PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. how many amps does a starter draw?
  2. New to RC
  3. Balance problem
  4. Transmitter Battery Charging
  5. Got my templates, let the cutting begin!!
  6. Washout ?
  7. Fail safe units
  8. Checking in from 30,000ft
  9. Flight sim goggles...
  10. OS 61FX leak?
  11. First Plane
  12. What would good numbers be for Magnum 91 4s
  13. Hobby Zone Super Cub
  14. pulse xt 40 owners
  15. Texas vs. Minnesota.
  16. RCS SV 17cc gas engine idle cut off
  17. need a sim on window 7
  18. Escapade
  19. South Eastern PA Folks
  20. Sig Four Star Wing Tips
  21. adjusting aileron servos equally
  22. looking for a new battery pack, any suggestions?
  23. Xmitter diode and field chargers
  24. Three- line setup
  25. Sig four star rebuild
  26. 4*60 build question
  27. How to decorate plastic engine cowls
  28. Storage
  29. conditions continued
  30. Taking dihedral out of Nexstar wing
  31. Dead sticks finally got my 60 size U-Can-Do
  32. Going gas
  33. Dubro inflatable wheels. What pump??
  34. mud in the engine?
  35. Breather Nipple on OS FT 160
  36. What kind of vehicles are good for transportation?
  37. Guanli 601 - how to connect aileron linkage to servo
  38. Starters - High Voltage
  39. My expensive Magnum 70 4 stokr don't run worth a Hoot....
  40. i just got parkzone p51, which glue do i need to fix it when i crash it?
  41. Fuel Type
  42. HOW TO PREVENT BIRD SHOT DOWNS?
  43. os max 46 ax prop size
  44. what a great weekend to fly in arkansas
  45. What is a gyro?
  46. Finally a warm day, but to much wind!
  47. what is the difference in these two coverings
  48. Avistar or Escapade for 2nd plane?
  49. Where to fly rc plane
  50. HOW TO CHOOSE THE RIGHT SERVOS FOR MY AIRPLANE?
  51. Great Planes Flight Flex (or something similar) for first plane
  52. arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh
  53. How can I be proactive with engine size?
  54. Can a simulator truly teach you how to fly?
  55. 3 cub setup questions
  56. Easystar reinforcement
  57. Engine suggestions
  58. New: Find Rc Flying Fields with Google Maps
  59. prop install order
  60. Looking for a Trainer in Charlotte, NC, area
  61. RC Fuel Cost
  62. Why do Stiks/Sticks fly so well?
  63. 3Ch.Trainer Rudder , Left or Right stick?
  64. Saito Crank vents
  65. Evolution TPS vs OS FXi
  66. Who makes this covering???
  67. control throws on alpha 60
  68. 2.4 Ghz Tx/Rx question
  69. RC car user thinking about moving to air.
  70. dumb epoxy qn
  71. HELPPPP!!!! Who's smart????
  72. Wing for Tower 40 RTF
  73. aviastar .53 vs magnum .52
  74. A question about engine types
  75. Im back with a new reciever quesion
  76. Super Tigre vs. O.S.
  77. need help with radio
  78. setting ailerons on a symmetrical wing
  79. when to stop trying
  80. 4 Stroke Crankcase Vent
  81. First low wing ?
  82. How much power can a Butterfly handle?
  83. another os120fs surpass problem
  84. how often do you crash?
  85. os 120 fs ???
  86. Cross Hairs on a Firewall problem, HELP!
  87. conditions
  88. Nylon Fiber Props vs Wooden Props
  89. VQ EXAN
  90. How much aileron slop is too much?
  91. New to elelctrics; need help with a motor
  92. radio system
  93. sig four star 40
  94. Throttle set up in Giant Super Sportster
  95. Aileron bevel help
  96. FUEL PUMP
  97. JR S300 Servo Noise
  98. Balanceing a plane
  99. Correct Alignment
  100. How Many Planes Do You Take To The Field?
  101. buddy box on 2.4
  102. Balsa vs Basswood??
  103. 6 channel radio
  104. Can you buddy box Hitec Optic 6?
  105. Mojo ARF?
  106. Recommend a prop for light plane.
  107. battery for 7.2V servo
  108. 2 Stroke R. P. M. To High ??
  109. Prop selection suggestions needed
  110. Crow ??
  111. My first maiden today with my Escapade
  112. OS 2-stroke high friction cut-out Please help!!!
  113. Help with a super stick fuel tank
  114. overheating esc?
  115. Peak Charger or Field Charger
  116. Volt Meter
  117. How Do I Know When Throw It Away
  118. speed 400 inline reduction gears
  119. Receiver batt question
  120. Discontinuation of JR's Radio Line?
  121. Mode I Purchase Advice
  122. anyone going to the flea market in lebanon pa?
