PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Lost Model Locator
  2. storing planes and equipment?
  3. Second plane?
  4. Converting trainer to a tail dragger?
  5. taxiing a warbird and taking off
  6. Fueling two tanks on my Kadet Senior.
  7. Throttle arm
  8. Rc biplane will it fly with one wing
  9. Decathlon 46 getting off Water ?
  10. Bearing noise
  11. Don't believe the CG point. Need help
  12. WL Toys V922
  13. Still looking for a wing tube
  14. My first Plane
  15. Solder Question???
  16. Blancing on CG
  17. need a wing tube
  18. second plane
  19. For the New Arrivals and some others.
  20. lipo battery charging ??
  21. Could a gyro help elderly student?
  22. Elevator Radio Set Up
  23. Servos
  24. aileron design/hinging
  25. 4s battery on apprentice 15e (vs 3s)
  26. U can do CG
  27. Gas Engine
  28. RCU Picture caption contest
  29. Improving stability
  30. pull start for airplanes?
  31. How to repair this
  32. AR600 hold problem please help
  33. Something Extra Throws
  34. Tip Stall
  35. Flutter
  36. Deployed flaps plane stalled and crashed
  37. Summer Carb Adjustment.
  38. Summer Carb Adjustment.
  39. a lesson to all
  40. Spinner size ?
  41. Engine mount
  42. flying around with flaps down
  43. oracover same as ultrakote
  44. Name this Bird
  45. anyone flying the SeaGull Cherokee
  46. Onboard glow, dummy needs help again
  47. Trim question
  48. Repairing A Hole In The Wing
  49. First plane
  50. Brake in after change bearing
  51. Inherited Eaglet 50
  52. Digital vs Analog trim
  53. Gas Engine set up
  54. New guy in East TN, What all did I buy?
  55. New to Nitro Throttle cable/pushrod
  56. parkzone ultra micro p51
  57. had a boo, boo. Need help
  58. Wing Saddle Gap how much is to much
  59. Balsa USA Student Trainer
  60. Aileron Differential on Trainer
  61. Help covering concave surfaces
  62. instructors in london ky
  63. OS 4 Stroke .91 low speed needle setting
  64. airplane covering and other help
  65. Rx battery question
  66. instructor needed in southwest mo
  67. Flyzone Corvalis 350 EP
  68. "Get on the Sticks, & Fly Right" video
  69. Possible radio electric ignition interference issue please help.
  70. What do the restorers use...
  71. Newbie flyer
  72. Replacing receiver in avistar Elite
  73. Noob Nitro question
  74. A Long Time Coming
  75. Picture of my G-Shark
  76. How do I hook up my opto kill switch
  77. DLE 30 Mysteries
  78. Electric conversion
  79. Need a canopy for aspire
  80. Teaching a friend to fly on a super cub
  81. need help
  82. Propeller mounting
  83. Twinstar Geometry
  84. clear coat??
  85. Need a book ...
  86. disassemble super tiger muffler
  87. Help: need correct spinner and adapter nut for pulse XT 40
  88. Engine size question
  89. evolution .90
  90. My first parkflier experience.
  91. Fuel filter to fit a AX .46
  92. Zurich Sunglasses
  93. I know what the kids are planning for fathersday
  94. Which stick for flaps?
  95. Cleaning motor???
  96. macs pipes
  97. Servos on Mustang
  98. What is your fuel mix ration?
  99. Monocote "jig"
  100. Stick
  101. When making a purchase
  102. Instructors, who needs them
  103. radian pro as second plane
  104. need instructor in Northeast Alabama
  105. noob from RI with a question about a used savage
  106. FMS P51 Mustang 1450 and 1700 Flight Times?
  107. Ha, ha, I went to the Toledo Show
  108. DLE20 in a Pheonix topmodel p-51
  109. basics of fabric covering
  110. Why an instructor is so important
  111. I need the plans for the fuselage pete'n'poke
  112. Prop size
  113. I'm trying to help but!!!!
  114. BRUSHED TO BRUSHLESS
  115. O.S. .46LA C/L Engine
  116. Is there an offical firebird stratos thread?
  117. Returning to the hobby
  118. Field accesories
  119. Online CG calculator vs Manufacture specs
  120. Robinhood 80
  121. Hello again
  122. Matt Chapman Eagle 580/4 /Stroke Engine
  123. CG based on change in weight
  124. OK gujys, I need help on CG
  125. 2nd airplane choice after trainer?
  126. EsC
  127. Restore shine of transmitter
  128. Kadet LT40 throttle linkage
  129. Science Olympiad
  130. Need advice on finding correct transmitter/reciever for Hangar 9 P-51
  131. fuel fill valve?
