- FIRST PLANE!!!!!!!!
- Satio 100, RPM?
- LT-40 Flaps
- Pics of Alpha 40 conversion =D
- Whats been the biggest effect of 2.4 ghz
- Got Wind?
- Help with G4 demo!
- Want to convert my PT40 to taildragger
- HELP: Engine To Engine Mount question
- Telemaster 40
- Coming back after 18 years - PT-40 build
- quick question.
- H9 Pulse 40 setup question
- TX DAMAGED NOW, WHY????
- Plastic cages on rear bearing
- Evolution 46 Stalls in turns.
- plane building
- field box
- CG explained
- Did I ruin my battery?
- Flying Thingz
- What website do you guys frequent?
- 2008 Internet fly in
- Just a note for newbs
- Battery charge puzzle
- Second Plane advice
- Guillows Giant Scale Balsa F4U-4 Corsair
- Second plane...should I do it?
- Started my buddy's KAOS
- WooHoo finally soloed
- First Flight !
- When should I buy a Hangar 9 showtime 4d
- How hard is it to fly a great planes L-39?
- Prop question?
- Easy covering Idea
- futaba or Spektrum 2.4?
- Elevator/Lift question
- Ball-end hex wrenches vs. regular
- best glow trainer kit
- Off the cord today!
- Tail Wheel Help
- Video: First flight in my new Arising Star Nitro Trainer!
- Small nitro plane... (.25 size engine and under)
- Alpha 40 into tail dragger Q's
- engine spacing
- Fuel Leak Inside Plane
- going gas???
- tiger 60 build question
- prop vs jet
- Hangar 9 pulse xt 60
- Breaking in a new engine
- Screwed up - need advice
- When should I buy a 2nd plane?
- Duties of the safety officer
- DX7 Throtle conversion
- Air filter?
- Modeltech Blue max???
- Where can I buy a hangar 9 pulse xt 60
- Hangar 9 tango 40???
- GP Electricub on floats
- Mixing fuel?
- Second day
- which one
- Finaly Sticking the Landings!!!!!
- How to determine if piston and liner need to be replaced?
- What can I use to cllean the face of my 9cap?
- ARF predrilled holes in root ribs???
- Interface cable for Flight Sim
- Magnum Pro 46 won't transition
- Factory low-speed needle setting on Saito 100?
- Dry cell Glow starters
- engine mount question
- megatech freedom flyer trouble
- REPLACING BATTERY
- Charger question (please help):
- HELP! Glue disaster
- Spinner will not fit APC prop?
- I just noticed
- First Solo Flight!
- HELP (plane crashed )
- spektrum dx6i throttle stick
- Hangar 9 pulse xt 60 ????
- Joining a club
- Not that handy, man
- BAD Day at the field
- F-22 .61 prop selection
- Radio and glo ignitor battery questions:
- Help setting up a SX600 radio.
- Seagull Space Walker 2
- Please Help
- First Flight
- looking to get into planes
- Problems with covering corners
- which engine is better
- sig four star 120??
- A GOOD 2nd PLANE
- needing a part, where to go?
- Ascent Glider Overkill / Thoughts?
- Seagull Models
- Infiltration factor
- Engine rating and quality
- Another "Is this plane a good start for me?" question from a newbie
- FIRST YAK 54 WHAT'S THE BEST 4 THE MONEY!!!
- Sig S.E. quick ?? about wing tubes
- "Second Plane" build thread, what do you think?
- wing bolt block question
- Club Rules
- Help with engine install
- Which plane could my brother begin on?
- Whats the most usefull thing you can have in your flight box?
- Wheel pants
- Engine mounting question
- Economic Stimulus Act of 2008
- Set Up Help
- Prop for a Pulse XT 60 w/ Evolution .61?
- What have ya got in yer flight box?
- Another " I FLEW AND LANDED SOLO!" thread
- Drunken Leading Edge JOB
- os 46 getting air
- I flew SOLO today!!
- OS .46 problems...
- Hanger Arrow vs Avistar vs Tower Trainer
- Why would I want a 4 Star .60
- Have you ever purchased a used trasnmitter to save money?
- OS 50SX HANGAR 9 PIZAZZ WHAT TO DO????
- What is a good 2nd plane?
- DX6i Spektrum transmitter"?
- Tower Trainer RTF Problem
- A Bad Series of Events (And a lot of stupidity)
- Pulse XT 40 or Ultra Stick 40?
