PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Cheap Electric Toy? Which one to buy?
  2. For what it's worth
  3. Dremel, balsa - misc questions!
  4. Cowl Issues
  5. Single Servo Aileron Setup???
  6. Maiden flight of my Pulse XT
  7. Dual Conversion
  8. Batteri/electrical setup help
  9. WAA WAA WE WAA, my MidStar is not maiden any more
  10. bind plug for spektrum tx
  11. 3d model what should down thrust be
  12. Soloed Saturday
  13. I need help on landing my cesna 182
  14. battery question #1 and #2
  15. 2 stroke fuel for a 4 stroke???
  16. what is not safe voltage for receiver batteries
  17. texasrcplanes wedsite
  18. Max Wind Slo-V can take
  19. Question about epoxy
  20. Simulator Downloads
  21. Second Plane Suggestions
  22. Servo Saver
  23. Is carpenders wood glue ok?
  24. Seagull AT6 Texan
  25. replacement canopy for Chip Hyde Vision
  26. Bubbles in the line
  27. Which one? Pros and Cons
  28. Blue loctite - how [and how much] to use?
  29. How to remove broken screw in wooden mount?
  30. Next plane
  31. What is it with some of these ARF's?
  32. New Plane HELP... (newb)
  33. color of wing tips
  34. whats the most wind?
  35. checking CG on a alpha trainer
  36. Upgrading and Flight Packs
  37. Nose heavy on Center of gravity looking for a trick or help.
  38. blue locktite--WAYYY off topic
  39. pulse xt pnp glow any good?
  40. CA v.s. Nylon hinges
  41. i´m Beginner in rc airplane
  42. Do you use a log book?
  43. Glassing wing joint
  44. Modeltech P51 D Mustang
  45. Mixing Epoxy Tip
  46. CA glue on covering?
  47. WildCat Fuel vs Cool Power
  48. I found Murphy
  49. Ailerons or Rudder
  50. Can't read plans!!!
  51. Pulse XT vs Avistar
  52. Need to learn more about types of screws..
  53. spitfire advice needed urgently
  54. WOO HOO !!!!!!!!
  55. Another prop question
  56. What is safe voltage range for JR Tx
  57. MINI REVIEW - SUPER STICK 40 - HANGAR 9
  58. Mounting Wing/Horizontal Stab
  59. Socket head screws for engine for rascal?
  60. Very Lucky
  61. Please reccomend a begginers small/cheap plane...
  62. Hot or cold ??
  63. what size prop to use on h9 thunderbolt
  64. electric rc planes:good or bad???
  65. Surpass 52 rev range?
  66. DX7 Heli vs Airplane versions - differences?
  67. Hobby Shows
  68. HELI FUEL/PLANE FUEL
  69. Any tips for training a youngster who panics?
  70. prop sizing
  71. What Next
  72. Rain seems to be here to stay in AR
  73. What fuel for sc .75
  74. fuel tank stopper sealant question
  75. epoxy
  76. new to 4 strokes.
  77. easy charging question
  78. leaking engine...
  79. APC 15x6 and 9/32" + 5/16" Tubing
  80. Firewall Blindnuts
  81. HAN3001 Glow Plug
  82. Begginer plane
  83. What things to check for during a pre-flight inspection?
  84. setting trows
  85. TAKE OFF ENGINE FAILURE
  86. Rossi engines - where to purchase?
  87. SERVO EXTENSIONS
  88. HOW TO remove coloring from landing gear??
  89. How old to get started?
  90. need more screws
  91. Replacing metal landing gear screws with nylon
  92. Importance of doing a proper pre-flight inspection
  93. Alpha 40 questions
  94. 4 stroke fuel?
  95. myths
  96. Can I Charge A 6V NiMH With My Futaba Charger?
  97. Wing washout ??
  98. Beginners Logbook? or what I learned today
  99. Darn weather !!!
  100. What should you learn on your first flightday?
  101. WOOWEEEEE!! x 3.
  102. 4* 60 question
  103. Self Discovery
  104. Futaba Trainer Box
  105. Folding prop for GENTLE LADY
  106. Hanger 9 F-22 PTS
  107. First covering job... complete (pics)
  108. Arrow 40 Control Throws
  109. Futaba 4YBF Any Info
  110. three more flights today
  111. First flight...
  112. Evolution Trainer Power System Engine Problems
  113. o.s. Max 40 FP ????
