- EDIT - - - "NO"CONVERSION then
- Another noobie question...this one on fuel filters
- Best way to get rid of wrinkles?
- a good beginner plane
- Instructor Needed
- CG Eagle 2
- Engines
- couple of questions
- Best iron setting for wrinkles ?
- H9 P-51 PTS
- GP Easy Sport or SIG 4 Star for first Low wing ?
- Four Star 60 wing tips need make over!!
- AMA or MAAC?
- Comming back to planes...maybe
- Obervations while assembling LT-40 ARF and other musings.
- Finally... a second plane.
- 3d
- help with hingin control surfaces
- Soloed in only 3 sessions!
- Ultra Stick 40 with OS 61 fx
- Airleron covering
- First Airplane
- Help for a newbe!!!
- Kadet MkII, first flight yesterday (pic)!
- San Antonio place to fly free?
- NEXSTAR made it's maiden......
- RANGE CHECKS
- Down is up.....DOWN IS UP!! (New Plane needed)
- SE Downthrust
- Sig Kadet Senior ARF with an O.S. 4-stroke
- pull-pull rudder better?
- flaps and spoilers what am I doing wrong?
- Question about neck strap
- Places to fly in the philly area?
- Hello to all
- Drill Starter
- Getting Started Again
- Plane for Saito 65
- Help me balance my first prop. Top Flight Magnetic balancer.
- Tiger Trainer 40 engine suggestions
- Another Battery charger question
- Radio battery question.
- landing backwards?
- In over my head
- HS-81 Servos good enough??
- stupid....stupid....STOOOPID!
- rubber bands......good or bad
- The Mystical Mythical 10 MPH Wind.
- Pushrod lube
- sanwa and airtronics...whats the different??
- Which electric rc plane?
- Pick on RCKen day!
- Dead Stick!.....almost
- GWS Slow Stick?
- Hitec and Futaba brand compatability question
- steerable nosewheel
- Pushrod installation ? Need to glue tubes ?
- WIRING DIAGRAM
- wing
- Hobbico Top Fueler MKIII
- First solo yesterday!!
- Teaching my children...comments, suggestions etc are MOST welcome!
- Hitec Rx with JR Tx
- Stocking up on balsa
- Adjusting OS .46 FXI
- Is this fix gonna work?
- where to buy buddy box
- Plane Stand
- HobbyZone Commander vs. Freedom
- End point adjustment on retract servo
- XP9303 Help
- which brand of engine is the "best"
- How do you adjust control throws?
- Trouble With Straight Loop With T-34..Ideas?
- Securing servo connectors
- How Do I Install An Engine?
- EPA HOW TO
- OS .50 Problem
- Tiger Moth 40 Size
- sig 4 star 40
- Realflight G3 question??
- Next Step of ARF Building!
- Identify and CG?
- Nitro Fuel Residue
- Flying field quality
- "Bad habits"
- CG Question
- engine test stand
- Please recommend a starter plane.
- beginner R/C forum question
- Stab wavy
- wing loose
- Mid wing begginer plane??????
- Newbie advice
- First solo...kinda of
- SIG LT40 tail drager
- 2-stroke or 4-stroke?
- Rebuild assistance
- can you fly anywhere.
- Info and videos on covering for beginners?
- goldberg "protege"
- Licence and learning
- jr xp6102 price
- A Preheater that Works!
- Hinges
- Good Trainer?
- Plane restraint question
- Servo Noise
- Recommendations for 6CH transmitter
- charging a lead acid
- Which field charger?
- Reversing Servos
- More Newbie Questions
- What plane to build around this Wankel engine?
- a new guy to r c flying
- 50millionth "what starter plane should i get"
- First Airplane Build - Hangar 9 Solo Sport
- Sig Kadet LT-40 ARF wing question
- My 13 year-old soloed last weekend!
- FMA Co-Pilot
- How Will This Plane Perform With A Saito Fa-40a?
- Installed my first aileron hinges
- RCUniverse Marketplace Shipping
- Instructions On 380c.c fuel tank.
- Great Planes Ultra Sport
- My flight line choices...hope I didnt screw up
- Beggener here
- Plane that sat for four years unused...
