PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. front wheel question..... what is this?
  2. Will these work?
  3. Saw my 1st turbine jet today - HOLY MONKEY!!!
  4. building servo mounts
  5. Advice on Repair of Sig LT40
  6. Cutting hinge slots
  7. Flight batteries for I.C.
  8. Setting correct surface throws
  9. 90 size engine in a 40 size airplane?
  10. Question for Ken or Minnflyer
  11. Looks like the wait is over for Alpha 40 DSM2
  12. Wooden props or plastic props
  13. Hats off to ya'll
  14. IDLE SCREW/ROTARY VALVE
  15. Spacer for spinner on a cowled setup
  16. Just a little braggin'
  17. Sad labor day scale story.
  18. hanger 9 T-34 mentor
  19. Little Help From Someone?
  20. Need RC Clamp and music wire
  21. Any idea what model this is?
  22. Bought my first biplane!
  23. Need Good Rudder Servo Advice...
  24. monokote over monokote
  25. Oh My Super Tigre
  26. Almost lost it today - easyglider
  27. Os 46sf starting to run hot
  28. Buying a RC.
  29. Teaching my 5yo son to fly
  30. Plane #3 near completion....
  31. Need input on mounting Saito .40a in SIG Lt-25
  32. Has anyone seen this plane before?
  33. newby looses plane while taxiing
  34. CA residue on monocote
  35. Looking for 3D Profile that I can use my OS 46AX
  36. Need help with radio programming
  37. AWESOME
  38. Need some advice
  39. Alpha 40 is on it's way!
  40. SSE
  41. 3D Plane differences
  42. This is for cappaj1
  43. Prop? Venus 40/ OS46ax
  44. Very weird behavior of Extra upon elevator input
  45. FIRST FLIGHT
  46. Saito 100 vs OS 120 four strokes
  47. New UAV owner
  48. 9C question using Hitec digitals and D/R etc.
  49. Black Exhaust
  50. Real Flight G4 Owners
  51. Hobbico Quick Field Charger question
  52. Seb Art Trainer
  53. What is this???
  54. Need Help Finding Landing Gear
  55. A Trainer Not to be Overlooked!!
  56. Battery charging question
  57. My little slice of Heaven...
  58. Lack of forums??
  59. Adjusting rudders and ailerons
  60. Contest
  61. tenet: Fly 2 to 3 mistakes high (((???)))
  62. Glow plug suggestions
  63. glitching
  64. cheapest place to buy servos?
  65. battery connectors
  66. Difference between A3 and #8 plugs??
  67. Horizon Hobby Pulse XT as a second plane
  68. tail dragger
  69. how does a matchbox work?
  70. What size battery is this?
  71. recovering airplane advice
  72. landing with cross wind
  73. Wing bolts
  74. Rubber bands on Avistar
  75. First Flight - Take Off - Solo - Approach, All in One Day.!
  76. tricks for replacing wing hold down dowel
  77. Begginer
  78. Four Stroke install help
  79. Question on installing landing gear
  80. Is my charging routine okay?
  81. Goldberg Ultimate Bipe - Good plane?
  82. Is there a safety margin on 6v RX batteries
  83. Battery Recall
  84. Plane Suggestions for Magnum GP .10
  85. how to use flex push rods
  86. Flex Rod for Dual Elev??
  87. Fuel Tank patch
  88. Futaba 9chp radio setup for f15 jet
  89. Electronics suggestions
  90. Servo question
  91. anyone mounted "landing wheels" on the wing tips?
  92. Can a fuel tank be cleaned w/o removing?
  93. Bad plug during break in
  94. Any pilots in the Selma, AL area here?
  95. REALLY stupid question.... wing profile
  96. Where to attach aileron servos (1 per aileron)
  97. OH my AX!!!
  98. Mid air - Bulsa vs foam
  99. MY students new 4* kit build!!
  100. 4 stroke question
  101. Newbie servo/pushrod questions
  102. Anyway that tower can ship without an invoice?
  103. OS .20FS exhaust valve leaking
  104. Servo Jitter
  105. New to Glow - have a question
  106. Cool airplane decals or design ideas
  107. Where us kids can talk!!
  108. Prop question
  109. Servo question
  110. tapeing flaps
  111. What kind of covering is this.
  112. Is there a backing on Aerokote?
  113. what radio to choose
  114. Sig Something Extra vs. 4*
  115. Looking for good trainer
  116. Searching an aerobatic/3d bipe
  117. Prop hard to tighten
  118. How can I get Aerokote to stick to Aerokote?
  119. Air Combat is nailbiting!
  120. best second airplane
  121. JR Radio battery charger
  122. Chargers...Is it okay to leave them plugged in
  123. Whats a good field charger for my reciever battery?
  124. Battery connection adaptors or splice a new plug?
  125. setting flaps on dx7
  126. How should I secure fuel tank?
  127. Melted the battery/esc connection
  128. Used Transmitter question
  129. Spektrum DX7 Owners
  130. Fuel Valve question
  131. APC Props.
  132. Magnum .20 four stroke
  133. New to RC Aircraft
  134. servo horns
  135. metal gear servos
  136. Damaged pitts muffler
  137. O.S. 91 Surpass vs Saito .91
  138. What voltages should I stop flying at?
  139. Well!! it went "Smack"
  140. my friemd steped on my plane?
