PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. New here could use advice
  2. Knowing the pitfalls of flaperons...
  3. OS 55ax fuel economy problem?
  4. Vendors
  5. NACA code for Ember 2
  6. Transmitter battery substitution
  7. what is a good starting airplane model kits?
  8. silently comes into airplane
  9. What should I have done?
  10. 6x-super
  11. Battery connectors
  12. Just no luck at all!
  13. New futaba 1000mah nicd rx batt breakin...
  14. DX7 question
  15. Spray can insulating foam for structural support under turtle back
  16. Magnum XLS .61 and K&B .61 engine
  17. Can you drill a forward bulkhead twice?
  18. Correct way to install a prop
  19. P51-D
  20. Idleing
  21. K&B engines
  22. Discharging a NiMH battery
  23. Trike Takeoff Trouble
  24. React-a-Pack adhesive
  25. 6v receiver pack voltage
  26. Hello =) - Optic 6 Help with programming Flaps
  27. Meet Frank
  28. Slow stick V-tail problem
  29. 4.8v or 6v for sports flyers
  30. 6v NiMH overcharging
  31. Saito FA-82 Glow Plug Choices
  32. nicd - nimh run time
  33. DX6i Binding issues
  34. Landing for the beginner
  35. Did I kill my plane?
  36. Hot engine
  37. Securing the micro Li-Po battery?!
  38. Futaba 1000mah 4.8v receiver packs
  39. Do 2.4 radio settings transfer to the trainer box?
  40. Whats up with Sig Mfg
  41. universal connector wires
  42. Prop reamer~do I need one?
  43. tenergy batteries
  44. nexstar ep select rtf battery charger
  45. Installing propeller for power 25 brushless
  46. Overnight Charge 600 mah batteries
  47. 2 supercubs flyin?
  48. Idea for someone to run with.
  49. Uno wot OR wot trainer?
  50. Painting without glassing?
  51. name this plane and engine
  52. A great day yesterday!!
  53. Avistar Help!
  54. Monokote trim solvent and Ultracote
  55. Beginners and experts, please note:
  56. Not a noob to rc but a complete noob to rc planes!
  57. arf construction
  58. champ vs p51
  59. DX8 officially official
  60. PA addiction Maiden Flight.
  61. Replacing receiver antenna
  62. My first carrier landing last night
  63. DX7 receiver and servo compatability
  64. Thunder Tiger S1903MG anyone?
  65. upgrade to Brushless
  66. 10x5 prop direct with a 3700kv inrunner?
  67. engine size
  68. rx
  69. 6v batterys
  70. futaba 7c 2.4 Programming
  71. Learning To fly RC Airplanes
  72. Prop Selection
  73. making my first balsa plane
  74. Trainer Questions - size, wings, engine
  75. High current draw????
  76. Just bought a DX7! First timer 2.4
  77. rx Lipo Battery
  78. Crash
  79. A second plane?
  80. bummer
  81. warped wing or to much pitch?
  82. Four Star 20 EP; still a good second plane?
  83. Charger for VG 400
  84. Venom Servos
  85. Capacity of the receiver battery?
  86. engine puffs in air...
  87. radio rx/tx crystals question
  88. Engine bogging at 1/4 throttle
  89. strengthening airframe with fiberglass: basics
  90. tuned pipe header cut?
  91. angle of the dangle
  92. starter battery
  93. Ultra Stick
  94. alpha 40 has turned into a floater
  95. Tachometer~what about these?
  96. weather in the 90's this weekend
  97. Safety staff.......Don't miss out!!
  98. Saito FA-82~Which Fuel?
  99. Thanks, Horizon
  100. Real Flight 3.5
  101. fuel nipple, Can I jb weld it on muffler?
  102. T 28 Trojan control problem
  103. LiFe Rx battery
  104. OK I'm done!!
  105. My "flying field"; how much plane can I fit into this space safely?
  106. Rolling flight line box~Cheap!
  107. KMS KMB 31/21 on slow stick
  108. Electric Starters~Do You Use One?
  109. seen somewhere about MG995 servo from Tesla?
  110. Hobbico FlyZone SkyFly Max EP
  111. Battery condition?
  112. Wing Bolts
  113. Looking for a good trainer
  114. Nice Outing with Grandson
  115. speed400 20oz plane prop and gearbox ideas please
  116. Help Repairing a Muffler
  117. Engines 2 or 4 Stroke & planes give you good vertical climb?
  118. 12v gel cell battery charge
  119. Member information
  120. Battery Voltage Drops....
  121. Need Help Identifying this plane.
  122. Battery cycling charger
  123. Cheapest Fasst Receiver???
  124. nexstar ep select rtf
  125. Seagull Decathlon 40
  126. Escapade
  127. os ax 55 engine problems
  128. engine problem
  129. How do I clean my engine properly?
  130. Aircraft lightning
  131. DX7 - dual aileron programming??
  132. Carl Goldberg Super Chipmunk
  133. I usually wait 'till I'm at the field to crash 'em...
  134. Motor Mount?
  135. Help - Tru turn spinner -
  136. Which Supercub for a beginner?
  137. Servo Torque Suggestion
  138. GP Extra 300 kit 60 size
  139. Looking for a new plane. Which if these two? Thanks!
  140. Pay it forward is coming back...
  141. Glow Starters ?
  142. UAS
  143. does fuel choice effect flight time?
