PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. What prop for 4*40?
  2. How often do you get to fly?
  3. V-mar
  4. somebody gave me a kit in winter of 95
  5. Restarting after a ten year hiatus from RC flying
  6. A Little Rudder On Landing ?
  7. Dubro Kwik Switch/Charging Jack
  8. :d
  9. The day to remember.......
  10. different kinds of field batteries and chargers
  11. Lots Of Questions!!!!!
  12. Never built a RC before, and need help.
  13. Need info on Sig Four Star
  14. "Don't get cocky"
  15. My first Radio Setup........ :\
  16. Glow Plugs
  17. wingo park flyer 4 beginner
  18. Fuel DOT VS remote Fuel like DUBRO ?
  19. Can't decide on third plane
  20. WING LOAD? HIGHER OR LOWER # easy to gly?
  21. Better battery for flaps???
  22. help-esc caught fire while breaking in motor
  23. Airtronics receiver question
  24. WING INCIDENCE?
  25. size of engine for astro hog
  26. Will 4.5 volts burn out my glow plugs?
  27. cleaning 4 stroke mufflers
  28. Can someone get a pic of hanger 9 Alpha trainer ARF
  29. 4* 40 Engine Choice
  30. Chalk up another SOLO!
  31. Computer Radio Question :)
  32. G-MAXX flight paks
  33. Can I move the engine forward on the mount to achive the correct CG on my SE?
  34. Encouragement for all you beginners
  35. Begginer Help !!
  36. Question about remote fueling after the fact
  37. Starter wont turn engine over
  38. Beginner in Covering, need help.
  39. Installing fuel tank
  40. Simulating an Avistar on Real Flight G2 Light
  41. i know,lots of threads about 2nd planes...
  42. Why did it deadstick flying upside down?
  43. Don't Loose Your Plane - Lost Plane Locator
  44. batter pack for an older transmitter Please help
  45. Landing technique(trainer)
  46. too rich or too lean
  47. Covering for Irvine Tutor 40
  48. help glued two pieces wrong
  49. How do i balance my plane???
  50. Starting Problems ???
  51. SOLOed my Sig LT 40 today.
  52. What's the best way install nylon hinges?
  53. Is there a Sig Kavalier ARF?
  54. both servos going in same direction, can I use a Y
  55. DIY simple parachute drop!
  56. Newbie wanting to start with TT Trainer 40 - Yellow
  57. Am I going about this in the right way??
  58. question
  59. Second Plane
  60. Information for ALL who enjoy R/C Flying!
  61. Buddy Box Question !!!!!!
  62. Places to race north of Houston--nitro car
  63. AVISTAR plastic engine mount help
  64. How to get the fuel to the carb in a plane with a cowl?.
  65. U-can-do 46 a good second plane??
  66. Flew My Madden Flight With My Xcell 46 Graphite
  67. I "soloed"......... kinda!!
  68. question about a new Hitec RX
  69. Venture 60 Engine Mount
  70. 2nd plane
  71. first time builder questions
  72. question about ready to fly plane
  73. From a trainer to SUPER STICK 60 w/ Satio 100!
  74. Preflight check list
  75. FF 6XS or JR XP-662
  76. Hitec Eclipse radio??????
  77. Couple of Questions
  78. Slight problem with ailerons...
  79. What's Cheaper? Internet of LHS
  80. Great afternoon to SOLO !!!
  81. Hobbico Avistar Engine Mount Question
  82. need help on firebird
  83. this plane
  84. help where to buy in chile??
  85. Why aren't there any gearboxes for glow engines?
  86. first plane chosen
  87. Soloed
  88. Where can I find a manual for the HOBBICO Power Panel Deluxe II?
  89. Wing tip modification for trainer?
  90. Looking for a club in Phoenix area
  91. Clubs in Sevilla Spain
  92. Prop selection for alpha trainer
  93. I activated ailerons on slowstick
  94. graupner`s extra wheels attaching question
  95. Avistar AWARF alot of assembly....
  96. jap zero
  97. Trainer aileron problems
  98. Six Years Old
  99. getting my plane on the ground
  100. Question on props
  101. Biplane as first tail dragger ?
  102. Whats the differance?
  103. astro hog a good second plane?
  104. please check out my pole
  105. Problem with Futaba radio ? or user error???
  106. motorizing a glider
  107. Error Plz Delete
  108. help is this alright
  109. Silicone Sealant?
  110. new guy lookin for a decent rc plane under $50
  111. Somethin' Extra and O.S. 40 LA?
  112. help me, ive got engine problems
  113. Oh Boy!!!!!
  114. EP run time
  115. Retractable gear w/ steering arm....
  116. TDC to crank angle ??
  117. Where to get info on Aerobatic Maneuvers?
  118. Need Help With ARTF !!!!!!!!!!!!
  119. Fire!
  120. Southern CA help for a newbie (L.A/Orange Counties)
  121. field box plans wanted
  122. turning glider into electric
  123. say what you will about Duraplanes...
