View Full Version : Beginners
- What % of nitro do you normally use?
- Hatch Building basics
- Need major help on Mustang 51!!
- anyone know how to put valve keepers on the valve stem 4 stroke Mag.
- Getting Back Into RC
- Setting up Radio (T6xas) for edge 540
- Posting Pics
- Help with Hitec RX Please
- Plastic wing tips
- Pull-Pull : Concensus
- What battery for a Tiger Stick TT.046?
- Any one heard of this plane?
- Hangar 9 F-22 Raptor
- 100% N00b asking for some guidence
- Upgrading batteries
- do a search
- New RC Flyer, where can I get help?
- charging battery?
- Another 7 flights today
- Solarfilm covering
- Pictures of the 95AX on the STIK
- Edge 540 as 2nd full time plane??
- Post Xmas deals
- stick plane for clear covering
- Weird glitch.
- Where can i find any wallpaper of warbird for my computer?
- How to re-cover a plane
- throttle hand surgery
- Adjusting valves on Magnum 4s
- help needed w/ super cub LP
- Motor Mount Bolts/locktite?
- Good 2nd plane for someone on a budget?
- What did ya get?
- First time engine start
- which plane to buy
- Please, don't spend much money on
- Dumb question about motor mounts
- Help Cant get my futaba 6ex to charge with field charger
- HO!! HO!!! HO-MERRY CHRISTMAS
- Wings held on with rubber bands?/Alternatives?
- Exponential with DX7
- Size matters, how to know?
- The New Guy!
- Super Chipmunk
- Snow Skis
- U-Can-Do landing gear collapse
- Warps out of aileron . . . please HELP
- inverted four stroke
- JRSX600 tx locked up need help
- It still flies
- Holbbyking or similar lipo for DX7
- Where is a good place to buy 2500mAh for my DX7
- Installing covering over covering
- Cycling without a cycler
- Hi im a complete newbie :(
- Giant Super Sporster engine....
- Great Planes Cherokee rudder pushrod problems
- f27B stryker
- Well No flying this weekend
- o.s 40 la
- Prop size help
- I want to fly, maybe...
- ESC not responding!! Very frustrated
- Spray bar location
- Prop. Sizing.12X6
- Great Planes Escapade Low Wing Sport GP/EP ARF 52.5"
- Saving Real Flights as avi, mpg or mov files
- Liberty 182 (Cessna)
- Seagull Decathlon
- JR DSX7
- RX battery options for AR6200 and 4 Futaba servos
- General question about Loctite
- Ignition Install
- Calling all 4-star owners
- 7.4 V servos - what receiver ??
- Customizing my PT 19
- Reviving U-Can_Do 60
- First Glow
- a first pattern plane not so pricey
- Advice on 1st RC plane.
- The first real flight
- Hitec Optic 6 2.4GHz is it any good?
- Servo gear lube
- Used engine inspection
- Tapping fixture
- ASP FS61 engine
- Been out of the game for awhile and need some help
- Perfect day to try my skis
- lets see your dirty planes
- tuned pipes for os 35?
- My f18 super hornet
- Hangar 9 cherokee tail problem
- Got a bump.
- Sheeting technics
- Spektrum Question
- Programing Aleirons as Flaps
- towerkote on monokote?
- BEWARE!
- Setting up dual servos on the Eagle 2
- Hanger 9 Funtana x 50 ???
- sure this gets asked a lot sorry
- Sealing surface gaps
- Receiver Question
- 40 size OS engine
- PT 19 Pics
- Can anyone tell me what kind of plane this is
- Hangar 9 Pulse 125 arf
- Cessna 182 arf
- Enlarging the propeller hole
- I can't Make up my mind
- covering wrinkles
- size of 4s compared to 2s
- Fuel Storage
- Starter trouble
- What's a good electric trainer with four channels that doesn't cost too much and isn't too small to
- Picked the plane...now the electronics?
- Can ParkZone Typhoon2 use PZ 480 BL motor from PZ corsair?
- Propeller popping off
- 90 sized engine recommendation
- PZ Typhoon 2 with PZ 480 BL outrunner?
- Spinner RANT!