  144. Which gas Motor?
  145. Need to talk to the Administrator
  146. P-Factor and how to measure
  147. Covering visibility help
  148. Sealing hinge gaps ?
  149. Red Bull Air Racer Skips Plane on the Water
  150. Fuel Tank Help
  151. How many rebuilds have you done on one airplane.
  152. Best way to tune 4 strokes
  153. any one flying a rascal or flown one.
  154. Cub or PA addiction
  155. COWLINGS AND 2 STROKES.
  156. shop ideas
  157. Recommendations about finishing the flight box
  158. Vinyl
  159. good idea or bad idea?
  160. PLEASE HELP!!! P-51s ultra micro mustang roll
  161. Cell phones ?
  162. Break-in for 25 Glow Engine ...
  163. PT 19 Giant maiden flight!!! Finally!!!
  164. Glow Amps
  165. LiFe or NiMH rx battery
  166. Mini Funtana (yellow and red)
  167. Hanger-9 p-51 pts mk II problems
  168. help!
  169. Is my RPM to high?
  170. Prop balancing
  171. Direct me to the correct forums?
  172. Vibration Issues
  173. Pt 19 trainer
  174. EVO .46 engine ?
  175. piper cub with floats
  176. Dual Ailerons
  177. Nelson Hobby Paint ?
  178. Aeroworks Edge 540T 60"
  179. Hobby City Delivery times
  180. How to get fiberglass off a cowl
  181. Servo size questions?
  182. Need help for prop size on electric motor
  183. Engine choice.
  184. Beginner solderer
  185. Suggestions on Phoenix Models Strega ARF!!
  186. Parkzone SU 26 BNF
  187. U Can Do 60 As A Trainer setup
  188. Double sided servo tape
  189. Which are good Runway choices, Tarmac, Concrete, Grass/Turf ?
  190. Flaperons on trainer?
  191. Futaba 6EX transmitter battery upgrade?
  192. slow poke 40 sport
  193. Wingtip Protection
  194. Coming back!
  195. When is it okay to go bigger?
  196. crow bar is not an option
  197. Power source for Turnigy charger
  198. need help choosing first rc plane.
  199. What prop for my trainer
  200. me and my Alpha 40-h9 ar500
  201. RX Battery Pack for Spektrum ar6200
  202. Copper wire resistance
  203. How to figure Prop Load
  204. 1st Ultra Sport 40
  205. trouble taking off
  206. digital vs analogue
  207. First FPV radio set.
  208. Screwed up transmitter
  209. tree reached up and grabed my plane and the woods ate it
  210. Is this a scam, or a good deal?
  211. Hnagar 9 Alpha 40 vs. Solo Star
  212. Has my CG changed?
  213. Servos
  214. Help ~ My Engine is a Plucker!!!!
  215. Finally some air time!!
  216. Central New York flying clubs
  217. expo%
  218. DIY transmitter/receiver
  219. Hobbico TorqMaster 90 starter
  220. HELP!!!
  221. engine cuts on landing approach...
  222. OS 95 AX
  223. altmeter, speedomeer and other instrumentaion platform.
  224. OUT OF STOCK
  225. Fox .50 (gas) For a LT40 ?
  226. Art-Tech Cessna 182 500 class
  227. Problems with aileron extensions
  228. Trainer cord / buddy box
  229. PHOENIX FLIGHT SIMULATOR - PROBLEMS WITH TRAINER JACK
  230. Flights per year....
  231. Returning to flying. Wish me luck
  232. start 'em young I say.
  233. Anxiety over switching to DX7
  234. Difference between 72 PCM AND 72 PCM1024
  235. servo extensions
  236. Never flown anything... What's the quickest road to an EDF jet?
  237. OS 55 ax Deadstick problem.
  238. rc timer on off switch
  239. What is the name of this plane and who made it?
  240. Beyond trainers: a universe of diverse models-Which is which?
  241. Egg all over my face!!!
  242. Super Tiger G61
  243. changing transmitters
  244. What servos with an Ultra Stick 40?
  245. GP J3 Cub
  246. Cleaning Engine
  247. Great afternoon of flying
  248. easy 2 trainer recover
  249. Noise limits and measurements
  250. Lipo reciever packs and reciever??
