View Full Version : Beginners
- Multi Servos on a CH and Accessories
- 2.4 tech question
- Engine temperature ranges
- First ARF build
- Covering Sequence
- crock pot method of cleaning
- Kindness Dangerous?
- Low Throttle Problems w/Evolution 46NX
- setting up a the throtle
- here is a stupid rookie mistake
- dumb move
- Fiberglass cowl resins?
- OS 91 SURPASS II Problems.
- Is it OK to route my antenna in a nyrod tube?
- Sort of a Beginner Set of Questions-Minnflyer/RC Ken or others??
- Engine life
- I finally did it!!!!
- Spektrum AR500 Receiver Question
- How to fine tune a 2 stroke
- New to scratch building!
- 4 Stroke poping back when I try and start it?
- Magic valley Air Force fly in - 4/24/10
- NEED HELP PLEASE!
- Engine Tuning Help
- Where to fly in Tucson,Az?
- towerpower
- patern prop question
- new 2 fly
- ***Hobbico NexStar Engine Advice ASAP***
- Mixing fuel
- Smoke Sysem
- Futaba 9CAP question
- Revolver maiden
- Ply?
- My first RC Aircraft flight....a failure :(
- Navion Canopy
- how much rev. os 50sx
- Micro-balloons, epoxy and foam???
- New RC Trainer ARTF - ORA Transformer - Now Shipping!!!!!
- Years of experience in R/C hobby including operating/flying & building
- Can model memory be added to FM 72 Mhz Radio/Tx?
- I think I may have a problem?
- good radio for my plane?
- Motor Mounting???
- Flight Simulator
- Any Boise State fans out there?
- Crosswind landings anyone?
- Charging LiPo Question!! (power source related)
- Paint Match for Ultracote Bright yellow???
- What is this called?
- No maiden last night
- Power Lines Suck...
- Hangar 9 Pulse XT 60 Engine choices
- adding trim over Coverite 21st century fabric
- Low wing sticks, pics?
- maiden tonight!!
- Qustion about wings and local wind
- Cg on Super Chipmunk
- just bought a new plane
- Toledo!!! Who's going?
- i need a main wing for a Accipiture Badius 3 channel slope diver yellow
- Electric Motor/ESC HELP.........
- What a Great Deal i got on Ebay
- Matching paint to Pearl Ultracote?
- 4ch question, basic
- TX Battery For RDS8000
- No room for my voltwatch...
- Extra 300 Vs Edge 540
- need advice regarding engine cowling repair
- Finally Joined Magnolia Aeromodeling Club, Magnolia TX
- G5 Simulator
- Fuel Proof H9 PNP Cub
- Fuel Tanks
- locate airplane mfg.
- rubber bands
- Trainer Mustang mark II Hanger 9
- A GOOD EBAY EXPERIANCE
- 4 stroke selection OS, Saito or ???
- Futaba transmitter
- recovering a wing - ailerons?
- what is the difference in the Extra's
- EDGE 540
- What's the correct way to use a Glow Stick?
- Getting a Nexstar tonight!
- RX got wet?
- When To Wing It
- A good trainer for an 8 year old?
- Slow Stick CoG (balancing)
- Windows 7 64bit ?
- Any plans for Foam Floats?
- Os. Max .46 prop size
- Need help with super chipmunk
- Had a servo failure today.
- gee bee 25
- How to clean wooden prop
- Are these mufflers the same?
- Brushless motor is cutting out above 20% throttle
- need Propeller help mine is broken
- Swappig motors, Prop direction question
- Running prop with no spinner
- Charleston, SC flyers????
- Easter Parade
- Carburator Screw
- Correct Control Horn Installation
- Neon Orange Monokote help
- OS FS 70 Surpass Muffler Help
- instant epoxy?
- adjusting needle valves - which direction -
- rossi 61 df
- Thundertiger 40 leaking a lot!
- 3-4 channel planes aileron and rudder set up
- HobbyKing Orders
- what motor do you recomend
- Spektrum battery with Futaba/Tower Hobbies receiver
- F3P Competition organization/ help
- trojan T-28D for beginner
- A question about 5 min. epoxy.
- First trainer
- What Changed?
- What ESC and LiPo?
- Looking for a beginner-friendly kit
- What’s so great about a cub?