  114. easy maneuvers
  115. Not sure...
  116. OS 46 LA Motor and Glow Plug Question
  117. How Long Is To Long Without Help
  118. Replace 2nd Plane
  119. First Flight
  120. HELP WITH MODEL TECH CAP 21 MODEL..
  121. SOMETHIN' EXTRA CG???
  122. What Battery for CG-207 Charger?
  123. second day of flying was eventfull
  124. 15 percent fuel
  125. Flaperons? Those keep your wings from getting tired, right?
  126. Toughlon covering ???
  127. RTF Park Flyer Suggestion
  128. Spinner opening question
  129. Horizontal Stabilizer
  130. Evo .46 was running funny this week.
  131. "Y" Connector Question
  132. Venus ll - 2 or 4 stroke?
  133. 2nd plane?
  134. Which one?
  135. Plan B
  136. Re-sticking decals
  137. satio and smoke
  138. Prop for OS 46 AX
  139. lost plane locater?
  140. Smoke
  141. Securing the battery question
  142. 1st flight today
  143. epoxy curing time question
  144. Epoxy in small hole
  145. New Pilot (Elec or Fuel)?
  146. What's the advantage to 3 & 4 blade props?
  147. ARF or Kit
  148. Mini Supersportster
  149. DAVE BROWN ALUMINUM SPINNER
  150. SSE vibration
  151. engine?????
  152. Aileron Question
  153. radio frequency label
  154. Plane weakness/ Warranty?
  155. trim??
  156. Need advice on Futaba Rx + starting out
  157. Removing Firewall
  158. airplane storage
  159. First Nitro Plane. Help me decide!
  160. Happy Birthday to me !!
  161. New field battery
  162. What's your preference?
  163. Paint and primers?
  164. Need recomendations on first everything!
  165. Does peel and stick Mono-Kote Shrink?
  166. Engine run problems, please help
  167. Painting Alum. Gear - Flexing
  168. What is the ideal & right approach for landing?
  169. SERVOS!!!!!!!!!!!!
  170. New to RCU but not a newbie
  171. a 50 cent airplane hangar. (how-to)
  172. Art-Tech Cessna Li-Poly Battery
  173. Field equipment??
  174. Construction Techniques!?
  175. solo'd my p-51 PTS
  176. replacing one aileron CA hinge
  177. Muffler exit deflector
  178. Tiger 40.
  179. wings pin
  180. which fuel works best for OS 46 AX?
  181. cub CG
  182. what type of ball and socket to use on my thunderbolt
  183. First buddy box on Thursday and computer flight sims...
  184. center of gravity effects?
  185. first lesson
  186. Shuttleworth Aerodrome
  187. standard vs ball bearing servo
  188. Slinger Help
  189. it was a bad day
  190. Online store???
  191. Austin Clubs
  192. Flap switch sanwa vg600
  193. what servo to use for rudder
  194. u can do 3d
  195. Sig Transparent Blue Covering - Patch?
  196. Prop for T80 Webra
  197. Cleaning oil from plane
  198. How long to charge Futaba t4yf
  199. I am sooooooo happy!
  200. aviomodelli tango
  201. Is there a place on here
  202. Battery/Charger Question
  203. How much control throw?
  204. Wing loading ?
  205. Batteries and Trainer
  206. So it runs.......
  207. Flight pack vs radio sysytem
  208. Accomodation for the Deaf
  209. Quick Question
  210. Stupid Question
  211. Sig Four Star vs. H9 Pulse XT
  212. Homemade Wing bags
  213. nexstar with out gizzmoes
  214. prop's what does what?
  215. beginner, slow, park not too big
  216. Nose drops when throttle is cut.
  217. Is there anyone who flies a rascal 40 with an inverted engine?
  218. Hobbico's Avistar with MonoKote
  219. Futaba 2.4 GHz radio
  220. RTF or ARF for a beginner?
  221. PCM, PPM? heh?
  222. Canopy Hazing - Acetone
  223. Trainer or not?
  224. cg mysteriously out of balance??
  225. Time to choose...
  226. What should I be practicing?
  227. setting up a pull-pull rudder system
  228. Great Planes T-Craft conversion?
  229. Thanx for naming this part!!!
  230. One allen wrench 'extension' for all sizes?
  231. Prop balancing
  232. Haven't even got off the ground yet!!!!
  233. Got my first plane...
  234. applying Top Flite Trim
  235. Reshaping balsa elevator & Wing balancing
  236. Assembling Dowl Based Push rods
  237. engine cut off
  238. Look what hinges i found in a LHS
  239. Need some advice
  240. Reciver battery
  241. t fitting for cowling.
  242. What the heck am I doing wrong???????????
  243. Prop Question!!
  244. What is your favourite rc story?
  245. Hobbistar with dual aileron servos.
  246. Transmitter, proper use
  247. Duraplane
  248. battery questions???
  249. Good First Kit But Second Plane
  250. ST Models???
