PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Christmas List 05/06
  2. Finally finished LT-40 kit!
  3. Multiplex Twinstar, help!!
  4. Are you supposed to balance wet or dry?
  5. coverite 21st century fabric
  6. How much wind is too much? Updated! I did it!
  7. How do you make a Nextar a taildragger?
  8. Finally, my Second plane (Easier to read)
  9. SKG's NexStar timeline
  10. Another beginner's build - SIG 4 Star 60
  11. Beginner Modeler
  12. Prop nut start?
  13. Small scale electric
  14. Hey guys,
  15. help installing a failsafe
  16. I you ever thought you could never fly an R/C plane, read this it may help
  17. newbie question
  18. Removing Dihedral, Taildragger
  19. crashed my nexstar...
  20. My Plane...
  21. balancing my plane
  22. Servio Connectors
  23. Gooey Exhaust???
  24. Just brought my first RC plane! Wind Spirit RC glider.
  25. Another Sweet Build thread (Venture 60)
  26. Extreme newbee question - transmitter
  27. Bad dayat the feild
  28. Need help mounting engine mount
  29. Big Stick or Duraplane
  30. Hitec Receiver help!
  31. What's with the percent (%)?
  32. Alpha 60 RTF 4 stroke conversion
  33. tighting a prop nut?
  34. Need advice/info on these two planes..thanx
  35. ** Looking for starter plane or any spare parts**
  36. 2c vs. 4c
  37. 1st dead stick oops!!
  38. Help, I broke my fin! (Vertical Stab)
  39. Finally did it!
  40. glow plug troubles?
  41. Wing Position
  42. Nexstar wing failure
  43. Clubs Near Carrollton Georgia
  44. Indestructible Trainer
  45. New alpha whoohoo!!
  46. Having trouble with my first tail dragger
  47. NEW KID ON THE BLOCK
  48. g-26 problem
  49. stupid trike gear, grrrrrr...
  50. Super Stick 60 need help
  51. QUICK HELP!!! On the way to the field..
  52. SIG Manual
  53. I am soloed now!!!
  54. Evolution of a trainer
  55. Is the match box ok now?
  56. FLIGHT PACK QUESTION
  57. would this biplane be a good second or third plane?
  58. New Build, need help
  59. Snark 2t
  60. LT-40 pushrod is a little stiff, help?
  61. nexstar advise.....
  62. Aerobird to Aerobird Challanger?
  63. cant decide what plane to get
  64. GWS ICS issue
  65. Beginners asking the same question...
  66. P-51D PTS What do you think?
  67. Where to get a field box?
  68. My beginner's plane - the Air Scout
  69. 25 size engine
  70. How do you?
  71. help!!help!! my s.c 25 wont run properly.
  72. YES!! just bought 4 star 40 kit, now need engine....
  73. Fuel Dots
  74. which plane to get?
  75. Need newbie guidance!
  76. disposable fuel filters
  77. O.S. .46 fx leaking ?
  78. engine recomendations...
  79. Help with spinner installation
  80. Hitex Chirstle
  81. Make a build forum inside this forum!!!
  82. Aerobird Challenger Motor Problem
  83. Uk laws on flying electric rc planes
  84. What a RUSH! - T2 first maiden
  85. Life of a glow engine
  86. Multiple Planes and recievers
  87. My first covering job..
  88. Exhaust Idea...
  89. And most guys think girls can't fly... Think again.
  90. I love my Nexstar
  91. Transmitter advice
  92. Planning to Buy Sig Kadet Senior ARF, Opinions?
  93. pulling!
  94. right fuel!!
  95. 3 channel flight
  96. WHAT PROP SHOULD I GET FOR MY S.C 25?
  97. plane goes round in a circle no flight
  98. choosing the correct fuel tank!!
  99. balancing props..
  100. Prop 10x6- what size spinner?
  101. Cessna 182 Skylane 40
  102. ama concerned
  103. scratch built electric rc
  104. RCM MAGAZINE. WHATS UP??????????
  105. Help with an O.S. .46 FX
  106. Easy Pigeon warped elevator
  107. Qustion on Evolution .40 muffler
  108. cleaning engines..
  109. Twin engine glow driver........
  110. Crystals Set doesn't match?
  111. Tower Hobbies Coupon Code? (getting geared up)
  112. Not your typical 2nd plane post...
  113. COVERING MY PT-40
  114. Flying a 25 size Piper Tomahawk
  115. Looking for a plane
  116. 2nd plane questions...
  117. CG problems
  118. best begginer airplane?
  119. LT-40 Monocoat'in questions
  120. The natural progression of skills....
  121. Four Star 120 question.
  122. Li-Poly battery charger for ParkFlyers.com Cessna 182...
  123. Anyone here have G3 and an electric Bi-Plane for it ?
  124. FLYING IN THE WIND
  125. sc.25 engine!!
