- Broken Receiver Antenna Wire
- almost ready to fly!
- Radio Mixing
- Grinding in NEW Super Tiger 45
- Nexstar Airfoil ???????
- engine clean up after a flight
- Super Tigre 45 ??
- Small electric plane
- Removing RC56
- Fly alone?
- Losing Fuel Pressure
- balancing both ways....
- 380 electric motor
- Pls suggest bigger wheels for....
- Nexstar to Ultra Stick
- Flaperons - How do these work with DX7
- Put monokote trim on
- Underpowered Sr. Falcon?
- LT-40 w/ O.S. FSa .56
- Hangar9 P51 PTS upgrade questions
- Engine problems with my Super Tigre 40
- A near flight experience...
- Instructions, Info on Ugly Stick 60??
- Flaperon setup
- A good begginer plane
- Rudder Pull Pull Help
- elevators
- JR 2610/6102 Dual elevator and aileron servos
- First Solo Flight Plus new Toy
- What makes an EXPERT
- Hit Your Field Box?
- Landing question
- Gettin' closer!
- Kadet Repair
- Overheating with muffler deflector
- Need help with engine problem!!!!!!!!!!
- first flight
- OS .25 Max FP hard to turn over...
- Wind Log
- plane and engine cleaning.
- balancing
- clevis size help......."please!"
- Monokote and Coverite
- Would the easy sport .40 be a good plane to start with?
- Loose CA hinge help
- sc .75 prop
- Tower System 3000 6XM interface
- Servo reversing problems`
- BATTERY CHARGING QUESTION
- Esky Nemo any good for beginner?
- DX7 - buzzing sound - normal?
- material to seal control surface gaps
- weird noise
- Question in English
- After Run or Not
- 4*40 question
- Washing a hot sock
- Which do you prefer?
- Does anyone know of any site where i can find line
- Recovering Nexstar
- Can't use CA
- Slower prop for T-34?
- Hangar 9 ALPHA 40
- tower hobbies
- OS46FX engine and misc stuff
- FILLER FOR PLASTIC COWL
- cleaning your plane
- WANTED
- Landing
- Any S.W. Wisconsin flyers here?
- Nexstar and moving up?
- quick question
- analyzer
- HiTec Receiver Question
- Houston, Tx hobby shops
- Web site with manuvers
- Static and unloaded propellor speed
- Changing Reciever in Nexstar
- Radio Decisions and opinions
- Fiberglass tape wing joint
- Seating a back nut in a 4*40
- Where's the best place to get a DX7
- ST 90 prop size
- Need advice on a first "real" plane
- Trimmed out but doesn't look right?
- Royal B17 retractable landing gear??
- What is the opinion on Great Planes Easy Sport 40 ARF?
- rudder alignment
- Ok, bout to take the plunge
- Need a New Plane for a rebuilt Saito 82
- fuel question
- up-thrust change...what affect???
- Pacer Hinge Glue...
- one box for two planes?
- Digital servos
- I broke my plane in the air, need advice how to fix it.
- Glow Plugs
- Servos problems
- PC 9 with evolution 40 motor.
- What size of spinner for what size of prop?
- flight stand easy cheap and quick
- Finally back in the air... for the first time in 15+ years!
- .46 AX Leaky muffler
- avistar tail dragger?
- Saito 180 ar7000 reciever
- My own "RTF" package...
- How to replace plastic pushrods
- WOOOOOOOO!!!
- Where to fly??
- Park Flyer $100
- Futaba one inch aluminum servo horn/horns?
- Beginners questions
- Don't Try This
- night flying
- newb with flight box questions
- medium fuel tubing vs. large??
- small flying space for glow
- HELP with RADIO
- Gosh Darn it! Please help.
- Great Planes F4U Corsair 40 kit
- Firebird Xl
- Working on SOLO
- Pro VS cons of converting to tail dragger?
- Fatuba 6 channel 2.4
- Evo .46 engine troubles
- attaching canopy?
- Dremel Issues - help!