- what is mode 1 and mode 2?
- MOVED: Looking for Minnesota people
- sukhoi 55cc, Power system, new to gas
- OS 1.20 ax throttle servo?
- Another crash, third since Nov.
- Throttle pushrod
- Alternitive to electric starter motor
- Pushrod Cover O-Ring FS-70 Surpass
- neon organe monokote
- Lets see the Work Shops and Hangers out there
- Opinions as beginner plane?
- Noobie about to go fly solo for the first time.
- Mixing different fuel brands in an engine
- PT 19 with decals
- Evolution 46 Problem
- Monokote trim sheets or iron film
- Making a servo move slower?
- Am I Making A Mistake ??
- up dated batts from 4.8 to 6.0 now have a problem
- Where is Channel Six???? Need Help Desperately!!!!
- OS 91 questions
- Toledo RC Show - Fuel
- DX6i and throttle programming question
- Servo Leads Falling out of Reciever
- I didn't know I could do that
- adjust the CG or trim
- My rolling hanger
- What trainer to get ?
- Battery Pack Option
- Battery adapters
- What glue for foam kits?
- LIPO questions
- Motors and Batteries
- lead battery charging ?
- What is recomended?
- 2.4 GHZ Recievers
- Which foam trainer?
- cheap equipment
- No Easy Star :(
- Time to start the King Kobra
- Perplexed over Hitec's Electron 6 +ive Shift RX
- Solar tex
- Photographing RC planes.
- Great planes yak 55 flight flex Repair
- Big Stik .46
- Prop size for CG w/ OS55AX
- Airfoil explanation
- Crazy simulator tricks
- Water take off speed
- Engine Vibrations
- Help with 46 evolution by hanger 9
- first flight ever today! well, kind of
- 4-channel parkflyer
- Will I ever learn
- anyone live in flint area?
- need sites
- gap filler with CA
- lipo charger
- Sheeting help
- Reusing gear from less flown planes
- Super Cub cuts off upside down
- New Here...Have Questions
- need help on first monokote job
- Switching to Lipo for Rx Power
- Great day at the field today!
- Magnum FS 70 Cylinder Head
- on board Glow plug warmers
- OS LA 65 Best prop size experiment
- How to cover fuselages with turtle deck
- Mixing brands and nitro % of fuel
- Slope Soaring - Northwest
- Flaps!
- RTV Gasket Material where & how?
- so many questions
- Need something for my adjusto Jig
- Left-over Nitro fuel in glow engine planes
- New battery Hybrid NIMH
- Motor question
- battery care...
- Difference between 4.8v and 6.0v?
- 1st Flight
- Nitro Planes EZ Trainer
- OS 40 LA Plane Suggestions?
- H9 Super Stick Help!!!
- jba engines
- Very Basic Questions
- A question about bolt together planes
- Bearing trouble!
- how to straighten warped balsa and ply
- Charger for 4.8v 1100 mah receiver pack
- H-9 Saratoga or Sig Mayham
- Evoultion 46 vs os 46
- Engine size help
- New flyer
- Recommend a simulator please...
- Covering ???
- futaba 7c Transmitter...
- Prop MPH Chart
- Kit building
- RC Parts Pricing
- Identify this plane please.
- Question about BroadBand 2.4Ghz TX & RX
- Hangar 9 Alpha 40 Nose Wheel
- Phoenix model Domino 40
- New plane for beginner
- Discontinued OS FS 70 Surpass manual
- I need to build a rc aircraft in one month please help
- Charging 12 yr old batteries
- Finally did my maiden on P51 Mustang MKII PTS
- Rules for 2 stroke engine's break-in
- what size lipo can i use with my starter??
- Sometimes it's better to be lucky than good
- What is a good 2.4ghz plane for new fliers
- Information needed On old Plane
- Help in Matching up Motor, ESC and Batteries
- electric park flier question
- Right and Down Thrust ?
- Drive Washer and Cowl - Spacer
- RX Futaba R168DF + DL50
- just curious
- Sevo gear replacment help
- royal 25
- Question about Voltwatch
- Looking for an inexpensive trainer
- I Got ripped off by a guy on in a trade on RCU
- Balance point ?
- I finally figured it out (with help of course)!
- Suitable for second plane?