  124. problem with recomended CG ? HELP !!!!!!
  125. covering question.
  126. Wich engine?
  127. Fuel Tank woes
  128. please explain a 3D aircraft
  129. Im thinking about the PT-40
  130. What are recommended aerobatics for a trainer?
  131. best advice
  132. wht 2nd plane
  133. Opinions: Sig Kadet LT 40 ARF???
  134. Prop suggestion for Somethin Extra with 46fx
  135. Engine Won't start
  136. beginner questions
  137. Weekend of Landings
  138. Great Planes 'Super Sportstar 40 KIT'
  139. Snap rolls for n00bs?????
  140. How long did it take you to solo?
  141. Declared an in-flight emergency today, HELP.
  142. I Flew!!:)
  143. question about beginner plane
  144. cost to start
  145. First two landings today.........
  146. Where to buy in the UK
  147. Spinner nut vs. prop nut
  148. Alpha or Extra Easy 2, which is a better deal
  149. DC-3 for a beginner?
  150. Looking to buy a trainer
  151. Newbies first time out the hard way!
  152. Cowling Problems
  153. Stierfome
  154. Symptoms of overheating?
  155. Field Box Plans
  156. Sky Scooter
  157. Well I bought something I know nothing about!!!Got Questions Need Answers
  158. what kind of engine should i be using
  159. RealFlight G2 or RealFlight G2 LIte
  160. Having troubles
  161. Spads
  162. Tiger 2 arf
  163. Dihedral removal????
  164. Verbose Post Mortem contemplation of Edge 540 Debris pile" or "Getting the Love Back"
  165. Cap231
  166. Has anybody modified the rudder on a Somethin' Extra?
  167. Piston Ring Blow-By
  168. Major Crash
  169. another dumb question
  170. Beginner P-51 Mustang???
  171. Is there an RTF that will fly in a backyard?
  172. Is this a good somrthing????????????????
  173. Is this smart???
  174. nose& tail , which is the better trainer?
  175. Hinge Repair
  176. Can I plug the AirAlert into the aileron Channel instead of the Throttle?
  177. ALL Surfaces Binding
  178. It flew and I did too !
  179. Many newbie questions
  180. 2nd Airplane to build and fly
  181. Tail wing question: High or low?
  182. Battery drain
  183. whats up with the crapy Outlaw
  184. FBOL Hobbyzone
  185. really stupid question
  186. newbie to rcplanes help
  187. How does Elevon Work?
  188. Special Perry Carbs.
  189. Firebird Outlaw
  190. another dumb question..
  191. 2 part question on evolution engine and props
  192. First Flight
  193. dumb question
  194. Just starting out.....
  195. This may be a stupid question ?
  196. Avistar select monocoat VS. Avistar MKII
  197. Nipple on back os Saito 91S
  198. 2nd half of muffler fell off. How to replace???
  199. What to do?
  200. 4 Blade to 2 Blade Props
  201. Vacuum Bagging Video Available at the NATS
  202. Learning the hard way
  203. Leak in the fuel tank.
  204. I really need help deciding
  205. Air Brushing
  206. hello
  207. Well, i guess im solo...
  208. Trainers
  209. Second plane "My Opinion"
  210. Balancing a master airscrew prop
  211. Quickie
  212. Prop Question
  213. Limbo Event + Metal Pole + First ever event =
  214. balance ?
  215. New Engine
  216. Beginners Don't Respond?
  217. if you fuel up and notice dripping pink stuff :(
  218. Engine Break In
  219. Need Help about Aerobird
  220. 13 year old beginner
  221. Suspend from ceiling?
  222. first crash
  223. My return to RC Planes
  224. chicken-stick
  225. Instructors only: I'm getting tired of instructing...
  226. Which way should the prop turn
  227. Northeastern aerodynamics
  228. Monokote & Koverall
  229. touchy elevator
  230. Finally
  231. My Goodness, It FLIES!!!
  232. Tiger 60 - Need tips/suggestions
  233. fuel tank position and CG
  234. Trees and transmitters...
  235. Maiden flight a success
  236. Monocote
  237. World's most aerobatic?
  238. Dirt on the wheels not on the wings!
  239. superstar select 40 takeoffs
  240. J-3 cub engine direction
  241. control rod sodering
  242. Kits for beginners
  243. Wrecked my trainer- whats next?
  244. engine tuning question
  245. Throttle help needed
  246. First FLight today!- Goldberg Eagle 2. Trim Question.........
  247. hi.. i need a bit of help
  248. Soloooooooo!!!
  249. LT 40 ARF build question
  250. Landings
