PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Telemaster 40 CG
  2. eagle wing question.
  3. throw adjustment
  4. Micro Park Flyer???
  5. Magnum 45 Pro
  6. KCRC Warbird Fly-IN
  7. Multiplex Acromaster / Servo's
  8. 9C SUPER PCM RADIO BY FUTABA
  9. Third Plane
  10. your favorite magazine
  11. nexstar ,good or bad
  12. interference problem
  13. Best online dealer for Futaba radio gear
  14. Your very first time
  15. Field box battery
  16. Aircraft Storage
  17. Super loop
  18. Control Rod too tight on rudder
  19. Whats in your field box?
  20. SOLOED!!!!!!!!!!!!!!
  21. Hobbico Superstar 40 Build Question
  22. Alpha 40 trainer
  23. Balancing techniques
  24. Building Up Elevator
  25. electric or simulation?
  26. What is the “dead stick procedure”?
  27. Lets see your work Area
  28. Spektrum DX6 Question
  29. Prop Nuts - Anything special?
  30. Help Needed
  31. Cowl and Engine question
  32. Wing Repair 101
  33. First flight.
  34. Gears for spektrum servo
  35. futaba 6exap
  36. Advice please
  37. Retract setup
  38. just a reminder
  39. Zurich Sunglasses - Junk?
  40. redneck test stand revisited
  41. focke wolf
  42. HELP!!!!SUPERCUB DRIFTS LEFT
  43. Ideal prop size for my engine/plane
  44. Success With the Spitfire
  45. Missed a perfect day for flying
  46. The BIG Bang!!!!
  47. Is there a special prop reamer for Saito 62 fs?
  48. ya i landed (but not so good)
  49. Rubber Band Help
  50. Duraplane Trainer 40
  51. Unidentified flying objecy
  52. Trainer Knife Edge
  53. glow size for parkflying?
  54. Prop placement 2 o'clock
  55. Hobbico Nexstar USB Interface Cable lost, where can I buy it?
  56. GOING IT ALONE
  57. Wheel pants or no wheel pants?
  58. L1 Birddog,China Models
  59. Gotta tell you about the bone-headed thing I did
  60. Evolution 46 carb draw bar needed
  61. got the plane done
  62. JR buddy box question
  63. Battteries and FAQ's about batteries
  64. Beginner with some concerns.....
  65. Battery Upgrade
  66. Futaba transmitter question
  67. The NEW 2.4GHZ system questions.
  68. Ultra coat
  69. Perfect Day
  70. Evo 46 Muffler
  71. Engine for Ultra Stick 60
  72. JR 6-channel radio
  73. I found another good airplane
  74. muffler for fox eagle 60
  75. hitec optic 6 need help
  76. finally- pics of my first ARF!
  77. New pilot
  78. Ultra Stick 40, OS 55 engine: Prop size?
  79. Prop installation question!
  80. HELP WITH UNBALANCED WINGS
  81. Fuel Proofing????
  82. i've got a prop
  83. 100% Newby
  84. What is a short kit?
  85. Moved up from the Nexstar
  86. Is my fuel getting contaminated
  87. 3D flying- how to?
  88. no pressure nipple on muffler
  89. Whats Best
  90. Ripmax Prodigy II Charger question
  91. Glueing an ABS Cowl
  92. Mini Ultra Stick
  93. From Trainer to next Plane
  94. LHS Experience
  95. Throttle set up
  96. Futaba 6 EXAS OR 2.4Ghz
  97. alpha 40trainor or hobbico electristar
  98. Alpha 60 question
  99. 100 degree heat and lean engines
  100. quick charger how to's ?
  101. LE balsa sheet repair question?
  102. Landing a plane without landing gear
  103. Engine down...
  104. New Plane to fit Equipment
  105. Showtime 50.....
  106. ParkZone Centurion
  107. New to planes
  108. Help Choosing a new plane
  109. oh crap! not again
  110. Donations???
  111. Beginner Electric Plane suggestions
  112. Nexstar vs H9 P51 (PTS)
  113. Fuel question
  114. Beginners dream maiden flight.
  115. Linear Throttle Travel
  116. Best trainer plane (lower budget)
  117. Foamie first build
  118. servo glitching
  119. Got her done
  120. IDENTIFY THIS PLANE PLEASE
  121. Damaged Lipo Pack
  122. *IMPORTANT* - help???
  123. need help for K&B 61
  124. Do I need to move on?
  125. Yellow Bee RC plane
  126. ahhhh NO!!!
