PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. can rx batterys be made cheaply
  2. Engine Chart
  3. Check out my new building board
  4. New to Planes
  5. servos
  6. Engine Start by bouncing off the compression stroke?
  7. Help with mounting a OS .61 with pump
  8. Best engine for 60 size trainer
  9. Plane Storage Rack
  10. throws
  11. Toledo show was lucky
  12. after run oil
  13. tuning question or problem
  14. Fuel protected "engine room" on ARF's?
  15. clevis or z-bend?
  16. OS 46ax question
  17. futaba attack 4
  18. Mini Cub?
  19. O.S. 46ax Glow Plugs
  20. WARNING: Sullivan Gold N Rod use
  21. Shaping leading edges
  22. 3 line fuel tank question
  23. After 12yrs of waiting, I'm finally in the air again!!!
  24. I went to the Toledo show
  25. Dying windows/windshield
  26. Need help selecting components
  27. I need a YS Engines FZ 91 high speed needle Valve?
  28. Plane Cam?
  29. Help with antenna install
  30. Wing repair
  31. Spektrum Radio
  32. tower.46 nitro engine
  33. Classic Rudder rookie mistake
  34. T-28 Trojan!
  35. Plane won't fly level!
  36. Avistar set up
  37. LiPo Wall Charger
  38. What should i start with?
  39. Death of the Strega
  40. putting an old radio back in service ?
  41. Gyro's ROCK!!!
  42. Nose Heavy?
  43. OS .61 with pump? supercharged?
  44. rx battery ?
  45. Your best building blunders! ...post em' here.
  46. the science of prop selection?
  47. 4 stroke tuneing/break in
  48. spinner installation
  49. 24V Starter
  50. Do you put a pilot in your cockpit
  51. Support the Little Man (LHS or Online)????
  52. mounting servos?
  53. Covering for Great Planes Piper Cub .20
  54. kit vs ARF
  55. Cowel attachment - wood screws or blind nuts
  56. Ultra Sport 40
  57. Accessories and gadgets that you love or hate
  58. Unorthodox way of Acheiving CG??
  59. spinners
  60. Robart 650 axle size ?? (collar)
  61. New Plane!
  62. Stik 60 or Stick 60 ?
  63. dings
  64. Control Surface Hardware
  65. Fuel Tank
  66. inverted engine quit
  67. Prop Hubs
  68. spinner
  69. Planes No One Should Have !!!
  70. Antenna & rubber band, YUK
  71. the big battery debate
  72. Antenna wire routing
  73. on line store
  74. GP P51
  75. Do I worry too much?
  76. My new 6-Volt System
  77. SAPAC f-22
  78. new airplane
  79. Are these Scales Accurate
  80. getting back to glow question ?
  81. 90 size engine on a Pulse XT 60
  82. Buddy Boxes.........
  83. rub out nelson's clear?
  84. I am looking for recomendations on a first plane
  85. Take a look at the newest future RC pilot!
  86. satio 1.00 high speed needle setting
  87. question about engine running...
  88. IIRC
  89. Double Bubble Epoxy
  90. Planes that everybody should have..
  91. How am I going to balance my Big Bingo
  92. Trickle Charger
  93. Landing
  94. range check
  95. prop suggestion
  96. good charger
  97. Rx Battery "time-to-quit" voltage
  98. Small Plane?
  99. Tiger 2?
  100. Metric Drill Bits
  101. tric. landing
  102. fuel proof
  103. WELL I ASSUMED I MIGHT AS WELL START MY OWN SINCE I SEEM TO NOT KNOW AS MUCH AS I THOUGHT I WOULD
  104. Heli vs Airplane Transmitter
  105. 1/2A build with standard servos
  106. Main gear location
  107. ball link
  108. sig/gp
  109. Connecting Elevator Halves
  110. Nylon hinges
  111. Gas to electric conversion
  112. T-28 Battery?
  113. Which Bind N Fly?
  114. Great Planes Fuel Tubing
  115. Wind?
  116. Mounting the Engine at a slight angle.
  117. Spectrum ar6100
  118. The E-bay poll
  119. Which Covering ?
  120. Repair of my trainer leading edge
  121. Malfunctioning EDF
  122. hog bipe prop
  123. Sullivan High Torque Starter? losing power?
  124. WHICH TRANSMITTER?
  125. ripmax harmony
  126. Perfect plane for small space but handles wind? Does it EXIST?
  127. Three Cheers for Hobbico!
  128. clevis
  129. Tiger 2 maiden flight !!!!! THANKS RCU
  130. GP Easy sport 40 with OS 75 AX is it over over power?
  131. removing ca
  132. Hayes Fuel tank questions
  133. looking for second plane, need help
  134. Muffler Gasket????
  135. Pictures of 1/4 clipped wing cub
  136. Engine sizes for different weight/class aircraft?
  137. recovering a plane?
