View Full Version : Beginners
- Jittering while engine running
- SSE Kit: Horn Location
- Ski Flying
- My landing gear got ripped off
- Powering a tiger 60?
- How to perform this turn?
- newbie looking for EDF plane. open for recommendations
- newby.
- What do I need to install my RCGF 26cc in a Cub 1/4
- did I ruin it?
- How to charge your field box...
- Engines
- Ironing out wrinkles??
- good computer chargers? and hobbycity questions
- Seagull Boomerang 40 building tips please
- crack in canopy help
- First Radio for a Newbie (in Japan)?
- Wife needs help with hubbies Gift
- Is the CR-1 charger good for a noob?
- pitts muffler
- Dihedral Question
- what octane gas do you use in your gassers
- Converting Hitec Optic 6 to mode 2
- question on cg
- Super Futaba 7C deal!
- Futaba 7C or Stock Futaba 4YBF on Hobbico NexSTAR
- GLOBAL QUALITY KITS - SKYLANE PARTS
- 2nd time DX6i has lost its bind.
- My 2nd plane??
- Park Zone RA672 Receiver
- Newbie
- GAS ENGINE OR GLOW???
- MOTOR PROBLEMS!
- first plane
- Which Glow Plug for Saito 125
- Gas engine for 1/4 scale clipped wing Cub
- LIQUID NAILS ADHESIVE????
- 3D Prop Guide/Chart
- help with spektrum ar6000 receiver
- Need engine information...
- Advice for a Beginner with no access to a club
- second plane
- info on hitec reciever
- Gluing Spar into Foam Core Wing
- Looking for Instructor/Mentor in Central Arkansas Area
- flyzone sky pilot???
- Great Deal on OS 55AX
- Ebay / Paypal Coupon
- Will there be a difference?
- My First flight (review)
- Ouch check this out!
- What do I need to connect the outrunner to the speed control
- BH model Piper J-3 Cub, crashed...
- CAN THIS BE USED BY A BEGINNER???
- Mode 3
- Prop/Landing Gear
- F-35 RTF: Breaking in the Motor
- Lets Talk Glow Plugs
- best engine combo for edge 540 60
- Prop questions and other ?s
- hobbyzone vs eflite?
- Exceed RC F-35 - Can I use a standard Receiver?
- Going from parkzone t-28 to great planes yak 54 25%
- Looks like I did it right the first time
- minium cessna 210 problem
- park flyer
- Removing Crankshaft from T.H. .46
- Trouble Starting SK90 Engine
- High Rates & Low Rates?
- Bought a new plane today!
- Weird Saito 82a behavior.... 4-Stroke gurus, Help please.
- glow plug
- glow plug
- Full Scale Dead Stick Landings
- Drilling holes for robart hinges.
- help please how do i get started with a sundowner 50 ??????
- stop charging at what voltage?
- Fuel Prices Now!!!!!
- help wiring 5th Cell (w/ pic)
- Binding, Binding , Binding
- Is my tank upside down?
- Whats the best beginners Airplane?
- preventing gummed engines?
- black friday deals
- I dont know?
- Sonic Instructions: Question!
- What is a pull-pull system?
- servo set up, need help......
- Happy TurkeyDay to all RCU members
- Automatic leveling systems?
- 4* 60 Maiden Flights
- Is it too cold to fly?
- Question about digital radio
- Wiring Advice
- SSE Tail Wheel hardware suggestions
- Covering Question
- How can one tell if his TX is on mode 1 or 2?
- trainer
- loose prop nut
- WINDSPEED/WEATHER HOUR X HOUR
- looking!!!
- Acetone No No
- Engine Mount ...Tap?
- Perfect second plane
- Funtana 90?
- Floats on snow?
- finally all the bugs worked out
- Electric Motors
- ys engine question
- changing transmitter frequencies
- Flaps and my Dx6I TX
- Another smoke system ?
- What should I do?
- one way valve
- RV-4 .40 by Great Planes
- TO PULL BROKEN BEARINGS?
- Something I saw this weekend
- Smoke System w/ Saito 125
- Winter build.
- Carb Stuck Shut...
- Hookup
- Anyone know about a Modelfly Jupiter?
- Witnessing a madien and a crash
- Whats the Best prop size for OS.46FX
- Not sure what it is.....???
