- Newbie Question.
- .46FX much smoother than .40FP
- Looking to get into Electric R/C planes...................
- 2nd Plane: Pulse vs. 4 Star vs. Tiger 2?
- ALPHA 40 RTF RADIO PROBLEMS
- Transmitter question
- First Kit Build Question
- The NexSTAR flew today!!!
- Choices, choices....
- Nexstar which Fuel ?
- Flying Simulators
- landings and takeoffs/Field Types
- How to choose the correct servo?
- Solo Flight
- Multiplex Easy Star upgrades
- Guess what I won
- Evolution engine backfires
- low wing trainers, what to look for?
- CONTROL THROWS
- TACHOMETER HELP-NO READING
- New Pilot
- You Crashed! So what, REBUILD!
- Transporting your aircraft?
- Just thought I would ask this...
- Can you help me decide?
- Fuel tank sliding back fixed
- Found an instructor
- Stryker F-27 for a starter plane??
- Test Bench
- Clear View flight sim...
- Am I a noob ?
- another question
- Crash and burn!!!!!
- Power Panel and Battery Leads
- Need help for build (first build)
- Covering tools?
- No Muffler!!
- bad reciever
- Pcm 146IPvs Fm 127DF
- learning on a cub?
- How the He** did I end up with 2 logins.
- FS One P51 PTS model
- Sig something extar Build
- tips for going vertical
- Beginner WWII Scale Warbirds
- Evolution Trainer Power System
- Futaba Conquest 4 or Attack 4
- Please recommend some prop sizes
- Setting up my aerobird extreme
- evolution .46 still cutting out
- wood filler...
- How to balance a low wing plane?
- Hinge slot cutting question for LT40
- Wireless camera newbie
- Pilot Update... and a Question
- Cockpit to print!
- Receiver freq. Question
- Use Old Radio ?
- Somebody kick me!
- new flyer with spare parts
- What can cause the glow plug to fail
- flew tower 40 first time now some questions (short flyby clip)
- Beginner Semi-symetrical or Flat Bottom wings
- High torque servos
- Capacitors
- Anyone hear of this plane? PHOENIX-2000 Electric RC Airplane RTF
- Thumbs or fingers?
- Pull-pull on a 40 size?
- Source for fuel line shut off clip like used on helos?
- What you guys think about this radio?
- 4* 60 and Tiger 60
- recommendations for electric fliers?
- elevator sensitivty
- Beginner with a super cub.....SO EASY!!!!!!
- Prop Rotation
- Joining a club
- engine mounting on profile plane
- help me please
- Reinforcing aerobird challenger
- Battery charger
- Nexstar...Air Brakes yes or no?
- Fuel tank slides aft...
- Proper engine tuning questions...
- Its mine all mine.
- Trainers vs. electric park flyers.
- Show us your trainers !!!
- Problem with prop coming loose
- Baltic Birch vs. aircraft ply
- How Windy Is To Windy
- more movement from control surfaces
- 4* 60 wing rib outline...
- FMS flight sim controller...
- How much torque is needed for a throttle servo?
- I
- Low Wing, Tail Dragger, Trainer
- can i make a 3 channel plane !!
- engine cut off
- T-HAWK advince for new buyer
- Need Expertise on Zagi 60" radio
- tail dragger prob.
- Recommendation on good 2nd plane
- Butterflies, still get them
- What can your Local Hobby Shop do for you ??
- Radio transmitter to reciever question
- Sanding expert
- New Builder Requires assistance.
- Servo advice for a trainer
- Is a bigger plane better to train with?
- Simulator and trainer for 9 years old
- question about servo extentions
- 2.4 dsm modules for all major brands
- Throttle servo binds
- alignment of motor
- Good small field fliers
- Spraying latex
- New RC builder kit help
- Sig Somethin' Extra Kit
- Can the Sig LT 40 be converted to 3 ch?
- SLO V
- Setting idle speed with tachometer
- Fuel?
- CL to RC conversion?
