- hobbico superstar select 40
- SIG Liberty Sport Instructions HELP!
- Sig Fazer
- Hitech prizm 7 and Crow???????
- Covering Engine area on LT-40
- What does low & high band mean
- Cordless Starter/Equipment
- fuel Q
- Painting of Aluminum Landing Gear
- Friggen Push Rods
- fuel tank removal
- What glue will do?
- Radio Advice Please :)
- Trick Names
- Servos for Sig 4 *60
- Dubro Aluminum Landing Gear Painting ???
- Coil cord for 12-Volt starter
- What kinda epoxy ?
- newbie blues
- difference between the eco8 and picclo
- ccpm set from rd6000-eco8
- What is the best way to discharge your receiver batteries?
- Help tuning an OS Max 40FP (novice)
- US Aircore Colt.
- Are you building a sig LT-40 Now ?
- Propeller for .46
- GWS SlowStick: a good first plane?
- Glowplug advice
- Can any one help
- Break In Prop ?
- LT-40 Taildragger Conversion Success! ?? Though
- Trainer Attitude
- Looking for the best Electric RTF airplane.
- a few questions before i take the plunge and buy a plane...
- Dfference between FM and PCM?
- ca hinges help!
- What is this miracle glue
- CA Hinges Seem Stiff
- tankextender for Cox Babe Bee
- Graupner MC15
- First flight.........Awesome!!
- wiil the satio 72 fit in the gp 51 40 size
- What radio to start out with?
- Du-Bro Tail wheel question
- heat gun glove
- take off
- It flies!!!... sort of. Question.
- Down Wind Turn
- How do you keep you plane in top condition?
- New to forum, quick question...
- Help. Problem with my 4*.
- first flight bummer
- new to the hobby
- SIG LT-40 Trainer and O.S. 46LA
- battery diference
- Midwest Me-109
- Term Explanation
- 4 * forty --> 4 stroke recommendations
- Du-Bro hinge installation
- ripmax, rc simulator, any good?
- Wash out
- what different equip. needed for gas vs glow?
- Help with Dubro Kwik Fuel Valve
- 1st Plane back in awhile
- three channel plane radio control
- Wing Joint
- can this work on a helicopter?
- LT-40 Recieve and Battery Placement Help
- Help!!!!!!!!!!
- I'm A Newbie. Please Advise Me. Thanks
- Great Planes Triton Charger
- Alignment
- metal clevis and jam nuts
- Wind and Magazines
- Duraplane vs. Airmadillo vs. Spadet
- Finishing up a landing
- What is the best covering for foam wings?
- receiver type servo or transmitter???
- RC simulators for macintosh
- Insurance Liabilities
- RC report
- help !!
- Prop sizes os 25la
- what age should children learn to fly RC planes?
- CA Glue Mess!
- Recommend a Quality Radio Case
- graupner extra 300s with hitec flash 5????
- What engine for a 1/4 scale Ryan STA?
- Putting Alpha Evolution engine into a ???
- 2-56 Pull-Pull Solder Problem
- WHAT DO YOU GUYS THINK...
- what engine to buy
- Thank You
- Servo Question
- please delete
- Plane
- how many Lbs can a TT46 pull?
- Low-wing Trainer?
- Southern California Flying and Instruction
- My first plane ( in a while)
- My First Trainer and a few ?'s NERVOUS
- Dubro 2-56 Pull-Pull Help
- tiger trainer 60 and oversized tires
- Negative/Positive shift
- Next Plane?
- Three questions about contruction
- engine mount repairs
- TP cessna 182
- Fast charge nicads in the home.
- Gripping the joystick
- Air/Fuel Mix as a function of air temp
- side mounted engine on aerobat-any benefits?
- Building question....please help.
- (wow) What The #@$*
- elevator issue...
- RV 4 dihedral
- Getting back in the hobby (Houston)
- Gp Rv4
- PT-19 .40 size----- Throws????
- Good 2nd Plane?
- Starting a New Motor, won't run
- Need Suggestion for AC to DC Battery Charger
- Pre-flight check.
- .25 Size stick
- What to wash a glow engine
- Fiberglassing a Beaver?
- Powering airplane battery charger with 12v car charger
- LT-40 Trainer
- First Flights GP Cherokee40 (wrong CG?)
- Wing Covering on LT-40
- Herey the pics
- Greetings,... and a few newbiw questions
- Can't start K&B .40 engine
- Another balancing question.
- Spad Debonar For A Trainer
- tt scooter
- tail dragger help for beginners
- \ prop size
- Receiver help
- What do these terms mean?
- ?? chicken stick ??
- Taildragger Mod Help
- Dragon Lady or CG Tiger 2 / 60 arf
- Putting together a field box
- First flight question
- Securing klunk to fuel line
- wing incidence on 4 Star 60
- Battery or Nitro Model
- Question regarding balancing the plane
- Solo'ed Today, No Trainer, No Instructor :-)
- Hanger 9 trainer is good?
