PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. how good are hobby king hxt900 servos?
  2. Keeping the Plane in GOOD SHAPE?
  3. Beginner's First Aircraft Choice
  4. air bubbles in fuel line?
  5. Hobbyzone Mini Super Cub Problem - Please help
  6. convert into electric?
  7. First Flight - In Air Collision
  8. Goldberg Eagle 2, .40 Used Glow Engine Needed
  9. good small 25 size airplane
  10. Got very lucky today
  11. Safe low Voltage cut-off for Lipo's
  12. Aurora 9
  13. No plane left to fly, Sigh!!!!!!
  14. Motor Size For J3 Cub?
  15. Axial CG Check
  16. CG question
  17. PCM Recievers
  18. Pic's of inherited planes
  19. First day with an instructor
  20. power?
  21. How do you clean your covering iron?
  22. where to buy??
  23. Prop Size
  24. new area of expertese needed
  25. Prop Thrust Measurement
  26. Opinions on the OS-FS91 SurpassII
  27. Haven't flow in 13 years, advice on new plane
  28. *UPDATE*$155.00 Needs a HOME!!!
  29. Second wind resistant plane
  30. Opinions on Magnum 4 strokes please
  31. OS 75AX
  32. Aircraft Recommendations
  33. Tank Size
  34. ARGH!!!
  35. Is too big bad with servos - Rascal 110
  36. Spectrum dx7 eu
  37. Cord of symetrical wing confirmation
  38. Sig Something Extra wing incidencer
  39. Covering 101 - newbie
  40. Tower Trainer & Magnum 52 4S Throttle issue
  41. Center of Gravity Issue ???
  42. How to identify and value inherited planes?
  43. os ax 120 wont start
  44. AR500 in a $500 model?
  45. Fuel tank set-up!
  46. glow igniter keeps killing plugs
  47. Evolution TPS Engine Modification Experiment
  48. Good time at the Nursing Home
  49. How to tune an engine?
  50. What should I expect from joining a Club
  51. my plane is missing the servo tray!
  52. Planted my new engine 6" deep!
  53. Boomerang
  54. The strangest thing
  55. fasteners
  56. BH (Black Horse) T-28 Questions
  57. cell monitor
  58. What is a size 10 to 15 airplane?
  59. Great Video - Thought some of you would like.
  60. Cessna 747 4 channel.
  61. seagull edge 540 68inch
  62. futaba 2.4 question
  63. t-28d parkflyer
  64. Are there any CORCS (Norman, OK) members here?
  65. Nitro Sport 2.5r
  66. Flying log.
  67. Balancing Low Wing
  68. smoke oil
  69. choosing an airframe for this motor?
  70. Electric fuel pump
  71. upping in cells
  72. Hi, new to RC
  73. O.S. 46LA lack of power
  74. ACE TRANSMITTER WITH FUTABE/HITEC?
  75. thinking of getting a plane
  76. Plane Recommendation
  77. Next step up...
  78. Plans Wanted
  79. Fun Fly Question
  80. EVo 40
  81. What sprayer for latex
  82. os 120 ax prop size
  83. Saito 150 gets bad mileage...
  84. Retract Servos???
  85. Newbie Question about control surfaces
  86. Balance/gliding/power question
  87. A question of balance!
  88. What Transmitter?
  89. brothers B-day present
  90. 60 Size Engine Mounting
  91. New Hobby Need Help
  92. quick question
  93. $155.00 Needs a HOME!!!
  94. is there a difference between irons?
  95. LiPo batteries can...
  96. ASP 80 FS
  97. stripped out spinner screw
  98. glider
  99. OS motor
  100. Magnum xl 30 4 stroke fuel
  101. blew up my Magnum .91RFS
  102. Which Hangar 9 P-51 Mustang PTS should I buy?
  103. NITRO ENGINE SIZE
  104. Finding cg on plane
  105. Bolt on wing conversion
  106. Plane suggestions?
  107. cleaning piston head
  108. Getting into electric: What about the Lipo
  109. how many flights out of a Battery!!!
  110. 4-Stroke Breather Nipple
  111. balanceing a Hanger ( solo sport trainer
  112. Powermaster fuel?? No more?
  113. What is tru-turn ?
  114. What to choose for 2 Stroke Engine, RPM or Thrust??
  115. What Motor Would you Use?
  116. What Motor Would you Use?
  117. Expo on DX6i
  118. pulse xt .40 for 2nd plane
  119. Cracked T28 Trojan Motor clicking sound
  120. Dx6i - Whats the antenna hinge for?
  121. LiFe packs
  122. Prop Question
  123. how much wind is generally too much?
  124. getting float rudder to move with rudder??
  125. recovering help needed
  126. I think I found my Tiger 60?
  127. Where do you find Carburetor caps
  128. Starter trouble - confused?
  129. rx lipo q?