  141. pro's vs con's of dual servo in wing
  142. Hangar-9 cessna 182
  143. Kudos for the Tower Trainer
  144. Nitroplanes
  145. Where to fly? Plainfield, IL
  146. maintenance of OS40FX
  147. Thread locker
  148. Really Crazy Dude!
  149. Cub As a trainer
  150. O.S. Engines-Model differences???
  151. What should I be checking after numerous flights?
  152. Best place to buy Saito's?
  153. CG for a tiger 60
  154. removing CA from canopy????
  155. Glue 101
  156. Help with engine placement..sundowner 50
  157. LT-40 kit Pay it Forward question for RCKen
  158. Flight boxes
  159. Anyone with experience with "The Wingsmaker" aircraft?
  160. How to "test run" an engine?
  161. Looking for good 4 stroke engine
  162. T-28 maiden voyage
  163. Airtronics questions
  164. Lesson learned the expensive way
  165. dual or single conversion receiver?
  166. Can't find Super Tigre Parts
  167. Fuel tank questions
  168. Tried and True position for landing target?
  169. Timer?
  170. crashed airplane - engine question
  171. Is it possible to blame power loss on faulty glow plug?
  172. Missing Thread ????
  173. Are you Self-Taught or Buddy Box ?
  174. 46 ax pitts muffler
  175. beginner lipo ?
  176. sky raider mach II
  177. more engine trouble....
  178. Advice needed with using a Perry pump
  179. reciver/transmitter question
  180. Direction for 2 stroke glo engines
  181. I am not sure what happened any thoughts?
  182. Having problems setting the throttle on my seamaster
  183. How to properly set up dual rates
  184. Cocky equals Loss of Plane
  185. I won't be using wholesaletrains.com again
  186. fuel system for cowled airplane
  187. Looking to step up, but I have issues
  188. Help needed mounting 2 servos on the wings
  189. WARNING about the JR X9303 transmiter
  190. Servo noise
  191. Super prop plane
  192. How's this for realistic?
  193. WorldStar 40 ARF modifications, and general recommendations.
  194. Use a glove to handstart large engines!!
  195. v tail advice
  196. Correct initial throttle setting
  197. pulse xt missing
  198. T-28 Trojan as second airplane
  199. threading 2-56 push rod
  200. Fuel proofing an LT-40
  201. rc ducted fan jets?
  202. Saito 4-stroke - what is this?
  203. Different radio for Parkzone P-51
  204. Looking for good 3rd plane.
  205. Am I "collecting" planes or is this my imagination?
  206. Prop shaving down cowl of J3
  207. Earlier Post -GIANT SCALE- redemption
  208. 34 year old OS Max 40SR engine revival
  209. ?? About wing fit
  210. RPM range on a OS 46AX?
  211. Am i running to lean?
  212. Industrial Arts in Schools Today
  213. Tx/rx compatability question
  214. Fuel trouble
  215. Best glue for Foam Wing Construction
  216. injury because of not paying attention
  217. How dos one tell the difference between 21st Century Fabric, and Solartex
  218. Is the Hangar 9 Twist any good?
  219. Whats the difference in servo extensions?
  220. JB Weld on control arms?
  221. RCU forums
  222. setting up ailerons as spoilers - DX6i ??
  223. What channel is 72.87
  224. Hey Guys
  225. Telemaster 40 Rates?
  226. Mixing ailerons and rudder to do or not to do?
  227. have to return Easy Glider!
  228. What size hinge? (pics)
  229. Prop for Dynam/eVo Cessna 400 EP
  230. Prop continues to fall off
  231. Production Idea
  232. 6V Charging
  233. 2 Stroke Fire Hazard?
  234. how tough are receivers?
  235. Alpha Trainer
  236. Sig Lt 40 CG
  237. What 3 blade prop for a 46?
  238. Two Stroke or 4 Stroke?
  239. how well do flight sims replace trainers?
  240. Removing decals
  241. Someday it JUST might
  242. Movement in drive shaft
  243. Giant scale and jet invite.
  244. Plumbing
  245. How NOT to get started in electric planes.
  246. retract help
  247. I flew a new trainer this week!
  248. removing baffle is more power? wuts up with the push bobcat and kangaroo?
  249. FMS sim "plane" question
  250. Dubro Vibe Reduction Mounts
