PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Stalling issue - too lean or too rich?
  2. Need advice on servos and reciever
  3. Choosing a spinner
  4. Hobbico Electristar
  5. What plane to get to fly in high winds but slowly
  6. Where to get parts?
  7. Cover foam-core cone with covering?
  8. inverted engine issue
  9. Help! Mini storm launcher
  10. Whats your favorite brand of CA?
  11. How to find your max rpm?
  12. Rascal 40 - Need electric conversion..
  13. Soloed my Tiger Trainer!!
  14. Solo today
  15. Purchase List
  16. Looking for a good 12v charger for vehicle
  17. Sapac T34
  18. Hinging thin control surfaces
  19. Removing wrinkles
  20. Thank goodness for Instructors
  21. OS 1.20 AX bearings
  22. World Models LA Racer
  23. Super Tigre GS-40 Throttle UP Problem
  24. Discharging batteries
  25. Plug question
  26. joss stik 60
  27. Paint
  28. Trainer plane economy pricing
  29. PRO PEAK INSTRUCTIONS
  30. RX SPEKTRUM QUESTION
  31. RX battery question/getting back into hobby
  32. Does aluminum-to-metal cause glitching?
  33. Four Star 60 Reborn
  34. Engine Question
  35. Need Advise on Aileron linkage
  36. Clamping help
  37. measuring engine thrust angle.....??
  38. sloppy builds vs. flying
  39. Alpha 60
  40. I Killed it !!!!
  41. LT-40 aileron alignment problem
  42. help selecting servo size!
  43. Releasing Thread Lock?
  44. Its here!!!!
  45. maiden my alpha 40
  46. Maiden.
  47. Stupidity leads to aircraft crash
  48. Build advise/Question on kit build
  49. Radios
  50. What is the best second plane to buy and build?
  51. 4 Stroke for Pulse XT?
  52. Disadvantages of Non-recommended size Props
  53. CG Protege 60 build, my 1st kit!
  54. Radio/Reciever Question
  55. Hangar 9 White Paint Not White
  56. Tiger 60 Re-Maiden
  57. A Promblem With My B-29 Bomber R/C Airplane
  58. Another NooB tip for aileron torque rod centering
  59. Help me to get started again
  60. What is it?
  61. Super Sportster 90/120 for a beginner?
  62. Painting Cowl
  63. engine mounting
  64. First build: Venture 60 vs Sig 4* 60
  65. name this part ??
  66. ASP 91 2Stroke any good ?
  67. well i took the plung!!!!
  68. Parkzone J3 Cub
  69. Landing gear!
  70. tail heavy, wing loading?
  71. Looking to buy first RC Plane/Glider
  72. funtana 40
  73. small glow planes
  74. TO all Newbies
  75. Looking to get back into flying
  76. Super Tigre .75
  77. Trainer &expo question
  78. Which props to which engines??
  79. Bomb Drops
  80. Three Channel or Four?
  81. Building tip
  82. In Kansas City willing to train me?
  83. Mounting new engine on 4 star 40
  84. home remedy?
  85. NEWBIE HAS TRASHED HIS CHEAP NEW PLANE..LOL
  86. Tuning problems
  87. HELP!!!!
  88. Awsome day 2 !!
  89. JR Reciever/Futaba Servo: other questions
  90. cm pro giles 202 50 size, best suited engine
  91. Question about Cool Power
  92. Bad Battery
  93. Hirobo sky limbo
  94. Diff in Props
  95. Snow Blindness
  96. how to get back flying
  97. Is Magnum .91 FSR 4 Stroke a good choice?
  98. Maiden Flight of My Easy Sport
  99. Awsome day!!!!!!
  100. Need help with battery packs
  101. dead stick owie
  102. MKII - MKIII : what they mean
  103. Transporting plane in pick-up bed...
  104. How long does it take?
  105. CG for Planes
  106. Can we use Carbon Fiber for Fuse?
  107. New wheels won't fit
  108. Taxiing in the wind - how to keep plane on its wheels?
  109. Hi
  110. Nylon Bolts
  111. Newbie ?'s about first plane
  112. Really lame: How do I get a PM?
  113. Melting Coverite Iron, anyone else?
  114. PICS OF MY NEW PLANE....
  115. Introducing the Dino-Might
  116. Coordinated turn
  117. 2 stroke or 4 stroke
  118. .15 Trainer
  119. pattern flying?
  120. ST 90 help
  121. real dumb question
  122. Tiger 60 w/ 91FX
  123. Is CG correct of my new 60 size plane?
  124. duraplane 20 on floats...she actually flew!
  125. Guess what i got!!!!!!!
  126. How do they do it?
  127. I had to buy it... I SWEAR
  128. Smoke systems
  129. How to store CA?
  130. Wing Tip Clearence
  131. logbook?
