PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Power Z rc plane I need info please
  2. is this all i need?
  3. firebird xl cg
  4. Switching to Glow: Now, Avistar, Superstar or Tower Trainer?
  5. extending the batt wires
  6. New Club Forum Opens....
  7. I need help
  8. where do the wires go?
  9. AM/FM radios
  10. Hobbico® FlyZone™ Aero Cruiser EP RTF A good first plane or not?
  11. Fuel metering device
  12. Beginner, which plane? YELLOW BEE or DRAGONFLY Plz help
  13. First Solo...not pretty!
  14. What type of spray paint for foam??
  15. Gas or electric. New to RC Planes Not sure what to buy.
  16. I'm new......what plane should I buy
  17. Too Lean Or Too Rich
  18. i'm a begginer
  19. First time on the sticks.
  20. need linkage adapter 2-56 to 4-40 both ends male
  21. I solo'd my plane
  22. Need info on Royal Air 20T
  23. my 1st sports trainer!
  24. flip starting with fingers,,,please be careful
  25. slow poke trainer or not ?
  26. good combo?
  27. Sheesh !! Slow Stick
  28. 4 Star 60 Pilot
  29. Help with starting
  30. Best Glue And Paint To Build Flight Box?
  31. About to take the plunge [again]
  32. 4 Star Maiden
  33. Would a great planes p-51d mustang be ok for second plane??
  34. Can I switch from am radio to fm??
  35. Can someone give me some tips on flipstarting an engine.
  36. advanced trainer question
  37. Battery Cycling
  38. thunder tiger screws
  39. OS46FX - Throttle Stop Screw - what does it do?
  40. Is this combo a good deal for a begginer??
  41. Help electronics on SLOW STICK ??
  42. way out of my league?
  43. OK! It worked Great!
  44. large prop belt drive on electric plane
  45. help me cove my plane
  46. Kyosho trainer tips?
  47. Old School vs. New School Club Members?
  48. running down the batts?
  49. Thanks for the help!
  50. Identify this plane, help?
  51. Cool Power vs. Mach 7
  52. Hooking up
  53. hi ppl this is 2nd kit
  54. I just bought my third plane, a CAP 232... mistake?
  55. how much wind is too much
  56. conversion of trainer to taildragger?
  57. landing and balancing
  58. ..Product Information Request..
  59. Airplane Choice
  60. ModelTech PT-17 (stearman)
  61. What could be the cause of this?.
  62. Any advice for me???
  63. landing nose over
  64. Glow Plug--Fuel--Prop Recommendations
  65. T8UAPS Help!
  66. Hard Starting
  67. PT 40 Rolling to the right
  68. A good second plane?
  69. Buddy Box Trims- WAY OUT
  70. Airplane Storage
  71. Small holes in monokote
  72. US 40 and Irvine 53. What size prop?
  73. supersportster
  74. Rubbish Turning
  75. sig 4 star 60
  76. INFO NEEDED spad for the beginner
  77. Avistar 40 Trainer
  78. New to RC planes need some info.
  79. Please help with Gap Sealing, Yes I've done a search!
  80. Gearbox For Superstar EP?
  81. Another Day, Another Lesson
  82. Things all should know
  83. OS40LA Help, please...
  84. Olympic 2
  85. What is expo?
  86. PLEASE HELP: jump start and other batteries for field charger?
  87. Twin engine JU88
  88. How many solos on trainer before moving to first low winger?
  89. why does my trainer climb so much?
  90. judging distance?
  91. glow or electric
  92. Help Building From Kit!!
  93. Supportive wife
  94. shaping leading edges
  95. Hey Razor
  96. Prop Balancing
  97. Warning: Ground Check
  98. Crash & Burn... my first.
  99. Coordinated turns with rudder/aileron
  100. Prop Size question
  101. Dave's Airplane Works Sailplanes
  102. advice on SIG Rascal
  103. VERY lucky learning flight
  104. Should I fly on the beach this weekend?
  105. Should I measure the CG with a full or empty tank?
  106. Aerobird - A great first or second plane
  107. I flew my 4*60 maiden.
  108. Spray paint foam? HELP !!!!!
  109. TX/RX question
  110. Another lesson learned
  111. castor as afterrun oil
  112. Need help in my first low wing!
  113. Is SUPERSTAR SELECT ep a good starter??
  114. good choice
  115. Linkage Question ? Hobbico arf trainer 40
  116. Another Newbie!
  117. Thunder Tiger Champion 45L
  118. Radio channels
  119. Hey! I Soloed
  120. Does anybody know of any good free rc sims?
  121. Computer Help?
  122. Ripped off by the AMA ?!?!
  123. Fuel Question
  124. noob question
  125. Any San Diego flying clubs?
  126. Avistar coming along, should fly this weekend!!
  127. vibrating plane
  128. BE AWARE The Gremlin
  129. OS .40la And T.H. 40 Kit
  130. Purpose of air bleed?
  131. Landing
  132. How To Break The Engine IN
  133. blind nut repair
  134. sad...too much power and you get a folded wing...
