View Full Version : Beginners
- Thunder Tiger Pegasus Trainer
- Motor Modifications
- MOVED: Need some ideas mounting wireless cam?
- Channel 44 or 68
- How much weight can I add?
- Broken wing on Slowstick.
- Setting up a club
- Newbie has many questions.
- Freq change in receiver?
- RC CHAT
- ATTN: Nexstar Owners!!!!
- What is washout? and do i need it?
- I need to help GTac01, anyone live near W. Palm Beach, Fl
- Real Flight Simulator from Great Planes.. Any Good ?
- NOOB help
- Its not balanced ir is it????
- A good day at the field....
- Channels - what do you do with 'em?
- Hard outside loop and engine stalls
- Balsa sheeted foam wings vs regular type ?
- removed double post sorry
- rookie mistake please help
- Engine sounds like popcorn
- SHORT SERVO TRAVEL & CHATTER
- 4stroke vs. 2 stroke?
- Avistar-Supertigre GS45 Help
- sheeting
- SERVOS for H9 Piper Cub 80"
- MIX Rudder and Aileron
- CG
- Flaps
- Looking for a field or Club
- MOVED: Smoke
- Sig Somethin Extra 40
- 12v field battery
- RC planes for idiots book
- Best Trainer a SPAD or ARF or RTF
- Prop size question
- Kyosho radio
- Servo lead question
- Dummy Pilot.. Where to buy ?
- Flying with discipline
- Control Throws-Help please!
- Smoke System for a CUB ?!
- firebird any good for the $$$
- Battery "cycling"?? what, why, when?
- Prop Spinner
- Center of gravity CG How to Find it
- 128.20!?!?!? What do you guys think?
- Homemade skis Check these Out !
- Bananna Clip leads
- ace 4-40
- engine idle + vertical = engine quits?
- Calling All Eindecker ARF Pilots--Advice needed !
- WANTED: Idiot's guide to vaseline and robart hinges
- New Guy thinking of a Sig Kadet LT-40
- Engine Tuning Question
- Change in trim
- glow plug Starter... Noob Question
- Help in choosing a trainer?
- Build your own power panel
- control system question
- 4 Star Bash Questions
- New to forums.. Question about my Nexstar!!
- Futaba TX question from newbie...?Please Help
- What is Aleron V-tail mix?
- Futaba Xmitter, Hitec Reciever?
- Has anyone seen the Sonic 25 High Wing ARF - 25 fly?
- "P" Factor
- Second Plane...
- Chosing your propeller
- Heat Gun Tips
- Super Sportster
- 2nd Plane Jitters
- Question Re Control Horn Orientation
- Old Engine Question !!!!!!
- Astro coupe?
- Crashing Jets Video - OUCH!!!
- Pushrod Newbie Question
- Easysport 60 with O.S. FS-1.20
- Need plans
- OPPOSITE RUDDER
- Skyward 60 Trainer
- Newbie question about Radio..
- Field Charger
- .46 Evolution Cylinder chipping????
- DAZZLER 40 (ARF)? any good for a 2nd plane
- routing antenna
- ? about learning to fly
- newbies bored?
- Prop Installation Question
- tt thunder tiger .46 ISO 9001 Certified
- chargers
- Installing new engine?
- Stab Vs Firewall incidence question
- Saito .56 Break In???
- First Robart hing install going well!
- Wet runways and grass
- EINDECKER 46 ARF owners & pros ....some help ?
- Plans for converting to taildragger.
- Hand launch DON'T DO!
- 6 months later
- installing Flaps?
- question
- Please help
- Simulator for Futaba 4VF
- tt thunder tiger .46 pro fuel break in
- First plane!!
- TT .61 pRO ON A AVISTAR !?!?!?
- question about using a flight simulator
- First Attempt at CA hinges??
- Here
- Need help,
- Need experienced help on a new plane..?
- Can someone identify this plane ?????
- Tach or Heat sensor ?
- Pro spinners
- Engine Test Stand
- It Flies!!!
- Starter
- What to do???
- Are these good trainers?
- Air intake area for cowled engine.Rules?
