View Full Version : Beginners
- Pre-Flight your TX!
- Got my new 2.4 6EX
- DX7 and other brand servos
- Thanks! (And 2 questions)
- GATOR RC
- What engine for Tiger 60 kit
- Looking at Second Planes
- More sport plane choices.
- photo help
- Training cable question
- RE: Four stroke Engine Problems
- Which engine should I get?
- tiger 2 tail dragger?
- What happened??
- Back yard flyer
- P-51 Hanger 9 WOW!!!!
- Really Old Flaperon System
- DX7 engine cutoff switch
- Hitec 6ch receiver
- Crash, Stall and Float question: Seagull Boomerang
- ? about receiver switches
- Found in a Barn, Help identify!
- Alfa trainer 40 ARF-what do you think?
- Receiver Placement
- Landing Gear Replacement
- When do I graduate from the trainer???
- Transferring settings between transmitters
- PARKZONE J3 Cub vs. J3 Cub BL - What's the Difference?
- falcon 56
- Did I stall???
- prop question re 1972 falcon 56
- CHEAP ENGINES? THAT WORK WELL? HELP!
- Finaly soloed!!!!!
- Power + Plane = Disaster
- Futaba 7C 2.4
- JR X9303 vs. Futaba 10C
- engine running backwards??? wut the ?
- Fast 3 or Flying fish?
- Nexstar EP
- guestion about buy
- What a dumb toss!!!!
- Trainer plane question.....
- First Plane
- Prop balancing - How to?
- avistar ?
- well I'm out $180
- low wing airplanes
- (still) Rudderly confused
- CG question
- second airplane
- Super Cub trans.
- I would like my Four Star 40 (4*) to be a bit more snappy
- High wing planes
- 46LA problems
- Calmato 40 Sport a good second plane?
- looking 4 next plane help
- failed radio range check-help!!
- How do you convert Esky Brushless Motor stats?
- ALIGNING ELEVATOR HALVES
- Evolution TPS "eating" plugs?
- Nexstar Select or ARF?
- good second plane
- Another begginerish question...
- Thank you to RCU and its members!
- pitts style muffler
- Hammerhead on a Four Star 40
- need help please !
- Rudder for loops?
- 4 Star building question
- Cutting/bending copper tubing for fuel tanks
- Avistar 3D flyer?
- What is the norm? Please help........
- All About Glues
- ESC issue
- Electronics Relationship - Motor, ESC, Battery, etc.
- ca hinges
- Balancing prop.
- What first plane to buy?
- How was the XFC championships
- what channel is this
- Cessna 182 skylane 50 - ARF
- problems with a ST 40
- hobbistar 60 wants to roll out of heavy elevator inputs*UPDATED VIDEO*
- H9 Arrow 40, Good Choice!
- First Plane
- engine rotation and battery memory
- Nexstar
- ABC or AAC?
- electristar, best way to charge and discharge flight pack & tx
- You guys see this on Youtube? (New Trainer)
- I cleared the plateu! (Air speed on landing)
- Which 2.4 radio should I get?
- Dumb Receiver question
- Someone doesn't want me to fly
- How much does 2.4 really help????
- slight miss when inverted
- rx interference
- Commander 2 Flight Controls
- Radio interference
- Changing Nitro Content
- Got my first planes. Woo Hoo!
- Cleaning radios....
- Why is my covering changing colors?
- Wow!
- Plane Storage
- OS 55AX
- 3years of flying
- Need help with ailerons!
- Where to run antenna wire?
- simulator
- Parkzone J3 cub
- motor for gp 1.20 gee bee?
- Finding the airplane once it crashes
- What types of glues to use to repair styrofoam?
- Futaba PA-2 Pilot Assist – worthwhile?
- New engine and tank location questions
- FUTABA 9C pal,Do you use "IDLE-DOWN" function ?
- 4 stroke rpms????
- Need your input on a Fuatba 7C FASST
- Antenna and field equipment question.
- Airframe for a ZENOAH 26cc
- Flight pack for an Ultra Stick 40?
- Well, I went in a totally different direction.
