PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. BRAND NEW!
  2. battery and charger question
  3. true Noob question
  4. Just bought a Parkzone T 28
  5. Question
  6. Looking for fourms for a Atr-Tech Cessna 182 Electric Plane
  7. another evo question
  8. tube size
  9. ultimat 120-55"
  10. Help for beginner
  11. Simulators
  12. Crossing my fingers!
  13. Building my first!!
  14. tower hobbies engines
  15. Glow Fuel Question
  16. OS 55ax Tuning
  17. evolution 40 hesitation
  18. Nexstar Question, PLEASE HELP
  19. Well, it finally happened...
  20. Taping the leading edge
  21. Crashed the NexStar
  22. next plane
  23. I ground looped another cub
  24. A few questions on a new Alpha trainer...
  25. sorry if i afended anyone apologize
  26. is this battery done???
  27. SkyFly 2 Issue with Climb
  28. CBRC
  29. Anyone know some Supertigre carb tricks?
  30. Turtle Deck
  31. twitter
  32. begin air
  33. converting from electric to gas
  34. Anyone Fly This?
  35. Servo reversing
  36. New to Hobby
  37. Does a flat wing always need ailerons?
  38. engine adj.
  39. Air Bleed
  40. Is this a good beginner plane???
  41. Need Help, Need Some Ideas
  42. third plane, cowl question
  43. Futaba RXs
  44. buddy box
  45. Baffle removal on four stroke
  46. Amps
  47. how to keep rubber diverter on muffler ?
  48. O.S. 60 FP problems.
  49. Falcon 56 Mark II, engine choice
  50. Fast charge question
  51. need a easy flyer for a OS46la
  52. got 2 new planes today!
  53. How Long Did You Fly Your Trainer Before You Stepped Up to Your 2nd Plane?
  54. Anyone Replaced The Landing Gear on Their Avistar
  55. Reusing your planes covering material?
  56. need help with a buddy box.
  57. computer radio
  58. What type of nitro plane to start out with?????
  59. dumb question
  60. unidentified plane
  61. Help with fuel disposal.
  62. H9 Ultra Stick - Last flight day
  63. Transporting Planes in a Pickup Truck
  64. Y-lead
  65. Prop for Evolution Trainer motor
  66. blade 400 / dx6i problems
  67. need help with color for bottom of plane
  68. Are these engines the same?
  69. CLub finder?
  70. prop sizes
  71. Fuel Tank? how to secure it?
  72. RC Plane Newbie
  73. goldberg?
  74. FCC fines for mentioning name brands?
  75. My day at the field
  76. SC 120 instructions?
  77. Soldering Muffler Extension
  78. PZ Corsair vs. Virgin 737
  79. What do you think about this? PZ Corsair vs. Virgin 737
  80. kyosho calmato 60 with os 90
  81. 7C mixing question
  82. Next plane option - Kyosho Minium (4ch) mastered...
  83. fuel pump
  84. titebond
  85. Engine Mount Problem ???
  86. cheap batts at TH....wow
  87. Futaba Batteries
  88. I need YOUR help! How to I pick the correct Motor/esc?
  89. Brushless on nimh
  90. Question for Oklahoma flyers
  91. roll & turn
  92. Ultra sport 60 kits
  93. Futaba 7cap/chp
  94. How far can an RC go
  95. Some shots of my field
  96. Something..........
  97. Battery Charger
  98. Carl Goldberg Tailwheel Assembly
  99. Anyone familiar with this?
  100. What would be a good airplane?
  101. dx7 and the famous DS821 servos
  102. RDS 8000 vs Futaba 7C
  103. Newbie - TX/RX Basic Question
  104. rds 8000 2.4ghz diode bypass
  105. Battery Life??
  106. 2.4 GHz systems
  107. Old engine
  108. end point adj.
  109. Receiver swapping
  110. ar 7000 receiver flashing
  111. My first RC plane
  112. ******** Extra 300 build
  113. Wanting to buy a superfly
  114. Spektrum AR6200/2.4ghz question ??
  115. Using a "TopFlite" Prop Balancer
  116. MUFFLER
  117. Interesting Find - HAL 2100 Autopilot
  118. First Solo
  119. RC Modeler Magazine
  120. Gas Engine
  121. glue
  122. another dead stick
  123. when do you know you are ready to go to third plane?