  132. need muffler bolts for ASP 108
  133. Beginner plane recommendations
  134. returning to the hobby
  135. trying to find a place to train someone how to fly in selma al
  136. New to the air
  137. Fuel Soaked Plywood
  138. Introduction and Collection
  139. throttle curve or servo limits?engine idle
  140. Anylink Problem
  141. One more question before first flight
  142. New Radio Releases Question
  143. Need help with my first plane
  144. DLE 20 Engine
  145. Putting silk on for the first time.
  146. OS Max 35AX ON A PT-40
  147. MOVED: Phoenix 30.3 & Mk4
  148. 50 sx should i yet?
  149. replace golden rod with steel pushrods?
  150. Prop Mounting
  151. Got my first plane put together, almost
  152. my return to rc air
  153. Minnflyer
  154. Refurbrishing an old airplane
  155. Another Newbie
  156. 2 tune a 50 sx with a Macs tuned pipe
  157. Beginner to RC Airplanes.
  158. HOW TO SELECT THE RIGHT SERVOS FOR MY AIRPLANE?
  159. Newbie needs help please?
  160. Have bare fuselage need help!
  161. SIG Discount Code
  162. Going flying for the first time in March
  163. 1/5 scale cesna battery/electronics
  164. Smoke & OS 120 FS
  165. Hey Folks, it's almost Toledo Time.
  166. FAST n QUICK QUESTION :D Can i used 12x8 props on OS.46 AX II ?
  167. Best deal , glow plugs ?
  168. kyosho micro props vs parkzone micro props
  169. looking at several planes, what's the best one
  170. Rotate a Saito Carb 180?
  171. I have a G-Shark that I need some information
  172. Hey all
  173. tried tinting canopy, didn't work
  174. Goldwing mx2 HELP
  175. Is all this right?
  176. Spektrum DX5e and Anylink.
  177. Need trainer/coach in Georgia or south carolina
  178. spektrum dx5e and anylink
  179. Help for NITRO Newbie
  180. Wing area calculation?
  181. piper cub question
  182. Recommendations for those new to RC Flight
  183. anyone know what plane this is
  184. Just had to post it
  185. props
  186. Trimsolvent. NEVER AGAIN!!!!!
  187. Flyzones New Acro-Wot Very Sporty Low Wing Entry
  188. Parkzones New Archer Low Wing Exceptional!
  189. New Alpha 40 Prop Problem
  190. New to electrics, need some advise
  191. Transparent Monokote
  192. New to RC Planes
  193. not sure this is OK to post
  194. OS Max 60 SR HELP!!
  195. Just bought 540qq 280 stoked
  196. Hitec HS-5245MG?
  197. ar6115e and flyzone switch
  198. JR400 tx9
  199. buddy boxing a dx7
  200. First non-trainer
  201. Noob to War Plane
  202. Spektrum DX7S help
  203. Hinging with covering
  204. Help with 2.4 radio after 17 yrs on the ground
  205. OS LA 46 revisited.
  206. Wing covering
  207. receiving post
  208. Which glue
  209. Rebuilding the Super Cub
  210. Beginner build questions
  211. It's been thirty years
  212. Help a noob get setup
  213. 1st RC Auction..
  214. Converting Hobbistar 60 to electric?
  215. how much is too heavy?
  216. First Kit Build
  217. Good Beginner plane
  218. Fixing a Bad Cell
  219. Kinda new to RC Planes,New Big Boy toy help
  220. Complete Noob Needs Help!
  221. 110FS rebuild?
  222. DX6i/AR7010
  223. Old servos?
  224. LiFe batteries on a starter?
  225. Fuse twist
  226. Getting back after 3 years
  227. looking for a buddy box
  228. QUestion about field supplies
  229. New here, getting back into RC Aircraft after 10+ years
  230. Trainer Cable
  231. carbonz yak 54 landing gear issues
  232. help with flaps!!!
  233. MOVED: do ailerons provide lift?
  234. trainer
  235. using 2 - 3s lipos to power 12v starter?
  236. A newbie goes it alone... film at 11!
  237. E sky 4channel transmitter question
  238. I did good
  239. Back in the game!
  240. Getting back into flying
  241. Sturdy Birdy II
  242. A newbie inviting criticism of his plans
  243. Wing Covers
  244. using blind nuts/securing cowl
  245. Bixler v1.1 Thoughts
  246. NEED HELP WITH RADIO SELECTION
  247. How to determine prop speed
  248. help please great planes spinner
  249. Questions, getting back into R/C
  250. CG on a mx2