- Request from someone with a 4* .60 and a .75 ST motor
- Cap 232 a good beginner low wing?
- dx 7 antenna
- How to convert a Duraplane from tricycle to taildragger(maiden report)
- How important is a balanced prop? AND help with landing gear
- Prop Question
- ed New Here
- engines ?
- Good 2nd plane?
- New Here
- Suggestions for Cold Weather Start-Ups
- Swapping Crystals Futaba to JR?
- digital servos..
- Hanger 9 easy fly 40
- charging lipos
- Magnum 52: Standard or Remote Needle Valve?
- Sheeting
- How to balance the Astro Hog
- RECEIVERS
- NEW to glow!
- kit balancing question
- Back for the first time in a while...couple of questions
- Covering tips
- My new baby just came in
- Why Does My TX Battery Drop Quicky
- Help with rust in engine
- Looking for a new FAST Airplane
- trim scheme
- 36" me 163
- Engine for a stik 40
- El Paso, Tx hobby shops, flying sites
- Extra 300
- Is .61 too much for GreatPlanes Cherokee?
- Where the heck can I buy fuel!??!
- Need Li-Po charger suggestion?
- Venting the ESC in an East Star
- what size engine to use
- Thunder Tiger 91 four stroke wreck
- Phoenix 25 High Wing
- What Prop size???
- Let Him Go or Hold Him Back?
- First Plane?
- engine size for plane
- Waterproof (resistant?) Battery Switch
- Solo and Crashed in same day
- Advantage hobby popup, be aware!
- First Glider?
- FUEL FOR OS120AX
- Jr XP6102 HELP!!
- modifing ailerons and hinge ?
- Funtana 40 CG
- Mounting heavy duty control horn Du-Bro
- blue angel or raptor
- where to buy batteries?
- Futaba T7C 2.4GHz Mix Programming
- Good Park flyer for back yard common ground?
- Made it harder than I had to
- 2nd Plane....How's this?
- aileron
- oiling engine , not flying for next few months
- Need help with charging a 6v receiver pack
- Beginner - Workshop/Tools/Materials
- Easy Refuel Cap??
- tower Uproar CG
- zlin z50/ saito fa80/ prop size?
- Good Economy setup for EasyStar & Minimag
- Is this wise to do?
- When is the average first crash?
- Should I ask santa for a cherokee for a second plane?
- WHAT TYPES OF INJURIES HAS YOUR PLANE(S) GAVE YOU?
- Piston Alignment
- parts for a Futana X100
- More than One Quote
- Hanger 9 super sport vs super star
- Kit calls for .29 to .40
- Fuel Tank Instalation
- Problem with my OS 46FXi Engine
- Dual Ailerons and Dual Rates Futaba 7C and 4*60
- Should i buy this plane??
- Correct way to adjust servo....
- !YIPEE! I just bought a rc plane!
- Should I buy This
- Push rods connectors?
- TX Slider style trims are important
- OS Max 40 FP question
- Tool Kit
- Cleaning CA frosting from covering
- Multiplex Ez Cub!
- Park Flyer WITH FLOATS for Backyard common ground
- Enya 90 4C Help
- Help !
- Indoor flying?
- glow plug? prop? engine size?
- Many years later, Yub Yub finally soloes!
- cold weather storage
- Good choices for a 10yr old and his first RC plane?
- A club isn't always available to a beginner
- tiger 60 or four* 60 kit ????
- November 11th
- Enamel over Aero Gloss Filler Coat Primer?
- Noob Servo Extension Question
- Im New To Planes Can Sombody Help??
- Stater batterys?
- Painting Question
- Warped elevator
- Re-Introduction to Aeromodelling!
- Astro Hog wing problem
- Where to get coroplast for a spad?
- DUBRO PNEUMATIC TIRES - leaking air
- EasyStar ARF
- looking for inexpensive first seaplane
- Power Starter or Manual flip?
- Found a great place to fly...
- model tech magic extra arf
- patching hole in plastic fuel tank?
- Spektrum DX7 Warranty/Support
- Lanier Stinger
- OS 46 AX Trouble
- How are ailerons mounted on Sig 1/4 Cub
- K2R Available in Calif
- Look under Engine for 1/4 Cub to see if you know the make
- Newbie Help for Ultrastik 40
- my
- Looking for a Lipo battery chargers
- New here and determined to learn right this time!
