PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. High Wind RC Aircraft
  2. Muffler falling off.
  3. How to adjust cg
  4. covering Irons question
  5. Futaba 6EXAS Radio Question
  6. Indoor flight??
  7. First Solo Flight
  8. Thin CA, corosion in lid
  9. thinning expoy
  10. Futaba 6EXAS 6-Channel FM/4 S3004 Servos 54
  11. Tx setting spreadsheet - good stuff!
  12. Fuel dot and fuel T for cowling covered eng
  13. E-Flige Mini Edge 540 Questions
  14. Transmitter Case
  15. Landing...
  16. tail wheel.
  17. Re-attatching a Canopy?
  18. Help me identify please....
  19. Hobbistar 60 Landing Gear
  20. .10 Kit
  21. Battery sense and nonsenseability
  22. returning after 15 years & need your input
  23. How to re-attach trim on nexstar?
  24. Is it customary
  25. Throttle linkage Setup
  26. Antenna Shroud - Do You Need It?
  27. MOVED: For the New Guys!!!!!
  28. Broken Props
  29. Manual needed for the "CMP F4U Corsair50"
  30. First Plane! Which between the two
  31. Input on Alpha .60 Hanger 9 ARF plane possibility for Trainer
  32. Newbie Simulator Experiences
  33. Industry ethics?
  34. Is a sea plane hard to fly
  35. A radio to grow with
  36. Taxiing Question; Tail dragger
  37. Where is my CG now?
  38. NEED HELP!!!!!
  39. Sig Kadet Junior 25 or 46
  40. Fiberglass wing tape?
  41. What is the best motor for the F4U Corsair 50?
  42. My first CMP F4U Corsair 50
  43. Additional Servos on a Hobbistar 60
  44. need airframe ideas..
  45. Repositioning Hi-speed needle
  46. Mid-Star 40 3 view drawing?
  47. Monocoat Hindges Safe?
  48. CG edge 540 Questions
  49. Improper break-in
  50. CMP F4UCorsair50
  51. Flying with Heavy Traffic
  52. Rookie question Twist 150 & Dx-7
  53. First Flights - Last Night
  54. Trying to Rebuild a SIG Kadet LT-40
  55. Homebrew fuel
  56. best links
  57. Do you find real life easier than the sim?
  58. Avistar questions
  59. Is 90 size plane too much to handle by a Beginner+Intermediate Pilot?
  60. Windex Method?
  61. Engine transition problem?
  62. engine cutting out
  63. Aero Ace - next step up?
  64. r/c controll
  65. Removing those sticky weights
  66. what do you do with your old trainer
  67. nylon bolts
  68. LT 40 Manual
  69. beginner plane
  70. Whoo Hoo !!!
  71. angle under which the engine should be placed ?
  72. Moved on to an Edge 540
  73. sweeeet!!!!!!!!!!!!!!!!!
  74. Unable to upload pic?
  75. What is the difference between tail dragger and three cycle?
  76. Stripped rudder/front gear servo
  77. Park Flyer Beginner
  78. Heat Iron
  79. What have i got
  80. Engine size question
  81. GP PT-20 w/Full Down Trim, Why?
  82. Rossi 90 ??
  83. Question about .61 glow engine.
  84. Where can I Start to fly in NY
  85. principle of turning???
  86. TT Trainers - Everything but a gallon of fuel
  87. Beginner Question: What exactly is a battery cycler?
  88. Beginner at Spray Painting
  89. Finding CG??
  90. What is the best lipo's setup in a challenger?
  91. airplane out of range
  92. y-harness on elevator
  93. First post...
  94. oh happy day
  95. The good, the bad, the ugly
  96. kadet ep-42(kind of a testimonial I suppose)
  97. Landing gear up on grass?
  98. finding the perfect center for engine
  99. balancing propeller
  100. testing plane at home/home build system
  101. fueling equipment.
