PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Edge - Too early?
  2. are bb servo's worth it
  3. Skylark 56
  4. Hangar 9 Pulse XT .40 arf
  5. soldering antenna wire?
  6. wrenches
  7. servos
  8. ok is this a good starter plane and deal ??
  9. Exhaust pressure line
  10. finally did it!
  11. When are glow plugs shot?
  12. Wheel and Spinner choice
  13. To foam Rx or Not ?
  14. On Off switch setup ??
  15. omnimodels
  16. Futuba 7c 2.4ghz Reciever 7 channel?
  17. cg machine
  18. Generally speaking, how long does it take to earn a pilot's licence for the average person?
  19. dirt in the engine
  20. Is this a good starter plane
  21. radio
  22. Programming Help (7C)
  23. throws
  24. Skylark 56 versus low wing trainer
  25. J-3 cub on skis!!
  26. Help with engine purchase
  27. Install of hinges
  28. first flight, first build
  29. What A DAY !!
  30. am i lucky, or does this happen all the time
  31. Gyro's
  32. help!
  33. Engine position for Topstar 60 / U-Can-Do 3D /Twist 3D
  34. Question about Tx rechargable batteries
  35. Running without prop
  36. Won't Start
  37. wing saddle
  38. H.P.
  39. Magnum Engines?
  40. Engine Starting - Stick or Electric?
  41. Question on my OS 55ax again, important?
  42. Got to try Realflight 4.5 at the LHS
  43. How do I remove the ailerons
  44. The balsa tree
  45. Found an Exide Classic 72 car battery in garage!
  46. Look at my new tx!
  47. training cord ?
  48. Titebond III
  49. Chicken Stick
  50. Wing Mounting Gasket Question
  51. Fast Charging: Quality of Charge
  52. What is the shelf life on Rx and Tx batteries?
  53. Question
  54. buckled ca hinge
  55. Balsa
  56. Money saver
  57. moving onto next plane here soon....
  58. goldberg
  59. fuel filter
  60. Eaglet 50 or PT-20?
  61. Digital Servo's
  62. Is this a good first plane?
  63. If lipo can be balanced, is it OKAY?
  64. When to replace RX Battery
  65. Micronta 22-211 Voltmeter
  66. Glow Plug Question
  67. Escapade Review in RC News
  68. servo question(s)
  69. where's the best priced 30 min epoxy
  70. It's been a while that I haven't been flying.
  71. New Seagull Edge 540
  72. New finger!!
  73. This never happened at a meeting before
  74. 10 charges and Lipo performance severely degraded!
  75. Best 7 Channel
  76. Most idiotic thing you have done
  77. TUCANO INVERTED ENGINE UPDATE
  78. Show Yourselves!!
  79. foam safe spray paint?
  80. the best workbench
  81. Back after a looooong break!
  82. Prop question.
  83. Join AMA?
  84. Prop saver attached right???
  85. Anybody play the RCU video game?
  86. Question about robart oleo struts
  87. What is the best way to paint EPP foam?
  88. How to do this covering?
  89. Wind Wind go away, I want to FLY!!!
  90. Smoke generator
  91. winds for a .60 size airplane
  92. How do you install blind nuts?
  93. RX battery website
  94. fuel proof
  95. Binding a DX-7 without a 3 wire switch
  96. Float plane video from yesterday
  97. Mustang P-51D from deprone
  98. How long can a lipo charger run off of a 12V Battery?
  99. OIL ON BALSA
  100. Why I love our club field!
  101. Problem tuning my 55ax
  102. Quality "Middle of the Road" TX???
  103. Sig Something Extra manual
  104. best motor for a slow stick
  105. New toy.
  106. Need Help to Tune Engine
  107. Is Wagner heat gun to hot for covering?
  108. control throes
  109. Typhoon maidan Solo
  110. Inverted Engine
  111. nice day at the field
  112. WARNING to new guys......Addicted !!!!
  113. rubberbands!
