PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Do fly it or not?
  2. Clear coat or clear covering for wood?
  3. Typhoon 3D - Where is the CG ???
  4. 2 maidens in one day!
  5. Car fuel in a 25?
  6. S/D Conversion
  7. Beginner Radio Question: Dymond?
  8. Where should the CG be on a custom plane?
  9. pitts muffler for magnum .46
  10. Quick Question
  11. What Radio system fo my trainer??
  12. ARF P-51D 60 For newbie.
  13. Tri - to - Drag
  14. Propellers
  15. OS .61 and Goldberg Aniversary CUB
  16. Evolution .46 inverted?
  17. Please help with this decision...
  18. futaba plane battery charge time
  19. Hobbico Quick Field DC Charger MKII 12 Volt
  20. How do I lock Mechanical Retracts?
  21. Charger Solution
  22. Sig Somethin Extra questions
  23. stupid question but thats life
  24. Need the Kyosho Kalmato manual
  25. Smallest trainer available to UK
  26. having a problem with my supre tigre 46 dying
  27. need help choose my first plane
  28. Newbie, Wanting Advice on Radio and EasyStar
  29. Sterling Stearman P 17???
  30. Tower Hobbies brand quality?
  31. Super Tigre .40
  32. radio's
  33. RCKen
  34. Need a little help
  35. How small a plane for a .40 engine? (reasonably)
  36. Winter flying?
  37. JR SPORT 6-CHANNEL SYSTEM MD2
  38. Micro receivers in standard flying
  39. What Is a Left Hand Person Suppose To Do?
  40. Engine cuts out
  41. Thumbs are twitching...
  42. What characteristics for good knife edge?
  43. nitro model rc planes
  44. Bought a Sig Hog Bipe and want a four stroke???
  45. Finally organized my garage!
  46. Hmmmmm, need help/ trainer built
  47. First Solo
  48. Aerobatic Day !!!
  49. Still a new pilot,but want a new plane
  50. I need help picking an engine
  51. I have a question about the alpha 60 with the evo engine
  52. help!!! what do you think?
  53. Nexstar
  54. FLEX-ZAP II
  55. Change your rubber bands...
  56. What about a space walker II
  57. Stupid beginner question
  58. Motor placement for a beginner.
  59. first contact
  60. Carbon Fiber
  61. Battery Charging
  62. Royal Air 40T--no instructions
  63. First Timer at Pull-Pull Cable
  64. can anyone help???
  65. wondering how to.
  66. Toothpic scratchbuild
  67. Avistar assembly question
  68. 2nd plane
  69. Sig Hog-Bipe ???
  70. Radio Advice
  71. Need a nice RTF beginner plane
  72. Velcro, Adhesives and Balsa--do they mix?
  73. Engine for Goldberg Eagle 2?
  74. 6V receiver pack question
  75. Hangar 9 Texan???
  76. Avistar vs Superstar
  77. OS .35 FP
  78. A reluctant question
  79. New Tower Trainer
  80. 1 dowel mounting to 2 dowel..???
  81. Thinking about my next plane
  82. Flapperons/spoilerons which is it?
  83. Seagull S Decthlon
  84. Just another day at the field
  85. R114F for large plane?
  86. Covering Tools
  87. help
  88. The wall of shame
  89. PATTERN FLYING HELP
  90. PROGRAMMING PROBLEMS
  91. Servo Extensions
  92. Four *60
  93. 2nd plane
  94. Where to start?
  95. Good charger
  96. Stearman vs. Super Stearman???
  97. P-51 PTS ARF instead of RTF?
  98. RECOVERING A PLANE AFTER CRASH
  99. Nexstar vs Avistar vs Magister
  100. os la 40, what prop?
  101. Funtana 90 question
  102. I nearly decided on my second plane - just one letter difference now
  103. antenna wire/pushrod tube?
  104. i need some advise
  105. where to buy planes/parts online?
  106. Hobbico Sky Pilot EP 3-Channel RTF???
  107. My first build (pics)
  108. Which Li-Po in GWS Formasa
  109. My first plane
  110. No Instructor - Need a Sturdy Trainer!
  111. tx problem?
  112. In flight CA hinge failure...
  113. simulator
  114. 360 video ?
  115. dolphin? good second plane or not?
  116. conversion project please help
  117. Setting incidence of trainer wing.
  118. terminology list?
  119. Alpha 40 RTF
  120. any good sources for crash repair?
  121. first nitro trainer
  122. Getting Gas
  123. I forgot to mention...
  124. cost of a flight instructor?
  125. Hanging plane from ceiling
  126. Flew my nexstar a few times today
  127. JR Radio with Hitec receiver?
  128. which to get?