- Help deciding number of channels.
- Radio Upgrade
- Beginner Plane 4 channel
- Titebond lll Glue for wood aip plane making
- What is up with Hanger 9 and their lack of inventory?
- Newby screw up. Aaaaarrrrggghhhh!
- Fail Safe Gadget Poll
- Taxi cub 2
- Will this plane take my O.S. .40 LA?
- WHo makes the better motor?
- 4 Ch electric foam Cessna (for beginners)
- Got most things narrowed down!
- New to planes what should i get for cheap?
- Help with turning??
- Boomerang trainer went in big time
- Who has a CC Lee C17E Biplane? Advice?
- Thinning Motor Mount
- engine for stinger 40
- sky fly prop help
- The moment of truth
- skyfly versus kyosho Calmato 40 RTF Trainer
- trying to decied on engine for tower trainer 40
- ultra stick nose heavy
- hangar 9 tango
- Fuels use... traxxas to use in airplane engine...
- Tough time today/Experience beats Knowledge
- another spektrum radio ?
- Tiger 60 2nd plane material?
- power system for foamie
- Cheap Alternatives to stuff at the hobby shop
- Question about Super Tigre .61
- For Evolution 46 Owners-Limiter Removal
- Tower Trainer vs Avistar
- Batteries
- Replace battery with two smaller???
- Radio gear for Avistar ARF
- Alpha 40 into a tail dragger??
- avistar into a taildragger
- Again, I would like some advice
- UP-START OR HI-START
- airtronics rx
- Nexstar veers to the right.
- ST-40 needs new battery pack
- Hoping to resolo tomorrow! (solo'd!)
- Hangar 9 pawnee 40
- What spinner for an 11x6 prop?
- Nexstar.....Tail-dragger ? ? ? ? ? ? ? ? ? ?
- Hobbyzone supercub ESC/transmitter burn up?
- When you buy RC gear do you shop price or brand?
- My Evolution .46 Engine wont get up to full RPM???
- Tower Hobbies .61 tight after storage
- Nexstar Prop Replacement?
- Learning to fly is going to be alot harder than I thought.
- changing valve springs on Mag. 70 4s
- hole in wing
- Upgrades for evolution engine? UPDATED AGAIN
- broken transmitter antenna
- Needle limiters on .46 evalution engine?
- 46 LA fuel?
- new 46AX
- DX6i verses JR Sport SX600
- UltraSport40 Nose weight
- Landing Practice
- Nitro eng doesn't need timing devices,why?
- spektrum radio ?
- LANIER CG point???
- Question About Elevation and Engines
- Will this work?
- aileron adjustment?
- How much fuel?
- hobbico avistar
- Cannot tighten Prop!
- Hanger 9 mini tach
- Kadet lt-40 ARF - Joining Wing Halves
- Tower Shipping Charges?
- Hanger9/Horizon Customer Support
- How is Wing tip Laminating Done?
- How is my money better spent new recevier or new radio and and reciever
- MY US 60 FLEW TODAY!!
- is this a good price for .40 trainer?
- I DID IT!!!
- Fuel
- Brakes?
- Airplane Storage?
- Magnum 70 4s ?
- 250$ for alpha 40?
- Starter problem at the field today
- STILLL not soloed
- battery for plane
- hole in wing from minor crash
- EFlightWiki
- JR sx600 Transmitter
- Servo choice for 60 size plane
- RX battery pack for 60 size warbird
- wire strut coils
- high speed needle extension: cowl
- Hooking up Dual Elevator
- GLOW or Electric debate.....Who won?
- Help Wheel Collar Sizes
- FMS simulator
- windsock
- COWLS & ORACOVER
- Hurray!!!!!
- Throttle linkage
- ultracote question
- Thoughts on this charger?
- Taking off on a bumpy grass field
- closing off a 3 line tank?
- RX REPAIR
- Instructions/Hinge Scan- Questions
- Throttle pushrods to flexable on my Kadet Sr.
- 30% NITRO (TO MUCH)?
- Hanger 9 F-22 Raptor/P-51 Mustang PTS
- Whats best buy the radio you can use now or buy the radio you can grow into?
- Receiver type
- Who knew what they were getting into with this hobby?
- BEC
- Tower Trainer crash and repair. or not!
- How to fashion a new leading edge?
- planes and parts