  114. Float Plane
  115. part for SuperTigre 61
  116. High Speed Flutter -Help!
  117. Fuel proofing
  118. improved prop balancer
  119. For an administrator
  120. 6 meter
  121. My 55ax on pulse?
  122. Triton 2 sizzled my batteries...What should I do now
  123. FP-R148DF
  124. Can Poor Solder limit draw from battery?
  125. next plane
  126. I think I've outgrown my garage!
  127. New Plane Reccomendation
  128. laterally balance
  129. NiCad Batteries mystery!
  130. What brand is this.
  131. OS Carb
  132. A step up...but how?
  133. hobbycity delay
  134. Ah! Sparks coming off my bullet heads that I soldered!
  135. Ready to run in engine...........
  136. TUCANO 40
  137. ultracote or paint
  138. paint muffler
  139. My t-28 trojan from BH models
  140. TX question
  141. Plane saving device
  142. Phoenix models Strega ARF,,,Flaperons ??
  143. engine starts backwards?
  144. CG setup Question
  145. biplane aileron servo question
  146. NiCd batteries
  147. YS engines?
  148. air or ground
  149. Pull-Pull
  150. GP PT 40 Gas to electric
  151. HELP! Painting propeller tips and balancing
  152. Good Dremel for cutting cowls?
  153. Corsair or Trojan?
  154. evoloution engine?
  155. Man!! how in the heck
  156. Surging top end questions
  157. Just put on Jett Muffler, have ?
  158. sealing iron temp.
  159. inverted to normal flight maneuver question
  160. Where is Minnflyer?
  161. Fuel selection
  162. ASP .60
  163. battery question
  164. How well will this engine work
  165. Fibreglass wing question
  166. Finally some pics of my mach 2!
  167. Magnum 4 strokes..?
  168. RPM Cessna high wing trainer 60" wingspan?
  169. prop.
  170. Astro Hog color
  171. a-10 tank buster
  172. First Time Flap Set-Up
  173. I like Horizon Hobby again!
  174. Hi-Tec RX Mini 6
  175. a mirror for a cutting board!
  176. Leaking muffler problem
  177. MINNFLYERS covering vids?
  178. Float flying success!
  179. what up with AMA?
  180. On Board Glow Driver
  181. Covering patterns
  182. Throttle servo challenge
  183. A few tips for the beginners from a fellow beginner.
  184. Balancing the PT-40
  185. Questions about cub.
  186. Help with floats please.
  187. Aileron servo
  188. 6ch or 7ch
  189. RX and servo question?
  190. Can I use a sock as an iron sock
  191. where to buy Spektrum TX
  192. Vinyl as a covering??
  193. horizion hobby value series ???
  194. Cable Length
  195. New! be warned
  196. Stryker (New Radio)
  197. uniflow the tank on a LT-40?
  198. more servo questions
  199. Fokker 7 need help
  200. Fuel Tank Question
  201. Please I need help
  202. How much oil in a gallon of fuel
  203. Guan-LI Thunderbird Power Glider-assistance
  204. Minnesota Frozen Float Fly - AGAIN!
  205. Few questions on nitro airplanes...
  206. slot cutter
  207. NexStar Maiden
  208. I feel cheated by Horizon Hobby
  209. Need help on how to cover my Sig Cub
  210. exhaust for hb .25
  211. banner towing help !!!!!!!!!
  212. what tank size
  213. scratch and dent tower hobbies
  214. homemade prop balancer!
  215. buddy box + expo
  216. Absolute genious.
  217. How do you plan you covering design?
  218. servo compatability
  219. advantage hobby
  220. UPS came! and I got some questions.
  221. What am I doing wrong?? (Adding fibreglass)
  222. Installing Servos
  223. magnetic work table
  224. GP Cherokee 40
  225. New member / Flyer
  226. Start all over again
  227. CG - How far is too far aft
  228. prop balancers.
  229. aerocraftrc.com
  230. gaint scale cloud dancer
  231. How to know where we posted?
  232. futaba receive battery????????????
  233. scratch & dent
  234. Are parkzone servos junk?
  235. Homemade stand and cg machine
  236. Transmitters
  237. strength of wood glue?
  238. Airtronics 2.4 did not do well in RCReport on 2.4's
  239. better servo upgrade from s3004
  240. reciever hitech?
  241. Need help seagull extra 300s/G90
  242. Futaba TX and JR RX compatibility?
  243. Starting engines in cold weather
  244. OS FS .91 Surpass
  245. Great Planes is GREAT read this
  246. Ultracote color choices
  247. First edf story/ tx endorsement
  248. Saito 56 mounting for SSE questions
  249. DX6i Recall
  250. Battery lead extension
