View Full Version : Beginners
- OS .46FX - idle
- 5ch Cessna 182
- Happy Father's Day
- Long time gas flier needs advice on going EP
- consistency
- 2 different channels still interfere
- FS-91 II Surpass 4-Stroke Prop
- Help with Four Star .60 build.
- problems with a-10 thunderbolt
- Fiberglass mount flexing???
- 2 and a half year old pilot!!!
- Flying wing and DX7? Problem!
- Will JR S400 work as buddy box for 2.4GHz radio
- How does this plane sound?
- Anyone have experience with Magic Hand product quality?
- Unfortunate crash video of a new DeHavilland Mosquito Twin
- Upgrade A-10 thunderbolt II
- hanger 9 Cherokee covering?
- Throttle servo swap - big change in cg?
- 14x4w Prop on Saito 82
- DX6I problems???
- More OS 4 stroke questions
- Ready to maiden?...HELP
- ysengines
- Discontinued model
- PTS Mustang question
- Cover shrinking
- AR 7000 Receiver Failure ??????????
- Extreme Flight 540T CG miles out?
- Acrobatic propeller
- OS FS70s II for $170?
- Alpha is here!
- Calculating CG
- what sise is my plane?
- flaps vs. speedbrakes
- AVISTAR ready-built (discontinued) purchase "trials and blues"
- help me decide,gp40stick or cgtiger2 arf's
- cover or paint
- dx7 and aileron switch
- Saito FA-82 setting
- The addiction?
- electric brushless motor
- repairing crack in cherokee firewall
- Will I ever need more than 6 channels?
- Low end needle
- Flyzone Diablo
- pusher prop or regular
- Man, sometimes you just don't want to throw it out!!
- Is the magnum xl 61 rfs a good engine?
- OS Engine Expert needed....engine "cackles"
- Should I send in my dx6i?
- CG question?
- outdoor or indoor
- 1st flights with "training wheels" off!
- Replacement glow plug washer???
- Orangehat44 Solo'd Today!
- Pitts Muffler for Tower Hobbies .61 Engine
- Super Stick 60
- What Size Spinner?
- Crash beeper / 2.4 ghz
- What RC Products?
- For those that want to be self taught...
- rc remote stunt kite
- The Spad has gone to war!
- Cant activate dual elevator...
- Too much thrust angle
- From Beginner to EXPERT?
- Balance-Four Star 40
- What adhesive should I use on foam?
- Beginner Plane Electric
- paint spinner
- FIRE or OH %@ !!!
- The worst radio installation you've seen?
- Finally got to fly again,
- MOVED: Preventive Maintenance
- in search of electric foam high wing trainer w/ailerons...any ideas?
- spinners Plastic or Metal
- Using an expanded scale voltmeter
- 2 stroke carburetor tips
- specs??
- what are the best bolts to attached the landing gear
- Checking Trim in Flight
- covering a compound curve.
- Spad ? for Ken or whoever can help.
- Hobby Lobby Telemaster 40 questions....
- Do you remember your 1st Crash?
- Engine Stuttering in inverted
- th fun 51 and muffler problems
- paint
- Spektrum Alpha 40 radio problems
- Starting a 4 stroke
- Parkzone Stryker F27c
- Setting Idle Mixture ('Low Speed Needle')
- Flap servo binding...
- SwitchGlo
- Remote Glow adapter
- clipped wing cub?
- Made my first landing
- spinner size
- aerial cam
- MOVED: dx6i/dx7
- It PAYS to SHOW UP at the field
- How do the cheap 2.4 radios work?
- Engine question
- Hobby-lobby Su-34 Fullback Vectored Thrust Jet
- can a pitts muffler be repaired?
- Love my Tiger!
- cable clevis
- Honda CR-V any good for carrying rc planes or too small?
- fueling up
- Engine too far to the left?
- prop for a 46AX
- Can you turn over 46AX with fingers?
- What could cause me to loose bind on DX7?
- bend tubing
- test stand
- First plane after helis
- CG Question
- 4 stroke spool down???
- Crashed my new Mustang...
- Adding Castor Oil to Fuel
- air cleaners for engines
- Battery Installation
- Mastering a Trainer?