  127. evolution 45/46
  128. Engine Running problems
  129. elevator direction
  130. swaping out electronics super cub
  131. pinned hinges
  132. decal for cub
  133. Radio Charging Diode
  134. O.S. Gurgle
  135. Adding Wieght to Tail
  136. great planes laser incidence meter
  137. nitroplanes.com
  138. BOBCAT 46-60 size ARF any good?
  139. bought a skyfly what next
  140. Tell Me what i did wrong
  141. difference in +expo and -expo
  142. Need Help With A Slimline Pitts Muffler
  143. help with new radio
  144. Stripped thread on motor mount holes / fixable?
  145. How to land?
  146. spektrum bind plug
  147. My new hobby & Slow Stick setup
  148. Pitt's muffler modification??????
  149. question on servos for a u-can do
  150. Which paint? Which Pilot?
  151. Looking for a good place to start
  152. robostruts
  153. Used Nexstar
  154. Looking for advice!
  155. making servo extensions.
  156. Falling leaf?
  157. whats the coldest?
  158. Help with Field Box
  159. Fuel Tank
  160. Help me pick a plane
  161. Cowl for Tri-Pacer
  162. Ask the pro's.. elevator servos
  163. CG question
  164. 1.20 size engine advice
  165. ?: How all these ARF’s and RTF’s are assembled?
  166. MY FIRST AIRPLANE!!! - excited
  167. Filter your fuel!!
  168. Firewall Reinforcement
  169. CAP snap
  170. What is the difference between wood and non wood props?
  171. Battery Charger??
  172. Nitromodel has terrible service!
  173. Fueling/Defueling through muffler tube?
  174. Super tigre 90 runs then quits.
  175. MDS trouble
  176. Two Elevator Servos
  177. 2nd plane a 40 or 60?
  178. How are planes fueled?
  179. HAIRSPRAY AS A COVERING BASE
  180. Fuel tank location
  181. Mini Camera Question
  182. What Is It?
  183. Next step to the Super Cub?
  184. Lanier Explorer 40 ARF, your thoughts please
  185. 480 motor
  186. BRAVO SC (CG) ? help...
  187. futaba 6exap
  188. Upgrading tx/rx batteries
  189. RV4-40 takeoff
  190. Experts wanted on 2nd plane selection!
  191. engine vooo doo
  192. 'cowl' on trainer broke
  193. offset
  194. YAS (yet another solo)
  195. Can't program a mix on the Fut 9cap
  196. OS 91 fsll 4-S
  197. Help with Easystar RTF
  198. NiCd charge/discharge rate
  199. Good plane for beginner - yay or nay?
  200. W.O.T. issues
  201. New plane in fleet from RCM plans...
  202. Paint primer for lustrekote paint?
  203. Spektrum DX7 w/ GP RV4-40 help?
  204. hand starting
  205. Aileron/Rudd mixing
  206. submarine with wings.
  207. I think I got it
  208. Servo compatibality
  209. collecting from Pay Pal?
  210. Picture on your post
  211. Gap sealing......
  212. Found Another Weak Spot
  213. RV-4 Dipping Problem
  214. Pacer hinge glue
  215. New Nitro Motor
  216. duct fan+brushless motor+esc set up HELP!
  217. throttle linkage Help
  218. Prop size for nexstar
  219. Now I know
  220. I know nothing but am willing to learn!
  221. Hookin up a ys 91 4 stroke
  222. Using an infrared temperature gauge
  223. Nitromodels Low wing trainer .40
  224. Redneck Engine test stand
  225. Battery runtime
  226. Control Rod question
  227. How to: Glo Starter with charger
  228. How do you trim your RC Radio
  229. where's the battery area?
  230. First Plane
  231. Help Picking a "second" plane!
  232. dont know what im doing wrong
  233. An Oops story
  234. Graphics for ARF
  235. Buddy cord cut after 1 day training... ? (My first real powered flight experience)
  236. from bands to bolts?
  237. monokote on plywood
  238. Foam elimination armorall
  239. Glow Plugs
  240. cordless drill as a starter?
  241. Dragon lady Motor Size.
  242. Futaba 9C
  243. Futaba 6ex 2.4gig and battery life.
  244. Solo Flight
  245. H9 tribute 36 as a second plane?
  246. Rebuilding Question
  247. Goldberg Freedom 20 Trainer Kit/ Sig LT 40
  248. Upgrade Motor for Lancair ES EP
  249. Where to fly west of Minneapolis
  250. sig kadet lt-40
