PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Difference between OS 46 fx, and fxi?
  2. What do you know about asphalt?
  3. Evolution Engine problem
  4. cg
  5. Newbie wants to Fly electric Airplane
  6. rudder question
  7. Anybody install a whistle on their plane?
  8. Maiden my uproar 40 this morning
  9. I retired the trainer.
  10. Saito 56 Break-in Prop
  11. DB Flexall
  12. O.S. 46 with Wildcat fuel?
  13. is the gws formosa a good second plane?
  14. nOOb in RC planes : How do you know youll ran out of gas soon ?
  15. Hobbico Electristar Components in New Plane
  16. what prop
  17. FOX 40 HELP !!!!!!!!!
  18. What kind of plane is this?
  19. Saito Engine High Speed Needle Valve
  20. Does ANYONE know what kind of plane this is?
  21. You can't judge a plane by it's looks!!!!
  22. first airplane flight, not to good at landing
  23. Any Advice on the Decathalon?
  24. RCUer MIA?
  25. Help Me Identify: Need CGHelp
  26. Idle stop screw
  27. Leaning the low end NV
  28. sig four star 40
  29. Need Help configuring flaps on DX6i
  30. Sig 4* 40 Maiden Report
  31. Newbie in Fresno,CA
  32. Best Houston RC Flying clubs ?
  33. Tx/Rx charging question
  34. Hobbico Superstar .40 ARF.
  35. reciver pack charger
  36. Low End Tune !!
  37. Easy glider Pro power pack installation ???
  38. what causes flutter?
  39. Futaba Reciever - Polarity
  40. *&%$£& engine problems!!!!
  41. Li-ion charging question
  42. Modeltech Extra 300
  43. FLAT PLATE WINGS
  44. Tower Trainer MK2 wings dihedral
  45. prop question.
  46. Throttle position for level flight vs. landing?
  47. Spad with dihedral as first .40 trainer ?
  48. Newbie to mixing - Futaba 6EX FASST
  49. Breaking in OS.46 FX
  50. Water landing
  51. Lost the back of the muffler on the maiden flight.
  52. Lets talk about landings
  53. servo arrangement of dual elevator servo's
  54. engine chart 2cyl vs 4 cyl
  55. Aileron Question?
  56. Breaking in engine?
  57. The PTS mustang is NOT a good trainer
  58. T-34 rtf
  59. micro flight cam???
  60. best day at the field in a long time.
  61. You gotta see this!
  62. More prop explanation needed please
  63. Tiger 60 to taildragger?
  64. split screen video of fuel tank
  65. Hangar-9 Pulse XT PNP
  66. Prop Problems
  67. no fuel
  68. shipping a plane
  69. PHEONIX SUPER DECATHLON "SQUIRRELY TAKE OFFS AND LANDINGS"
  70. recomended batt for running 7 servoes and spectrum
  71. AM frequency ??? Questions
  72. help??? Second Plane from walmart??
  73. rudder repair
  74. CG for cmpro cessna 182 50 size
  75. Electric Foamie Trainer
  76. Interesting morning at the field
  77. The high cost of lower quality 6XM
  78. Video of me at Elk City fly in
  79. Well I did it....
  80. Solo !!!
  81. "Re"maidened the sundowner today.
  82. mode 1 or mode 2?
  83. cmpro cessna 182 engine
  84. Trimming problem
  85. trainer
  86. How the heck do I build this thing?
  87. Maiden of Alpha 40 DSM2
  88. looking for a SMALL high wing plane with ailerons
  89. Ocean City NJ Air Fest
  90. tm-8 module blinking green
  91. Unsure whether flying is my thing
  92. Flight pack for Big Stik
  93. Found my tuning problem
  94. os25 counter rotating crankshaft
  95. What is a book that all RCers should have?
  96. Should I buy it?
  97. need a glue or bond.
  98. Nitro Models Extra 330L convert to Electric
  99. carb setting for ASP 108 glo engine
  100. How should I load my car?
  101. Trim Question
  102. Getting engine started
  103. Plane ideas - Your thoughts?
  104. Q: Explanation of "digital proportional control"?
  105. having trouble with my dumb thumb
  106. Abbreviations and acronyms
  107. Yak 54 offer - good value?
  108. low needle speed question?
  109. engine problems, fuel gone bad? another lesson!
  110. Any trouble with applying epoxy over epoxy?
  111. Warped ailerons- Covering problem?
  112. warped prop????
  113. My new rolling field box
  114. Air bubbles
  115. Sig Astro Hog a good 2nd airplane?
  116. difference between Bison Pitts and Slimline Q muffler
  117. Suggestions for installing FlyLite Light Tubes
  118. Why won't my field charger detect my 6EX?
  119. Engine wouldnt turn???
  120. Charging a DX-7 TX
  121. Maiden flight of the Big Stik
  122. Prop size question
  123. great website for beginners
  124. Engine for a Kyosho Focke Wulf 50???
  125. Anyone flown this thing yet?
  126. Old OS .40FX will not fire
  127. Sig 4* Servo Question
  128. A question about landing
  129. Which Fail-Safe throttle position do you use?
  130. need advice on Hobbico SuperStar EP
  131. Prop questions
  132. feul tank mounting?