  126. FLYING HELP . . . I WANT TO LEARN
  127. ESC problems
  128. Beginner Recommendations
  129. New To PLanes
  130. 3D Hype
  131. Reliable R/C shop in Hongkong or Shenzhen
  132. Questions about equipment
  133. Great Planes Combat Series- Where are the parts??
  134. Best Glue I've Found Review...
  135. my m8s 0.s 46 la
  136. Kamdax MiG build (Instructionsless)
  137. Funtana 40 recommended to beginners?!
  138. servo troubles....
  139. Normal color of epoxy after drying...
  140. Hitec Laser 4 TX radio setup
  141. mig-3 woes....
  142. Looking for advice in choosing my first Trainer
  143. Want to increase your OS .46AX output power?
  144. new brushless motor on Slo-V (help)
  145. arg...help please
  146. Sig Kadet Ep
  147. confusion on ailerons
  148. Electronic Component Compatibility
  149. How good is Carl Goldberg with their Warranty?
  150. solo questions.... advice please
  151. First Plane, I want Elevator Aileron, should i settle for Elevator Rudder?
  152. Batter Charge Time
  153. UK 3D Hype
  154. Solo
  155. Help with a Webra .46
  156. Do you use afer -run engine oil
  157. New To This, Need Advice
  158. Zagi Tazz vs. XS
  159. Muffler Seal?
  160. Covering 4* Stringers
  161. not shure what to do here..... help me out
  162. engine rust?
  163. A CHANGE OF SCENE FOR MY PT-40
  164. Looking for my 2nd aircraft!
  165. Father/Son 4* 60 Build
  166. How old is old enough to learn?
  167. Vegetable Oil Burning Airplane?
  168. Any swap meets in northern/central IL?
  169. Will this engine be to much?
  170. soloed and maidened my LT-40 today
  171. Cleaning fuel from balsa
  172. need advice with aileron Y
  173. os max pp 20
  174. splits
  175. What prop size
  176. Another 4*60 on the building board
  177. Help me please.....
  178. Any good intermediate books on R/C Airplanes?
  179. Cleaning fuel residue off aircraft ?
  180. Learn to Fly without an instructor
  181. I was looking over fly things products....
  182. flight time
  183. os 91 fs prop hanging
  184. filed charging a JR radio
  185. landing gear!
  186. A BIG crash, Help...
  187. sig somthin' extra
  188. LT 25 Mods
  189. Nexstar RTF - Bank right
  190. GLOW PLUG ..... MAGNUM 91 4 STROKE
  191. Hobbistar RTF and Field Supplies
  192. Glow starters...
  193. Need quick Help on what engine to get For my trainer
  194. First solo slow stick
  195. Lanier Explorer 40 Trainer
  196. thinking about new engine...
  197. getting into nitro planes, need help
  198. my 1st solo!!!
  199. I had an interesting flying time last night.
  200. maidend uproar and soloed stuka w/pic
  201. Test Pilot or Instructor
  202. Glow plugs don't glow....
  203. Carbon spinners
  204. Help With A EZ Bee II
  205. CA fogging on covering
  206. I FLEW THE P51 TRAINER FROM HORIZON TODAY
  207. radio problem?
  208. pete n poke maiden w/ pics
  209. How's the Tower Hobbies® Tower Trainer™ 40 MKII RTF
  210. Looking to move up or over from electrics to glow, what plane?
  211. .25 trainer
  212. Monokote Application Help!
  213. Tough to choose for a beginner.
  214. 3 trainers dead in 2 minutes with instructors
  215. Next plane????
  216. Houston Flying?
  217. Will 15% heli fuel work in a O.S. 46 LA?
  218. show ur planes people!!
  219. In katrina's bullseye?
  220. Prop size for Thundertiger .61GP
  221. Should I cut my losses now?
  222. Engine rev-up problem
  223. Taking the plunge....Advice needed!
  224. What voltage is too low for RX battery!?
  225. engine surges in mid air ?????
  226. Looking For Radio Advice
  227. question on maiden flights
  228. Dual Ailerons and Elevator
  229. Bigginer what plane please
  230. How ofen should I change glow plugs?
  231. balance at CG
  232. 60 size trainer recommendations?
  233. TT Pro .46
  234. battery question
  235. Help me Please ... Thanks
  236. Nexstar Simulator vs. Real time in the air
  237. Another prop question?
  238. .46LA or .46AX for 4*40
  239. Something Extra COG
  240. help me out here...
  241. PRO-PELLERS??
  242. Midstar 40 cg...up or down???
  243. flying questions...
  244. TURNING A 2 BLADE SPINNER INTO A 3?
  245. os 61 muffler question
  246. Electric Trainers! Are there any good ones out there?
  247. Super Tiger G75 Muffler question?
  248. finally finished the pete n poke
  249. Has any body used 10% Omega in a 4 stroke ?
  250. P51- TRAINER FROM HORIZON
