PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. I went to the Fair
  2. Looking for your low-wing trainer?Haha.What's this!
  3. Safety Question
  4. Hobbico Twin Star Question
  5. Cheap , sturdy plane stand
  6. P-47 40 size
  7. re-monokoting a Tower Kaos ARF
  8. Sealing decals
  9. new to flying
  10. Flight Log
  11. VERY scarry experience at the field
  12. Main Landing gear
  13. Just a standard newbie question.
  14. engine mounting dilemna Sig Senior
  15. radio help
  16. How can I conver H9 Ultra Stick 60 into Tricycle gear?
  17. Bipes no harder than monoplanes?
  18. Ok so I ordered this engine...
  19. Using covering material as hinges??
  20. Looking for Evo .61 Muffler baffle
  21. which prop: APC or Master Airscrew
  22. 10-6 or 8-4
  23. Prop Selections ? Twist 60 and Stik 60
  24. My first SOLO
  25. Phoenix models STREGA
  26. My First crash !!!
  27. Fuel Tank mounting problem help!
  28. Twist 3D maiden ends in......
  29. standard servos
  30. Aerobatic basics
  31. engine advise
  32. wicking CA in servo screw holes
  33. Du-bro slotter question
  34. Saying hello and looking forward to suggestions
  35. Good flight pack?
  36. RCU How to article covering monokote question
  37. Sig Piper Cub 1/6, help needed on setting and flying it.
  38. Fuel tank hookup ??
  39. How to use flap in 9C flaperon function?
  40. Tips and advice for First maidens?
  41. How do i make the flaps into ailerons?
  42. Ran out of planes today...
  43. ROYAL 40 T WEIGHT?
  44. Mustang P-51 PTS question
  45. another os .40la question
  46. Many thanks to everyone here
  47. plane for my old man
  48. To All Pilots (Noobie or Not)
  49. Just finished my 2nd plane
  50. MonoKote Trimsheets - Iron On?
  51. "Double Beep" With JR Radios
  52. Just got a New plane!!
  53. Hobbico SuperStar Select MkII RTF good for beginner?
  54. OS 46 FXi
  55. 3 rd plane
  56. Nexstar select 40 or Hobbyzone supercub
  57. Bought A new plane! WOOT
  58. Servos and Recivers
  59. Wood for spares
  60. Another good example for flight instruction.
  61. Rascal 40 - stupid questions.....
  62. airplane power
  63. RealFlight G3 Question
  64. Need help with p-51 pts landing gear repair.
  65. Nubie ARF Questions
  66. The im at work, and want to go flying Thread
  67. any swap meet in NJ or PA
  68. Different Stik?
  69. First plane
  70. Hangar 9 Twist, need some help.
  71. New to Glow, what the Heck do I have to buy??
  72. Electric Motor Size Needed?
  73. prop size?
  74. Can't wait to get it up.....
  75. Twist 3d 40 ARF build. need input.
  76. Propulsion questions - Newbie
  77. Need Help : JR Buddy Box System !!!
  78. Thunder Tiger Pro .40 or .46 Carb
  79. Monokote on Ultracote???
  80. 4 or 6 channel
  81. student tx from JR
  82. I need help
  83. Brain Fart About Battery Voltage
  84. Impulse buying
  85. Saito FA100
  86. Problem locating nose wheel pushrod on T-34
  87. Sneaky Ground!
  88. using electric starter long term
  89. Plane ever been attacked by a bird?
  90. Engine problems
  91. Any Article on how to make silicone gasket?
  92. How long should I be able to fly?
  93. WM Super Sports SR. tip
  94. Ft myers FL
  95. Monokoto edges no longer stick. Glue?
  96. parkzone stryker B 7,4 lipo on standard set?
  97. Spinners - plastic vs aluminum
  98. Tower Hobbies discount code
  99. Do I have to have an instructor?
  100. Fixing cloth hinges?
  101. Sail plane good for first plane
  102. channel number list
  103. Nextstar... To the limits...
  104. Found new Cessna on the side of the road! :)
  105. Robart Hinge Installation: dos and dont's
  106. Landing a PIG!
  107. Hobbico Nexstar Rolling left before takeoff
  108. Big Stik 40 Wing Lug Broken
  109. Why do the flaps hang down when the plane is off?
  110. Got me a new ride today.......
  111. Smoke with muffler pressure only
  112. Fuel tank alignment
  113. CA or Wood Glue
  114. Gas or Nitro
  115. motor question for parkzone decathlon
  116. help with Dubro Kwik Switch/Charging Jack
  117. So... Whats this rudder for?
  118. Please help!
  119. Hitec Adjustable Servo Arms OK to use?
  120. ultimate 40 need help
  121. ARF 3D? Which one and with what gear?
  122. How Much Trouble is A Glow Plane???
  123. Wheels Recommandation
  124. help me pick my RTF ??
