View Full Version : Beginners
- Questions re: Mixes, Remote Glow, Simulators
- Basic radio question
- Aerofly New Version
- Tach question
- Another ...Why?
- OS 70 S ll Mounting options ???
- Prop Size for Avistar with TT. 46
- Futaba 6EXA
- Vote Today and let your voice be heard!
- Great Planes Cap 232
- Sig Somethin' Extra
- first plane
- Aerofly Pro or Great Planes Real Flight G3
- Best Online shops
- 4*60 flight #2 - What's that falling object?
- how long do glow plugs last
- New here. Just wanted to pop in and say hi!
- Best Prop for easy takeoff from grass
- At my wit's end...
- TT MK2 converting to tail dragger
- PLease help Wife wants to get her hubby his 1st plane
- Tissue Covering Removal HELP!!!!
- Watt-age
- Am I Mental???
- OS46FX Leaking Fuel
- Crash repair...
- low battery stopped solo
- glow plug differences
- My Vmar Extra 330L - HELP
- What store online- paypal
- Hinge installation
- field tote paint?
- Saito 100 mount on Tiger 60?
- Taking Dehidral out of a wing....
- Magnum XL 61 Questions
- Mounting TT Pro .46 engine in ARF Avistar Mounts
- PT-40: Help fixing a binding nose gear steering wire
- Retracts
- Piper Cub and engine
- HITEC OPTIC
- servo sense
- Servo Mounting
- Buzzing /clicking in Servos
- How to charge Li-poly cells on a Commander?
- Great second plane
- Radio system problem
- installing the engine,mount too tight
- 2nd plane-can't decide
- ANY LITERATURE ON INSTALLING ULTRACOTE OR MONOCOTE?
- Help me with my ARF Avistar please!
- Sig four star 60 or 40
- No power to servos... need help ASAP
- O.S. .40LA discolored during break-in??
- What is "Real Time Response" ?
- Trainer mods?
- Painting canopy lines...
- Tiger 2 with .61
- Beginner, what Stuff should I get??
- Newbee needs engines 101
- My Beginners-Equipment-Guide!
- paint?
- .25 size engine question
- 4*40 Aileron Hookup Problem
- 4 channel RTF electrics?
- Best Motor Mount - Best Tailwheel Assembly?
- AMA Membership Question
- First flight with Hanger 9 T-34 mentor
- Tip for beginners to get girlfriend approval on RC-hobby
- I jumped! (another newbee)
- Break-away engine mount
- First glow (4*60) maiden = success!
- Saito 82 plumbing question
- Tiger 60 with Saito 100?!
- Need plane radio system recommendations.
- Translating dimensions from full size planes to model planes
- Good engine brands/types
- First Monokoting Experience: How bad is bad?
- Want another engine..
- Ideas to trap castor oil mess when test running engine...
- Balancing Props
- Getting shot down
- I think my wife was right
- OS40FP/twist
- SIG Kougar 2nd plane
- help with engine problems
- Its finished!!
- How do you know what your engines operating temperature is supposed to be?
- What's the best Radio setup???
- How do you check flight batteries?
- whats the use for real flight
- Tower Pro receiver compatible with anyone?
- WingsPro composite trainer?
- I am looking for a dealer who sells the Protech Megastar XL 120 ARF. I anyone knows where I can find
- Spinner questions.
- Is the GP 40 cub a second or third plane
- Engines and Mounting
- Prop reemer?
- 4 stroke vs. 2 stroke
- Is it possible to get something flight ready for 315 dolalrs?
- FINALLY ORDERED!!
- Flight Craft Cardinal
- heli shop in NJ?
- I got her made
- Hitec Optic 6
- Prop size for Avistar with TT Pro .46?
- Phoenix Models Sonic 25 Low Wing ARF -- 4-Stroke
- Thank goodness for RealFlite!
- JR 9X & Throttle servo?
- First Plane, Got Some Questions
- What plug for TT Pro .46?
- Sign of the times
- What do you use..
- Exhaust mist? And other engine questions
- Lots of newbie questions
- Which .46?
- Futaba 6EXA and 7C, big difference?
- .20 Size "Park style" or Sport Plane
- How do u Check the CG of a plane?
- Forums are Great for Information
- What's the best way to seal my hinge lines?
- batteries
- Fuel to a four banger Saito 100!? plz advice!
- Moderator????
