View Full Version : Beginners
- slow cooker to clean engines?
- Simple quesiion
- Tiger 2 CG help
- [help] building Extra 300s .45 size
- Different types of after-run oil
- High and Low rates
- prop chosen
- I feel stupid now, I should have known
- Engine tuning problem or Engine not idiot proof.....
- Radio-Reciever confusion
- Can anyone help me identify this biplane?
- LIPO Zippy LightMax Battery? Y so Cheap? PolyCharge4?
- need help with elevators
- Do I need a different flap servo?
- Muffler for gp-46 magnum
- !2 minute epoxy gone, nit, nada.....
- Oshkosh AirVenture 2009
- what to do
- Not sure if to buy a simulator or a new radio
- Phoenix Models Extra 300s
- would a scroll saw be a good investmet?
- 10th flight complete
- Prop for O.S. .61 FX engine
- Field Supplies
- RC Report Magazine!!!
- Glitching Problem Found!!
- Good Handheld Rotary Tool
- avistar nose heavy
- RealFlight 4.5 - Instructor Substitute?
- first ARF build
- Muduck Trainer plane?
- Saito 1.80 GK first test stand run
- Four Star 60 thrust.
- RPM vs PROP
- SULLIVAN TAILWHEEL BRACKET DIFFERENCE?
- backrest question for hog bipe
- YS63-S replaced by YS70-S - available? Price?
- Leaking saito, normal?
- Crosswind landings
- wing stress test
- When did they make the OS .46 FX the AX?
- Tack gluing question?
- Trojan T-28 Foam Repair
- Nickel-Metal Hidride Battery - discharge
- covering question.
- Tiger 2 help
- So I finished building my first kit and I feel like I am flying a used plane
- Tail Dragger Question
- It actually flies!
- smaller prop
- resins
- Super Tigre G 40 idle mixture screw
- Control issue
- os engines
- park flyer
- fixed the prob
- Battery too small for Kadet Senior
- OS 91 fx tuning problem! HELP!!!!
- I got my plane into a spin and never came out
- First Plane?
- How the heck to I put these decals on?
- Battery storage
- 40 year man in moom
- Vintage OS Motor Help?????
- Flying Instruction advice for first EDF Jet
- P-51 Stolen
- SAITO FA65
- What a great training night !!
- Rx Battery questions
- prop size?
- Help with my Sig Something Wild, er, I mean Sig Something Extra
- NEWBIE that needs help
- Most Skill Required To Fly Well?
- HOMEMADE RC TRAINER FROM WEAD EATER ENGINE
- I went to my dad's yesterday, and.....
- I want one of these!
- ready mk3 novice
- model tech blue max ??
- How to set up a 6v regulator Lipo so I can charge easily???????????????
- Second and 3rd plane.
- chargeing battery
- Battery Basics Site?
- Motor Mount
- rich enough
- help choosing battery!
- Minor Hinge Repair Hopefully
- first solo's!
- Maiden Flight/Test Flight
- maiden cap flight
- You think you have wind problems??
- Voltage too low can not charge
- mousse can question.
- A bigginners story Trainer Phoenix Classic EP
- noticed something
- Whats your dream?
- What kind of plane is this?
- aeroamphibious pathfinder
- RC SR71 Jet
- Futaba Buddy System Question
- CG balancing
- what radio should i get
- Parkzone Micro Citabria
- My First Plane
- Super Tigre 45
- Gravity RC
- Microballoons and Milled Fiber
- Mission accomplished!
- Tailgear Spring
- Finally Soloed Today
- wing loading
- Engine LOT number
- Not enough prop?
- 4 and 2 stroke glo plugs
- Engine Stalling
- Tower Hobbies TOWER Trainer 40 MkII ARF Landing Gear
- Kangke Extra 300S/60
- what prop should I get
- prop for OS .52 4-stroke
- hitec 055 micro receiver
- A first for me..
- do any online stores have cheap shipping for small items?
