PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Cheap field gear, anyone?!?!?
  2. Second Plane Advice
  3. Sealing Hinge Gaps?
  4. Can you paint on top of iron-on covering?
  5. Any one here from Singapore ?
  6. Is Scanner a good choice
  7. Solo'd on second day flying ! ! Do I get my wings?
  8. megatech capitol flyer rtf????
  9. Flying in Plane....
  10. Wing Strengthening-HOW?
  11. Belgian seeks rc-advice
  12. Transmitter-Computer?
  13. electric/gas.......
  14. Which plane should I buy?
  15. denatured Alcohol
  16. My first trainer - Please Help
  17. Why don't rc plane engines require an air filter?
  18. COG ?
  19. Sig rascal ARF tips
  20. Sig rascal ARF tips, advice, anything
  21. look here
  22. with/without instructor???
  23. Difficulties With my New Plane
  24. what is glow??
  25. Got the plane, now what?
  26. Do instructors usually need training too?
  27. Flight capablities of Trainers?
  28. new to the RC airplanes scene....need help!!!!!
  29. CA Debonder won't get CA or Epoxy off!
  30. Do I need 2 use ThreadLocker?
  31. How do I fuel my plane?!?!?
  32. low voltage indicator.
  33. Windy decision
  34. First construction First flight w/o instructor
  35. Propeller Choice for Skis
  36. Cheap Covering Help Needed ;-0
  37. More engine questions
  38. Engine Troubles
  39. Sig Cadet wing rib plans needed
  40. 3 channel setup question
  41. Aww Dang!! I can't convert Standard to Remote Needle Valve
  42. ARF question
  43. evolution .46NT or Evolution Trainer
  44. degrees of deflection on my GP cub
  45. Radio Range?
  46. TX with 6 Channels & RX with 7 channels !!!!
  47. Mode 1 vs. Mode 2 radios
  48. This is for the guy's that think they dont need an instuctor.
  49. dubro easy links any good ?
  50. How to Seal Fuel tank
  51. WITCH ONE?
  52. tips for building the sig rascal ARF electric
  53. **First flight of my hobbico nexSTAR** Add your experiences too ! !
  54. How do I glass a wing joint?
  55. Caution on Covering
  56. Too Much Power?
  57. recovering/recoating?
  58. need some good sound advice
  59. Newbie with Tower Trainer ARF
  60. Take off/landing in snow/cold conditions?
  61. Rx Antenna Placement?
  62. Spark plug and minimmum RPM
  63. Tuned pipe
  64. Wind question
  65. I know this is really odd, but being its xmas
  66. My Radio Control is going crazy...
  67. Skis/Floats on the nexSTAR?
  68. Gas or Electric
  69. Help with Starting out
  70. Anyone member of PVMAC in So Cal?
  71. Begginer question About Glow Starters.
  72. another transmitter question
  73. Cessna 180 RTF
  74. Kadet Senior wings... glue them or leave them seperated?
  75. It's MY turn to ask for help from the NEWBIES!
  76. Improving Basic abilities???
  77. Does anyone have a good condition 6XAS Tx Only?
  78. flying in light rain or sprinkling weather
  79. flutter?
  80. help with floats
  81. Aero-Star 40's Steerable Nose-Wheel???
  82. What do you use to cut 5/32 plywood with?
  83. park flyers
  84. why not thumb on top rather than index and thumb
  85. How do I fuel-proof decals?
  86. any clue on a 220V. TX/RX charger ?!!!
  87. control slots
  88. Change battery how often? Checked under load?
  89. 2nd radio
  90. Exponential for Beginners-Good Idea??
  91. Help with retracts for 75.5" corsair
  92. a few ?'s about buying an LT-40...
  93. what's the diff between a radio and transmitter?
  94. When to upgrade from "standard servos"
  95. First timer needs help
  96. What are the 4 channels in a trainer ????
  97. last coat of dope what next
  98. Wankel engine
  99. Midstar 40 engine size ?
  100. Check out this link about Flapperons
  101. FM vs. PCM radios ??!!!
  102. Breaking In Engine
  103. Engine Tuning
  104. batteries ni-cad / ????????????
  105. Anyone flying in Uvalde, Tx area
  106. More Hinge Questions...Please Help!
  107. Where to find an experienced pilot???
  108. What to do when CA hinge fails...Help!
  109. Pica T-28
  110. Initial needle valve setting... 1 turn =???
  111. Kit advice
  112. Three Fuel Line Setups for Cowled Aircraft
  113. HELP! Evolution .46NT vs OS .46FX in WM T-34
  114. Risks at the first fly ?????????
  115. Ag Aircraft
  116. Problems with the Futaba Skyport radio?
  117. Piper Cub Kit
  118. the night before my babys first flight..
  119. how to cover a repaired wing
  120. 12v starter bat.- discharge-charge time
  121. Nexstar Battery charging????
  122. Wondering about gliders
  123. Servo and C of G Question !!!!!!
  124. flaperons on sig kadet senior?
