PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. first solo today!
  2. Good kit to start with
  3. Leaving rc universe
  4. Real Flight 6 simulator
  5. How do you balance a spinner?
  6. Idle Problem with my TT Pro 46
  7. Escapade or stinger 2
  8. Tried repairing starter..
  9. RCU WILL BE DOWN AT MIDNIGHT FOR ABOUT AN HOUR!!!
  10. 2nd plane suggestions
  11. Lipo battery battery charging question (wire color code )
  12. Don't know how to delete this post haha!
  13. building rc plane.
  14. I tried to warn him
  15. I need to cycle manually
  16. AHHH!! Got my fix, I went to the Toledo show
  17. Gluing Plywood & PVC
  18. See ya in Toledo
  19. question about prop?
  20. WOOPIE!!!!!!
  21. Some experience not a lot.Question
  22. Starter has no torque
  23. How to tune this engine
  24. Close call today!
  25. Simulator flying problems..??
  26. Stumped
  27. Carb Mounting screws
  28. can't make my futaba buddy box work
  29. looking for sim
  30. Dope???
  31. pushrod assembly
  32. Fueling a Cowled Engine
  33. ParkZone PKZ4500 J-3 Cub BL RTF Electric questions
  34. Recovering
  35. engine question
  36. flying tips
  37. I guess learning on a Heli does have it's benifits
  38. 1/4 scale Citabria don't want to turn
  39. How do you get a new engine broke in?
  40. Devo12 12 Ch Computer Radio
  41. hawk sky fuselage
  42. going from 2 stroke to 4 stroke
  43. Retract Servo problems
  44. WARNING BE CAREFUL
  45. Prop for H9 Alpha 40
  46. Piper Cub .60 (GP) toe in
  47. Dynam 4 CH 2.4 ghz help
  48. Charger for Plane
  49. Have questions on thunder tiger pro 46 need help new with gas motors
  50. T T pro 46
  51. Wheel Upsizing; Is 2.5" > 3.5" Too Much?
  52. Looking for comprehensive manuals on how RC systems work
  53. Just got my first plane and need some help
  54. What plane do i start with?
  55. What happened to "The Realm"?
  56. help for noob
  57. New to the RC hobby.. I'd love some help.
  58. Antenna Placement?
  59. nicd charge rates
  60. PT 19 is RTF again
  61. Fun Ideas
  62. Understanding RC LiPo batteries (found this )(must read )
  63. Where is RCKen
  64. Acetone on Monocote?
  65. OS FS91SII running backward
  66. Flying first time "by myself"
  67. Jammed prop nut
  68. Landing Gear Block Nightmare?
  69. engine isnt running right
  70. new speed brake idea ... what do u guys think ?
  71. Decal paper for printer
  72. general Safety
  73. Have any battery people here..question on Li-Po's
  74. General Hobby Piper J-3 Cub 60 81' ARF
  75. Back in after 20+ years
  76. Ordered a banana hobby 6 ch. cessna 182 (arrived today 3-27-12 )
  77. Engine Vibration ..... please help
  78. What servos for a kadet senior
  79. New plane
  80. Fuel tank question
  81. Radio Choice?
  82. New To RC Nitro Planes !! HELP FOR A NOOB !!!!
  83. Plane
  84. Bud Nosen Citabria
  85. How are you drilling your props
  86. What would cause the light to blink
  87. engine is choppy
  88. OOPS
  89. low NiCd capacity
  90. torch plug to NGK
  91. What causes a brownout?
  92. model aircraft with flaps!
  93. where do i start tx/rx
  94. I have three lead-in's where do they go
  95. monocote
  96. Aileron Help!
  97. Dx7s flapperons - Incorrect travel
  98. multiplex magistrar brushless motor (new to planes!)
  99. Fuel Tank Questions/Issues w/Goldberg Sr. Falcon?
  100. Skill transfer between indoor heli and .40 trainer?
  101. OK, where can I get one of these
  102. Need help with my DX-7
  103. Top Speed
  104. Telemaster planes
  105. I need some wheels
  106. Did I read somewhere in a post about hot glue
  107. Super Frontier Senior question
  108. Hinges
  109. Twisted tail on foam corvalis
  110. Rtf for Gopro
  111. choosing second plane
  112. beginner TX RX help
  113. PT 19 wing recovered and decaled
  114. POLE-CAT BEST BEGINNER
  115. OS 91 Valve Spring question?
  116. Tower Hobbies promo code
  117. Help me pick!!
  118. Kadet Mark 2 Wing Ribs
  119. Help With Plane Name and CG
  120. Real Flight Basic
  121. Low Level Charging
  122. Spektrum AR500 rx in a nitro plane?
  123. Motor Mounting Questions
  124. Prop tutorial?
  125. futaba servo
  126. MOVED: What is a good beginner rc helicopter a step up from?
  127. Radio Help
  128. Finally at long last
  129. Can't start engine
  130. What Servo?
  131. Getting started, on a budget, with a size limit
  132. Newbie [What plane?]
  133. Do you remember being a beginner???
  134. Electric trainer with room for growing into aerial photography and FPV flying
  135. Pretty Sweet Deal on Hitec Radios Going On...
  136. Buddy box dx7/dx5
  137. 4-Strokes for Beginners??
