PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Nexstar Flaps
  2. U-Can-Do 3D 46 need nose weight?
  3. 3 line fuel system setup
  4. How do I setup side by side servos - LT40
  5. First 4 Stroke
  6. Bigger wheels or smaller prop?
  7. Warped Aileron Need Help!
  8. Sig 4*40 vs 4*60
  9. Evolution 61 NT
  10. Model flying schools ????????
  11. How long did it take you to solo?
  12. I messed up my aileron
  13. I Finally Did it!
  14. Battery Check
  15. Great Planes Super Sportster 40 MKII as a second plane
  16. Great Planes Super Sportster 40 MKII as a second plane
  17. whats a good second scale-sport plane to buy
  18. Airfoil / wingload questions
  19. Vmar WEBSITE
  20. Remote and Engine Question for 300S
  21. Need tips for LT-40 Taildragger Conversion
  22. Frame for carting around plane in back of pickup???
  23. Please Read
  24. 6 flights in with instructor
  25. Please read
  26. Prop question. APC vs Master Airscrew
  27. Gaps in my Canopy
  28. JR and Futaba Compatibilty
  29. Training on the sim
  30. Engine Problems (Again)
  31. newbie never flown
  32. Vibrating Kyosho Trainer 40 problem
  33. avistar
  34. Simple glowplug-question
  35. Performance Mods for Glow Engines?
  36. Elevator CA Hinge Problem
  37. How to balance a prop??
  38. CG on Hangar 9 cap 232 40
  39. Tail dragger repair
  40. FOUR STAR WEBSITE?
  41. Parkzone F-27 Stryker
  42. What is a ballbearing servos?
  43. buddy lead
  44. Control throws on an older Kit
  45. Second Plane
  46. Need Help (Flair Junior 60)
  47. 10%
  48. I think i just wasted $90 on a flight pack
  49. Something Extra Engine?
  50. Can ultracote be applied over monokote?
  51. soloed today!
  52. Payload Question
  53. Which Trainer?
  54. Just Ordered First Plane
  55. AERO WORKS 540T
  56. Biggest Trainer?
  57. For all you aeronautical engineers
  58. Help With Twinjet
  59. okay i think i have it under controll
  60. beware when buying new battery packs
  61. Maiden Flight of my PC9!!! (Pic)
  62. Can I switch from PCM to PPM??
  63. What Are the Risks!?!?!?!
  64. Saito ?'s
  65. Need advice for a beginner friend of mine?
  66. whats a good second plane???
  67. Finally Solo'd
  68. 4*60 ARF ready:-)
  69. Battery question
  70. Aerobatics/throttle ATV.
  71. Is this a good engine
  72. SuperSportster first flight
  73. Lost AMA card
  74. Method for mixture valve/idle adjustment
  75. how do I convert a trike trainer to a taildragger
  76. MOVED: what to buy?
  77. Pheaton II Biplane
  78. Charged receiver battery but didn't fly today
  79. To those of you who dont have enough money
  80. no crystals at LHS
  81. Problems starting engine
  82. Ugly stick..
  83. I need to built a hangar!
  84. Transporting RC airplane fusalage
  85. Radio wont pass range check
  86. Somethin Extra
  87. How long does glow fuel last?
  88. Engine Torque
  89. newbie first flight and engine question
  90. goldberg tiger 2
  91. Saito FA-65 for UCD .46
  92. Battary discharger question
  93. next plane?
  94. Lazy Engine
  95. Sport plane as a 2nd??
  96. a little something i build for breaking in and running engines
  97. Old guy coming back to the hobby :D
  98. Second Plane
  99. Where To Buy Nitro Online???
  100. First Solo.....First Crash
  101. radios
  102. are any of you scared to fly?
  103. CA Glue in a blind nut??
  104. Plane Continues to Climb?
  105. Sky Raider Mach-II
  106. Just realized about flight packs....
  107. question about cleaning agent and antenna tie off
  108. I flew my Engine (Close call)
  109. Question about CA hinges
  110. To start an engine.
  111. tourer to monster
  112. What plane is this?
  113. tuning engines
  114. Hotshot Glow Starter
  115. Talking about fields
  116. prop size
  117. RealFlight Trim schemes and templates
  118. What fuel to use when braking in O.S.LA?
  119. After I master the trainer what is a good starter prop jet that I can buy?
  120. Spinners for APC Props
  121. GWS Beaver Pulls to Left
  122. Don't buy the Aero Cruiser.
  123. Changing fuel brands
  124. SIG website ?
  125. Engine Care !!! ( After A Day At The Feild )
  126. SIG SE question.
  127. [Hopefully], final questions on my Sig 4* 40
  128. Help with plane stats
  129. Sig Kavalier conversions/mods
  130. Beginneri R/c Plane
  131. Need fuel line advise
  132. Privately developed Rocket Plane Scheduled for Launch Mon. June 21
  133. Hobbistar or Superstar
  134. interesting questions on gaz motors for quadrocopter
  135. Using buddy boxes
  136. a bolt of lightning and a puff of smoke.
