PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. LiPo balancing wire question.
  2. Ch5 as second elevator servo using F9
  3. super stick
  4. After run oil
  5. Thunder Tiger f.75s
  6. NEW Flyer what to do
  7. To hot to fly
  8. How do I get CA out of the control surface hinges?
  9. Keep your fingers crossed!!!!
  10. Plane #3 on the bench
  11. Epoxy Wing Strengthening Fiber
  12. New Guy trying to build a F4F-4 WildCat
  13. Oh no.. my trainer!!!
  14. Super prop in need of a spinner
  15. Changing Rx channel
  16. Scale Model Advice
  17. Question about American flag on plane
  18. balsa snapping????
  19. Yet another question on aerobatic maneuvers: Snap roll
  20. Question about prop characteristics
  21. help with minnow rebuild!
  22. DUMB NEWBIE MISTAKE
  23. Need suggestions for tail dragger conversion
  24. please explain? charging question
  25. 4-stroke = to a AX .46 by OS
  26. O no!
  27. Lanier SeaBirdgluing plastic
  28. Laptop power supply for RC Charger??
  29. Crosswind takeoffs and landings
  30. Are there any full scale R/C model aircraft? (80% so far)
  31. Snap Exit?
  32. 10c FUTABA
  33. futaba radio
  34. Second plane SIG Something Special
  35. Battery substitution
  36. Attaching Wings??
  37. cutting flexible pushrods
  38. Trainign session woes
  39. Thunder Tiger F91S Problems
  40. OS 46ax dripping out oil that is BLACK? Normal? now with PICS!
  41. Fuel line problem
  42. OS 25 multiple deadsticks
  43. charging starter battery
  44. Tug conversion
  45. Got my wings!
  46. Red Bull Air Race
  47. How do you recommend I seal this?
  48. Went to my first pattern meet!
  49. PULL/PULL SETUP
  50. prop balancing
  51. electronics going crazy
  52. Newbie question
  53. Choosing my first plane, and simulator question.
  54. Engine trouble
  55. I actually did it!
  56. Holding the airplane up at full throttle??
  57. Futaba/JR Trainer Link????
  58. asp 46
  59. My Trainer plane
  60. Hobbico NexSTAR 46 rtf
  61. SATIO 100
  62. Transmitter check up
  63. Can a Heli engine be modified for planes?
  64. Extra plane suggestions.
  65. Prop recomendation for a .91FX on a .60 size plane
  66. Question about RC flier books
  67. 8300rpm saito?
  68. Is this a ringed engine?
  69. Foam vs rubber wheels?
  70. New plane for the hanger
  71. Upgrading RX Battery
  72. Fueling without disconnecting lines??
  73. DX7 heli for airplane use
  74. Tower trainer landing gear bouncy :(
  75. Shutting down the engine
  76. Question about G4 simulator demo
  77. Sheeting leading edge LT-40
  78. Batteries...
  79. Engine Carburettor Rotor Doesn't Close Completely? Help!
  80. Spinner question
  81. radio help
  82. Planes one should fly before trying an 86" Yak
  83. just bought and flew the new Vapor
  84. hangar 9 super stick 60
  85. first buried engine landing
  86. satio 100
  87. Charging two batteries at same time?
  88. Robart Control Horns and Linkages
  89. Looking for advice.....
  90. Four Star RPMs drop in knife edge
  91. Question about battery and ESC matching
  92. GPS Locator
  93. FRIEND WANTS A CUB
  94. F-22 raptor, How to land it properly?
  95. Engine Problem
  96. My kids got the bug ;D
  97. How to practice Pattern flying
  98. Hangar9 P51 PTS trainer
  99. did anyone use this servo S15CLN-MG-BB
  100. Damaged prop repair
  101. CA question/ gap filling, thick or thin?
  102. after first crash - what supplys should i have
  103. Ideas on why glow plug failed from one day to the next
  104. engine overheating help
  105. Testing for amp draw on servos and receivers.
  106. First flight on rebuild
  107. Landing Gear for a 40 size plane?
  108. HAND LAUNCHING
  109. H9 Ultra Stick 40 much slower than H9 Pulse XT 40
  110. Best Economy Servo's
  111. super stick questions?
  112. I hate plumbing.
  113. Prop hole too big
  114. How do you clean the transmitter?
  115. Starting out - may go electric though.
  116. When is time to change the glow plug?
  117. Starter Battery Pack
  118. Battery question
  119. Elect Co-pilot
  120. First Plane...
  121. Supertigre gs 45 quiting during idle
  122. Traski Maidened the Dolphin Today!!
  123. Rx battery charger question
  124. need advice.
  125. Newbie Airplane Order/Build/BreakIn/Maiden/SoloVideo/Deadsticks!!
  126. My first covering job!
  127. Beginner equiptment?
  128. OS FXi 46 Engine cutting off issue
  129. futaba crystal with jr rx ???
