View Full Version : Beginners
- need help
- Maiden Flight How To?
- Clubs in Sugarland, Tx
- throttle linkage driving me crazy--advice please
- .09 Trainer?
- What is it?
- Electric or gas?? And what model?
- Field size anyone?
- Beginner...
- flaperon questions ?
- Dubro kwik-fill fueler
- WORST trainer I have ever flown.. (video)
- 8uaf Vs. 8uafs
- Airplane engine screw stuck
- Help Lost Manual
- Club Recommendation
- Propeller types
- cg
- tiger or 4*
- very new to this stuff.
- 2 Stroke vs. 4 Stroke
- Hot Bodies A-7 Corsair Ducted Fan ARF w/.18 Engine 47"
- thundre tiger engine parts
- Ettique WHEN S#$ HAPPENS - your error & someone else's plane / equipment
- all the electornics in the tail section?
- trainors are not only for begginers!!! but can do some awsome stuff while stock!!!!!
- Airelon
- Sig Senior Kadet ARF- Taildragger Conversion
- receiving crystal?
- Thanks!!!
- Soloing
- Field Charger / Battery Help
- Looking for 21st century fabric, Cub Yellow
- Engine offset?
- Training Wheels? (attn: Unstable)
- Decals popping off!!
- oils ain't oils?
- J-3 Cub for noob ?
- First Flight PT40
- New PT40 Out There
- Need to know where to add tail weight?
- What Trainer
- the rules of the runway?
- Fast Stable plane
- Hobbico Superstar Select
- Can someone explain prop's to me?
- Recovering Problem
- Glow plug batteries
- New
- Low Band Receiver
- If you have been thinking about getting a plane; you might want to check one out.
- I'm getting closer...
- Dave Patrick Ultimate 40 ARF
- Flexing Horizontal Stab?
- muffler question
- what does coupled mean?
- PT40 wing advice
- super stick 40
- Is price of Fuel at the hobby shop way out of line ?
- Drilling
- Best plane for windy conditions?
- My Trainer is DONE!....or is it :)
- Low cost plane for beginer?
- Big Stick Differences
- Should Expo used during landing?
- New flyer at local school
- SPAD for now?
- Lost Transmiters>>>>help!!!!!!!!
- 4 * 60 Rudder Problem
- PT40 newbie
- Solo yipyipyip yahoo
- Spads
- What are the best windy day electrics?
- How to fuelproof properly
- Recommended Micros Flyers?
- HELP!!!! Servo Programming? Y'S?
- Second beginner type plane
- Left thumb instruction
- Asp 4 Stroke Fs 91ar
- Futaba Controller - Crystal?
- What Engine Should I....
- Leonardo ARF
- Ima Newbie
- What crystal do I use?
- finally off the ground!!
- New shop in the UK
- Slow!
- Also
- thanks for the help
- Dual Rates & Exponentials
- Lady Dragon for first low wing?
- Engine for Cessna?
- soldering connectors?
- a good .25 sized J3 cub
- Are trainer planes fun for seasoned flyers too?
- Plane covering
- Help With LT-40 Kit
- Rudder/Elevator Pull Pull Systems
- GP slowpoke do you have one ? whats the best engine for this plane ?
- Flying wire/Guide wire for strength?
- Training cord
- has any one seen this thing fly
- Gee Bee Z R2 for G2
- Need Help Fiberglassing Over Foam - First Time
- Sig Kadet Sr. Arf nows its been out a while what do u think?
- rx for a 4*60
- I need some training in trainers
- Pt20
- Fueling Valve
- Parts for Hobbico Flightstar 40
- Warped Ailerons
- best second plane
- plane help
- Goldberg Ultimate-Advice?
- Transparent ?
- What to put in the field box?????
- ? Correct way to hold tx
- Adding flaps to a .20 corsair
- First ARF
- Hinge Gaps Sealed?
- Which trainer?
- My first time monokoting
- Lost Plane Locator
- Don't Loose Your Plane - Lost Plane Locator
- [B]First Successful Solo Flight ![/B]
- Best engine type for beginner, 2 cyl. or 4 cyl.?
- engine for ARF
- anyone ever have this happen--weird
- My LT-40
- anyone own a aerobird?
- Questionable Batteries
- flight sims
- Wing Balance
- first build
- Newbie wants to say Hi!
- Charging a 6V Battery Pack
- using Hobbylite or another balsa filler?
- Blimps
- Build First KIt
- how to land
- Flaperons and elevator control
- I have finally flown successfully!
- PVC Stand
- Want to build first kit
- How much glue?
- Cleaning pencil smudge from Coverite covering
- I need a plan to start
- need help on runway
- first r/c airplane
- Pull starts
- Fuel proofing
- First Kit Plane, Built
- Servo troubles
- Geared Speed 400 Turning Backwards
- Tx & Rx Battery Life
- Choice of 3 planes to train with...HELP!
- Clubs? what clubs?
- Radio recomendations
- Laws regarding Flying RC Planes?
- 12 y/o daughter said she wants to fly....???
- help on roll rate-unintentional
- Contact info in plane!
- This is Dangerous!
- helllp!
- Better to fly aieleron or Rudder ?
- First Flight
- Prop Painting Question
- Lazor Works
- DP Edge 540
- Flying fields around Sacramento
- Diode BACK in the 9C??
- fuel line
- Ultra Stick owners--need help!
- proper balance on a prop
- help me
- Beginner Fuel Question
- Problem with nuts & prop
- Wing Detailing
- break in satio 180
- Is there a Way to remove factory decals ?
- How to measure degrees of "right thrust"
- When to use CA glue Accelerator?
- Building the PC9
- Battery charging misc
- Reduce Dihedral on Avistar ARF
- Beginner Question
- Alert: Newbie Question about controls
- Essential Field Equipment
- Flight Kit
- Silly question, want to fly today, how long to charge?
- Delta Wings
- First time on ailarons
- Attn Unstable: going from Ch. 38 --> 25
- Wheel Wells
- Battery-amp-speed control wingo question?????
- Newbie starting out...I've got questions
- YS 91 vs. Saito 100
- cheap begginer plane?
- Servo performance after a crash?
- Hobbico Field Gear Help
- Plane and Heli
- Antenna Placement Question
- LT-40 Balance SUCCESS!!
- 10 year old daughter wants to fly
- Beginner's essential tools
- radios
- Made my first flights - Awesome!!!
- Getting Started
- Firebird XL
- First GLOW Plane
- 4*60 Kit questions
- Lesson learned
- easy2 vtrf
- Balancing LT-40
- 2nd plane
- Prop Crud!!!
- A good beginner RTF your advise please
- Switches:
- antenna reciever wire
- tuned mufflers
- Prop Chart
- should i go with a.........
- Stabilizer Reinforment Question
- Beginner needs help
- Second Plane
- Which Fuel Tank?
- which one over which?
- Beginning glow user: fuel line, throttle link, prop runout questions
- Alternative to 30 min. epoxy??
- Soft mounting an engine.
- LT40 ARF taildragger conversion
- Confused about trainer selection...
- Our tools dangerous? Bah!
- Engine Selection for a twin
- question about JR radio buddy box/trainer cord?
- Ripped covering on plane. Fix?
- Screw on wings, no rubber bands. Superstar.
- Point made!
- MonoKote Metalic Gold?
- Gluing hinge... Hinge glue, or epoxy?
- Batteries - Generic vs Branded
- something called a spad
- Crow option on US 60 w/t6xa radio
- another question
- Thermal Flying
- question
- Spinner bushing help Please
- Now I have a radio system problem
- attaching props
