PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Membership Finally
  2. U Can Do 60
  3. Sig Somethin' Extra Build Thread
  4. Lazy Tiger with .25 FX
  5. wrong picture
  6. Anyone Know about old school servos?
  7. One wing is shorter than the other
  8. Flying without and instructor
  9. Well I am jumping into the insanity. PICS!!
  10. need a little advice
  11. four star 60 or ventura 60
  12. Dual rate transmiters.
  13. Raise RCKen's pay?
  14. what set up for this plane?
  15. second plane purchase
  16. Hanger 9 Easy Fly 40 Throws and dual rates
  17. four star 40 dual rates
  18. hog bipe faperons? dual rate throws?
  19. Prop for US 40 with OS 61 fx
  20. Adjusting control throws?
  21. 2nd maiden flight
  22. Third plane? Am I nuts?
  23. Field Box Paint?
  24. fuel tank setup with header tank
  25. Superstitions..... bad luck?
  26. How Do I Get rid of this smile???
  27. Complete beginner
  28. Stripped Servo??
  29. Good plane for youngens
  30. Throttle/Servo Not Moving Properly
  31. Retract installation instructions needed please
  32. How is flying?
  33. personalizing ARF's
  34. 9C radio and servo set up
  35. From 40 size trainer to 61 size low wing
  36. Best computer training program
  37. Mini Funtana > Convert to glow <
  38. have a jr buddy box
  39. Hanger 9 Trainer Link ???
  40. spinner and wheel questions? huh?
  41. Home Made servo extensions ..is this the
  42. tiger 60 arf or 4* 60 arf
  43. Choosing your first RC airplane
  44. Maidened my Cessna 182
  45. Is an os .46 fx suitable for a sig LT-40?
  46. Engine care question
  47. Any finger picking guitar players out ther?
  48. Propellers
  49. Best Prep For Sport Scale Warbirds??
  50. 2 aileron servos, How does that work
  51. old model needs a face lift?
  52. SIG SENIOR PIC THREAD
  53. trainer plane
  54. Smallest gasoline engine?
  55. Which radio should i purchase???
  56. I need help with my 4 Star 40! Warped wings
  57. Second Plane Time!
  58. Just wanna keep it simple
  59. Quick field chargers
  60. How Long Does Fuel Last??
  61. Equip. suggestions for a beginner.
  62. Brown fuel residue?
  63. aluminum landing gear
  64. Fuel tank assembly question
  65. Mini-Funtana crash
  66. Charging NiMH
  67. os .40 fp
  68. Battery upgrade for Aerobird Challenger?
  69. instructor says i'm ready to solo
  70. fuel tank
  71. Brushless Electric Prop Set-up
  72. Those that have left the hobby.......
  73. Spraying latex
  74. first low wing tail dragger
  75. IT'S FRIDAY AGAIN KEN
  76. Items in your field box
  77. Hello=)
  78. First Low-wing Tail dragger
  79. help with 1st plane
  80. MY first GOOD plane
  81. Foam versus Rubber Tires?
  82. Futaba's PA-2 Pilot Assist Link
  83. Radios?
  84. Aileron to Servo Setup
  85. jr rx and futaba tx compatability
  86. just to say thanks
  87. slipping pushrods
  88. Local clubs (boston area)....
  89. V-Tail
  90. first plane
  91. Great Planes Viper 500
  92. ARF Search 2006!!
  93. Optimum work surface & control line prep.
  94. Help with landing gear
  95. SIG KADET SENIOR
  96. erratic flight
  97. Painting a prop
  98. Quique's Setup Instructions
  99. Fuel tank orientation
  100. How Heavy?
  101. question for the NexStar Guru
  102. Futaba controller JR micro reciever...
  103. glow starter....what's the best method.
  104. LT-40 Maiden - the saga continues...
  105. Plane for OS FS .26 4 stroke
  106. Engine Break-in
  107. LT-40 vs Nexstar
  108. Flight instructor HELP
  109. Help on Funtana
  110. SSE - Sig Somethin' Extra Visio Template
  111. 1st Solo flight on the P51 PTS trainer
  112. fw-190 saga comes to an end
  113. First crash :-(
  114. Prop balancing?
  115. Brushless Electric setup
  116. My son and I are certified!
  117. Clubs and strips
  118. single wing or bi-plane?
  119. engine shuts off when plane is pointed upright
  120. Cold weather help please
  121. Lateral Balance
  122. Old Xmtr/Rcvr Still Good?
  123. servo trays
  124. Problem with Hydrimax battery
  125. OS needle valves
  126. Centre of Gravity - wet or dry?
  127. Product Alerts/Service Bulletins
  128. First low wing tail dragger?
  129. Sig LT-25 missing parts *Updated* Pics added
  130. Transmitter questions
  131. questions from beginner
  132. Propeller to "wide" for Spinner
  133. Selecting Glow Fuel?
  134. How much did you spend on fuel last year?
  135. PICK ON KEN DAY - AGAIN
  136. HAULING YOUR PLANE TO THE FIELD
  137. Paint over Ultracote?
  138. Setting up my first tail dragger
  139. My first, well second flight :) (quite lengthy)
  140. minimum safe voltage on transmitter?
