PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Planes available for the Aero Fly flight sim??
  2. Help Starting Older Tower .46
  3. Flight Simulators
  4. Elevator/stabilizer play
  5. nbew wing
  6. Nexstar ARF - Nitro or Electric
  7. What servo would be like the HiTec 645
  8. Looking for something I can get aerobatic with.
  9. Can u paint a foam parkzone?
  10. I have wind.........
  11. Installing control horns
  12. How do you land?
  13. muffler leaking on a OS 46Fx
  14. New Here, few questions
  15. Airplane "size"
  16. futaba servos in jr receiver
  17. When will you change your plug?
  18. hmm.. What esc + battery should i pair up with my 50mm diameter 300kv rating motor?
  19. Which is better bang for your buck?
  20. lube question?
  21. Super Cub vs. Parkzone J-3 BL
  22. technique to mix your fuel....
  23. Sig Four Star VS Pacific Knockabout
  24. prop fitting
  25. Construction question
  26. Brake Systems?
  27. Will OS 70 Surpass fly the Funtana X 50?
  28. This hobby would be much more popular..........
  29. Firebird Freedom Mods
  30. Using the same TX on differnt planes
  31. Nexstar Engine Mount
  32. Tractor Vs. Pusher
  33. engine
  34. Newbie with Servo and Radio questions
  35. problems
  36. New to rc. Need help starting.
  37. High Speed Electric and the Pipe Dream
  38. 2 questions:
  39. What ya think?
  40. Four Star 40 about to be conceived.
  41. prop size for 180 4s.
  42. thread lock on servo screws?
  43. Discoveries in Friend's Basement!
  44. Super Tigre G.51 runs backwards
  45. What fuel for Saito .72
  46. Wing Dragon plane
  47. Beginner needs advice
  48. Four stroke Saito dying in air. Tweaks?
  49. Does the Funtana X 50 ARF come with a spinner?
  50. How long does a battery receiver charge last?
  51. Tiger 60 servo extensions and Y harness
  52. A Second Plane!
  53. HELP!!!!!
  54. BEC VS Receiver Battery(s)
  55. Four Star .40 Balance Question
  56. Prop Sizes
  57. Tower 40 Maiden
  58. Experience pays off.
  59. Still struggling with Nexstar nosegear
  60. prop size for most pull: .75 glow
  61. fuel ghanged color
  62. Suggestion for servos for Seamaster 120
  63. Nexstar steering linkage/nosegear
  64. Tower Hobbies .75 help
  65. dave gierki engine break-in debate!!
  66. Tiger 60 Kit Balance Point ??
  67. Nylon mounts for Saito .82
  68. Fuel Tubing Problem
  69. BEGINNER QUESTION ON FUEL
  70. swap meet pick up
  71. GREAT HOBBIES proving to be irresponsible
  72. Need help!!
  73. Has anybody bought from Raiden ?
  74. Maiden flight on Sig 4*
  75. Aileron Hinges!
  76. Why no aircore?
  77. Futaba 7C 2.4 vs. JR X9303 2.4
  78. Propeller help
  79. My first glow plane finally purchased!
  80. Epoxy use on foam
  81. Tower 40 Dihedral
  82. Some help starting a Fox 40BB please!!
  83. Futaba Futaba TP-FSM Synthesized RF Module
  84. Nexstar Engine Mounting
  85. Good Deal If Any One Needs A Flight Box
  86. help me choosing a prop
  87. AccuThrow Deflection Meter
  88. Ripmax Trainers
  89. engine/fuel problems
  90. just a couple newbie questions
  91. Best way to run antennae on a Sig Kadet LT-40
  92. Tower Shipping!
  93. fuel proofing
  94. Can't keep it running
  95. Hydro-Lock!!!
  96. Motor for SeaMaster 120
  97. New here, and new to RC !
  98. I cannot put this Giant Super Sportster together can anyone help
  99. Skylark 70 done
  100. Nexstar Landing gear
  101. Building a kit with my daughter
  102. Fuel Damaged?
  103. another noob CG question
  104. Avistar's Demise.
  105. Oil content for break-in
  106. Remote Needle Valves
  107. Need advice for electric setup...
  108. need your opinion on this engine
  109. front nose gear problem
  110. alpha 60 cg way off
  111. Rechargeable Glow Starter
  112. how to get expo off of monokote? Hmmmm
  113. Tail Dragger Low wing
  114. I need to know how to setup a gas tank
  115. difference between OS .46 FX ABC and OS .46 FX ringed...
  116. Great Planes Rapture 40 maiden, a success
  117. is this a good brand????
  118. World Modells mach x Tail heavy
  119. It's only money!
  120. Close call with receiver battery
  121. preferred type of airplane
  122. Tail dragger take offs
  123. 700 mah/6.0V NIMH endurance
  124. Thunderbird 54 Brushless Esc
  125. Nexstar Fuel Tank
  126. Voltwatch, you all use 'em?
  127. Help getting Radio and servos to work please
  128. Determining good advice for beginners
  129. some question
  130. when to use which glow plugs?