  123. How to assemble a cox warbird
  124. Extra nipple on fuel tank????
  125. Seeing It Fly The First Time
  126. Dumb Rx Question
  127. Evo trainer system ( Problem with transition)
  128. How to land a trainer with a loooong glide
  129. Proctor Antic
  130. Tower Trainer & Magnum 52 4 stroke
  131. Dubro's Hand Fuel Pump Repair????
  132. O.S. 55AX opinions
  133. Trying to wire an Electric Motor to ESC - Help Needed
  134. question about c.g.
  135. fast EDF jets ?
  136. Expo question
  137. plane cam
  138. Anyone experience this with Ultracote
  139. P-40E Top flite
  140. futaba 2.4 reciever prices to high, lower em?
  141. apprentice battery question
  142. Toy Aeroplanes?
  143. Thumbs or Finger and thumb
  144. Custom Field Boxes
  145. O.S 91 four stroke starting problems
  146. Landing Gear Bolts
  147. real flight g5
  148. whats the best way to breakin ina os 46
  149. Any Ideas On Lightening Up an ARF
  150. Installing New Servo for Parkzone Trojan
  151. Finally soloed
  152. Suggestions for someone new to RC Planes?
  153. OS .46FXi wont draw fuel
  154. Painting foam plane
  155. 4 stroke
  156. New to me Spitfire
  157. Nitro exhaust gasket?
  158. Alpha 40 trainer Crash, need help
  159. Maybe Hobbypeople should change their engine boxes
  160. Parts for adjusto Jig
  161. three line fuel tank
  162. Futaba 7c Radio batterys
  163. Wire Landing Gear vs Aluminum
  164. 2 line gas Tank Adding Filler line a T
  165. Sideways or verical engine mount?
  166. Inoperative servo
  167. Tower .46 engine - to try or not to try?
  168. box of stuff
  169. What kind of hindge is this?
  170. FM Radios?
  171. Need Help
  172. Glow Plug
  173. NO GAP HINGE
  174. 2 fuel tanks?
  175. DAD WANTS TO LEARN TO FLY NOW TO PICK OUT HIM A TRAINER
  176. Flaps-possible with 1 servo on each wing?
  177. Magnum Pro 45 ??
  178. Servo specs page?
  179. Futaba Receiver
  180. Tower hobbies easy pay
  181. Rehinging help needed!!!
  182. Futaba S3114M servo adapter
  183. LANDING BEFORE EMPTY ?
  184. Help cuttin cowl
  185. Wall Charger for Receiver/Transmitter
  186. looking to buy a futaba 9c can i update it to 2.4
  187. Weighing the options
  188. Which engine, K&b40 or Saito 50?
  189. os 46 AX Setting??
  190. Getting into it....
  191. new with gasoline engines - help
  192. reciever and controler ????
  193. New Comer!
  194. Receiver / battery foam padding
  195. Bye Bye Birdie
  196. Radio Up Grade
  197. steel clevis upgrade
  198. Beginer Foamie
  199. Hangar-9's P-51 Mustang Mk II PTS
  200. Li-po Fire today
  201. Basic Questions
  202. New Decathlon canopy
  203. cable to carb???
  204. adjusto jig
  205. Cool Aerobatics with Alpha 40 Trainer (Onboard Video)
  206. Recieved my 15E Apprentice RTF today
  207. Automotive paint
  208. Need advice on a plane and engine combo
  209. Airtronics 2.4 rds8000 buddy box
  210. magnum .91 4 stroke grub screw size ?
  211. which one has more power?
  212. What engine on spacewalker
  213. Programming ESC's???
  214. I can wait to try this. So cool
  215. Long time no fly...
  216. Contaminated Fuel problem?????
  217. RC Aircraft Noob question - Electrical Setup
  218. 3-bladed prop size?
  219. Suggestions Neede
  220. need help with a dx6i spektrum controller and reciever
  221. Thundertiger Engines
  222. looking at the dynam super cub
  223. When to paint your covering?
  224. Mission complete
  225. How do I choose a 6ch set up?
  226. Cheap 2.4 System
  227. Good deal ??
  228. Anyone have a good source for OS or thundertigre 4 S
  229. smoke
  230. O.S. VS. SAITO???
  231. JBA Engines from Knox Hobbies
  232. HobbiStar 60 MK III ARF
  233. Hobbypeople got in my knickers
  234. New To Planes
  235. Fuelproofing firewall
  236. Escapade Wing Joiner Tube
  237. another CA hinge question
  238. Wing Incidence help
  239. Glues????
  240. cleaning engines
  241. Continuous tone from receiver
  242. Crashed my first flight
  243. Anyone know this plane?
  244. Remove dihedral tower trainer
  245. first time ARF need help
  246. New Jersey snow
  247. just ordered my First plane..Wahoo!!
  248. What am I doing wrong?
  249. Strange Propeller numbers.
  250. Mounting the AR6200 Receiver
