PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128
  1. getting wood glue out of clothes?
  2. need help
  3. might work for you
  4. Where can I get JTec wire guides?
  5. Question on how to balance wood prop
  6. props and glow plugs
  7. Glow Fuel in Clothes / Rags
  8. taildragger landing
  9. sevo rods
  10. References
  11. What is this like, Sky Surfer
  12. Fitting servos
  13. Hook and Loop Velcro
  14. Sig Kouger
  15. Ailerons work like elvons
  16. CG Tiger 2 ARF Engine??
  17. Balsa Building Board
  18. Motor won't run continuously
  19. A good Airplane
  20. Packing tape removal
  21. Prop Shop
  22. Secondhand Super Tigre engine
  23. bigger wheels
  24. non-steerable nosegear
  25. Using two receiver batteries
  26. Remote Needle Vavle
  27. Beginner learning to fly
  28. Radio problems
  29. Spinner Size
  30. Ball Bearing vs standard servos
  31. Storing fuel ? how long?
  32. 3ding?
  33. what sim is the most useful to learn to fly?
  34. Anyone in Goldsboro NC?
  35. Local Gas Clubs (Los Angeles, CA)?
  36. Hardest Question I Have Asked; So Far
  37. Public Fields in vegas
  38. Firebird II any special instructions ?
  39. Eagle 2 Downthrust
  40. Need help in advancing from trainer to low wing aircraft
  41. beginner cg question????
  42. Indisputable beginner
  43. What kind of battery to use in field box to power starters?
  44. wing struts--which planes need them?
  45. Avistar Select batter charging question
  46. my begginers story
  47. Airfoil Designing
  48. nosegear
  49. Regarding Large 1/12 scale B-17
  50. os 46fx
  51. Is this sound normal?
  52. Duhhh... what me worry?
  53. Oops during right wing construction for G.P. PT-40
  54. Gap Width Question
  55. Flaperon Question
  56. After-run Oil
  57. .40 Size Pilot, Installed- Thanks!
  58. not a must starting with a trainer?
  59. ailerons
  60. Bought my radio today!
  61. Lanier Edge 540 90"
  62. CA Hinge HALP!
  63. Bubbes in fuel line while running and throttle adjustment problem.
  64. Rigging A fuel tank
  65. the wife has got the bug
  66. first solo plane
  67. starting out new to hobby
  68. low wing flying
  69. Tiporare
  70. OS 61FX Break In- Help Needed
  71. Blue and Pink fuel lines.....
  72. Superstar ARF Build Gripes
  73. What makes the plane fly?
  74. Totally new, need help in deciding
  75. Starting Engine... What's the "proper" way to do it?
  76. looking for trainer without rubber band wing
  77. Flight sims
  78. Massachusetts???
  79. Yet another newbie question???
  80. Where to buy a new canopy...
  81. What diameter drill for Saito 72 prop shaft?
  82. R/C Clubs and instructors in London area
  83. Aileron Hinge
  84. Club rules how about sharing the safety rules!
  85. What weight Sevenstrand wire for pull-pull system?
  86. Which one??
  87. check out my new and improved scratch built flight box
  88. Totally Clueless! Help!!!
  89. In relation to pathetic Instructors and Students, rewards?
  90. what kind of airplane
  91. Beginners, What Plane Should I Buy?
  92. Who knows where I can get these wire guides at? Thanks.
  93. Pathetic Insructors
  94. I Solo'd!!! Thanks all you instructors!
  95. schumacher 10
  96. Can someone help me get info on this kit please
  97. Can someone help me get info on this kit please
  98. Newbie Books
  99. Newbie
  100. OK...I'm startin to freak out here.
  101. Finger tip prop balancer, both my APC props are balanced???
  102. Newbie radio question
  103. Four Stroke torque rolling
  104. epoxy for wing halves on avistar?
  105. 3 dumb questions on OS 70 chokes
  106. Superstar EP flying info
  107. soldering question
  108. Avistar first plane?
  109. Rudder/Elevator or Aileron/Elevator for a 2-channel model?
  110. Worn Servo Mounts
  111. RC flight schools
  112. 1st low wing ARF
  113. OK to start engine without wing?
  114. How many times do you filter your fuel??
  115. Electric starters: the horror!
  116. LT-40 ARF Balance vs engine
  117. Fuel supply in a dive
  118. Engine Break-in - Ouch
  119. durplane help and questions
  120. Bomb Drop
  121. going out to perhaps solo tom. for first time.