- trimming with monokote
- New pilot
- new to rc planes need help
- Sr-falcon
- Where to fly?
- Help me fix it! please ...
- WING HOLD-ON BANDS - couple questions
- 2nd purchaseto be done at an auction
- Sealing Hinge gaps ?
- AMA's Introductory Pilot program
- Detail Break In routine ABC /ABN Checksheet
- What Age
- .46
- Warped Aileron Stock: What to do??
- This Hobby Saves Money
- What is Tail Moment?
- What's washout?
- Getting a slow stick ? ? ?
- Removing monokote
- Newbie needs Advice
- bubbles in fuel lines
- Help needed quickly!
- RC and Technical Education...
- SYSTEM3000 Beginner's question
- Noobie Needs help with E-starter
- Landing in a field?
- Installing fuel cap fitting on gallon container...
- Can a Receiver(Rx) get failed during flight
- P-38 Kit, Build Begins..
- hello everyone
- Dual Aileron Servos - Y Cable or Not?
- trimming surfaces in flight?
- first time out typhoon 3d
- What plane is this?
- New to Flying Planes Nead Advice????
- crash
- rc plane
- Flying in Rain? Good or Bad?
- Lowest Temperature For Flying an Electric RC?
- Trying to understand proper Break-In
- Found my fuel leak
- Lucky Star 25 trainer any good?
- Nexstar Landing gear Repair
- Moose Can Mufflers
- Covering "Symbols" technique question
- gws r-6n receiver
- Engine size for ARF
- motor mounting
- What Engine Manufacturer?
- hello
- Next step
- battery care.....cycling
- What is the most popular Trainer/Engine/Radio?
- What to look for in a new nose cone/spinner
- Going solo-no instructor
- Paper pipe gasket
- Glow Plug Help
- Radio/servo problems
- Fuel Issues
- leaking muffler
- custom build
- Mini B-17, balence problem! Help!
- enya 604c exhaust
- CG- Measuring in. to cm.
- Quickie 500
- Fuel flow question
- First Timer - Need Help Choosing Trainer
- So.. Ya.. I broke my iron...
- Can't start my engine on new NexSTAR
- setting the controll throws with a futaba 7 cap
- Park flying
- What's the best way to attach my fiberglass cowl to my fuselage?
- anyone out there with dx6? help please!
- Learning to build with videos
- Which flight box?
- After run oil...how important?
- recommendations for low wing trainer
- Servo Buzz
- Engine run question
- Yet another battery question
- wierd question
- Prop?
- Too many decisions! Arrow vs. Avistar
- The History of RC airplanes Documentaries
- a question about using aluminium spinners
- would this plane be ok to mess around with?
- How to tell if battery is going bad? voltmeter?
- servo dancing at switch on
- CG PROBLEMS
- Evolution .46 problems
- Sig Kadet Senior
- Help me with the colour of my plane
- Best Gas plane?
- Best radio to get?
- Haven't flown in 6 months...need help
- Looking at a PT-20 for first plane
- Simple servo question
- Just bought new TX RX batteries....what is the proper care for them?
- firewall protection against fuel soaking
- Question about RX
- I spoke with an elderly gentlmen today..
- Helllp me! GP or EP?
- Fuse Covering Bubbling ?
- Tower Trainer ARF 60 MKII Speed
- H9 Alpha Trainer 40 or 60
- Avistar right wing needed
- Futaba Transmitter w/ JR Receiver
- First time with retracts
- New to RC aircraft
- Cutting the Cowl
- Beginners Aerobatics
- How to build from plans?
- Balsa USA stick 40 plus design ?
- Battery Question
- Pattern Plane
- Crystals
- Engines
- How bad did I mess up?
- Moving up to Aerobatics
- nexstar speedbrakes removal
- Engine Cleaner Basics
- Setting the Center of Gravity on my .46 trainer??
- Help me chose a 2nd plane
- The F-22 raptor
- newbies please read...and enjoy this great hobby
- anyone with plans for PT 40 trainer?
- foamy's first
- Radio problem
