PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Newbie Plane
  2. I need a little help
  3. filling fuel
  4. Get out of here cat!!!
  5. Rx Batteries selection
  6. old "G" servos-new "J" ends???????
  7. Engine up and down thrust
  8. Need the best .25 trainer
  9. DX 6 (JR/Spektrum) trainer cord works with????
  10. valves on magnum 52 4 stroke
  11. warbird
  12. radio tension
  13. aileron hinge ?
  14. GP Skylark rebuild help needed
  15. More Power Needed, I Think
  16. Talk to me about radios
  17. Air Tanks for retracts
  18. hobby zone super cub problem?
  19. Going Brushless With The GP Slinger
  20. Fuel and Wet Servo
  21. just sharing
  22. Hobbico diablo video
  23. inquiring here???
  24. Cutting cowlings? What's the best way...
  25. Experienced modeler with a newbee question
  26. Building Hanger 9 P-51 PTS
  27. ar7000 battery question
  28. dual servos
  29. need help patching some holes in a fin
  30. wheels
  31. Superbrain 977 Charger to charge LiPo batteries?
  32. cowl covering or painting
  33. Making decals "STICK"
  34. Ultracote over ultracote
  35. Worth the effort?
  36. KYOSO EDF 55
  37. CA and EPoxy
  38. Nexstar does not want to turn on slight climb
  39. help!!!!
  40. Hanger 9 F22 pts price drop! Why?
  41. I need help with reciever placement!!!!!!!!!!
  42. Buy a kit with Futaba conquest 72.190 mhz or is there a better option
  43. World star 40 always climbing
  44. HIGH RATES LOW RATES
  45. Is there a good way to adjust CG at the field?
  46. Gas powered trainer
  47. glider to airplane
  48. Is this a good idea?
  49. Refueling a Cowled engine
  50. Goldberg Cub Decal kit
  51. ripmax zepyhr
  52. Eaglet 50 and OS LA15
  53. Prop size
  54. kit tools
  55. hitec rx and fut tx compatable?
  56. ar7000 question
  57. balance question
  58. inverted OS 46 AX engine
  59. 6v NiMH 1200 mah batteries ...difference in flight
  60. TWO separate engine problems
  61. radio suggestions
  62. Uproar 40 with 3D flag
  63. 6v NiMH battery charger
  64. reciever hookup question
  65. supertigre gs40
  66. Snow Flying Video Remixed
  67. Upgrade radio question
  68. Wrong Radio Equiptment?
  69. Weak Signal Toledo Show
  70. Slightly Off Topic. "Plane Crazy" video
  71. Simulators?
  72. Just got a plane but need Advice please read
  73. finding thrust line
  74. Unidentifed part for Hobbico Nexstar Arf
  75. SIG Four Star vs Phoenix Dolphin
  76. SkyFly modding
  77. accu cycle elite--having problems.
  78. warped control surfaces
  79. Evolution 46 exhaust plugging pressure line?
  80. covering wing on Uproar 40
  81. Would this fit a super cub
  82. new to electric
  83. what is the best charger that puts out 1 amp
  84. Cessna 182 Motor Cuts Out
  85. Ground Loop
  86. Cedar Hobbies Stick 40 CG?
  87. First Post
  88. OK I have made up my mind. I want an ARF trainer
  89. IS THIS A GOOD TRAINER??
  90. H9 Alpha 40 - first Nitro
  91. O.S.MAX 91F SR
  92. CMP Edge 540T - Need help
  93. Voted Three Best RTF Trainers
  94. How cold is too cold?
  95. witch is a better second plane?
  96. Firewall removal
  97. Realflight G4 Aircraft Editing
  98. Servo Replacement??????????
  99. Thought this was neat
  100. glue drying time
  101. decals for planes
  102. A cute story
  103. new to hobby what plane?
  104. best expoxy?