- How do I take-off with Tail wheel
- pt40 to a taildragger?
- Spacewalker II underpowered w/ YS 110?
- servo alignment assist needed
- question about Kyosho Calmato ?!?!?!?
- balancing props
- Begginer Plane
- checkered covering
- Covering Edges
- Trying to figure out what channel for Futaba Tx,.. anyone ?
- GEE BEE Struts... / landing gear 120 size
- Gonna build a carrier
- Goldberg extreme 330 as 2nd Plane?
- couple of questions
- Pendulum balance - lateral balance.
- prop question
- How to Wing Bolt Conversion??
- STRAIGHTEN UP AND FLY RIGHT NO LEFT?
- change from trike to tail.
- PT-60 Finished
- Recommendations for 40 size glow engine trainer
- Is this a good plane?
- saito FA65 in a PT40
- Another "help me pick a plane post"
- Post your pics!
- wing joiner play...
- Help the new guy...
- Air cleaner...
- Help with First Flight...
- Nexstar or Avistar
- Feilds in Texas?
- Avistar Question
- What to do with old models??
- what is the trick to starting a glow motor in the cold
- Neighbors flying over house
- Ultra stick 4* or other
- Goldberg super tote... defective wood?
- airitronics vg 400 and the Duraplane Aerobat any good
- New Model tech 300
- Whats going on with OS ?
- This is the greatest hobby ever!!!
- Looking for info SIG.
- Aluminum spinner slightly bent ? Is this normal ?
- Some Advice for a UK Newbie
- JR/Hitec? futaba compatabilty
- newbie and his cub
- Flair Attila Control Throws ?
- Buddy box question
- New and Need Advice
- Opinions on Magnum???
- house paint on koverall
- Any suggestions? Which Engine/retracts shoud I use??
- prop numbers
- citabrea as a second plane
- wheels
- JR PCM10x air radio/need trainer that can handle this
- Beginners Guide
- Alpha 60
- 75.5 ARF Corsair
- Got some questions need help!!!
- Which Radio?
- My second plane ready to go.
- Reversing help
- Super Tiger 51
- Y harness help
- Great Planes PT 40
- Yee-Hah! Go John @ HHH! My engine started!
- Lets talk about SAFETY
- How long do you charge your plane???
- Another Question For Servos...
- Need Help with Ailerons Servo. Please Help!!
- CG
- Newbie
- sig kadet senior, use or not.
- Brown OS 46 FX
- Panel lines
- balancing latitude
- Nose dive
- Wana-b Glider Novice needs advice
- Starting planes with spinner nuts
- Is suggested antenna routing on a SIG SE okay?
- First flight...(smile)...but do I suck???
- Need help w/PIZAZZ
- Support for GP
- Solo on your own?
- Saito 56 or RCV 58
- Four Star 40 Question
- Delimma!
- CG
- PAINTABLE COVERINGS?
- smoke system
- Great Planes.....Blah!
- Begginner Trimming His own Plane?
- Oops, Water Damage!
- stuck carb
- Oups.... how can I fix this...
- Painting question
- Spinner slots don't fit prop... Can I cut?
- describe 3D flying/patterns
- Got these old JR PROPO servos... help.
- Help me choose my first plane.
- Can an Avistar flat spin?
- Just saying hello again
- prop safety
- Dual Conversion?
- Covering Help-Vert. Stab and Rudder
- Best 50 size four stroke?
- I Need "Radio 101" Anyone ? Anyone?
- Durastick
- Head to head
- Finding the CG, Using the Pendulum Method?
- Washout via raised ailerons?
- Engine Thrust Question !!!
- Need Advice for 2nd Plane. Small size preferred
- Trim Question for newby
- GLASSING QUESTION
- Covering issues
- MOVED: Tigershark Engine that can't pass the vert test
- Engine Problems
- Control linkage
- Futaba & Tower servo's-Same?
- Sig Koverall question
- Century Laser 4 Transmitter, what receiver?
- Why is my Tiger II landing hot
- Balsa wood filler?
- Breaking in O.S. .46 AX (Newbie)
- Check list
