View Full Version : Beginners
- whats a servo saver?
- 1st Radio !
- Where should I start and where do I go from there?
- How long before Kadet gets boring?
- Engine cutout
- affect of front wheel on flying and servo
- new to r/c planes, advice appreciated
- beginning beginner
- Gel Cell Batteries
- Nyrod question
- Is monokote water proof
- Why is the 8uaf so popular?
- 6 years old...
- Prop Question
- Advice from the pros...?
- Nose and tail wheel "throw"
- Pete n' Poke
- Flash 5 (Hitec)
- Ailerons & rudder
- rubber bands or bolt on wings????
- 2nd Plane
- Trying not to be cocky
- Shopping List
- 2 or 4 Stroke??
- Flat-bottom vs semi-symmetrical airfoil.
- titebond glue
- When to use servo saver ?
- Prop size and Pitch
- Fuel soaked fuse
- tuned pipes???
- New to R/C Planes & Joining AMA
- Flight trim article
- My 2 cents
- Four Star 60 covering job
- Hitec to Futaba compatibility
- Radio/Receiver Match
- newbie question
- What fuel level when balancing?
- GP PT-20 w/ o.s. 25la-enough power?
- Whats the most Important Item to have in a field Box.
- basic building/repair questions
- gws micro Rx, for example.....
- servo chatter
- my first solo flight
- Sig LT-40 Control Throws?
- landing
- kyosho spifire 2nd plane?
- is enya a goof engine?
- Color scheme
- please vote!
- airplane hold downs for the field ?
- please vote!
- What's a good 3rd plane?
- U.S Aircore for 1st trainer?
- Engine for LT-40
- with aleron or not?
- First Plane
- How to move from a trainer?
- What type of plane is this?
- Some LT-40 Set-Up Questions
- elevator repair
- servo repair?
- Good Scale Second Plane
- Good article on prop sizes in this months Model aviation magazine.
- what are the basic equipmant for a new beginner?
- tail heavy trainer
- Wing Rebuilding
- Realflight G2 is it worth it????
- some nomenclature:
- Beginner in USA - NY metro area
- What is a good 6ch second plane
- Seagull PC-9 for second plane?
- Finish on GRP?
- Smooth wrinkles in covering?
- Should I glue wing halves together?
- sealing control surface
- Drilling ca hinge slots
- where is the Best spot to locate a Hi Start Launch Hook??
- Electric fuel pump
- Airplane Model for my engine
- Plans for plane transport rack
- Newbie plane type
- Re: Insurance
- Beginner needs help in electric r/c car
- Depth Perception
- Wheel pants assembly.
- Thunder Tiger 60 Balance Point
- convert Avistar to wing bolts
- Sig Kadet LT-25
- Should I?????
- AM verse FM Radios
- balancing props
- New Club
- Which mode?
- tried everything?
- Wing loading...
- Engine troubles...
- engine vibration // running rough
- which prop for an irvine 53
- newbie question : In an ideal world...
- High wing vs. low wing
- UH - OH... i went and did it...
- Old Futaba Servos
- Simulators
- Best Prop for Big Stik 60?
- Royal Air 20T
- Balancing ARF in longitudinal axis
- Dynaflight, Mustang
- Need help
- Re: Good wire
- Slow Poke Good second plane?
- How level should a plane be on it's wheels?
- Credit Card Scam
- Engine Dies when nose lifted
- Spoilerons?
- 5 Min Epoxy
- Changing Tx Crytals
- Lost novice on a small budget
- I broke my plane
- Battery Chargers
- Glow Plugs Don't Come With A 5 Year Guarantee
- Quality training?
- Which heat gun ?
- Cleaning my engine?
- Just another question
- Losing your edge - better not to fly that day
- I'm confused
- Crash!! Now it is time to rebuild......
- Etiquette
- New to the scene, needing some input
- Cowling HELP!!!
- Thoughts on my C.G. - SS60
- Have to start out with a trainer?
- s-z pcm/ppm selectable???????
- Question about Tx crystals
- 2nd Plane
- First Taildragger !! ..bipe .. any tips??
- First Flight
- Futaba DSC setup
- What is a torque roll?
- Moving to a low wing airplane...
- What steps would you take?...........
- Falcon 56 Mark II Info needed
- A Valuable Takeoff Lesson
- Gyro or Not?
- Irvine for Trainer
- Which radio!???
- Elevon Mixer Question
- Starter Question
- Pt60-issues
- Needle adjustments
- Shonky retailers
- Smooth sanded finish
- Too much dihedrahl?
- In kit building when to use CA and when to use epoy?
- bigger wheels?
- Showing appreciation to an instructor
- Venture 60 vs. 4 Star 60
- TX Control
- Balancing KADET LT-40
- Converting 2T fuel to 4T
- Club on Long Island
- tip of the week -- basics of NiCD charging/discharging
- How to use starter correctly ?
- basic aerobatics
- Why R/C?
- CO-Pilot
- p-51 question
- Skybolt bipe
- Propellor Nut
- Fixing Fuel Soaked balsa for Monokote?
- Starting Torque
- kadet ly-40 and the Easy Fuler
- Receiver hookup
- clockwise or counter-clockwise??
- Warbird for second plane?
- SIG LT-40 ARF Hatch
- Paint question
- spinning prop off
- Glue: CA Thin Vs. CA Medium
- my first trip to the field
- how to make a runway
- Newbie here. Need advice on first plane.
- 2nd plane
- Engine gremlin?
- Sig Kadet Senior
- trainers, boring
- dual aileron servos
- Is it unleaded or leaded fuel for the magnum 46
- 3ch or 2ch?
- Maiden Flight !!!
- torque vs rpm vs horsepower -- tip of the week
- wiind??
- Hangar 9 Planes!?!?!?!?
- www.indiarc.com
- Trainer Tail Dragger Conversion
- Fuel tank problem
- Unklunky klunk
- never happened to us,
- Where can i go?
- i'll be needing your help.......yes all of you
- Transition from Tricycle to Taildragger
- Sig Senior
- size of spinner?and what to do with twisted wing
- Second Plane opinion for beginner!
- How to "fill" the gap between aileron and trailing edge?
- website
- Beginner R/C questions...
- Epoxy ( 30 min Vs. 6 min)
- Aileron Length / Gap...
- Newbie Please Help Almost There???
- glo fuel and paint
- Newbie Needs Help??
- Push Rods
- Symetrical vs Flat bottom aerofoil
- oops
- What size spinner to use with APC 12x6 prop?
- Lots of great beginner sites!
- Tip -- high speed needle tuning for your engine's life
- Rx Antennae
- Os 46
- 91 fx in Cap 232?????????
- Clipped T-craft, clipped Cub, or decathalon?
- Megatech Planes
- thermals?
- Magnum .91 4 stroke - need manual
- buying boat
- Second Model
- CA Hinges...
- JR 642 flaperon mixing
- Right Rudder = Pronounced Nose Down
- The R/C Aircraft Proving Grounds
- Help guys- Kyosho Hpi or traxx??
- Receivers and Batteries
- How to make control for fin
- Worst Trainer?
- Balance methods?
- Searched and searched, but cannot find, needle valve adjustment?
- Down Thrust and Sidethrsut
- Attacked by a big green weed!
- Which plane is right?
- Does this price sound right?
- New to GLOW flight. Non-linear throttle?
- 1st Us Rc Flight School
- spad -need alternatives materials
- first heli
- monokote over monokote
- FUEL FLOW PROBLEM? Please Help
- Question......
