View Full Version : Beginners
- Is this a beginner plane
- LA65 OS engine
- Herr Piper Cub #109 glow conversion
- RUDDER - CABLES or ?????????
- I need help with a gas plane
- first scale warbird
- Stuka JU87 B planet hobby
- Help with RC Engine ID
- What rc plane for beginners?
- What plane for beginners?
- Beginner on Champ RTF
- Lazy Bee
- HZ Firebird Stratos not binding!
- When or if is the time to retire an airframe, specifically a composite turbine jet pr
- Thinning CA
- ESC problem or motor?
- Dhc beaver
- I haven't quite figured things out
- Re-Beginning, Starting Over or Like I've Never Left?
- Using Polyreuthane instead of Epoxy
- Futaba 3001 Servo
- New to RC planes, looking for advice
- My Quadcopter wont lift off!
- Should I use tail flying wires and how?
- Beginner budget Micro Skyhunter 780mm
- Transmitter and FPV Help
- Starting a new build. BUT WHAT MATERIAL?
- AUX Pulse
- Building First Gasser
- A perfect wing
- Super Sport 40s powered by OS 55 AX
- Help! Fan-Powered Pinewood Derby Car
- direct connection w/o esc = what??
- Nitro engine cleaning
- The Chinese way ?
- Cleaning engines.
- Do I have a proper electrical component build?
- Direction for choosing the right Motor/Prop!
- Perfect Outdoor Airplane for Beginners, almost Unbreakable
- Seagull Challenger 40 sport
- Os max sf 46
- CG first flight.
- Newbie Battery Recommendation Please
- Attic find - help needed to get it running - Fox .15
- Traxxas Titan 380 18T
- CG Blues - Decathlon
- New 8' Super Cub Info
- Magnum 46 xls engine troubles
- Glow Fuel Fuel Sensor
- Radio question
- Guillows 400 series p51 to electric gas
- SIG Kadet Senior for first plane?
- Amp draw on a four channel w/standard servos
- New member, burnt out motor!
- E-flite Opterra 2m giant flyingwing for beginners
- New to the Air, Vet on the ground
- New Guy with Project Idea
- For guys who just got RC planes for Christmas
- Digital Tachometer
- 2.4 mhz receiver dual antenna.
- Best Second Plane
- APC Propellers
- Realflight X
- Best Beginners Quadcopter for $50: Syma X5C-1
- Gathering parts for Top Flite Spitfire Mk IX Gold edition. Input requested.
- Question about horizontal stab
- Simple question about batteries and connectors
- Best Quadcopter for beginners !!
- question about camera
- Royal B-17F Kit Question
- ca hinges on foam planes
- Esc question
- Dual NIMH battery pack setup
- Please welcome a new Moderator to the forum.
- Binding DX6e to Night Vapor: Modes
- how "flat"building board
- Ideal trainer characteristics
- Advice on Hobbico Nexstar RTF
- Rank Beginner
- Plane refurb. Require advice please.
- Senior Telemaster Manual Needed
- Help on building my new quadcopter.
- Been away from flying for a couple of years, trying to get back
- Too much up elevator trim. How to fix it?
- RC buggie steering problem help please
- Prop substitution
- Blind nuts, or threaded inserts
- Born Again (RC) Virgin
- New Transmitter recomendation
- XK Innovations DHC-2 A600
- Need help restoring.
- piper j3 cub
- cross country planes
- Balancing props
- How and where to start
- Empty, Flat Desert
- Sim to real life transitioning
- Westerly 2000
- Tactic or Spektrum
- insulating
- Control surface flutter on throttle up while sitting on the table!
- Brand new to the hobby.....Phoenix R/C Sim
- Gas engine question
- Spektrum vs Turnigy
- DLE 20 Tuning
- pushrods
- Battery type selection
- Sportster Bipe 40
- first kit
- wing
- Was this a good-to-go ground test .....or am I grounded??
- Mini Super Cub ESC/reciever! HELP!
- Flap setting
- Ar636 receiver settings
- Nexstar select
- Am I tail heavy?
- Removing paint
- gas kadet senior
- Landing Gear Coils
- Durafly tundra
- How to use rubber bands on avistar.
- 3 tries and 3 crashes, is my foamy underpowered?
- help identifying airplane
- Warbird transition
- sig kadet senior
- phoenix models rainbow 2000
- Reversed control surfaces
- Are valves leaking?
- Good thermometer for me to buy for covering? Applying Monokote onto Monokote?
- My first BIG crash
- Age old "First plane?" question with a twist.