  130. Bridi Deception need help
  131. 2nd plane
  132. Difficulties with figure eights - need tips please!!
  133. tail wheel size?
  134. Grass Field = BIG wheels
  135. Emailing Horizon
  136. Fail Safe feature of Futaba 7C 2.4 GHz
  137. CG for Seagull jumper 25
  138. prop material
  139. Where should trim be set for throttle and elevator?
  140. Electronics compatibilty
  141. Got my wings last night!
  142. BEST LOW-WING 2nd PLANE
  143. Need help setting up mix on 6EX
  144. Crazy day home to work to home to......
  145. Aluminum Spinner
  146. Question time again; RE: How often do you tune your engine?
  147. Battery Charging
  148. A faulty transmitter story
  149. electric motor question
  150. How often do you tune your engine
  151. Started my blog
  152. AMA coverage only good if you have a spotter?
  153. FUEL TANK REPAIR
  154. SIG Kadet LT40 - ARF or Kit
  155. First planE
  156. floats on a trainer
  157. Question to Germany
  158. Firebird Phantum Boom Fix - no glue
  159. How to tap metal
  160. 46AX keeps dead sticking
  161. Kyosho Calmato 40 in kit form?
  162. Radio range check
  163. Need help taking off? I did it! I did it!
  164. Futaba 7c help No throttle
  165. HELP installing linkages!
  166. Wish me luck!
  167. whats different between tractor and pusher Propeller
  168. Finger position on the controller
  169. Second plane dilemma
  170. Wing covering procedure?
  171. Battery Failure Questions
  172. OS Max 46AX ABL with mufller. ABL?
  173. "Tower Pro" "Volt Watch"
  174. Can crank cases rust???
  175. 12" prop on a 46AX?
  176. Bad Mojo: my buddy crashed 3 planes in two days
  177. Beginning in 3D flight
  178. Can I point exhaust down?
  179. night flying
  180. Wing covering
  181. Question about Futaba charging jack
  182. Draining fuel and running the engine until it quits
  183. Quickie 500
  184. H9 Pulse XT 60
  185. 51,52,53,55 where do they fit?
  186. Is this servo ok to use?
  187. Just a little braggin'
  188. Can anyone help explain stalls to me?
  189. All-Battery - good vendor, my experience
  190. Help! what is it? It needs a wing.
  191. IS THIS OK for an electric plane I just want to toss around??
  192. FINGERNAIL POLISH QUESTION
  193. Charging Tx/Rx frequency
  194. It's true what they say about your second plane...
  195. NEED INSTRUCTIONS for Thunder Tiger Eagle-15T!!!
  196. Radio problem
  197. Sky Fly Servo Problems
  198. Buddy Box
  199. Update of Armody from Texas
  200. rolling out of outside loops...
  201. Equal Elevator trav w/ dual servos
  202. I would like to buy a first plane and need advice.
  203. I flew at the field, but not R/C
  204. F-22 raptor PTS Need help taking off!!!
  205. keeping exhaust residue off the plane Four star
  206. 4.8 vs 6.0 receiver batteries
  207. How much castor??
  208. Battery swich
  209. Wing alignment
  210. Morgan Fuel
  211. Digital vs Ball Bearing Servos- which one?
  212. hangar 9 frenzy
  213. 9Cap programming choices flaps/ailerons
  214. Monocote removal
  215. Penny for your thoughts?
  216. Real Flight G4 Simulated Failures???
  217. Can some one explain robostruts to me.
  218. How should i fix this wing tip?
  219. Glue
  220. four stroke opinions, please.
  221. AIRPLANE CLEANING
  222. Symbols on Threads page
  223. Manual for OS 46 sf
  224. landing gear question
  225. Slow flight, Advice from a new pilot too new pilots:
  226. Brushless ESC & Brushed motor
  227. Kinda, sort of, but not really soloed!
  228. What causes this?
  229. Deadstick Landings
  230. Astro 010 Brushless. What plane to use?
  231. Time for another new trainer
  232. What is a good plane for a begginer?
  233. DX6I
  234. I love this hobby...
  235. cutting antenna wire
  236. Whats this
  237. Uneventfull Deadstick, Then Disaster
  238. 10c FUTABA
  239. Fuel valves, fillers, and dots for cowls...
  240. Setting up new radio
  241. Help me choose please....!!!
  242. Device for measuring thrust
  243. Talk me out of buying this plane
  244. Practicing landings with G4 and need tips
  245. Spektrum DX6i question
  246. Trouble charging my RX batterie
  247. Radio battery cycling unit
  248. As promised, my almost crash story:
  249. 6 vs 7 channel for beginner
  250. CA Hinges