  138. How do you teach?
  139. Wanting to get started.
  140. Simulators
  141. Hello from a new RC addict
  142. ,
  143. Power System
  144. reciever setup
  145. Fuel Tank/Balance Question
  146. Life Battery Discharge Question
  147. dx6i
  148. Remember This?
  149. Servos go crazy- do I need a new transmitter and reciever?
  150. First ARF (newb to airplanes)
  151. New to RC planes.
  152. Installing Lipo in Old SuperCub...Need Advice
  153. Landing technique examined
  154. Help Me 'Rig' My New ARF Trainer!
  155. Where to Buy
  156. Maiden Flight For Plane And Pilot! Video Inside!
  157. Okay to keep airplane kits in workshop/shed?
  158. AC 680 charger, balancer
  159. Noob mistake by an "old" guy
  160. Should I Quit
  161. pnp planes
  162. where should i start?
  163. What is the cutoff point for lipo's
  164. Adding Flaps to Parkzone Trojan
  165. 4.8 NIMH battery
  166. I need a canopy
  167. Futaba 600 mah nicad battery packs
  168. RX voltage differance
  169. ID Planes Size & Model
  170. MOVED: Vintage Control Line Airplanes ID
  171. GP Easy Sport, help
  172. My friend wants a cool looking starter plane.
  173. the best beginer plane for aroud $100
  174. balance point for F-15
  175. DX7s beginners question
  176. CG Tuning
  177. I am new
  178. To flap or not to Flap. That is the question
  179. should have flown today..
  180. Someone gave me an old rc plane - may need new battery, not sure what fuel to use
  181. Selection HELP!
  182. OS 75AX Question
  183. ic to electric
  184. Engine mounting
  185. Which lipo for driving a starter?
  186. trainer plane
  187. Why Beginners Do Not Want To Join Clubs
  188. manual
  189. nitro to electric
  190. First Flight of the T-28 Triojan
  191. My first Homemade plane
  192. cause of servo movement?
  193. NEW TO GASS'Rs
  194. battery advice
  195. Hinging
  196. Applying Rotary Wing Skills to Fixed-Wing
  197. Lipo chargers
  198. Newcomer Looking for Info On New Equipment.
  199. P51 PTS Trainer Issue??
  200. My flying buddy and new Marine
  201. Best in wind out of these
  202. 3D For Front Yard !
  203. which plane
  204. motors, and ESC's, and batteries... OH MY!
  205. How do you know when a bearing is going bad?
  206. Super tiger engine
  207. place to buy retracts.?
  208. receiver advice
  209. putting a Pitts muffler on a stik
  210. Nitro Newbe Here Need help!
  211. Transmitter?
  212. I Dont Have IT
  213. Servo selection
  214. Flyzone Corvalis 350
  215. The typical newbie thread
  216. What do you call these wheel spacers?
  217. spektrum DX6i battery question
  218. DO NOT BUY FROM BANANA HOBBY
  219. EZ connector on a servo horn
  220. nine eagles sky eagle motor
  221. 1* and 8
  222. glow engines...whats the difference?
  223. Back Ordered ! How long?
  224. Clubs around Daytona Beach?
  225. Futaba 6ex Transmitter Battery
  226. How to replace a crankshaft bearing?
  227. Air in my fuel line?
  228. Cookies for the swap meet
  229. Deals on RC
  230. RC Plane Hobby Is Not Expensive !
  231. Replacement transmitter knobs
  232. SERVO COMPARISON CHART???
  233. Gyro on main gear or rudder
  234. Futaba 6EX vs 6JA
  235. Engine selection
  236. Brand new nitro rc planes
  237. Open hole in fuse?
  238. Need Someone to complete Stearman Build
  239. need help???
  240. Semi-Symmetrical, Hi-wing, ARF/RTF Options?
  241. Looking to come into the hobby need some guidance
  242. Hangar 9 P-51 Mustang pts
  243. Slow vs Fast flying Planes
  244. Cold Thumbs
  245. Tail Wheel Support Bracket
  246. Tail Dragger Conversion, Skylark 70
  247. Computer radio Headache
  248. Radio systems explained.... could someone point me to some good threads? thanks!
  249. Cessna 350 Corvalis
  250. starter jet?
