PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Engine for 1/4 scale Cub
  2. HELP! OS 46LA reverse!
  3. Which airplane to buy ? :)
  4. Fuel tank position
  5. gear drive
  6. Airplane ADVICE
  7. Tx recommended config
  8. minimag props
  9. READY2FLY rc aircraft (AWC)
  10. What is the same diameter but longer than a 4 40 screw
  11. Warbirds, harder to fly/land than sport planes?
  12. NiCad batteries discharge
  13. Pacer Hinge Glue
  14. alignment of wing, fuselage and tail surfaces?
  15. "Refurbished Plane" ????
  16. Beech Musketeer
  17. ASP 4-stroke run in
  18. Help with motor choice for a Hyperion Edge 25e
  19. Training update.
  20. Event List for 2008 and 2009
  21. Attaching Canopy Help
  22. Flew my scratch built Not-for-sale today
  23. Cold weather flight prep questions.
  24. OS Carb Sticking
  25. Long time no see
  26. Whats a good case for a X9303???
  27. Saito Engine Price Increase
  28. os wankel starting problem
  29. Applying Vinyl Decals
  30. Electric Starters
  31. Help with 2nd plane choice
  32. Anyone have tricks for beveling ailerons
  33. Homebrewing???
  34. Why did scotch tape come with plane?
  35. Y LEADS
  36. Anyone familiar with this plane?
  37. cheap nitro planes
  38. Engine Interference/Noise with Spektrum DX7???
  39. 9 year old a little punchy on sticks
  40. Balancing a Taildragger
  41. NEED HELP LOW SPEED NEEDLE TT PRO 46?
  42. Re-use radio equip from RTF?
  43. Delta wing help
  44. From RC to Full Scale
  45. PC 9
  46. Great Planes Flight Box
  47. Why did my Battery Pack Explode*pics*
  48. Problem by getting fuel into carburetor(OS 46LA)*Added pics*
  49. What is a "crutch"?
  50. whats the best thing to cover my airplane plan with
  51. Advice on 2nd Plane
  52. Two questions Re: 4*40
  53. Macs muffler cracked.. Why?
  54. Screwed upspinner rubs on cowl
  55. This just has to be shared
  56. futaba 2.4 6EX battery
  57. Flaperons, Spoilerons
  58. 4-60 Bipe, is OS61FS Ok?
  59. Flaperons/Spoilerons
  60. JUST GOT FIrst plane
  61. Build suggestions
  62. f27 stryker motor question
  63. how to install aileron servos in SIG FOUR STAR
  64. Fuel Tank System
  65. 1st time cowl cutting
  66. tiger 60 with a 26cc engine?
  67. Before your first new plane flight.
  68. Good engine .40 or .46
  69. What to use to cover my first kit build
  70. Could use some help for throttle hook-up
  71. Name this Crop duster
  72. Supre Tiger GS 90
  73. Which fuel???
  74. Need advce/suggestions
  75. Four Star 40 with Saito 56 maiden...finally
  76. need suggestions for servos
  77. OS Pixie transmitter/Receiver
  78. senior telemaster
  79. super tiger trainer .60
  80. Twist .40 Nail-biting Maiden Flight
  81. copies of instrument panels
  82. New engine for your second plane?
  83. Cuban 8's: Tips and advice needed
  84. Ripmax Trainer 40
  85. Flutter on Skyraider mach 2!
  86. Covering Repair
  87. Airplane Stake/Peg
  88. Spinner! Can't find one that will work!
  89. Aileron tape hinges on Apprentice 15e
  90. Help With Engine Choice
  91. OK, flying, doing the basics, what’s next?
  92. Fly my Ultra Stick 40 for the first time today!!
  93. How do I neutral ailerons on Twist .40?
  94. Transmitter cover and hand warmer
  95. Control Surface Adjustment Tips
  96. PT-40
  97. newbie doing research
  98. winterize
  99. tinting a canopy
  100. Balancing a Spinner
  101. Used Sig Star 4 60 Questions little help.
  102. Giving it up to myself!
  103. Pulse XT 60 Engine?
  104. BATTERY PACK
  105. Engine Installation Help
  106. which G4 plane to start with
  107. kit building
  108. Cartoon w/RC Plane
  109. Saito 72 and Dave Brown Spinner
  110. First bipe?
  111. Why no aircore?
  112. how to steer plane
  113. Help with electric motor install on foam Extra 300s, please
  114. The trend in over-powering our models make for less prepared pilots?
  115. Learn a friend to fly on a katana?
  116. my first build...question on glueing
  117. Skyraider Mk2 floats too much!
  118. trainer cables
  119. Adding weight?
  120. controller stick orientation
  121. Need advice to buy an RC Plane for a kid.
  122. Anyone online now that can help setting up flaps on an Ultra Stick 40?
  123. I search a good plane EPP RTR?
  124. Running Backwards
  125. + Help me choose a starter Electric plane please+
  126. Second plane
  127. EVOE100 Engine Problems/Settings
  128. Is it possible / easy to add flaps to an existing wing?
  129. replacing muffler gasket?
