View Full Version : Beginners
- Welcome Carroll S
- did my first flight but need some advice
- mounting Ailerons
- Changing throttle linkage?
- plane for my os .61 fx
- Towerhobbies Mistake
- HElp! battery not charged??
- Nexstar repair help
- F-22 raptor .61 (1st flight)
- Firewall Repair ?
- The Day Has Come!
- Tiger Moth.
- What does "snap" mean?
- Great Planes Fuel Tuning
- Dual ailerons
- Tri cycle conversion to tail dragger question??
- Servo install question
- Trouble removing Carb
- Battery Question
- Does anybody know anything about this plane ?
- Spektrum DX7
- Futuba 8U vs. 7C plus FASST
- crashed on the maiden
- Tail dragger conversion; Why?
- Starting Bench Safety Issues
- Static Balance of CG Questions
- Can I use car fuel in my plane?
- Correct engine temperature
- After run drips out of engine...normal?
- Finally got some good training time in!
- how to adjust control surface movement?
- .70 4-stroke. Need a plane to put it in
- Designing space for repairs/kit building
- Basic charging questions
- PT40 conversion coming along nicely
- Need parts to repair airplane...
- New Power plant! Oh YA!!!!
- Bind plug when buying a Radio?
- second plane
- Has anybody tried any of these?
- 1st start tonight
- Covering Questions
- Epoxy gone bad?
- 40 Size ARF Options: Four Star, Kaos, or Easy Sport?
- Just another update and repair report.
- Easy Kits
- whats up with all these sticks?
- Best place to install fuel filters
- Which LiPo and which Field charger?
- Started my Phoenix Dolphin 40
- Clamps
- New to RC need some guidance
- Warbird Supercub?
- Windy Day
- Enya 35V won't suck fuel & aerostar .40 ?
- How soon we forget!
- E-FLY 100 C Rx - Help!
- Birthday Items
- A newbie with (nitro) identification questions!
- Monokote NOT wanting to stay on....
- Makeshift Runway
- Hanger 9 F-22 Raptor
- GWS products
- mounting a Saito 56 on a Ultra Stick 40?
- visiting another club... Montgomery, Alabama (RAMM)
- Ailerons and Du-bro heavy duty control horns
- Poor nexstar taking a beating...
- How a Carb Works
- Help me w/ordering the right carb....
- Initial Engine Run Questions
- Final control suface adjustment?
- First dead stick landing today... fun stufff
- OS 55AX in 60 size plane
- Electric Vs Nitro
- Fuel dot setup
- Hanger 9 Cessna advanced trainer or Hobbico Avistar
- Engine Mount for OS fs-91 II Surpass 4-Stroke
- What are these o rings for?
- Engine quit while inverted
- How to know the amount of charge a new battery needs?
- Problem with going full throttle
- Second plane Idea...
- Glue Pulse XT40 wing together?
- Some issues with Magnum XL40
- Best trainer for me to re-learn?
- questions about ailerons
- Aileron Connectors
- glow plane set up?
- Ultra Stick Mini Battery Recommendation
- What's a good starter Radio system?
- Beautiful Flight
- Who makes the best airplanes?
- Bummer
- Muffler Keeps Coming Loose
- what needs adjusted
- ? about futaba t4ybf radio and receiver
- Tiger Moth Question
- CG- ad lots of tail weight on bi-plane???
- Prop balancing without fancy equipment
- What is enough when it comes to batteries?
- lipo balancers
- Not expecting too, but I SOLOED Tonight!
- repairing mono-coat
- Still need help with tuning
- Horizon Hobby kudos
- Starting Problems
- covering iron
- charging a LiPo battery
- Need help for Magnum 28 2stroke
- P 51 Trainer
- Solo Sport Tail vibrations. Help Please, w/VIDEO
- anti rotation pins: where do I get them?
- re-tuning
- Which plane?
- Very quick question
- Sundowner 50
- OS 4 strokes
- Recovering Venus 40
- Prop for .91 4-stroke?
- How tough is the Four Star .40?
- need help deciding on first plane?
- duel wing servo control??
- Engine tuning
- questions about tower trainers
- Four Star .40 with OS 46ax
- What is the Firewall?
- We can aspire to this, being a beginner and all :)
- wing bolts
- Epoxy
- what causes this?