  131. DOPE THINNERS
  132. Fuel fill valve placement
  133. O.S. 91SII problems
  134. glow plug cross reference Mc coy-59
  135. What Prop For This Combo?
  136. OS 46 Newer/Older motor won't start
  137. Why do you love flying planes?
  138. Radio on sale
  139. Pheonix models Sonic
  140. RPM range for O.S. 46fx
  141. Who's going to Toledo Expo this year?
  142. When does one use the rudder?
  143. First Gasser/radio question
  144. Super Tigre or Magnum?
  145. New Jet Question...
  146. What propeller to use?
  147. o.s .25 cuts out on takeoff.WHY????
  148. Maiden Avistar flight & Questions!
  149. Spread Spectrum Compatibility With Old Buddy Boxes
  150. Engine Questions/Decision
  151. My son's first set-up, look okay?
  152. Goldberg Skylark 70 build..errr.. assembly
  153. engine wouldn't start
  154. Building from plans
  155. Nitro trainers...
  156. engine deadsticks, need help!
  157. What do you think of this setup?
  158. CAN YOU PLEASE TELL ME
  159. Newbie, Sort Of. . .
  160. Danger Warning
  161. Charleston Area Hobby Shops
  162. Got my kit today!
  163. Explaining CG
  164. quick glow plug question
  165. How much does it cost a teen to learn?
  166. .15 size plane suggestions
  167. Air Bleed Adjustments Opposite High End?
  168. Maiden flight F-27
  169. bubbles in my monokote...
  170. Slow Poke flight limits...
  171. autoshift/autogain remedial explanation
  172. WOT- Servo Feedback
  173. 9Cap radio vs. 9Cap Super...???
  174. Basic Radio Question
  175. Hangar 9 Alpha 60 ?
  176. Need Recommendations For A Tachometer
  177. Changing the Nitro % on my engine !
  178. O.S. 46 will not start.
  179. motor turns?
  180. Fuel Shipping price
  181. Seagull Edge 540 engine selection
  182. f-22 raptor
  183. Designing a trainer
  184. another successful Super Cub Solo
  185. I dont know what to fly?
  186. Engine break-in question
  187. Prop Basics
  188. Parkzone BL J-3
  189. how often do you change your TX batterys?
  190. Magazines
  191. 4.8v or 6.0v?
  192. Astro Blinky!
  193. muffler gasket
  194. Monokote over ultracoat
  195. Whats the difference in Z-PCM & S-PCM
  196. Does cold affect electronics?
  197. Seagull Edge 540 muffler
  198. Should have stayed out of the hobby store!
  199. HORIZON HOBBY IS A GREAT COMPANY TO DEAL WITH
  200. HELP!!! on elevon mixing
  201. balancing a prop
  202. Flight Training
  203. just added a plane to my hanger
  204. Tower hobbies servos and receiver
  205. H-9 Pulse XT 40 cowl
  206. Parkzone p-51/fw-190
  207. Flaperons- how exactly does it work?
  208. After Run oil Necessary?
  209. Balancer lead's
  210. prop sizes for OS 91 four stroke
  211. Freedom Firebird, Commander 2, Skyfly, or Slo-V ???
  212. How to break-in engine
  213. Beginner Build - 35% Sukhoi
  214. .51 engine too big?
  215. Flaps on six channel AR 6200 and DX7
  216. Is there a constant speed RC prop?
  217. battery doesnt charge
  218. New to hobby
  219. My opinion on the Pulse XT 40 PNP
  220. Spinner Prop Nut ????
  221. Lipo Storage
  222. PROP ?
  223. weird prop question
  224. throttle arm problem
  225. Balance ?
  226. Prop won't fit in Spinner
  227. Mixing Channels - aka Aileron & Rudder
  228. Fuel Leak HELP!
  229. Trainer or not?
  230. Another genius newbie question- radio
  231. Deans antenna
  232. Avistar Elevator Throws
  233. pulse xt control throws
  234. Inrunner motor in outrunner ESC of the same amps = bad idea?
  235. Nitro low wing trainer
  236. OS 46 AX muffler extension
  237. WHAT IS BEST FOR MY TRAINER???
  238. minimum vision requirements to fly RC?
  239. Reciever Antennas
  240. Storage for planes
  241. servos
  242. Repost: Flying tips (don't know what happened to my post!)
  243. My choice for first fixed wing
  244. Evolution .46 NT question-dropping the flywheel
  245. I just got a Nexstar then read bad reviews...
  246. Prop Help
  247. Where to get fuel in Philadelphia area?!!?!?
  248. Types of balsa
  249. New Pulse XT 60 arf
  250. Evolution .46 NT question.