  130. Looking for a 40 size Biplane
  131. Cutting Cowls
  132. Towerhobbies .75
  133. FOUR STAR 60 CG??
  134. an A30 10XL HACKER MOTOR?
  135. CHEEP BL MOTORS
  136. Rx battery - good?
  137. Just a few questions from a beginner
  138. Anyone tried one of these?
  139. Anyone know where to buy a DuraPlane Funfly online?
  140. RC Ken or Minn need help.
  141. spinner and prop keep flying off
  142. ARF Trainer - Crack forming across firewall
  143. Spectrum DX7 and AR7000RX
  144. Twist .40 Build Help
  145. new airplane help
  146. Help ( Ideas ) Finding A Spinner
  147. anyone have or seen one of these planes?
  148. What would you do
  149. Good as new!
  150. converting fa100 gold knight to gasoline?
  151. 2nd plane
  152. Can I maiden trainer with a new engine?
  153. Maybe a beginner, again?
  154. To A Administrator
  155. OS46LA . tring to get it to idle
  156. Skyraider mach1 fuel tank question?
  157. VQ MDOELS TOMHAWK!
  158. Throw Measurement
  159. First Plane
  160. Tower Hobby Phone sales people
  161. Saito 72 Assistance
  162. Prop and Spinner
  163. Hanger 9 F-22 PTS
  164. Big BingoI need help
  165. Winter Storage
  166. Transformation of a Skyraider Mach 2!
  167. Whick prop for 46AX on Twist .40?
  168. What Servo's for Twist .40?
  169. Wont run when pointed UP
  170. Help Covering
  171. Low mixture Engine question
  172. Field box with battery, or individual battery powered
  173. Muffler fuel leak
  174. Kyosho Calmato Sports as a Second Plane.?
  175. worn out starter
  176. Receiver range
  177. 4* 60 ARF Assembly Questions
  178. HobbyPeoples SportsFlyer "WASP" ARF
  179. Hangar 9 TANGO
  180. park flyer
  181. plane suggestions for TTPro .36
  182. Tx and Rx
  183. Tower Trainer Question
  184. Crystals Failure?
  185. My first kit build, send help please.
  186. after run oil
  187. Sig Senior Kadet OS with .91 4 stroke
  188. Lucky Star Trainer ??
  189. i cant control my plane!
  190. Wont stay running/Air bubbles?
  191. Engine Choice for Hobbistar 60 MKIII
  192. biggest prop
  193. Prop keeps coming off
  194. DX7 Battery
  195. Not sure where to go
  196. Saito Muffler
  197. 2nd Plane: OS 0.55 or 0.75
  198. Ironing Film
  199. I left my rx on for two days
  200. Using A leaf blower Motor
  201. Best way to fix this is how?
  202. Sig LT 40 ARF
  203. What is NARO ????
  204. Where do I drill holes for fuel lines?
  205. Prop balancing - what does this mean?
  206. Calculate max airspeed of a plane?
  207. Four Star 40 CG concerns
  208. CMpro Giles CG
  209. low wing landings
  210. Up side down engine
  211. Upgrading on-board batteries on Nitro plane
  212. throttle servo hardware
  213. Small kit plane
  214. Prop for Alpha 40/Evolution Trainer Engine
  215. whats mode 1 and mode 2 ?
  216. Warning: Lipo fire
  217. 4* pushed beyond it's limits.... sugguestions?
  218. Aileron travel
  219. Anyone know where the CG is for a Breitling Cap 232
  220. Who has the best price/sale for Spektrum DX7
  221. is this ok?
  222. OS .55AX engine break-in and usage
  223. Futaba servo connector to Micro Connector
  224. Full size RX vs. Micro RX
  225. Phoenix Tucano 60: Open question to all
  226. Help with filling hole
  227. Help starting an OS 46SF
  228. Lesson learned the hard way!
  229. Heli to fixed wing
  230. Suggestion for Beginning Builders
  231. New wings for an old trainer
  232. Spektrum DX6i help!
  233. Aileron/ Servo ? World Model Extra300L
  234. Dowel control rods?
  235. Need Simulator ASAP
  236. electric starter
  237. Goldberg Tiger 2 "Extreme Plane Makeover"
  238. Our jets and giants fly in pics.
  239. SAITO FA-56 ENGINE HELP
  240. Solo'd Sept 13, crashed Oct 6
  241. First landing and then....oops!
  242. Evoloution .61 Question
  243. Rotostart to start plane?
  244. What would you do?
  245. Stubborn Fuel Tank Stopper Problem
  246. Another "Name that plane" game.
  247. Looking for a Radio for ARF
  248. My new aerobatic team!
  249. Prop size for stick
  250. Help Me Pick My Next Plane: Intermediate 60 size