  102. COVERING QUESTION!!!!!!!!!!!!!!!!
  103. Just saw a flight box on ebay
  104. need some intelligent idea for Battery and receiver placement
  105. Which Mag
  106. Item sold to someone else?
  107. Fuel cap.
  108. Webra engine?
  109. What do you do when you Don’t see the airplane in the air?
  110. Increasing Throws
  111. Aileron to reciever hookup?
  112. New Boomerang 40 Trainer
  113. Measuring throws
  114. I got lucky today!
  115. Good third plane?
  116. Where can I get this
  117. Great Planes' Slot Machine - piece of junk?
  118. Best option for my first trainer
  119. I got this for $20 bucks.
  120. Nexstar prop ?
  121. Will this aluminum fuel tank cap fit a Dubro tank?
  122. Fly Boy 50 ?
  123. Does size matter?
  124. Best procedure for adding monocote trim
  125. Freq. risk of flying at unmonitored field
  126. Covering warped my stabilizer
  127. Can You Identify This Trainer???
  128. Dual Rates
  129. front bearing
  130. Beginner Firebird Phantom?
  131. new toy
  132. Good Aerobatics?
  133. multi planes on 1 remote
  134. Need help with wing set for alpha trainer
  135. Fuel Tank Location in Relation to CG
  136. Who makes the best starter to handle a 1.6 cu.in eng.?
  137. My First Balsa Build
  138. What's the shaft size on the OS 160FX?
  139. DEATH TO R/C?????????
  140. Super tiger 61
  141. I'm no longer a bystander
  142. Solo'd after five flights!
  143. Delta experimental flying wing.
  144. 2.4g Futaba Flight Packs?
  145. Comprehensive battery guide for a beginner
  146. Free sim download
  147. What do you use ?
  148. Shakey knees...
  149. Making Your Own Battery Packs
  150. 4 Star or SSE ?
  151. longer range planes
  152. Throttle push rod?
  153. greatplanes big stik
  154. needle settings Irvine 40
  155. Strega Push Rods and Sullivan Clevis 2-56
  156. esc's
  157. Aerosport 40 help
  158. You know you're hooked when....
  159. The Kadet Senior
  160. Changing from rubber bands to bolts
  161. Flying in the rain?
  162. Sig Kadet Senior 80"
  163. electric motor problem
  164. EDGE 540T ARF
  165. Neutralizing servos?
  166. My first Maiden!
  167. HELP!! Li-PO batteries on Guanli Models!!
  168. volt meter
  169. Hobbico Quick Field DC Charger MKII - Comments
  170. First Build
  171. Dang It!
  172. FLYING TIMER
  173. Need another Receiver
  174. What are the advantages & disadvantages of using Elevons & Flaprons
  175. looking for first radio and plane after trainer
  176. GP Big Stik 60
  177. Crash Etiqutte for Dummies
  178. Thanks 2nd rc flight school
  179. 1St Gasser-Budget for project= $0
  180. What should I be looking for?
  181. Batteries and charging question
  182. What are the things to remember for first flight?
  183. Engine problem
  184. SERVO MOVES
  185. moving from paved runway to grass
  186. landing on rough field
  187. Wing Tube Selection
  188. Which airplane should I buy?
  189. PROPER RADIO SETUP
  190. Learning in Nassau County, Long Island
  191. wing incedence
  192. Best trainer plane?
  193. Field Boxes
  194. In need of suggestions...
  195. Painting Covering - Ahhhhhhhh!!!!
  196. How makes custom canopies?
  197. ESC Questions?
  198. Howdy from Texas
  199. How to route an antenna?
  200. Retractable landing gear, F-4 Phantom
  201. wrinkle in coating
  202. second rc plane help?
  203. Alfa mig glassing the bottom
  204. What does flutter sound like?
  205. How to measure altitude?
  206. Wouldn't it be cool to have a knowledge base?
  207. PHX Model Strega - Motor Mount
  208. Maxx Products HD LED Switch
  209. Hobbico Superstar EP
  210. Prop spins after radio is turned off
  211. OS 91 pitts muffler
  212. looking for a 400 size brushless
  213. gws em400 Motor Issue
  214. Veco 61
  215. Electric fuel pump?
  216. hobbico charger
  217. aerobatic instruction
  218. Servo buzzing
  219. Cutting down APC props
  220. Super chipmunk as next plane
  221. Straight nose gear - How?
  222. Question about Props
  223. FM or AM ???
  224. NEW PLANE!!!
  225. AMA Model Aviation Magazine - May Issue
  226. need to bring an airplane as a gift
  227. newbie help please!!!!
  228. first time engine repair
  229. flying in high altitude
  230. exponential % rate
  231. OS .46 sf fuel and prop ?
  232. Futaba 7CAP vs. Futaba 6EX w/2.4GHz
  233. Looking for a new trainer!
  234. Smaller versions of kits
  235. servos compatability
  236. Toledo RC Show
  237. Toledo RC
  238. Wrong section to post. DELETE.
  239. Tiger Trainer Parts
  240. how often do you crash on your maidens?
  241. Side Thrust Off - how to correct?
  242. lanier explorer maiden....."success"
  243. very new - need help....
  244. Mounthly Training
  245. Guidence, reconsidering the hobby
  246. After five years, IM BACK!!!
  247. Help Identifying an Engine
  248. Recomendations for a beginner?
  249. NEXSTAR TRAINING AIDS ADVICE
  250. radio service center