  137. Flight Simulator for custom models?
  138. Setting up a Magum 40 engine
  139. Back in the loop, i need some suggestions
  140. 2nd Airplane
  141. How often do you Fly?
  142. Where to shop
  143. Servo Question
  144. ON / OFF switch. Yes or no?
  145. TS91AR .91 engine
  146. I got a Hobbico Nexstar, what should I do to make a trainers life easier?
  147. LT-40 taildragger conversion DONE !
  148. wind maps?
  149. What would a negative dihedral do?
  150. Newbie needs list over reg. fieldequipment
  151. Wing balancing question
  152. newbie to planes not R/C.
  153. Cutting grass
  154. nova 40 trainer problem help!!!
  155. Arrow wing bolt conversion
  156. Spinner Question
  157. Handle the wind
  158. Handle the wind
  159. Building aircrafts
  160. Help, E-starter weight, what is good?
  161. Converting my alpha to a tail drager?
  162. R700
  163. New flying partner
  164. What should I do with a Trainer plane.
  165. exhaust deflector
  166. Pt .40 wing on Superstar?
  167. Starting up New website!!!!
  168. Quick repair ?
  169. frequency problem...
  170. First Airplane engine
  171. twizzlestick
  172. Real Flight G2 question
  173. NiMh Batteries
  174. Making my own batteries
  175. OS 46 LA problem continues, with head picture
  176. Hangar 9 sport Cap 232
  177. MUST use epoxy?
  178. Houston, we've had a problem!
  179. 1/5 scale Cub, full or clipped wing?
  180. Havent flew in 2 years.
  181. What 4-Stroke replaces a .40 2-Stroke?
  182. Last night
  183. warp in my wing.
  184. 4*60 Unlimited vertical?
  185. Types of Engines
  186. RX Battery
  187. Accipiter Badius
  188. Piper Cub Question
  189. Crystal replacement...
  190. Nexstar Success Guarantee
  191. OS 46 LA problems
  192. Taildragger as first plane?
  193. Pitts Special as a second?
  194. Minnflyer's Covering Video
  195. Can I Fly?
  196. Building models with foam
  197. Cybird....
  198. SIG easy hinges?
  199. Who makes this landing gear?
  200. RV-4 or Ultra Sport 40+
  201. SOLO!
  202. Back in it
  203. A turbine as a first PLANE
  204. take to the field?
  205. Engine starting safety
  206. O.S. .46 AX props question
  207. ???Charging problem?...??
  208. 3D plane for a second???
  209. two blade prop for alpha
  210. Hardened surface
  211. simulaters
  212. skylane
  213. LT-40 taildragger conversion problem?
  214. First Solo Flight, Thank you
  215. ****MARTIAL BLISS CALCULATOR****
  216. Looking for a First Plane
  217. Voltage tester for Rx battery
  218. Ultra Stick 40
  219. Alright, time to finish my Sig 4-star
  220. Two steps forward...
  221. What trainer should I buy?
  222. Sig 4 * 60
  223. 4 stroke
  224. O.S. 46LA vs 46FX. For Trainer & 2nd.plane
  225. Does anyone have some slow poke photos?
  226. My plane is too loud (OS46FX in GP Super Sportster) - help.
  227. Who are good/reliable distributors?
  228. First Flight
  229. Ultra stick 40
  230. Norvel .061
  231. Older Planes Kits
  232. finished my landing strip
  233. Changing Fuels
  234. Crashed my Trainer
  235. Defective Nexstar Select
  236. I did maiden flight today....
  237. First Major Crash:(
  238. Good first plane?????
  239. another problem
  240. Fuel Supply Problem
  241. Solo'd first day at the field !
  242. Newbie here with questions (Nexstar)
  243. glow plug
  244. Color Scheme
  245. i need help
  246. A day like today....
  247. futaba radio question
  248. I'm so lucky!
  249. newbie
  250. Prop shaft isn't long enough
