View Full Version : Beginners
- install those jam nuts!
- ? re fuel tank placement
- Good Online-shops?
- Re: Plastic clevis pins
- Let me tell you exactly how bad I got it...
- US 120--? removable wing
- wheels
- Futaba 6YG or Hitec flash 5X???
- Found my break in stand
- Begginer's Question
- Astro Flight 02
- Aileron issue...
- Kits???
- Hinges Help etc...
- Electric Trainer Recommendation?
- Low Wing + Co-pilot = good trainer?
- Crazy story
- bubbles, tiny little bubbles
- Balsa Dent Removal
- What the heck is this???
- Graduated!!!!
- Primer Other Than Lustrokote
- Trike vs. Tail Dragger on Sig Kadet Senior ARF
- Beginner Equipment? Spadet?
- biplane wing supports
- engine break in stand
- Just a couple more "What's better when learning" questions
- Low Rates/ High Rates?
- How do I know which servos?
- FighterBird, GONE, GONE GONE!!!
- Bad Glow Plug Starter? Can't start engine
- What is better when learning?
- High wing vs. low wing
- REAL flight experience when learning to fly
- Which ARTF Trainer?
- Sig Something extra
- Advice: Pt-19
- Options
- Aerobird VS. Sky Scooter Pro
- Aerobatic!
- Sheeting outer balsa wing panels
- Anyone have experience with Aerobird?
- Spinning Muffler on Alpha Trainer
- How do you pay for stuff
- Advice:Sig 4*40
- when is ok to fly
- flair technique
- hinge gap
- enya 4 stroke?
- LT-40 CG location
- 11x6 to 10x6
- is this a good radio for the price
- Comming Back AGAIN
- enginetrouble
- help w/GP PT19 & G23 engine
- GP cap 232
- fuel tank size
- Pushrod connectors
- Starting O.S .25la
- i am looking for a biggner plane
- ca hinges
- Jr radio!
- Anyone have the TT Carrymaster
- Saito 150 too much????
- I'va had it...
- Foam covering
- Sopwith Pup
- Apha trainer?????
- Wing Joint Reinforcing..need advise
- Wowww! 25 min flying time with sky scooter
- agreed
- quick fueler for glow engine on cub
- Low Wing instructor?
- How do you "spin" and airplane?
- Dubro Hinges
- ca hinges
- First Kit Builder...
- Sig or Not to Sig that is the Question ?
- prop size for os46 la
- Tchannels?
- Old Epoxy
- Tower .46 sometimes runs backwards!
- I know...another newb trainer size post (Giant Scale)
- Miss Los Angeles
- New interest in the sport
- Radio choice's
- Beginner Brain Blowout
- Broaden Your Horizons!
- Help with my 4* cowl!
- Throttle pushrod installation
- Bending Wire Struts For Retractable Gears??
- ringed vs. nonringed
- ENGINE MOUNTING{SIDEWAYS} Newbe needs help.
- propeller size which flies slower? larger or smaller
- engine for world models cub
- servo mounting problem
- Help!!!
- Sig Lt-40 To Warbird / Input Needed
- .40 LA for a Durastik?
- What Airplane with these components?
- I need some clarification of radio systems.
- hobby shops in Ottawa
- Getted started, radio, etc?
- Went the my LHS today!
- Tail draggers for beginners (and some pro's)
- Damage TX/RX
- Beginner!! Need help!
- Throttle set -up question.
- *** What A Prop Will Do To Your Hand*** "NO MORE PICS"
- K&B engine
- clevis ends
- What size beginner should I get?
- ***What A Prop Will Do To Your Hand*** Pictures On Request!
- Covering repair on ARF
- Balancing Prop
- gws slow stick "flight pack"
- A R C Ready 2
- Glue help!!!
- Vmar Corsair Wheels Broke On Landing!!!
- coordinated turns ??
- First flight with sig 4*
- Recommend my 2nd Plane, Please
- Should I get a Simulator or a RTF?
- Breaking in Tower .46pro-help needed!