- Battery requirements
- PZ Radian sailplane spiralling when climbing high
- receiver for futaba T6XAs
- How do you know it's too lean on a 4-Stroke?
- Wheels for a PT- 60
- Coupon code for RTL Fasteners 40% off!
- Magnum vs O.S.
- DX9 + AR6210 + Hobbico Nexstar Trainer
- Epoxy Brands
- Tower Trainer 40
- Rookie Plane Selection
- How to set surfaces after aircraft is trimmed??
- Prop keeps spinning off!
- What is it?
- Fuselage help
- EMax GT 5345/09 MOTOR
- Bubbles in fuel line. Would Bubbleless Clunk help?
- Starting out in rc planes with nothing more than an engine. I'm gonna need help.
- First timer here
- 3S 3200mAh instead of 3S 1800mAh?
- Best onboard camera to record flights?
- Remove fly wheel and go from 3-blade prop to 2-blade prop will it increase power?
- Servos making buzzing noise.
- Can I use the electronics from Apprentice 15e for Super Stearman?
- Need electronics advice
- Difference Between Silicone and Tygon?
- Brand new Tx and Rx - one servo only moves in one direction
- Glow Plug, Which One?
- Getting back into the hobby.... What type of receiver battery should I get?
- Experienced with electric but new to glow, what should I expect in flight?
- Glow engine hesitates when going to full throttle.
- Spinners
- where to buy electric prop ???
- Battery-Servo Compatibility Question
- First Build gone wrong
- First plane -need to mod before maiden
- dx4e transmitter compatibility
- LIFE charger question...
- How long does your LT-40 fly
- Storing CA glue in fridge/freezer?
- Prop Washer Question
- Flyzone sensei trainer
- First r/c plane
- Control surface differential
- Horizon Hobby Service Center A+++
- Beginner looking for some tips
- How different is flying planes in a PC flight simulator from RC model flying?
- beeping ESC on new brushless outrunner need help?
- Fa 91 satio
- Help: Black Horse Model 71" Piper J-3 setup
- Stolen Cub Springfield Mo 3/3/2016 pass this on please
- New Member needs advice on PT-40 Trainer build
- Help needed with Badger 150 airbrush
- Help in finding DIY simple glider plans for beginners
- weight distribution
- UM P-51 Rebuild Question
- Binding wings on Telemaster 1450
- EZ Bellanca Decathlon
- What size engine should I use?
- New to glow/nitro engine
- What is this?
- controld question for rc
- Flying 3D. Thumbs only or fingers and thumbs?
- 1/4 scale jet sprint boat hull
- Check out our new RC youtube Channel!
- University design project motor selection for e-bike pedal assist
- Newb sort of and question
- How do I rescue a drone from a big tree?
- Want to upgrade the electronics in my trainers
- elevons
- Sig sanding sealer
- micro-telemaster/motor mounting question
- YS 45 FS Carb problems
- Kit recommendation
- ROA Parkour 280 Racer
- Fuel Proofing Stickers and Decals
- wanting to start a build
- servo trouble for new builder
- another esc motor matching question
- WLToys F959: FREE GIVEAWAY
- First Crash
- Sometimes simpler is better!
- Real Flight
- Good place to fly
- Landing Gear / Wheel Compatibility?
- Hello from a newb and first ever flight
- Where to fly after 30 miles restriction?
- Check out Hover, the must have app for RC airplane pilots!
- Happy New Year
- Saito FA62A Air Bleed adj.
- New user looking for help
- Dilemma over modes
- Setting fuel ratio on carby
- Different battery
- Biplane wing support cables
- RC Pane, info and value?
- DLE 20 RA on a Hanger 9 Sbach
- VERY new to RC planes
- the Dm007 is only $29.99
- Advise on radio equipment setup 2.4GHz
- HOB P-51 glass fuse
- Rc101
- rc plane noob
- Water slide decals
- Evolution engine
- JP Prangster plane: can I use a .61 engine?
- Lazy Bee-- Electric
- Why You Need to Keep Your Throttle Cut Engaged and Fly With a Partner
- politically incorrect
- Spectrum Radio Help - Mixing
- Need help with airfoil / electrical components
- hey everyone
- Electric Flight Battery Question
- Trying To Start Flying Again
- What way up to mount a DLE 20 RA
- Need suggestions; first real build project Giant P47
- Can I put a Tower Hobbies trainer 40 wing on a Goldberg eagle 63?
- Koverall Mishap
- Second plane, first kit?
