View Full Version : Beginners
- Starting Over Again - Starter Plan needed
- Battery help !!!
- R.i.p
- how to hinge a thick aileron?
- Starting out - with no depth perception
- Did I just make a big mistake?
- World Models P47 Thunderbolt
- Converting servo torque in kg to ounces
- 20 year old abandoned trainer VS Beginner
- xoar laminated props
- Parkzone Ultra Micro T-28 Battery Swap?
- Proper way to maintain, store and test nitro engines without installing in plane
- Happy New Year
- Suggestions on where I should set the rod
- Xoar wooden props
- Noob- need part number for carbon cub ss servo epoxy
- Agm 30 good or bad?
- radio question
- Super Chipmunk
- Os 160fx - 0s 200fs p
- Pushrod Housing attachment on Apprentice S
- Seagull Extra 160-180
- Ailerons twitch when throttle is pressed 1/4 and above.
- My Forums
- RC Radio Airplane PC trainers
- Not sure what way to go OS 50SX or 61FX
- TX & Ni-MH batteries
- Side mounted carbie good or bad outside of the cowl?
- Beginner
- Is any day a good day to run in a motor?
- charging a Li-PO
- Seagull Extra 260 160-180 need advice on what sevos would be good for this plane
- jester_s1 I need your help
- futaba t6exhp
- Transmitters
- Beginner needs help with purchase
- Bi-planes
- New to planes Help:D
- First aiplane flight ever...success!
- more power or best prop for Goldberg eagle 2
- Extra 300S 60 class plane need a good but cheap motor any suggestions?
- FTL 52cc
- what to get
- 91 FS 11 need advise
- Koverall application tip for wing
- Prop selection questions
- Looking for an instructor in the Hernando, Mississippi area.
- Cessna loses power fast
- Instructor to beginner again
- Servo's
- What's best way to repair my damaged wing leading edge?
- Is this wing too damaged to fly? Pics included
- first rc
- ParkZone Cub
- How to remove Engine from Mount?
- CG Big Stik 60
- P-51 Musang "Marie" by Power Zone
- How critical is fuel tank level in relation to carb?
- Cleaning CA off Monokote
- E-Flite Ultra Stick Wing Failure
- Servo Control Arm Position
- rubber bands peresing
- Dual and single conversion Hitec 35mhz
- Os fs 91 s 11
- Os 55 ax
- JR receiver help???
- Vertical Stabilizer - which glue?
- Help with Trainer 60
- Prop Pitch And Speed
- Newbie
- After nearly 30 years
- Older Futaba FM receivers and BEC
- Just got my first Plane!
- This is what its all about
- Flaps
- Questions re Bixler 2 and where to purchase
- A Beginners Thoughts on AS3X and Self Training
- My trainer seems to dive a lot whn I try to roll it
- Bixler 1.1 and Turnigy Plush 40A BEC compatibility?
- SIG Super Flight & Airspan & Light Span?
- Noob introduction here along with opinions needed on a Tx
- Self teaching - Looking for my next steps in learning please guys
- Whats with the aerodynamics on foan planes
- Vintage sterling ringmaster jr
- quick one, os max 15la mounting hole size?
- No more DuraPlanes?
- New Here From S. Alabama, New to RCF, RealFlight Basic Question.
- Want to build a biplane
- Wing coatings adhere to plastic and carbon fiber?
- using Illustrator to help color scheme..
- I learned a big lesson
- Sig Fazzer
- Parkzone P51 Question
- telementry temp DLA 56cc
- 1st Prop Bite 1 week later.
- Any tips on landing a Seagull Pilatus PC-9
- Suggestion for first plane?
- Recovering tail section around hinges?
- Rc turbine jet
- Pod and Wing repair maiden
- Flying in the rain?
- Velcro That Battery!
- first prop bite!
- Os 55ax
- I have created short movie of Paper model to show all of you.
- pod and wing repair
- CG biplane gas engine?
- mode 1 or 2 ?
- Learning to fly warbirds
- Aluminum spinner question
- Looking to get gasoline plane.
- Aircraft plywood?
- Striped Covering
- Twinn K Gyro I
- School Project - Help
- difference in rudder steering and aileron steering
- officially back in rc
- Just starting out/Introducing myself
- Cleveland Ohio area shout out
- A Beginners Tale...UM Spitfire
- Kinda new, have some Questions.
- start w/ 40 or 60
- Studied A Long Time, Hoping for Input
- Sealed fuel still good?
- Fuel spraying from cylinder head.
- What makes this paper airplane flying endlessly over the heating plate?