  132. Rudder
  133. Too many trainers to choose from.
  134. Torque on Takeoff Causing Big Trouble!
  135. It is complete(well except for balancing and engine break in
  136. Fuel tank question
  137. Some questions from a beginner
  138. New RC Flyer Build Questions (PT-60)
  139. Cover pattern ideas
  140. Bi-plane
  141. Tiger 120 weight issues
  142. TX Batteries
  143. Remind me why do we fly glow planes, compare to electric planes,
  144. covering woes!!
  145. learning to fly
  146. I should have posted here.
  147. radio!!!
  148. Question??
  149. More throttle/servo hook up questions
  150. If one has no Recycler/Discharger for Tx Battery?
  151. Floats
  152. What second plane?
  153. Super Tiger .40 throttle/servo set up
  154. Fuel Tank Repair
  155. ACRO WOT
  156. Busted aileron hinge - repair suggestions?
  157. TX Battery
  158. Finally an electric plane that doesn't dissapoint
  159. engine mounting video?
  160. O.S. FS.70-II
  161. ideas for a first plane
  162. Plastic pushrods.....
  163. UPGRADE PROP FITMENT
  164. high band on low band receiver
  165. Li-Ion basic question: meter
  166. Trainer Choice (again)
  167. help me before i hurt myself
  168. First Solo
  169. Engine cleaning/Overhaul?
  170. 3 blade props
  171. Problem with pushrods binding on yak54 41"
  172. another good 2nd Plane post.
  173. Now for the Rudder... is this space bad?
  174. Newbie
  175. Start with old Global Freestyle 46 or get a smaller plane?
  176. Zeroing out trim settings
  177. HELP!!! what is a #6 washer?
  178. wa wa wE wa, mid star pilot ,i’ll afraid to flyit at the end.
  179. Add or Remove
  180. muffler cleaning? and Biplane trainer?
  181. How long should a glow plug last?
  182. applying rudder?
  183. Problems starting OS LA .65
  184. Mustang PTS????
  185. "POP" then strange smell - 12 volt charger fried?
  186. TX Question
  187. 4 stroke help needed
  188. 4*40 4 stroke
  189. Is Easy Sport a 2nd Plane?
  190. Hobbico Top Fueler repairs?
  191. found 2 planes in a classified ad
  192. Did it today and wife's still here !
  193. Nitromodels Zlin Z-50
  194. Hand starting procedure...
  195. Joining Wing Halves with 45 min Epoxy?
  196. What type of Propeller?
  197. Something i need to understand about Tower Hobbies
  198. Air bleed screw - how to use?
  199. usable fuel
  200. Hanger9 F-22 Raptor trainer
  201. MAIDEN!!!!!....kinda
  202. Glow engines forum
  203. Mid star and antena tube
  204. kyosho p-40 (retracts)
  205. Motor mount made too small?
  206. Does OS 46 AX not too much of an overpower for Sig midstar 40?
  207. First Plane - Almost ready to go - Give pointers?
  208. MY PARKZONE SPITFIRE SMALL REVIEW
  209. ways to attach a canopy?
  210. What range of reciever is good?
  211. darkend fuel residue
  212. How far into the fuel tank should the clunk go to?
  213. Starter looking for first plane
  214. What is your favourite cycle?
  215. Canapy Troubles
  216. I hate rubber bands - possible to convert to screw?
  217. Buying a B-day gift (airlplane) for a friend: Please Advise
  218. I want to get into glow/gas planes......questions
  219. thunder tiger Dragonfly .15
  220. Remove nosecone with messed up screw
  221. Will I ever get it?
  222. how strong are servos?
  223. In this hobby what was your favourite moment
  224. Make Own discharger for RX/TX
  225. Sullivan Retaining Clips
  226. Got some flying time in this weekend
  227. 3d parkfliers
  228. engine running in winter?
  229. Flying areas around Philadelphia, PA
  230. Did I buy the wrong plane?
  231. Batteries?
  232. Trainer for the wife and grandkids
  233. Not happy with cover job. Please help
  234. Help me choose a plane!
  235. Tower Trainer 40 MkII maiden flight
  236. Four Star 60 Firewall
  237. What went wrong
  238. Interference?
  239. storage ideas
  240. RX and TX do they have to be same brand
  241. Super Tigre Manifold Gasket Options
  242. couple of newbee questions....
  243. Tips on removing/preventing engine varnish
  244. Definitions
  245. Frequency hogs
  246. Centering a Servo AND TX controls
  247. It's friday, the official return of "Pick on Ken" day!!
  248. metal to metal interference
  249. Ultra Stick 60 pushrod question
  250. Repair questions.