  105. is my low speed needle broken? evolution 46
  106. Where do I go from here?
  107. What is the difference
  108. Propeller sizing worm can
  109. Balancing
  110. handling 2.4 radios
  111. OS.46AX into Alpha Trainer
  112. spinner prop washer allow 1.5 turns on the nut
  113. how to cut throttle with digial trims
  114. Adjusting Elevator on Slo-V
  115. need help recovering a wing
  116. Making my own Slow stick-Transmitter question...
  117. NEED A PLANE for my engine
  118. whats the deal with servos
  119. Engine break in/ Cold weather
  120. Beginners Beware...Cub in Trouble
  121. Li-po batteries.....
  122. Next step
  123. Lets pass on our thanks!
  124. super cub shorting out
  125. NiCad Charging Question
  126. Radio
  127. just starting out bulding from ebay
  128. Recovered my Nexstar
  129. ElectricStar Question before 1st Flight???
  130. Strap it or screw it on?
  131. Newb looking for inexpencive easy to fly?
  132. Flew in the snow today
  133. Best place to shop...
  134. I broke my MRC Super Brain last night.
  135. What did you get for Xmas?
  136. covering ailerons
  137. Receiver and Servos for 2nd plane
  138. Channel 1-2 not working LAMA
  139. Rating brushless motors
  140. Carl Goldberg *SAFE* Maiden flight
  141. bad glue job
  142. x-mas
  143. Merry Christmas
  144. Where to start
  145. looking for member
  146. MinnFlyer's PVC Pipe Airplane Stand??
  147. A Word To The Wise For Beginners
  148. T-hawk in sim & real life
  149. A must see for beginners
  150. Magnets in our planes
  151. smoke on evo 46
  152. jst connectors
  153. My first snow fly
  154. Oh, OH!! problems with Futab 6exap
  155. P-51
  156. Check Your Bearings.
  157. p-5i pts with evo 52? and trainer cord question
  158. reaming prop
  159. Best engine for Goldberg. cub
  160. Don't understand
  161. Optimum 46 2-stroke RPM`s ?
  162. Amps motors and batterys!!!!!!
  163. is there a better way to clevis onto pushrod
  164. Sig Giant Kadet Senior / OS .70 FS?????
  165. 1st.60 size airplane . help
  166. Removing dihedral from big stick 60
  167. need a new wing
  168. Airtronic VG 400 feedback
  169. Getting back into the hobby!
  170. startin now
  171. Idle speed adjustment
  172. Spinner Question
  173. Broken CA Hinge - Rehinge aileron?
  174. rudders
  175. Nexstar covering question?
  176. paint for the props
  177. fighting the wind..
  178. How to measure sunburst for covering plane
  179. I told you it was snowing
  180. will this work?
  181. Hanger 9 F22 Raptor
  182. learning
  183. Explain how a Hayes fuel tank is hooked up
  184. flight simulator
  185. CG HotStick
  186. Great SOLO
  187. Wilga 2000 - Installing a Brushless motor
  188. picking a engine
  189. Help with new runway
  190. scale and percentage
  191. My father
  192. F-22 Raptor .61
  193. Brake on ESC
  194. Need a fuel tank for a Super Sportsters 40
  195. Clipped or full wing on piper
  196. Choosing a 46 sized engine...
  197. Impression on goldberg edition Piper
  198. PALM-Z
  199. Piper Tail wheel
  200. How do I use this hot sock?
  201. Tower Trainer to Tail Dragger?
  202. Epoxy in the cold?
  203. 1st Plane: flying space too small for park flyer??
  204. Hi all. Need some pointers.
  205. First plane
  206. Snow Skies
  207. Big stik 60 assembly and thoughts on my combo!!
  208. I am thinking aobut buying
  209. If you're thinking about giving up look here!
  210. first plane
  211. blind nut fell into wing
  212. Ken's LT-40 Build
  213. Redrilling Firewall mount holes????????????
  214. Elevator Authority At Low (Landing ) Speeds?
  215. 2 planes differnt battery voltages
  216. Pitts style muffler on an OS 1.60 FX
  217. What kind of plane is this
  218. rudder failure please help
  219. cap 21
  220. Avistar four stroke
  221. engine tuning problems and more
  222. tx battery pack
  223. I think I found the right plane for me.
  224. Deadsticks
  225. What is the difference between...
  226. Thanks MinnFlyer
  227. Tidying up the Trainer
  228. Is this a good plane for a beginner?
  229. Glue, Aircore 40
  230. Need help with a taildragger
  231. Hey MinnFlyer!
  232. Is this a good starter?
  233. Glue and Prop questions
  234. Asp engine question 4 stroke
  235. how to make a 6 volt pack
  236. Zagi XT Twin too much for a n00b?
  237. Cap 232
  238. Ordered my first kit!
  239. GP Super Sportster 40 and propeller
  240. Tiger 60 servos
  241. Tank size recommendation
  242. SLOW STICK PLASTIC PARTS KIT????WHERE R' THEY!!!
  243. Better tail wheel assembly for Ultra Stick 60
  244. Help carbon fiber control rod vibrating
  245. Can someone explain vertical balance to me
  246. Just bought another plane.
  247. Hypothetical building question
  248. Prop off center
  249. positive dihedral/negative
  250. Does anyone see a problem with this?