  130. Got o.s engine but how do i start it?!!
  131. Prop shaft question
  132. 120ax frenzy
  133. Batteries
  134. .61 to .91 swap
  135. organization of in the fuse of the plane with the servo wires
  136. OS #3 Glow Plug
  137. cleaning monokote patch or not?
  138. advice on starting old engine
  139. sunuoo 6 ch receiver
  140. New feature in the XPO Co-op system
  141. Right thrust
  142. Converting T28 Trojan to Spektrum.
  143. ASP 80 FS
  144. Need Help with Goldberg Electra glider! Brushed to Brushless!
  145. [Build Log] Pheonix Tucano 40
  146. engine question?
  147. Homemade starter
  148. Free Flight?
  149. Now, THIS is cool!
  150. How to properly cover a balsa wood model
  151. Anyone for an Onboard Flight? Dual Cameras
  152. Diff between analog & digital servo???
  153. Seagull Edge 540 v2
  154. Help with antenna for DX-7
  155. adjusting mechanical VS radio ????
  156. How do connect split elevators?
  157. Easy star odd and ends
  158. are these servos okay to use
  159. BEST RC TRAINER
  160. GOLDBERG EAGLE II
  161. 3rd plane rough field.
  162. Battery Question
  163. Dead Engine Help
  164. Idle on an OS .15LA
  165. is this engine any good? found in swamp
  166. First Time Pilot Maiden Flight w/ Video
  167. Help with 2nd Plane Choices
  168. how to connect a brushless motor to a speed controller
  169. Thunder Tiger Pro 40.
  170. SSE rebuild completed
  171. Another plane!!
  172. Lost my Tiger 60 today...
  173. Which Charger to buy & which Futaba charge plug?
  174. to:
  175. First time priming a cowl - ?
  176. T-34 Mentor simulator model??
  177. Non-Steerable tail wheel on Ultra Stick 40??
  178. rainy spring weekends I hate them
  179. Definition of Potentiometer & Exponential
  180. Definition of Potentiometer & Exponential & their advantages
  181. Is it time to build?
  182. Servo screw sizes?
  183. uneven aileron throws
  184. Filling wood and reusing spot for hinge?
  185. anyone interested in a engine tuneing video/explination?
  186. High School Teacher Needs Advice
  187. .60 size trainer kit
  188. .60 glow engine in a Giles 202 .46
  189. CROSSWIND LANDINGS...
  190. White Lustrekote vs white ultracote- close match?
  191. Trainer recover
  192. Is this a good first trainer ???
  193. first fly. Nitro airstrike
  194. Nexstar to....?
  195. os max ax 75
  196. Soo many servos! Its hurting my head....
  197. stupid prop question
  198. Switch and charge
  199. My TTT40 Story
  200. Spinner question ( saito 100 Golden Night)
  201. Any experience with Hitec's Supreme IIS 8 Channel FM Receiver?
  202. Holding transmitter sticks: proper flying "technique"?
  203. Servos are bad?
  204. batteries question...
  205. Were do I start ?
  206. Charging an A123 battery?
  207. Second trainer in the hanger!
  208. hello alll
  209. Parkzone Ultra-Micro P-51 Mustang
  210. Spec for royal 28 engines
  211. Spectrum AR6100E RX Question. X 2
  212. Need Help with a V Q P.51D Mustang(Servo)
  213. Need Funtana X100 Canopy
  214. evo 45 trainer engine
  215. How to cover a curved verticle stab?
  216. Correct size pilot figure
  217. 3 possibilities for next kit build.
  218. need help yet again..
  219. Lipo Batteries not taking a full charge!
  220. lifting tail
  221. magnum .25 gp?
  222. glowplug
  223. Dark colored exhaust
  224. Evolution .46 NX
  225. Replace Retracts with Fixes
  226. Nitro Air Filters
  227. ELEVATOR TRIM
  228. Vertigo RC VTOL
  229. Lesson Learned!
  230. HelpPlease Servo set up Mixing
  231. 2.4 Rx Antenna Wires
  232. BEC question?
  233. Hooking up Elevator - Glider
  234. Spinner question
  235. Looking for club near Peoria, IL
  236. e-flite mini pulse
  237. Best way to cover elev/stab ends?
  238. RC Shop marketing tactics
  239. got my new aerostar 40
  240. Battery pack safe to use?
  241. cant get my os max 90 started
  242. Beginners, Old-Timers, Interesting to look at.
  243. Bind N FLy & Transmitters
  244. Having problems binding my DX-7
  245. Is it necessary to use washer with prop nut?
  246. Help with paint!
  247. Multi Servos on a CH and Accessories
  248. Alpha 40 Bolt on wing ?
  249. New product for multiple airplane owners
  250. SPEKTRUM RADIOS