- Learned how not to check for leaks in a fuel tank
- Gas to Oil Ratio Question
- advice
- slow flyer prop
- Parkzone Slo V battery HELP
- Plane balancing question
- Will this cause a problem?
- Sky Fly 2 vs Aerobird 3
- Throttle Trim adjustment for idling
- Avistar taildragger question
- Super Tigre GS 51 on a 40 size plane
- Junk or worth restoring? Pic. heavy warning for slow connections!
- what engine for my hog?
- My choice for first plane
- RTF Shipping
- Pattern IMAC F3A questions
- Good trainer for ASP 32
- Receiver range
- Filling drill hole in balsa block
- paint
- Beginner??? Probably!
- fuel pump
- Safe engine mods
- The return of seemefly_1
- Mini Super Cub
- RCLander 70mm EDF F-16D Electric Ducted Fan AirFrame Kit w/ Retra
- Plastic pushrods
- Engine mounting
- spot my Cap232
- Sometimes you have no choice but to teach yourself
- Cap 232
- No more Aerostars?!!
- Charger settings on Swallow AC/DC 2
- the Cub Curse is over!!!!!
- Prop Spinner Size?
- Anyone use anything for eyes when tearing?
- FUN FLY ROCKS !!!
- Binding AR6100e
- RC TRAINER FROM SCRATCH
- pushrods for Avistar
- trainer help!
- GP .40 Cub CG???
- HS 82mg servo Buzzing
- 2009 RC wish list - whats on yours?
- CA Disaster HELP
- You never know who is reading!
- SIG Kadet LT-25 engine oddity ...
- lipo battery question/explanation
- Why we do pre and post-flight inspections
- Thumb rests for your transmitter sticks.
- Getting ready to put together my new toy
- A little problem
- Help! E-DOMODEL F-15E
- landing gear
- Help choosing my next Tx
- Trials and Tribulations of a self taught flyer
- SuperCub LP.
- First solo flight
- Looking for suggestions
- can you use JR servos with Futaba receiver and tx??
- Perfect night for flying
- What engine should i put in my Kadet?
- Pattern Flying
- Twin spad
- Summer Heat
- number of club members and flights
- Radio/Plane for a new guy
- Beechcraft Staggerwing Help
- is this motor ok?
- rx antenna
- New Bearings
- Hobby People
- Should I have not flown?
- JR XP8103...is it worth converting to 2.4
- Tower Hobbies
- Hello from the twin cities, minnesota
- Do I have to use an actual retract servo or not?
- first cub
- problem 2 or 3 blades
- TS 40
- pitts muffler exhaust nipple
- Good prop size for OS 61sf?
- Cant shut engine off in flight?
- PCM- Is it worth it?
- 2nd R/C plane
- 1st contest, 3rd place...
- Good engine for Senior telemaster?
- Super Sportster40 turtledeck covering
- Speaking of Hobby Shops...
- New Hobby Shop in Bradenton, FL
- servos
- decals
- Timer recommendations
- Tips for first four stroke please
- Check out this little jewel!
- need help cox motor
- Creating a "portable" runway out of my farm!
- hand launching
- What is the suggested and maximum wind speed for beginners? Poll=Max
- High altitude ???
- stripped blind nuts..
- Scales ?
- Another Newbie
- Servos
- why after run oil should be used
- Phoenix model Trainer 60?
- How to takeoff a Piper Cub?
- Total Weights Influence
- Will this engine be plenty of power for FW-190?
- Lawn Darts, Part 1 and Part 2
- Building a fuselage for my 2nd wing
- New Plane
- How many rubber bands? and what do you think of this?
- MDS engines???
- dark fuel problem at half tank
- new in rc gas planes any advice
- Phoenix Extra 300s ARF Engine
- 40%
- 2.4 or 14 MHZ??????
- 1st R/C plane
- Mini Super
- Waht determines a plane's size?
- SuperStar 40 Covering issues
- good battery checker?
- muffler temp
- Club trainers. How do you manage them?
- Just picked up a GP Big Stik 60! Engine Recommendations?
- Safety Equipment - Whatcha Got
- Flying on 72 or 2.4 ?