  125. NEW REVIEW: Hangar 9 Alpha Trainer
  126. Dual Rates
  127. Wing taping
  128. Clear Duct Tape!
  129. Wing Loading
  130. Uproar 60
  131. what/how do you fly in the winter?
  132. skis on an avistar?
  133. Looking for R/C Airplane Plans
  134. A Few Questions from a begginer....
  135. Sig Rascal electric ARF tools needed???
  136. Glue storage
  137. New flier
  138. engine ?s i am really mad at my engine
  139. What does ABS stand for, ABS Cowl...?
  140. Fox Racing Glow plug ?'s
  141. I have a dumb question...
  142. servo tape?
  143. great planes p51-mustang arf good start????
  144. Transporting your aircraft
  145. Telemaster 40 questions
  146. engine question
  147. How to post picture in Post ?
  148. Anybody Flying Around the St. Louis Area?
  149. Engine question
  150. Balsa-sheeted foam core wing ?
  151. Advanced (?) Beginner reentering hobby . . .
  152. spinner nut size
  153. build question
  154. stepping up
  155. How do you cover the engine cowl?
  156. Engine mount guestion
  157. mode 1 or mode 2?
  158. next plane after first low wing
  159. Fuel Tank help needned
  160. my next radio
  161. "Dumb Thumbs"
  162. Over powered Extra Special?
  163. LOOKING FOR MY FIRST WAR BIRD
  164. Futaba 6EXA or 6XAs?
  165. Pete-n-poke
  166. Good indoor electric plane?
  167. cub or nexstar...
  168. Overpowering an LT-25
  169. Question
  170. Just got
  171. LT-40 Aileron Roll
  172. Steering/ Rudder Servo Question
  173. mystery planes and eng.
  174. grain?
  175. Next problem... Engine for Tiger Trainer 40
  176. Thunder Tiger 60 ARF
  177. GB tiger 2 ARF
  178. Easy 2 Landing Gear?
  179. help!!!please!!!108 on u can do 3d .60
  180. paper or plastic?
  181. Help me decide. WorldModel T-34 or Seagull PC-9 for second plane ?
  182. LT40 Wing Joining
  183. What engine on an LT40?
  184. 3 holes in fuel tank?WHAT THE @#!$%
  185. 4 channels and 5 servos?
  186. Flaperons?
  187. radio
  188. RE-Covering
  189. Forsaken Trainer
  190. realflight vs. real
  191. At what phase
  192. ALPHA Owners, Check Your Wings!!!!!!
  193. Learning on Skis
  194. Pneumatic tool oil
  195. new multiplex cargo plane any1 flown it yet ?????
  196. Thank You
  197. Engine tunning
  198. Sig LT 40 Prints
  199. NEW REVIEW: Hobbico NexSTAR
  200. ringed and non-ringed engine
  201. FUEL TANK - CLUNK
  202. NITRATE DOPE
  203. WINGERONS
  204. OS 90 4 stroke New guy to 4 cycle!
  205. Last chance to choose! What trainer!
  206. <<<WHICH IS THE BEST TRAINER>>>
  207. Did it fly or crash?
  208. Hobbico Nexstar
  209. Spinner size for 10-6 prop
  210. ENGINE STARTING
  211. help me
  212. Skyshark R/C
  213. Best plane for me, a newbie.
  214. Landing!!! The Hardest but Best part about Flying!
  215. Irvine .46
  216. Flaps on 40 class plane?
  217. Sig Kadet LT-40 building....
  218. TT F90S 4-Stroke Engine Question
  219. Which Engine
  220. Please help
  221. MOVED: do i have to put a rudder on a spad gnat?
  222. High winds and a stalling engine...
  223. Just bought my first engine, now what?
  224. Acronyms for beginners
  225. CA Hing Problem
  226. Trainer advice
  227. Today I Finally...
  228. baby, it's cold outside
  229. Steering while inverted???
  230. Wing Washout
  231. i need a straight answer...
  232. Heli radio for an airplane?
  233. What kind of field gearbox??
  234. Any Hobbico NexSTAR CRASHES or MISHAPS???
  235. MOVED: Did you use too much "Thread Locker?"
  236. A DROP BOX ON THE NEXS*T*A*R???
  237. Went to LHS today
  238. Dumb question about my wrinkles!
  239. Hobbico Nexstar Videos
  240. Nexstar engine and servo's question
  241. Securing Battery & Reciever???
  242. What can u do with a Tiger II?? Hey that rhymes
  243. Need help balancing the sig kadet senior arf
  244. Can u take off dried epoxy?
  245. Area the size of a football field big enough?
  246. Prop Balancing
  247. How do you go about putting a video camera on ur plane?
  248. Filling Question / Needle Vaulve!!!!!!!
  249. Monmouth County, NJ Flyers??
  250. With Instructor, without Buddy Cord?