  129. Planes in the Attic for 5 years....
  130. beginner needs help!
  131. Basic arcobatics.
  132. USING THE CENTURY ELITE 6CH FM HELI RADIO FOR OTHER APPlications
  133. I soloed
  134. RX questions
  135. P-51 PTS trainer = must right rudder?!
  136. Plane types
  137. motor placement
  138. Exhaust Deflector - loss of power?
  139. High/Low Rates - what's the purpose?
  140. OS FX Max Engines
  141. spinner for p-47 40 size with magnum .46
  142. charging gell filled field box battery?
  143. Props: Master Air Screw VRS APC etc.
  144. Hotstik Problem!!!
  145. Dolphin 40 landing gear
  146. Bigger engine on P-51 PTS RTF?
  147. Sterling Stearman P 17 ?????
  148. My first Nitro Plane
  149. Hobbico Nexstar lessons learned the hard way :-d
  150. P-51, Final Flight
  151. TX Question
  152. .25 size engine on a .15 plane
  153. Retracts for a 40 size p-47
  154. Extra with 90 fs
  155. I bought my second plane and did not fly the first one yet!
  156. Flew the hotstick 46 for the first time.
  157. Futaba PNP
  158. fixing styrofoam: how and what glue?
  159. Extra deep sound of a four stroke????
  160. WHOO! Yeah! Dublin Rocks!
  161. Different Banana Plugs?
  162. Weekend is almost upon us...
  163. Rossi Exhaust Issue
  164. Pinned Hinges ?
  165. OS .91 Muffler - Do I need the extension?
  166. Spinner, propeller... everything went off!!
  167. Second Plane... Something big?
  168. Well I bit the bullet!!!
  169. Vlach ignition
  170. Nexstar Select wing tip extensions
  171. Changing TX channels, Myth or Fact?
  172. 2nd plane
  173. JR 6102 Questions
  174. RC Revolution Engines
  175. FM and PCM difference?
  176. Hey Hogflyer!
  177. A couple Super Tigre .46 questions
  178. Multiple Models - new radio gear??
  179. Trimming a new plane!
  180. OH SNAP! WHY?!!!!
  181. saito 100 wont idle
  182. Good Trainer/cheap?
  183. Engine burn in on bench
  184. newplane
  185. Another maiden!!
  186. Upgrades to the SkyFly
  187. Propeller crash course!
  188. any info
  189. Chicken Sticks - Why?
  190. Muffler leaking
  191. Sig Kadet Senior
  192. Engine problems!!!!
  193. Crash of the Avistar
  194. Making a wing sheet out of fiberglass
  195. whats the best plane to learn on
  196. Flaps up or down?
  197. starting question
  198. What plane to buy after 7 years out of hobby...
  199. PCM Vs. FM Radios
  200. Hangar 9 Twist 3D
  201. Range check each flight or day?
  202. etBouncing Landings - Cure?
  203. Hitec 635HB Good/Bad?
  204. Sig senior ready to soar
  205. Hangar9 P51 trainer motor size???
  206. What is the best glow trainer for under $400.00
  207. Goldberg Eagle 2 ARF trainer?????
  208. Charger
  209. Fuel Tubing for OS .91 Two Stroke
  210. High winds + "Watch this"... = ... :(
  211. Beginer questions
  212. servo arm?
  213. Finding a flight instructor???
  214. Questions for RCKen or anyone who can help??
  215. In need of your opinions.
  216. Extra 300 rolling while doing a loop
  217. Hangar 9 P 51 trainer??
  218. new plane
  219. Putting on steel clevis's?
  220. GreatPlanes RealFlight G3
  221. Another c of g question
  222. Strut Bending Tool - CRC ?
  223. GP Extra 300s and weak firewall ???
  224. Sorting out my shop
  225. z bends
  226. Field Box Schematic Needed
  227. esky simulator downloads?
  228. Control set up
  229. Cheapest way to balance an electric prop
  230. on board battery checker problems
  231. Engine stalls when plane is climbing
  232. monkote trim sheets
  233. After Run Oil
  234. music wire dimensions
  235. saito 72 won't idle
  236. Please stop raining
  237. center of gravity
  238. what exactly are flaps for????
  239. Second plan? a scat??
  240. New to RC Airplanes
  241. Motor won't turn!
  242. Engine mounting position.
  243. servos and glow fuel
  244. How hard is it.....
  245. Kyosho Oxalys : second plane help wanted
  246. how much is enough?
  247. Sportsman Aviation F4U, Power: 52-61 two stroke, 70 four stroke
  248. O.S. FS-91 II Surpass w/Pump
  249. Installing R/C equipment
  250. SkyFly camera setup