- DECAL SITE
- looking for a trainer
- Nexstar Owners/Future Owners---Listen up!!
- Nexstar
- the next stage
- crimping tool
- Landing Gear Newb Question
- Eagle 2 wing warp
- Hanger 9 Evolution .46 engine question
- Where Should I go from here?
- aerodynamics drag ext.
- First Plane Help
- Banged the cub......
- First plane
- Spinner question
- Towerkote too heavy & cable pushrods????
- Control throws for LT-40
- Battery cycling
- Tiger 2 needs TLC
- Do Leaky carb & muffler make a difference in Engine's Performance?
- Position of throttle while taking vertical nose dive?
- FIRST TIME CUSTOM BUILD. NEED HELP!
- Shoestring for second plane?
- Covering Questions For Fuse
- Prop balancing article in Model Aviation
- gas tank stopper
- Which one?
- US Modelling Association
- Fitting a prop
- Flaperons????
- Side mounted engine issues?
- upgrading RX/TX batteries
- Extra 300 as a second plane
- 2 Questions for NOOB
- Hi i bought this J3 3ch Pipercub here any tips?
- CA thickness
- my first solo
- new funtana
- i need help picking a begginer airplane
- is oil dangerus sitting around
- I screwed up something
- Battery question
- 3 bladed props and ext.
- Misc questions about engines
- Reversing Y harness or mixing ??
- Radio problem or interference?
- SERVOS GO FLIPSY
- My journey towards flight
- nexstar dying out when nose drops
- balancing a mid wing plane..."right side up?"
- Motor / electrical problem??
- a plane for a .36 engine
- Trainer as a Short Take Off and Landing planes
- 0% nitro content
- 2nd Plane Suggestions?
- Training gear off
- Muffler is too obvious
- Beginners, don't rush yourself.
- Great Planes Cessna 182 ARF?
- LOST...HELP PLEASE!
- Car guy looking to get into planes.
- Fuel tubing
- Sig Kadet Senior ARF assembly
- Engine mounting
- Maiden (and most likley only :D) Flight 2 Morro!!!
- Coordinated turn ?
- ac/dc converter
- Next plane help
- Paint on propeller and balance
- Battery location?
- JR and Hitec compatability argument
- Travelling with my plane
- Why use hairspray with rc models?
- Rx Questions, I Need Answers Please
- Second Plane - Extra 300???
- PCM/FM vs 2.6GHz
- NexStar on floats
- Helpless on maiden.
- PUMPED UP
- Fuel on ply...how to remove before covering?
- where to buy charge leads/ no combos
- Spinner balance
- I've Soloed!
- Deans Micro End on Lipo Battery
- Thunder Tiger .46 muffler compatible
- Cowl CUtting
- Notes on a first flight and 1 question
- need help breaking in new engine
- Servo Question
- looking for aircraft
- Servo Buzz
- Getting back in after 30 years
- Finally got a stick.
- First plane
- Where to get covering scheme
- Good Starter Plane ?
- pos and neg shift???
- What is Crow?
- Transfering plans to balsa
- Hobbico Hobbistar 60 flight problems
- what propeller?
- radios and servos and kadets .. oh my...
- Slow Stick good first plane?
- Should there be a seperate electric beginners forum?
- 2 Stroke Sizing (or Elec. options)...
- BuddyBox on a 2.4GHZ FASST
- chunk out of prop, possible to fix.
- Twin Engine Setup
- what dimensions the fuel compartment in sig mini boss field box?
- OS.61FX Idle Problem in Alpha 60 Trainer
- fuel tank installation problem
- Does Nitro reduce Engine's Life??
- How to trim level flight
- Hobbico SkyFly
- What to get
- What's the expiration date on fuels?
- Its not like riding a bike
- Saito .82 stopping in the air
- 4-cycle sizing????
- First-time charge
- HELP!!!!!!!!!!!!!!!!!!
- Aerobatic Sticking
- WAIT, before you buy the Progressive Trainer (P-51 or F-22)