  135. Simulator helps or not ?
  136. Sig's LT25 -- you can't go wrong
  137. Cloud Dancer 60 from plans...
  138. Solo.
  139. megatech m46 engine problems
  140. Who says flying is difficult?
  141. RealFlight and the Avistar
  142. Forum question
  143. looking for my 1st low wing plane?
  144. My stick flies!! First symetrical airfoil plane....
  145. im glad i didn't get a avistar
  146. Meter on power panel question
  147. Best Cleaner at the end of the day
  148. need advice
  149. Best Prop Size for an O.S 40LA
  150. Question about the battery for an elec sailplane
  151. Decent 2 channel glider designs?
  152. Monocote, Ultracote, second cote ...
  153. How much weight did it take to balance your Kadet Sr
  154. Help with prop selection
  155. Left or Right Handed Question
  156. I took off,landed,did loops,rolls all kinds of stuff!!!!
  157. Converting Aero Bird receiver
  158. Searching for best 2nd Plane
  159. what should be my next plane
  160. Moving to gas
  161. Flying with rudder!
  162. should the engine be idling or above while landing?
  163. Tower Hobbies .46 Abc Info.
  164. post pics of your trainer planes!
  165. Saito 30 4-stroke Break In
  166. OS 40La Glow Plug
  167. Stupid move
  168. Engine comparison
  169. Solo! Another vote for RealFlight...
  170. Good Deal Gws Planes !
  171. Life of Battery Charge???
  172. Batteries
  173. monokote
  174. chicago aerosport
  175. solooooo!!
  176. Question for GrnBrt
  177. Sig LT .40 with OS .40fx
  178. Torn Monokote
  179. Saito 100 Break-In
  180. Engine Loading
  181. Repairing wing cover, Monokote
  182. WOOOHOOO Tok the Plunge :), already hiding receipts
  183. Is realflight worth it?
  184. exhaust deflector
  185. ASP .61 New Got if with plane... Is it junk or ok to run?
  186. get an instructor
  187. Help with speed...
  188. Hi! everybody! I am hobby in Peking China!
  189. Tint canopy
  190. beginner's questions
  191. Got my wings!!
  192. Propellers and Engines
  193. CG limits... Close enough??
  194. Glow Plug Question
  195. Mixing for newbies learning ( should I ?)
  196. World models Extra-300?? (40 size) C.O.G
  197. Need help on Field equipment basics
  198. Servo question
  199. Newbie with a glue question
  200. Instructor In Illinois
  201. im bored
  202. Megatech Sucks!
  203. ummmmmmmmmm other acseesories
  204. Took the plunge
  205. C.o.g.
  206. Super Thin or Gap Filling CA for Hinges?
  207. Tachometer
  208. How to make the Plane Smoke
  209. PC Interface for Futaba Radio?
  210. Company Logo's on a Plane
  211. Somethin´Extra!
  212. Hobbico SuperStar 40 Select RTF 60"
  213. Cheap and easy in air ??
  214. What can be used as hinges?
  215. How do you get people interested in flying??
  216. best product to clean off planes
  217. flaperon mixing question
  218. GS 300 STUDACHER( good second plane?)
  219. Is there a print view in RCUniverse?
  220. Aerobird !!! Sweet for beginners !!!
  221. Park Flyer Suggestion PLEASE
  222. Total Noob. Can only get my COX .409 to run for 20 sec.
  223. 4 stroke on a CG Tiger 2 ??
  224. Hog Bipe question
  225. Engine problems.
  226. Wing bent opposite way... anyway to fix?
  227. 2nd airplane for windy location
  228. Could soneone suggest a plane for me please? (slightly unusual application)
  229. What is the maximum wind a 46 size trainer can handle?
  230. Transmitter cases on the cheap
  231. Finally... a clean flight.
  232. OS 46 LA dying
  233. 6 yr. old son fly's rc trainer
  234. New with questions on prop & starting
  235. Model Tech Dragon Lady 60-90 arf Opinions on plane?
  236. 540T can it be a second plane with good Instructor help?
  237. YESS!! I flew my Firebird II
  238. Beginner with good skills Next Step?
  239. servo setup
  240. Four Stroke!!! OS or SAITO????
  241. OS 40 FX Mixture screw,where is it ??
  242. i finnaly got to fly today :)
  243. another OS FX 40 ?
  244. First Flight
  245. Solo'd straight away ?
  246. trimming
  247. Problems with OS 40 FX
  248. First Flight
  249. Plastic spinners with aluminum backplates
  250. how long till solo after landing?