  122. tiporare bring it back
  123. 2-Stroke Engine Selection
  124. duraplane
  125. Inflight Trim Warning for Newbee's, being stupid is easy.
  126. Antenae Wire Length
  127. I can fly:)
  128. I think my rx battery may be toast.
  129. First Flight
  130. Superstar Stuffed
  131. tower hobby arf trainer40 VS MKII
  132. Tail-dragger Landing
  133. Bomb Drop
  134. What goes up?
  135. Spinner Question
  136. Anyone fly this Hobbico Flyzap?
  137. Futaba Rx Question.. Whats best
  138. 2 motors 1 controller?
  139. Engel Telemaster
  140. LA .65 Prop Questions
  141. check out my scratch built flight box
  142. More than I can handle?
  143. Help me decide
  144. Help Please
  145. Aviation Registration No. font?
  146. ARF FEAVER?
  147. New to RC and RC Universe
  148. FMA Co-pilot vs Futaba PA-2
  149. prop question
  150. H 9 P-51 ARF qwestion.
  151. What is the purpose of tuned pipes?
  152. Kadet Senior + OS 48 Surpass?
  153. Beginner engine question
  154. Voltage question for power panel
  155. Leaking fuel tank, please help
  156. Servo reversing
  157. How long are batteries good for
  158. gp easy fueler vale problem
  159. Got my Trainer Built: Now What?
  160. best way to set cg
  161. Understanding Engine Names?
  162. Kadet Seniorita .25
  163. any place cheaper than Tower?? for engines??
  164. How to mark your depleted battery
  165. another first flight report
  166. wm t-34 for FMS ??? anyone know where?
  167. Next plane?
  168. Model Tech Magic ARF
  169. Model Tech Magic ARF
  170. Good Plane for OS 40
  171. Another Avistar Select question...
  172. draing the batts?
  173. Beginner: Need help!
  174. Need help with epoxy decision.....
  175. all these plugs
  176. Airstike
  177. chaep camera mount onto avistar HELP please
  178. t-34 with thunder tiger pro 46 and laser 6 radio ..
  179. both servos are going in the same direction
  180. JR Charging Jack installation
  181. Training on a 4*40
  182. Is this a good plane to buy?
  183. Hinge Alignment Problem
  184. Great for Advanced and Beginners.
  185. GP extra 300s 40 For 3rd plane?
  186. What is the best method to balance a plane?
  187. motor is angled?
  188. The Ultra Sport 40 kit is GREAT!
  189. First Low-Wing Plane Maiden Flight Yesterday!
  190. Sig Rascal
  191. Flying Fields ?????
  192. Hobbico Avistar Select a little help please.
  193. Futaba 8UAF Super TX help please
  194. fuel filler
  195. Gold-n-Cable = Gold-n-Garbage?
  196. different modes
  197. Recover???
  198. Sig 4* 60 or Venture 60
  199. Pathetic Student
  200. Any Sugestions?
  201. tail feathers/flying wires
  202. Other beginner mistakes
  203. Beginner mistake
  204. Superstar Wings don't quite align
  205. Glow Fuel and Engines, Someone please explain!
  206. A mouth full of Gas!! LOL
  207. How do you charge multiple household items with this?
  208. Pushrod Glueing- Having a problem
  209. how fast is the aerobird?
  210. .10 Engine
  211. World's biggest idiot
  212. how to set up a 4 stroke in my Kadet Sr. Arf
  213. Approaches by the numbers...
  214. How to make flying wires....??
  215. 3rd wire on RX bat
  216. So A friend gave the word....
  217. FMA Direct Supernova Charger
  218. bubbles?
  219. engine won't run at high RPM
  220. JR radios/buddy box ??
  221. F-18 SuperHornet
  222. Trainer switch... Why can't they use a toggle switch?
  223. got my plane :)
  224. It is alive...
  225. Hopefully the last
  226. Does it matter?
  227. Mini Piper
  228. Painting question?
  229. 1/4 20 bolts
  230. Help
  231. Bought my plane finally
  232. Does anyone know how to get a plane down from a tree?
  233. OS 61 FX Spinner Problem!! HELP!
  234. Clubs Near Cape Girardeau
  235. Bolts On A Low Wing Tail Drager
  236. How do i start?
  237. I Solod!
  238. Does anyone know a good website or book to hepl me learn aerobatics?
  239. Remove epoxied parts
  240. Dynaflite Corsair 40 Canopy !
  241. Need help with Airmadillos
  242. Decal Removal
  243. How do you seal the edges of monokote?
  244. Pull Pull Control Horns?
  245. Just bought my first plane, an Alpha!
  246. First time building/flying a powered RC airplane.
  247. Wing Hinge Rework
  248. Elevator pushrod binding
  249. ARC Ready 2
  250. Full tank,forward CG?