- great planes rv4
- Still trying to learn to fly!
- 4* covering help!!!
- centering aileron electronically
- Wich Tx for Airtronics Rx?
- Gentl'ing a Giant - Ultra Stick and Mag 80 4-Stroke
- .46 engine for Avistar
- can smoke be setup on a 60 size motor?
- Sky Raider Mach-II First flight!!
- A Motor, A radio control, What Cheap Plane??
- What fuel is everyone using for an OS 91 Surpass
- How often does Trim need to be set on same plane
- Jamara Corsair Manual English
- Can I fly in the USA?
- Engine Tuning 101
- 46 OS Inverted Trouble
- which for the 40LA?
- Did I waste my money on a Buddy Box?
- Calling all SuperStar and Avistar owners.
- Someone please explain 'Slipping' for me...
- New Saito 91 needle valve settings
- Plane climbs under power... Problem???
- Good webshop in Europe?
- Hobbico Superstar
- ARC 'plastic' models (Now with pics and reviews)
- .52 or .70 4-stroke on Trainer plane?
- Flight Box
- 4 star 60 or Tiger 60?
- OS 40 LA / AVISTAR SELECT
- Engine trouble
- What about magnum engines?
- Radio for Beginner
- OS.46 or TT.46???
- Great Planes RV-4 .40
- Tiger Trainer Throws and CG?
- gasoline engines
- Rookie Question about antennae???
- Finding a niche
- Adding weight for Lateral CG?
- Get all you can get out of your trainer
- 1/8" foam sheet stock..where do I get it?
- sig 4*40 throws
- Newbie looking for Karachi Resources
- Purchasing Etiquette?
- ARF hinges
- Check flight sobb story and a little gloat...
- Airtronics
- What size fuel tank for a 91 engine???
- Greetings! First timer with a basic question
- Engine Issues - bubbles in fuel line
- The question of a first plane????
- Ducted Fan Info
- Glow plug
- What windspeed grounds you?
- What do you mix your epoxy in??
- Newbie Question
- Funtana For #3?
- Super Glue
- 4 inches of new snow!!!! Oct. 16, 2004
- Battery Problems...
- Balancing 4*40
- Putting down a fairly large stripe, monokote over monokote?
- Extremely good article-
- engine swap ?
- Glow plug ?
- Dual Rates
- Air pocket in fueltanks. Question
- 2nd Plane Blues:(
- Prop size for 4*40
- Buying Kits
- homemade deflection meter
- 4 star or Tiger 2?
- Newbie Slowstick & radio shopping list
- How to set the CG of a plane
- Landing a tail dragger
- DP Ultimate 120
- What's the difference? Four-Star or Somethin' Extra
- My turn,, I Soloed!!!
- Servo Compatability Hitec/Futaba????
- GMS .47 or Magnum XLS 52 for SIG SE
- Newbie Question
- Flight suspended at field
- clunk won't fall forward?
- Airplane stands
- Not sure
- jett 46 inn 4 star
- FUEL !?!?
- Where to put in the after-run oil?
- 4*40 nose heavy
- Contra-Rotating Props Question [Where to Buy/How to make?]
- How do I get rid of the edges on my stickers?
- Transmitter Channels
- Flight sim physics realism???
- Newbies don't forget the Preflight checks
- ULTRACOTE COLOR MATCHING
- Modify four-star 40
- Thinking about beginning(Charlotte people?)
- Dago Red
- four star engine mounting
- proper way to hold the control stick
- Control Surface / Servo Setup
- Newbie
- starter question
- Sig four star,
- Evolution TPS .46
- Compensation for RC Instruction
- Battery Wiring Diagram?
- THE most contrary thing I've ever owned
- GP Extra 300 .40 What Engine???
- Second Plane
- Hobbico Top Fueler Mk III problem (I'm not sure this is the right forum for this)
- Radio Question
- Price of RC training ?
- FM, PPM and PCM... huh?
- MINI COOPER S - what can you fit in it
- Gas engine fuel tank help
- How much time between flying sessions?
- I need a good way to taper the leading edge of my ailerons
- First plane choice.. wondering what you all think
- newbie...2nd plane?
- SIG Big Mig Sport .074
- I SOLOED
- What kind of solder do I use?
- Centering Servos Before The Big Close.....
- Beginners: watch this video FIRST
- G2 controller as buddy box?