  124. I all most hit some people today
  125. First start!!! and a question
  126. Mystery deadstick !!!
  127. cessna
  128. How about a spinner question....
  129. OS FX or AX
  130. PPM or PCM
  131. 75 ax
  132. Trimming for landing
  133. How does your club train new members?
  134. What's the name of that switch?
  135. starter cone
  136. Flew the laser 200 again today!
  137. Field etiquette
  138. RADIOS ON EBAY
  139. Saito .82 Quits when idle
  140. Trainer delay with Futaba 6exp
  141. What is a good electric rtf?
  142. my OS 46 muffler leak fuel
  143. Another prop question
  144. TF Beachcraft Staggerwing
  145. A what if question
  146. WOOD PROP OR PLASTIC PROP?
  147. field box
  148. buddy box
  149. Trimming for level flight?
  150. last order
  151. Spektrum DX6i problem.
  152. Loss of signal to an AR500
  153. MOVED: new to this hobby
  154. Hangar 9 Easy Fly 40 trike to taildragger
  155. Can't find 1/4in blue core foam
  156. show us your field box...
  157. laser 200 maiden, have some questions?
  158. .46 glow to electric conversion
  159. Combo Recommendation
  160. covering technique? (wingtips)
  161. Getting rid of sawdust
  162. 2.4 Transmitter
  163. Problem with servo reverse on DX-7
  164. what do i need to convert to brushless?
  165. Servos for RDS8000
  166. Pay It Forward Sig LT-40 Build Question
  167. what to use instead of CA
  168. WOW/ROFL at Hong Kong post, hobbycity shippment
  169. What's Happened to All of the Rolling Toolboxes
  170. Servo tester? See how many amps they draw??
  171. 2.4 ghz TX/RX/Battery question
  172. asp108 head gaskets
  173. Radio Gear - What to use
  174. another problem with my supercub, please look!
  175. radio install
  176. How is this engine?
  177. Looking for RC flying Instrutor in Northern california
  178. the Cub Curse ended today
  179. Elevator and rudder problem
  180. yaw
  181. What would be the best begginer plane?
  182. CG question
  183. Flaps on .52 j-3
  184. MDS .68 Muffler bolts HEX or Metric?
  185. ABC or Ring super tigre
  186. CA HINGE INSTALL
  187. What is UNSAFE flight voltage (6v battery)
  188. trainer lead between 6ex and 6ex
  189. Beginners note - firewall from cardboard
  190. Fuel pump / battery question
  191. Nicad Battery Help
  192. first plane build (easy on the jokes)
  193. problem with my supercub please take a look!!!
  194. EXPO RATES ON TRANSMITTER ?
  195. flywheel balncing
  196. wzak29 - upload
  197. upload
  198. What to put on before paint.
  199. wind reading on my pc.?how
  200. Saito FA 56
  201. Tower Trainer
  202. Revive my Accucyle or a new charger?
  203. Aerobatics Plane?
  204. Magnum XL 52 four stroke engine froze up.
  205. upload photos
  206. servo plug
  207. ar6100 question
  208. JR SX600 TX
  209. Scale model
  210. Crashed Receivers
  211. Brand New - Wrinkly H9 Alpha ARF
  212. Ryan STA 40 arf parts?????
  213. asp 108
  214. Looking for another trainer...suggestions?
  215. Parkzone Corsair
  216. crimping tool
  217. Replacement Motor?
  218. Control Throws
  219. Looking for part?
  220. Elevator linkage
  221. RX battery useage question
  222. How do I make Y shaped pushrod
  223. Our club's master builder's new plane
  224. How'd I do?
  225. Which Cub to buy, H9 or GP
  226. wildcat fuel?
  227. The worst thing happened?
  228. JR R600 Reciever issues
  229. New to 2.4 anything I should know about/ maiden flight today
  230. 21st century fabric
  231. Good and bad of our radios on how they have been growing.
  232. how to fix this?
  233. dope question....
  234. Evolution Engine and Glow Plug
  235. what to buy?
  236. Tower .46 Engine Problem (knocking)
  237. Better to buy a transmitter or another plane?
  238. limit needle valve
  239. New to RC Flying, need input
  240. Elevator alignment
  241. H9 Alpha RTF/Spektrum Combo
  242. Shopping list for Nitro planes?
  243. Pitts Style Muffler for a 4 Stroke
  244. ni-cd vs ni-mh
  245. Tx aileron travel adjustment
  246. Aileron sevos
  247. charging battery
  248. chrge jack
  249. V. Q. Warbirds???
  250. .91 magnum 4 stroke discontinued?