- Decal removal and painting tip props
- Recomendations for second plane to build
- terminology
- Koverall question
- Engine Troubles
- Engine Basics
- New to this, lookign for a wing jig
- From mini RC prop to jet?
- Teaching small kids how to fly
- Need Help on AFR Sky Raider
- Aileron Repair Question
- Thunder Tiger Skylark 40s
- Is it *very* bad if a wing's tailing edge is warped?
- Help with Aileron Repair
- stryker f27-b
- Anyone know which MA magazine had the checker board article?
- "Almost Ready to Fly"
- Skymaster F-18E
- Help please: using angle template
- Four-Stroke Mounting
- Props
- Help with mail order....
- OS 60 FP
- G.P. PT 40 MK 2 TRAINER BUILD
- ace hobby A+++
- Retracts in the p51 PTS
- Radio Compatability
- Futaba Super 9CAPS ??
- Am I going to crash + burn with this?
- Best way to set up the throttle ?
- Gorilla Glue...Epoxy??
- Checking batteries
- Futaba T6XA PROGRAMMER
- Newbie with some questions
- anyone who can help i would appreciate it!
- Electonics for a Tiger Moth 400
- Changing landing gear position....help
- Aileron hinge question?
- Best Place to M.O. CA?
- thanks
- tailwheel
- better
- speed
- need muffler bolts
- Life stinks...(kinda long)
- Batteries in the rear?
- SSE Main Gear Upgrade
- Small screw on back of muffler?
- Overtightened prop nut, now it won't come off...
- SIG LT 40 CG
- Stupid build question
- covering question
- 2 and 4 stroke Exhaust Temperatures
- Throttle servo arm position ?
- Prop fitting, wing dowels and RX antenna fitting
- Senior Telemaster ARF as a trainer?
- how to give a positive member rating
- A First!...well..for me anyway
- Second Plane!!
- Excess Oil on Nexstar?
- Battery Charging
- new engine but dont know what it is
- Please reccomend a good Radio system
- Finding the best fuel tank position
- a year off, got the bug - want to get back into it
- Covering Question
- How to break in engine
- just starting
- whoo hoo, im back from teh kansas city MO rc airplane swapmeet!!
- First time starting .46 AX by OS engines
- Hanger 9 Alpha 40 or 60?
- L/E sheeting glueing
- A good plane to get for Newbs.
- Eagle II dihedral
- Somethin Extra Engine Selection
- Best Book to learn Hobby
- Dual servo aileron reversal question
- inverted engines
- 5 minute epoxy vs. 30 minute epoxy?
- SiG kadet lt 40 is finally here
- RTF, not really ready to fly... A newbies chronicle
- how cold is to cold?
- Flying the Sky Pilot RTF Need Some Help
- Is Global J-3 Cub 45-60 a good 1st plane?
- self teaching
- Eagle 2
- Hangar 9 Heat sealing Iron
- Comments on First Plane Choices?
- basic flight
- Confused and unsure
- Another newbie prop question. Balancing
- Flight Pack Reccomendation
- ARC Jupiter
- 3-Blade Prop on New OS 46AX
- Woo-Hoo! New Toys
- SIG Kadet Senior with a Magnum .91
- Beginner KITS
- kadet seniorita
- connecting aileron to rudder servo
- Nexstar solo w/o Instructor...what are my odds?
- Noobie Xmitter choices & Dig vs. Conv servos
- need help with air plane engines
- BALL-LINKS & NOSEGEARS
- Correct Prop size for a Hobbistar 60 w/OS.65
- First trainer after 5 years and countless planes.
- Field box
- What plane do I want?
- Post kit building threads in the kit building forum
- GP PT40 kit
- stuka's back
- prop size for 25
- Evolution Trainer Spinner Diameter????
- Thoughts on my first build
- Tower Hobbies Discount
- ball links
- Spinning the Prop Wrong Way???
- uproar vs 4 star
- exhaust deflect
- Tightening prop nut with a spinner...
- Irvine Tutor 40 fuel tank
- Removing twist (DOH!) built into tail section..
- Recovering an Avistar in Monocoat....