  133. Engine rubbing - is this OK?
  134. Half throttle too rich, any ideas?
  135. Master Battery question. Please help!
  136. Folding props
  137. Spektrum DX6i setup for Nexstar 46 (glow)
  138. Judging to much wind?
  139. Spectrum radio batt charger with 6 VOLT??
  140. dual elevator bell crank question
  141. Heck of a mess!!!
  142. Decided on my First Set of Wings.
  143. Norvel .40
  144. Ultra Stick ARF Build issue
  145. 6-32 bolts - wrench
  146. Where to get needle keepers?
  147. CG confusion
  148. Battery Problem?
  149. my tiger60.- Maiden today!!!
  150. DX7 Losing Receiver Bind
  151. Brakes.. Where to buy?
  152. ARF Firewall crooked?
  153. World Models Mach I Lands Itself
  154. What can I use to "remote" place my glow plug so I can get the ignitor in a smaller more....
  155. Pre-Flight Checklist?
  156. Official Pics thread?
  157. SOLO'D Today !!!!
  158. Receivers, Transmitter Packs
  159. Just finished my rebuild!!!
  160. Lesson learned: use the threadlocker
  161. Are we expecting any new OS engine???
  162. Maiden will have to wait
  163. FOX 40 HELP!!!!!
  164. control throw setting ? home made tool ?
  165. Airtronics question
  166. First build ideas?
  167. Quick fill fueling valve for plane with a cowl
  168. Superstar EP and dx7
  169. Withdrawal symptoms: I GOTTA FLY
  170. What do you use to clean a plane
  171. Flight Training
  172. whats harder?
  173. What exhaust options for OS 91 surpass?
  174. Need asap - Digital caliper and talking timer
  175. Would this be a good 3rd plane kit ?
  176. RTL Fasteners Discount code or promo ad
  177. Outrunner plus Sand =
  178. What is the formula to figure your scale?
  179. Tiger 60 ARF build tips anyone?
  180. ELAPOR FOAM with EPOXY?
  181. open a dfx file?
  182. Universal chargers (which one)?????
  183. Help to patch balsa plane.
  184. First kit inquiry.
  185. Sig Rascal 40 - Ground handling Bad?
  186. Airtronics to Futaba
  187. RTF radios
  188. How to secure receiver and battery
  189. Elevator Question?
  190. covering
  191. 55 ax revs then dies?
  192. Maidened the downer... good and bad/help with fuel soak plz
  193. New trainer for my kids
  194. Alu undercarriage
  195. Different Futaba FAAST 7 channel receivers
  196. Is there any chance that this is a real shot??
  197. Congrats GaRCfield!
  198. Fuel Consumption - O.S vs Super Tigre
  199. Hitec servo catastrophic failure and my first crash.
  200. Maidening my extra this week, any tips? (MAIDEN UPDATE)
  201. VMAR DISCOVERY 40
  202. ChuckW
  203. soldering a metal clevis
  204. It's Christmas in September!!!!
  205. Venus 40 Landing gear upgrade
  206. Can you start engine with a drill?
  207. Engine mount too short for prop to clear cowling
  208. Engine Test Stand questions
  209. Awww hell... cant use my X9303
  210. Higher Prices ***!!!
  211. Which type servos should I use in a bipe?
  212. Flexible exhaust line for four stroke
  213. Question about exhaust routing.
  214. What Brushless motor to buy
  215. Propeller: Wood Vs. Plastic on a gas engine.
  216. Warning! Mad Scientist At Work!!!
  217. Propellor Fitting Question
  218. Ailerons moving in sam direction. DX7
  219. OS - 15 LA, Engine Question...
  220. Programming for dual elevator servos
  221. 4* Maiden
  222. OS 120 four stroke questions?
  223. tribute 36 rudder
  224. perfect loop
  225. 4* 40 rudder problem
  226. how often do u guys fly?
  227. Disappointed with G4 sim
  228. Radio Problem
  229. What's wrong with this picture?
  230. My Super Decathlon
  231. What would you do?
  232. Off to the Skymaster's float fly
  233. CMP Zero 50 retracts
  234. Ever afraid to start an ARF in fear of screwing it up?
  235. Waddup with glow plug prices!?!?
  236. Hitec servos with Spektrum reciever
  237. radio gear
  238. batteries, motors, and esc?
  239. Question about "real" version of FMS plane
  240. Foot Start
  241. Advice for a new build
  242. Tiger 40 or 60 arf?
  243. Troubles with finishing wood
  244. What brand servo's are compatible with the Spektrum recievers?
  245. Assistance needed in San Antonio area
  246. Zero scale?
  247. Need a Simple Kit for my nephew!
  248. good childs plane
  249. Used Engine
  250. Installing wiring within a foam wing to outboard ailerons