- Crahsed, kept the battery, help please.
- Sirrus Plug Styles????
- Terminals and wire for batteries, radios, and servos
- Flaperons Pros and Cons
- 1st Gaser
- Fuel tank placement question
- Regulator connections
- cover iron help
- Good first biplane?
- Need a RX battery for my Avistar .40
- Engine bearings...plastic insert?? huh?
- Minimum voltage to safely fly
- Next step after sheeting.
- Batteries in a series - C's
- Effect of too much nose weight
- Need Servo Advice
- OS F plug in 2 stroke?
- OS 61FX Carb Question.
- Assembly of OS 1.60 two stroke - questions
- OS 61FX break-in?
- Simulator question
- Help! Need Plane Recommendation?
- RC Radio for beginner
- Testing servos
- saito 180 question
- Sheeting on a curve.
- OS 95AX for Big Stik 60
- RC Bugs
- New Tower codes
- First 4-stroke engine. Help?
- Another Fuel Question
- Source Needed for OS Parts
- Soaking an engine in antifreeze in a crock
- E-flite P-40 Warhawk 300... it won't fly (looong)
- Avoid TroyBuiltModels.com
- 2.4ghz tx/rx Do I nee more than 4ch?
- CA hinges on a P-51
- servo compare
- spektrum rx
- What one gift I want for Christmas; how about you?
- Engine not sucking fuel
- NOVA maiden and crash
- Help
- best .60 sized pattern plane?? with a magnum .91fs
- Uproar 40 or 60 and why?
- Help choose from two kits
- Spectrum DX6i AR6200/ servos
- Question on OS 91 Four Stroke
- I'm going through withdrawals
- Friend wants to know quality of RTF?
- parkzone P51 Micro problem
- Old Kit Build, Electric
- Aileron and Elevator MIX 12FG
- New rc Aviator
- Getting engine back in service.
- transmitters
- training help (from instructor standpoint)
- Servo programmer - burning in a new servo?
- Flexible exhaust pipe
- Servo mounting tips needed
- maiden flight....
- usb sim cable
- TDM models
- Name this Plane
- Black Friday
- Radios?
- Recommend an Airplane?
- PCM vs FM receivers and Futaba servo rebuild
- os 35 in a 1/12 scale?
- Battery Help
- motor getting hot
- Happy Turkeyday, ham day, duck day.
- Spektrum rx's 6100 or 6200
- Lustrekote on covering
- fell in love with os
- Beginner wants to use RC plane with video cam
- most ridiculous story this year
- Gas engine vibrations when idling
- Not enough ElE travel
- Sim v/s actual model
- posting pics?
- Which Li-Po charge is best
- Breaking in new plane?
- Back to Flying - 2
- Weedwacker converted engines for R/C Airplanes?
- Wiring Questions ?
- Black Friday sales?
- Rudder and After run Oil
- batteries
- Onboard glow warmer runs off battery and has switch?
- Thanks Gary!!
- Radio questions
- Nova ready to maiden!
- Slowstick floatplane mod
- Electric RC Battery Voltage Question.
- How do you keep a 15 yr old girl busy?
- cmpro composite
- Havent flown in about 9 years
- How to glue magnets to foam
- towerhobbies uproar 40
- Prop bite revisited
- New club
- Back to flying
- Out of trim trainer
- Nexstar EP mini Batteries
- best for begginers
- enya
- Color scheme for best visibility
- Pitts or Ultimate
- Specktrum Flight Log
- FUtaba skysport 6 question
- eflite apprentic 15e 1st catastrophe
- One more Pull
- Slowpoke 40 ARF
- Learn something new everyday
- Truck Bed Rack, 2-Planes ??
- mini servos in .40 sized plane a no-no?
- more right offset on eng?
- Throttle Servo Setup
- Hangar nine at6 texan
- Flaps
- New Flying Addict-Got Stock Up the Hobby Shop Now..LOL
- Edge 540
- Engine Only Starts UPSIDE-DOWN???
- Need advice on unsticking an OS 120 nonsurpas engine
- The greatest flight box
- Hangar 9 Alpha 60 Trainer ARF
- motor mount
- Balsa Nova fliers