- fairly bad dead stick, turned out ok..
- Firewall Blind Nuts - Plywood Firewall
- Good starter
- Where are my P.M.'s?
- Does anybody have this charger?
- whats good for me?
- E-Flight Apprentice 15e RTF trainer
- Graupner T-28 Trojan
- Prop slipping on spinner?
- Fixing Avistar Horizontal Stab
- Busted Pt 2
- What colour?
- How to set prop for horizontal stop?
- Calculate Propeller Pitch
- Recovering an Already Built Plane
- Y Cable or not?
- How do you overcome the fear or maidening a kit?
- mac's mufflers?
- HELP PLEASE____1989 46SF-S ABC
- locknut/washer engine mount
- Horizon/Hanger9 Now 0 for 2
- Came into some money.... what to get.. :)
- Newbie to Airplanes, Price (Specific Aircrafts) question !?
- Just doesn't line up
- PT40 dihedral
- NO!!!! on NitroModels
- Essential tools and kit needed @ the field?
- Making Dubro Spinner fit with prop
- Hello new here
- Glow Igniter issue, I think.
- Weather codes translated...
- Discontinued thing
- Plane Specification
- Stan's Fibertech (AeroFiberTech) vs. Fiberglass Specialties
- Reciever battery help
- Club Dues
- hobbico nexstar select trainer?
- I need to know if this is going to cause glitches or range problems
- Wing rib repair complete w/ pics
- Landing under power...
- Pulse XT 40 without dihedral?
- Fuel line setups
- Combo Find
- Magnum XL 40 Stalls when going vertical???
- Alpha 40 Trainer
- 2.4ghz - Spektrum or Futuba?
- Is Futaba 6EX with flaperon mix equivalent to 7ch?
- Buying a radio: servo question
- HS75BB Retract Servo question: OK with 6.0v?
- How do you check your batteries?
- Lt-40, NexStar, Tower Trainer whats the difference?
- Retract servos
- Symptons of dirt in Engine?
- The NexSTAR arf cost more to outfit than the RTF
- First time out!!
- Does the color of your fuel mean anything?
- PULSE 60 AND SUNDOWNER 50
- What's in your tank?
- Sat. Shipping( delivery)?
- Any instructors?
- Covering
- Recovering Fuel Soaked Balsa
- From NexStar to Four Star
- Aileron servo lead clips?
- Battery upgrade for Spektrum
- How much ultra/mono do I need to cover a tower 40?
- Tips for re-enforcing firewall/landing gear area on a ARF?
- Nexstar VS hanger 9 alpha
- servo noise
- Noob question on what to buy
- What do I do about loose covering in really small places?
- Right Thrust
- Servos for an Ultra Stick 40?
- airplane transportation
- Peak/Field Chargers. What do you use?
- FS-70 Surpass ?
- Patterns
- You guys cut the throttle at top of your loop?
- Tail Heavy Plane
- can Electric wires cause interference on a 2.4ghz spektrum?
- Leaps and bounds...
- power panel
- Nitroplanes Ultimate 40 ARF
- Soldering Iron
- What did I do?! (Electronics / battery gurus, this is for you.)
- DX7/Programing
- Do I need a voltwatch?
- How to apply ultra-cote/mono-cote?
- Rib repair on wing question?
- Spinning Direction
- Have you flown the H9 Pulse XT40?
- How to re-thin CA
- Can we expect O.S gassers?
- I got BUSTED today!
- Charger
- DX7 and DX6i RX compatibility
- Finish building 20 year old plane?
- Solo Sport Rebuild
- slow stick flight time
- ultra stick 40 performance
- MORE brushless POWER!!!!!!!!!
- Interchangable frequency crystals
- Ultra Stick 60 Elevator/Rudder Servos
- Brushless....
- Piper cub PTP engine help..??
- Complete NOOB with a few questions
- Newbie Engine Question part2
- Heli & Air Radio
- How long does it take to stop
- Manufacturers and their quality?
- Expo for Newb's?
- Simulation instread of trainer?
- Quick Question
- (os ax) what does ax stand for?
- Spektrum DX7 fuse
- Magnum XL 40 manual
- What size engine?
- Help identify this plane.
- Help with TX Futaba T6EXA