  141. Slip and Crab
  142. Range Check
  143. Im new please help
  144. Easy Sport 40
  145. My first Flight
  146. Glow plug heaters
  147. Experienced builders needed - Help with repairing crashed Decathlon
  148. four star
  149. Replacement Nexstar Wing Won't Fit
  150. Flair Focke Wulf 190 prop size ?
  151. cheapest reliable mail order.
  152. new plane...engine selection?
  153. Yet another Kadet LT-40 plug
  154. Balancer Build your own or Buy ?
  155. engine specs
  156. The best way to run-in an engine
  157. maiden flight crash
  158. Adhesives?
  159. Complicated words ;)
  160. Work Plane..I get PAID for this?
  161. Nexstar went up without
  162. Resin / fiberglass questions (Cont.)
  163. Its Official, I suck at covering.
  164. Piper J3 Cub O.S. Engine
  165. First Flight!
  166. Thanks!!
  167. alpha 60 flying help
  168. House of Balsa Chea-Pass Float Plane .10 BUILD COMPLETE *
  169. steel wool in pipe on .46 tower
  170. What's up with Airtronics?
  171. LT-40 ARF maiden taxi and a "little hop"
  172. Kadet senior
  173. laser 6 help
  174. Removing Ailerons
  175. any one ever buy a richmodels aircraft??
  176. used JR xp8103 TX only $150??
  177. Aileron servo buzz
  178. Connecting rod dia. for retractrs on .60 P-51
  179. Resin / Fiberglass Questions
  180. RC Flight sim demo
  181. wing mounted servo ?
  182. what planes to buy before jet
  183. Changing radio to other plane ?'s
  184. $20 trainer - Mini Telemaster kit
  185. Paint and fuel question?
  186. AIRTRONICS RD8000....IS IT A GOOD RADIO??
  187. Ballooning Thunder Tiger Trainer
  188. TT Pro .46 fuel line and carb installation
  189. Bit off more than I can chew...I think
  190. center of gravity H-9 T-34
  191. Recommended throws for an Avistar....
  192. Re-covering an ARF
  193. futaba standard2004 servo ?
  194. Oil Leak
  195. Hitec Flash5 Problem
  196. Need instructor in Central NJ
  197. NEXSTAR upgrade question ....
  198. Servo Noise?
  199. nubie here flying alpha 60 rtf
  200. RC Airplane Enthusiast Beginner Resource
  201. Nobler, Anybody still flying this plane?
  202. STUPID!
  203. Which Forum/What Kinda plane?
  204. Need a fuel-proof hardwood finish
  205. How do you adjust the throttle on a Queen Bee .074?
  206. How to wire twin Aileron servos?
  207. 90* Rule????
  208. Don's Hobby Shop email address
  209. Fun Flyer
  210. Propeller Sizes
  211. Tiger Moth on Floats
  212. Too Chicken to fly in winds
  213. Cheapest ARF Trainer
  214. Tower Hobbies .46 engine
  215. Want my next plane to be big.
  216. I almost lost my stick this weekend
  217. electronic ignition
  218. Nexstar Break in
  219. AiBack in Business
  220. Plane Dives to left on Hand Launch
  221. ABX control horn
  222. 2nd Plane... From Avistar to Sig Mayhem 90
  223. Help with receiver
  224. New to flight, looking for advice
  225. Piper J3 Cub
  226. How to hook up TX to comp. using the sim that comes with H9 Trainers?
  227. Exhaust hole position?!
  228. Glow igniter
  229. Flight simulators
  230. Plane Smoke
  231. How do I center servo arm?
  232. First flight tomorrow, alone
  233. Avistar Now a Navy Paratrooper plane!
  234. What's Glassing?
  235. @#$%^&#$#$!!!!!
  236. HELP FOR BEGINNER-LAUNCHING
  237. Does this sound OK to you?
  238. How much CA?
  239. Global Cessna 180
  240. Starting an engine.
  241. Nylon strip on wing?
  242. starter?
  243. NEED 6VOLT 400 SPEED MOTOR OR EQUIVALENT
  244. thinking about a twist 3d 40.....
  245. Covering CA hinge slots
  246. wm super sports senior 90 for 2nd plane
  247. radios 'n' things
  248. Starting all Over
  249. Thunder Tiger .46 Pro
  250. Fuel Lines