- UMX Carbon Cub = Next Step?
- is this a good plane to knock rust off?
- Getting back into Flying
- Ultra Sport 60
- looking for first glow trainer
- Death of a Vixen
- JR Servos with Hitec receiver
- Where can I find a retailer for small planes at take os15 engines?
- Best way to clean the varnish off my engine?
- E-Flight Apprentice
- Need a hobby shop in Jax fl
- Champ replacement
- LIPO setup for Giant Scale: See attachment
- Which prop/spinner nut?
- Something about those micros...
- Enya 35-V rebuild
- I need a rx battery charger
- I think I broke your plane...
- RealFlight Simulator G35
- Issue swapping crystals from futaba 4ex to Hitec optic 6
- You know it's windy when....
- Tail dragger not turning
- new engine sticks at TDC
- Learning to Fly
- Engine Conversion
- Measuring prop???? and other ????
- Beginner at 66
- Are replacement parts for Apprentice S 15e the same as for the older version?
- Rebuilding an Apprentice 15e...what is that adhesive?
- Changed to IE to see if I can get on RCU
- What Next After the Hobbyzone Champ?? Getting Into Flying....
- Back after 34 years
- Remote glow starter charging
- Is running an upside down mounted engine different?
- Installing motor into esc on apprentice is tricky
- Do I have to use digital servos?
- Learn to fly How to video I did a few years back hope this helps someone
- coming back to flying and R/C universe after 2 years away !!! wish me luck :)
- Self-taught Flying, A Different Approach
- Posting a message
- Ahhh Stuck in Tree :(
- What's best to re-cover my ripmax trainer?
- What sort of stress will my Ripmax 40 Trainer take?
- How low should I let my fuel get before I land?
- Heres my first contribution to the forum "new plane stand"
- Dual brushless + dual esc help !!!!!!
- 2/4 stroke gasser question
- How to apply koverall?
- HI Its been a few yeas since I was on RCU
- New RC Universe
- Apprentice 15e basic Mods
- Help electric motor size for 46 size trainer
- Need suggestion on setting throws
- Long time - no RC! Various questions
- Is it possible to take off in high winds without ground speed?
- Electric Kadet Senior
- Distance judging
- Self taught flying - My diary / progress
- How do you remove cup on front of starter?
- Can I temporarily use a 11 x 7 prom on my Magnum GP 40?
- Battery charging problems
- rebuild or go with new frame??
- Is there any small fun flyer that will take all my large servos?
- 68 year old novice OH OH
- How low should I get my idle speed?
- Servo setup
- a few battery questions
- Novice seeking advice
- Stable flying 38-40" electric
- First flight on my own - attempt 2 (report and videeo)
- Simular to a bad boy problem.
- Transmitter won't charge my battery
- newb cant tune worth anything...
- Major RCU Upgrade
- Car won't start, tried everything
- glow plug for m-46 engine
- cap 232 help
- Going for first ever flight solo later. Wind or no wind?
- How do change my email address in RCUnivrse?
- cutting matts foam planes
- Further upgrading to my Parkzone P-51D Mustang BL.
- Landing gear and push fod material
- How to make cheap pushrods? .055in music wire?
- Can you make ailerons act like flaps using mixing?
- MOVED: Electric Planes at our field.
- Getting back into it
- CADET/KADET
- Runway take off trouble
- Advice for newbie
- Painted Fuse Cleanup questions
- Need engine and servo suggestions on new build
- air filters for planes
- gear for pattern
- DX6i Noisy Beeper
- Hobbyking Junkers Ju-42 problems
- Instructors wanted: ********lessons.com
- help with engine selection
- Help finding airplane scale
- first flight today!
- Spektrum DX6i no longer working - Guidance Needed
- Real Flight RC Plane Simulator
- Front steerable strut - how to
- Ultra cote and programming help
- Beginner looking for first plane
- Which is a better beginner airplane? Super Cub, or Mini Super Cub
- Futaba factory manual
- Suggestions for a beginner going solo... and a few questions!
- First Radio
- where is my thread
- Kadet Senior Control Rod and Hatch Question
- zippy lipos are they any good
- Foam Glider conversion Tutorial
- Dynam Tx As Simulator
- Our first plane
- glow fuel - what can I expect to pay?
- Edge 540 60 ARF by Seagull (SEA4000)
- Can i save a rusted nitro motor?
- Rudder mixing
- Lipo charger
- Trouble setting up Delta Wing configuration with Devo 7 Radio
- Nitro fueling question
- flaperons and spolerones
- Radio questions
- A good deal or crap?