  125. looking too fly
  126. Having Problems with nexstar engine
  127. Dripped Some CA Debonder On Radio
  128. what is it ?
  129. Great offer for new membership to AMA
  130. How funny can an RC plane be?
  131. Engine compression
  132. Charging 12v battery from power panel?
  133. where do i buy planes in sa, australia??
  134. 2CH , 3CH , 4CH , 6CH ??
  135. How to put hetic on typhoon?
  136. .35 to fit in a Avistar?
  137. Tower radio/Futaba receiver?
  138. Signal "shadows"
  139. Typhoon smoking!!!!
  140. Epoxy Hobbyco Nexstar Wings
  141. sig senior problems
  142. The end of my Cessna!
  143. Flight Instructor support
  144. plans pleez
  145. Micro reciever for 60 size extra?
  146. where do i start?!?!
  147. 2 1/2 year old first solo R/C Plane VIDEO!!!!
  148. Just got a GP extra 300s for first plane UPDATED
  149. Soloed
  150. Torn CA Hinge
  151. CAP
  152. Hi, I need help selecting from these 2 planes
  153. Look for a set of crystals for a JR setup
  154. Need advice please
  155. glowplug trouble
  156. Transmitter engine kill switch
  157. hole in wing
  158. Hitech Servos and Futaba
  159. Great Labour Day Weekend
  160. need pilot for h9 p-51 pts
  161. I really need help wiring this GP extra 300s
  162. Tower Uproar 60 kit
  163. ENGINE PROBLEM
  164. ASP Super Series, where to buy???
  165. newbie questions
  166. instructor opinions wanted; H9 P-51 PTS
  167. My Sig Fazer Build
  168. Gap in Elevator Hinge
  169. bipe
  170. 6 or 8
  171. replacing ailerons
  172. Sealing monokote
  173. JR to Futaba servo extension
  174. Hobbyzone Super Cub RTF
  175. Reverser
  176. is this a good plane??
  177. wheel pants: paint or cover?
  178. What plane to buy??
  179. Putting together my Sky Raider MK1 and need some advice
  180. Which Stick ARF
  181. Servos for the Sig Fazer
  182. Huge Servo Sale at ServoCity!
  183. RC Dvd's
  184. Odd Carb Problem...
  185. Tiger 2 vs. Pulse XT
  186. dragon lady arf
  187. H9 P-51 PTS ARF maiden flight.
  188. End of my season in NY.. Time to plan a build
  189. tiger 60 kit/which engine
  190. vibrations with Saito 82
  191. Help identifying servo and battery connector
  192. Electric ARF
  193. Im 50 years old and wife said find a hobby here I am
  194. My trainer scares me.
  195. Where to buy balsa?
  196. Balancing: with or without fuel?
  197. How Much Weight Is Too Much?
  198. new trainer
  199. Accident?
  200. New Flyer, Cheap Plane
  201. Fast Charging a Radio
  202. Easy Star Wing Assembly
  203. Canopy - Can I just screw it on?
  204. Technique for loose servo screws: help
  205. simulators
  206. new to gas
  207. digital servos in a trainer
  208. OS LA Engines
  209. newbie questions
  210. Fuel Dot
  211. About to start first build
  212. What happened to Pay It Forward?
  213. Nexstar Crash
  214. Rascal 40 - Decal question
  215. Tower Hobbies .46 BB abc or O.S. 46 AX
  216. 2C Or 4C
  217. Typhoon Battery-What size lipo?
  218. how high can an rc plane fly ?
  219. Cycling batteries without a "cycler"
  220. New Beginners Kit Questions:
  221. Super glue HELP!!!!!!!
  222. Ooops...First Crash Repairable?
  223. SECOND plane!!! :D
  224. My TT Easy Trainer .40
  225. Inverted 4 strokes
  226. PZ Cub to Twist 40
  227. Tx/Rx battery question
  228. Photos of Tyro Major
  229. AK field wife
  230. Charging Radio
  231. worldmodels 1/8 cub 26s
  232. Kwik Fuel Valves or ? - Cowl
  233. Transmitter Battery Question
  234. Gas tank leak - how can I prevent?
  235. Vintage Second Plane?
  236. Complete plane noob. Where to start?
  237. arrow 40 taildragger?
  238. Wondering about Control-Line Flying
  239. Brand spanking new neophyte in Miami
  240. What is the biggest plane a .15 2T engine can bring to flight?
  241. Recover or Paint Fuselage
  242. new engine wont start
  243. Frustrated with Covering
  244. Difference between FS-70 & FL-70
  245. installing a larger wheel?
  246. bec soldering issues, newbie in need of your help!!
  247. Aircraft progression
  248. Tiger 60 Rudder enlargment ??
  249. Saito Mounting
  250. Begin Air - Servo Issue