- Advice wanted on covering corflute.
- best way to mount motor
- charging a lipo - volt high???????
- tire bending. how do i fix?
- Fuel system maintenance???
- 2 Stroke vs. 4 Stroke
- Looking for help getting oscar the grouch pilot for new mustang kit
- hayes hinges
- PAY ATTENTION
- Which paint is best for foam?
- ENGINE TROUBLE
- Fuel Tank running out of fuel
- spinner
- Fixed the decathlon!
- Engine problems...
- Shaping EPP tips?
- The joys of instructing
- Tower Hobbies .75 help tunning
- wind speed
- TSI 46 carb set up help...
- glow plug question
- how to set CofG if you are alone???
- Props what do i need to know?
- after run oil / no after run oil?
- Confidence killed the trojan...ALMOST!
- What's he going to do next
- Engine test stand pics please
- CG balance confusion
- Trainer, Bolt-on-Wing mod
- MADE IN THE USA
- adjusting needle
- 2 stroke and 4 stroke fuel question
- Throttle cut on DX-7
- Landing A Parkzone Trojan...
- Pacific Aero Model Starter
- Whats the diffrence?
- OS40 LA
- Prop Reaming Question
- AIRPLANE OR HELLI ENGINE?
- Removal of clips from connectors
- Why there aren't more instructors!
- Lithium Ion packs for plane and radio
- A couple engine questions
- RCU Roll call time..Where are you from?
- questions about CA hinges
- I made a very preventable mistake
- servo horns
- Rude RCU posters..The matter-of-facters
- how to collect the airplane
- First time with Lipos, what do I need to know
- Muffler pressure - yes or no
- Stuck on what to get next
- Ressurecting old motors.
- Supersonic RC planes?
- Safe brushless operating temps?
- dropped a lipo...
- maiden flight for my GP P-51
- What semi-trainer plane for this set up?
- 1st glow plane on order tonight!
- Hobbico NexStar Landing Gear Problems
- Great day!!
- Amazing DVII
- Can't get plane off ground
- New to hobby
- Servos hanger 9 replacement makes?
- Question - Why do we promote clubs?
- O.S. 91FX
- wiring setup for servos/receiver.
- New Guy
- CA Hinges - appropriate for large scale ?
- Take off w/ trike gear
- Nosegear coil
- Glow Starter Charge Life
- tru-turn bushing replacement
- 2nd flight, and a question.
- Pushrods for a Retractable Landing Gear
- Bigger prop for break in?
- DX6i Returned, New DX7 works, Finaly maidened My Tiger! Busy day
- cutting balsa wood
- big gap
- EPP Tape & film types, what is best?
- PT 19 Trainer
- U-CAN-DO any good for getting into 3D?
- Good Tips For first Time Model Airplane flyer
- I DID IT!!!!!!!!!
- Sandable plastic filler???
- I made the jump to a low wing
- Wheel pants at sharp angle
- need situations for G2
- What next after Trojan?
- Ultracote & Monocote
- My first flight, 6 foot nitro SOLO
- Tank volume for 120 / 160 glow engines ?
- Fiberglass fix/reinforcement ?'s
- struts for retracts on top flight p51 kit
- colored horns & clevises
- do lipos have memory problems?
- Saito flex muffler
- Bondo???
- head temp. on 2 cycle engines
- Good easy r/c plane for a 5y/o to fly?
- Buddy Box Questions
- Z bend
- Escape VS Stik VS Tiger VS Kougar
- 2mm
- F27B Stryker won't fly
- wireless buddy box
- finding a kit
- Electric v. Glow?!
- engine break in question
- Nothing Standardized in This Hobby
- UAV for airsoft games?
- PLEASE HELP NEED TO FIND A MOTOR!
- If you have to bend over 4 times it was a really bad landing.
- Wing Question
- How long can I fly
- HEY ALL
- Noobie Gas Engine Questions
- magnum xl 70rfs engine questions
- engine mount for Saito 72
- Yak - Can anyone suggest an inexpensive ARF or RTF?
- Aleron Pushrod Install
- CA removal and cleanup question
- CA Hinge Removal
- which reciever?
- Wing and Tail Covers/Totes