- Engine Trouble. Please Help
- What is the good brand of RC glow plane?
- Latex foam better then soft foam? FREE FOAM BY THE TONS
- Electric flight eBook for beginners
- What's mah?
- Need Help setting up Trainer plane
- Any such thing as a low wing trainer?
- Good Lessons Page
- Losing radio signal during flight?
- PT40 wing washout
- Re:` Hobbico hand crank fuel pump
- Cox "Electric Sundance" Airplane
- Elevator, Aileron Throws- 1mm too little-Problem or not?
- Left Handed Mode 2 ?
- Good shop to to buy all I need?
- Is It Safe To Use Bondo Autobody Filler On Abs Plastic
- Question
- Newbie Radio question
- tower hobbies 46
- Am I missing something?
- 4 stroke??
- engine for trainer
- JR Transmitter Battery
- should i or not?
- First flight!
- Tower 40 RTF Servos Humming
- Sig 4* 60 nose tail heavy?
- Good Radio's?
- How to learn the skills faster?
- Warbirds/Warships
- Nyrods: Expansion/contraction with temperature changes
- Engine mount
- Ducted fan vs External Propeller
- help radio problems
- Just getting started, and could sure use some advice
- Newbie Ques: RX Antenna routing on glider
- Info on the Ready2 or the Jupiter
- Make this model RC? or not RC that is the question
- Need Advice on Picking an Instructor and Club
- Picking my plane
- Newby with $$$ question
- Starting in RC Planes, need suggestions.
- wing incidence??
- I need help deciding everything!
- Basic Questions
- STORAGE HANGAR
- length of runway to take off?
- Dihedral braces ??
- Color patterns for an LT-40 Trainer
- 2 Questions
- New here, anyone from Minnesota?
- Rudder Mod for Four Star
- Tower Hobbies Customer Support Horrible!
- Lighting Switch
- City flier for a newbie!
- Preparing for a potential dead stick landing
- HELP what trainer should I buy???
- Flap controlled remote glow?
- Securing self adhesive lead weights
- Prop Pitch
- Os Fp 40/tank Needs To Be Cleaned?
- can you mount an engine at a 45 degree angle?
- Help
- Just got new plane-Do guys fly this time of Year?
- Firebirdxl
- airplane categories?
- Duraplane trainer???
- UPS or FedEx
- Motor size question
- LT-40 Questions
- Mirage 550
- Best Trainer
- The Best Trainer
- FMA Co-pilot
- Gp .20 Cub
- Hello to all
- Looking for Tips writer for website
- Throttle control
- How do I add dihedral to GP 81" ARF Cub?
- solider control arms....won't stick!
- right thrust??..
- PULL - PULL CONNECTIONS?
- My first flight.
- RC Boats build skills for first flight
- First Flight
- What is a Cline Regulator?
- Wing Dihedral on Kadet Mark II
- Too much elevator on my Avistar?
- OT Space Shuttle
- Plastic + Foam what glue? CA+or Epoxy?
- TH Super Star Select 40 Crash tester
- help is needed
- Will hobbieco replace bad ARF
- P-82 Twin Mustang
- New to gas airplanes but not new to RC flying need help with ARF's
- Thrust measurement
- New Boy On Block
- Tower Hobby new BIG trainer
- airtronics
- AVistar/Trainer & steel leading edge rod
- Fuel proofing Field box
- Mutiplex Radio gear
- 20 Pound Bumble Bee
- Barndoor ailerons and RC books
- Another Newbie Jumping on the Train...er, Plane!
- Batteries
- Where to find an instructor?
- What type of Foam
- battery charging???
- Hitec to Hitec buddy box lead.
- Help me pick an easy build
- servo extention leads
- rudder/alieron mixing
- What is the best electric trainer?
- Control Line Plane Converted To Rc
- I'm a little nervous
- First Plane and a Kit at that?
- balsa filler problem
- .46 FX on Avistar
- Pressurized Fuel Tank
- Need urgent HELP with a plane im building please
- Orderd my 2nd Plane!
- Goldberg models...?
- How to best clean an engine?