  138. Manual says 10% for break in, LHS say 15% will be fine; Which one is correct?
  139. Kudo's to Horizon
  140. Accu-cycle Elite Charger
  141. LiPo C Rating
  142. LiPo Battery Dying Fast
  143. good 1st plane
  144. T-28 Trojan?
  145. Aileron Servos "hanging out in the wind"
  146. elevator does not go up more than I would like...
  147. NY / NJ Club Members - Newbie
  148. buying e-bay
  149. Avitars
  150. soldering
  151. Servo Mounting Screws
  152. First Post - NEWBIE - Trainer/Plane Questions
  153. Tx ???
  154. I'm done with the adjustable engine mounts
  155. Servos for Pulse 60
  156. first 4 stroke glow engine
  157. Changing flight pattern?
  158. Which Plane is better?
  159. Where is: Readytoflyfun.com?
  160. which plane???
  161. dx6i recall
  162. landing gear height
  163. Mount Battery Under Cowl?
  164. Solo - Then Private Air Show - AT6 Texan
  165. FUEL
  166. Tiger 2 FINISHED !!!!!
  167. Problem with Mag 46 XLS carb
  168. Tucano Maiden Flight!!!
  169. .70 or .91 magnum on undecided plane (gp extra 300 maybe)
  170. Is this a good beginner plane?
  171. Ultra Sport 40+ Done!
  172. sig kadet w/ a evolution engine
  173. modulation
  174. Tightening Futaba switch plates
  175. New to fly an airplane
  176. engines
  177. Major Injury at the Field Today
  178. P61 questions
  179. New to Planes?
  180. Prop Question
  181. Poetic justice for flight distractions
  182. CG PT-40
  183. Curious !!!
  184. field stand?
  185. old fuel?
  186. setting daul rates
  187. Nose gear
  188. What is S.P.A.D.
  189. NextStar Anti Stall Baffles what happens when you take them off
  190. How would you like to fly here . . .
  191. Good digital camera?
  192. magnum engine advice
  193. Katana S 140 CG location Help Needed!!!!
  194. 75% Complete GP Escapde
  195. electric parkflyer
  196. Sky Raider Mach 1 or Super Stick .60
  197. Best way to build a plane rack?
  198. Protege 60
  199. Hobbycity Super Simple ESC
  200. Trimming out new plane
  201. What to do after "landing" in water??
  202. skyfly parts
  203. flying a pt-40
  204. Escapade
  205. It's TOLEDO Time! Who's going?
  206. Hitec HFS-05MS in .40 size Glow?
  207. Does this RTF come with a SS radio?
  208. Looking for a nice small plane to start with
  209. HELP - - How Do I Land
  210. VQ Warbird P51 Dago Red
  211. rudder & roll
  212. Help with weak landing gear
  213. starter battery
  214. Can't see my post
  215. Tiger Hornet
  216. troubleshooting radio
  217. Mid-Air Collision Aftermath
  218. Trying to balance my uproar
  219. bubbles
  220. Need a plane
  221. Electric flight take 2...
  222. 4 CH setup
  223. Bought a used 40 sized P-51 has issues.....
  224. How can I disable mixing on a Eflite Heli Tx??? Please!
  225. Bow in fuse sides
  226. nitro content limit
  227. Wire less trainer box
  228. FASST
  229. elevator gap
  230. Will I get away with this ?
  231. Wednesday Night Fight Club
  232. Can I use a Helicopter receiver in an Airplane???
  233. What's the old saying, A nose heavy plane flys poorly BUT....
  234. Recovering a swizzle stick
  235. Upgraded tx battery question
  236. What are you flying this year?
  237. Fasst antenna placement in a SSE
  238. tower hobby rx compatability issue?
  239. fuel pressure
  240. inverted flight - loosing tank pressure/slowing rpms
  241. new pilot
  242. What Things Could/Can cause Fm 72mzh Radio Interference?
  243. 4-star rebuild - maiden flight
  244. what is a synthesized dual- conv reciever
  245. How long do you let your lipo cool before recharging?
  246. ball thing
  247. RC planes at the museum
  248. looking for second plane, needs to be strong!
  249. First Time Installing Retracts
  250. Fasst Rx Install in SSE