- RDS8000 Review
- Castor oil
- Replacement muffler options
- Flight time
- Prop keeps falling off
- Giant scale manufacturer quality
- Good beginner- intermediate RTF Plane?
- Twitchy Super Cub Servo
- need help setting a wing servo
- Making a load meter
- Stripped muffler hole
- Should I wait or not to get the new Alpha DSM?
- after flight procedures?
- This might sound like a dumb question
- Evolution .46 vibration
- Rtf airplane battery problem
- Phoenix Dolphin 40 wooden push rods
- Showtime 50 Pattern/3D prop
- nylon bolts/landing gear
- Another Newbe
- 4 star prop?
- Metal deposits in fuel filter after break-in
- Stuck high in a tree now what?
- 1ST 4 STROKE
- KE roll??????
- Great Planes easy sport or Hobbico Avistar
- LT-40 Build question
- Filling (fiberglass?) holes...
- starting out
- Wind wind go away come again never!
- need help-newbe
- If I switch props will it slow me down on approach?
- Bad Luck
- tightening prop?
- Flooded flying fields in the midwest.....
- Wing tips
- first kit build
- Interesting day..
- Quick question.. 2 elevator servos
- GLOW MAGISTER flight video
- Expired today
- MY COMPLETED PT-40 MODS
- SkyFly to Superstar EP?
- GP Cherokee Really a Good Second Plane?
- BEGGINER'S MUSTANG QUESTION
- AX/Dolphin: Doesn't fit well
- 1st flight
- Complete newb - very (not as) frustrated!
- Tiger 60 build issue
- Wings out of square...
- extending muffler exhaust
- what a wonderful day for flying RC in the north east.
- Flight time after break in?
- Air in fuel line
- best plane for begginers
- Weird engine problem.
- receiver after crashes...
- Becoming an intsructor
- CAN NOT REPLACE CARBURETOR RETAINER
- Any advantage to wood push rods?
- magister converted to glow
- K&B .61 Glow motor
- Choosing Plane for Gliders and Sailplanes
- Excess servo wire
- 2 or 3 Line Fuel Tank Set Up
- Spektrum Buddy Box...Anyone?
- Have to share my SIG engine results
- fuel proofing flightline box/tote
- CA for building
- How to take this 46AX apart?
- Landing Gear Dimensions
- Buddy boxing a Spektrum
- receiver question
- raptor f 22
- Share your Construction Techniques Expertise.
- Uproar Setup
- O.S 61 carb question..
- Nitromodels
- Will JR servos work with Futaba system?
- What makes a pattern plane?
- Oops, I did it again...
- My fleet,..and a thanks!
- Custom muffler gasket
- Best Day Ever
- Various break in doubts
- Mistake?
- Help with prop selection
- Recovering Tower Trainer 40 ARF
- prop balancing
- Landing with the wind
- Landing/Touch and Go question...
- Trainer or Stick for first plane
- Model Technics fuel.
- Sunlight wrinkled my planes covering...
- ESC
- fueling up
- A look back.
- Unsightly Drop of CA
- glow plug gone bad?
- Moved on to my second plane, horrendous results
- help with prop size
- Rubber tires?
- Typhoon 2 3D with Spektrum DX6i - how to setup dual rates??
- I want my plane to pull a banner/sign
- My Glow Starter won't fit on the glow plug!!!!!!!
- Beefing up Dolphin landing gear...
- sportsman aviation sport stik 40????
- GMS .47 Running Problem
- Solo Flight This Weekend
- Student Syllabus?
- air foil, speed and lift question....
- Not the right hobby for all!!!
- Bigger then 1/2a, but smaller then 40 size....
- Y SERVO HARNESS
- CAN NOT TIGHTEN CARBURETOR
- Balancing - Confused
- New instructor question
- taking off
- battery charging and dual instructors
- Wend from Nexstar to Avistar...
- Went to the air show yesterday
- Now I went and did it!
- My airplane gets into these tight on a dime uncontrolled maneuvers.
- Cleaning engine after a crash
- Bittesweet end to a good plane
- can anybody recommend...
- Need to know about this plane ASAP!!!
