View Full Version : Beginners
- Taking the prop off
- 1/2a
- Better way to tighten the prop?
- Slow poke 40 sports
- engine oil
- glass covering
- Magnum GP 10
- Right Thrust
- next plane after firebird(slowflyers)
- looking for a good trainer
- Horse Power
- Building Albatros D III. by FunAero
- Range Checking...
- Re: GLOW PLUGS # 3 or # 8?
- Basic Aerodynamics
- H9 Easy 2 first flight easy!
- Wattage Wind Cruiser
- A few newbie que's
- Prop size!
- Gold Sticker
- Next Plane After Firebird XL
- a good trainer
- prop nut
- Question for the prop experts
- HOW REAL IS IT?? (RealFlight G2)
- Second Plane?
- Hirobo XRB Help!
- Recommendation for Beginners and a Question
- Cant Start Engine
- Modifications for sig kadet LT-40 help needed
- Quick Question
- Prop size vs engine size
- Question on wing.Keep together or take apart
- Need advice on Fuel fill adapter
- Removing CA from fingers
- Newbie web page information
- Electronic buddy-box release
- repairing wing... ouch.... I soloed...
- Best Trainer
- fuel proof paint
- wrinkled covering
- bingo flat spin
- Eindecker 46 SFM
- electric motor and battery overheating?
- Heli Gyro for H9 Cub J-3 rudder?
- Trim Templates
- how do u guys check for CG? i am a noob
- Hanger 9 Alpha
- Measuring travel rate...
- First glow plane
- First Flight, First Solo
- good plane yes or no
- How do I take off?
- Types of glue
- Sanwa Web Page
- Sport
- Prop Selection?
- Engine for trainer?
- Loose Clevises - What is going on?
- Sig Rascal 40 ARF vs. Sig Kadet Sr. ARF as trainer
- place to get new batt. for Tx&Rx
- My first flight
- Duraplane vs. Hobbico Sturdy Birdy
- engine question
- Beginner questions
- Newbie Questions, first ARF Piper Cub
- Crashed My Trainer, what's this wood called?
- Futaba or JR?
- Fuel Lead Question
- Robart Fuelers....
- Help, I'm new and need a plane
- First Plane Assembly Help, Fuel Tank??
- ultra stick and jr652
- Propeller question
- Expensive lesion learned
- "Range" Checking your Plane
- JR - R610M Receiver question
- Control Rod Question
- good plane - yes or no
- CG machine ?
- Happy New Year
- First plane - Projeti
- Engine Troubles
- Sig 4 * Questions?
- need help for a young lady in Orlando
- Warped Balsa Sticks
- Engine Question for Trainer
- Venture 60 questions
- Where/how to add tail weight?
- Building from plan
- Do you recommand this?
- New Engine Break in On or Off
- Aileron Hook Ups
- First flight!
- what should I buy
- Hinges
- RTF planes
- Hitec micro 555
- tail wheel
- Our new club
- Just starting with kids
- Hanger 9 P-51 ARF Flights
- New Memebr needs help: I keep crashing
- I finally got my first two planes
- Question Re Attaching Control Rods to Servo Arms
- how perfect does it have to be
- Model Combat
- Real Flight G2 RC Simulator
- New plane setup....
- Best Plane for a Beginner, that will stay fun
- Got my first plane!
- Prop Material/Design
- tower hobbies
- Questions on prop balancing
- covering repair
- Engine thrust vs airplane weight
- whitw glue
- Reverse wing plan
- Book Recommendations
- O.s. Or Saito?
- Please read!
- Grass Takeoff & Landing Help
- Contender 60 Maiden
- Apward and Sal_11 Dec 26 flying
- HOBBICO'S R/C Multimeter
- Landing
- Lazy Bee Kit Good Or Bad
- Glow Fuel Setup
- First plane
- Safty Warning!
- Helicopters
- storage of batteries for winter
- Beginner Flight Problems
- Flight Training
- Second Plane?
- Fields near Upland/Pomona CA
- Engine / Radio switching?
- How can I find out what my old r/c trainer is worth?
- delta wing
- How to create smoke??
- Engine Question
- .21-.26 4-stroke
- Trainer recommendation?
- Looking at Phoenix scanner .. anyone got one??
- Cost cutting vs. reality
- need an exhaust gasket fast, with household materials..HELP!
- Wing Loading
- i ve bought a irvine tutor 40 as my first plane is this a good choice.
- What does "Pitch Coupling" mean?
- Second flight goes well but..........
- Good source for RC
- Time to switch hobbies; Need some suggestions
- wanting to buy a plain cheap
- Os 52 Surp Heli For Airplane Use?
- Columbia-Mid Missouri Flyers
- NOVA Flying Clubs
- Beechcraft Baron 58
- Control Flutter and Hinge line gaps (Myth revealed)
- Calculating Wing Loading?
- solartex fabric covering
- Airplane Wing
- CA verses yellow elmers
- gap sealing- conflicting reports
- ARF for first trainer
- Is this a good price
- Question: How many get past the first trainer?
- Clubs in Southampton, UK.
- Cowling
- Great Planes REALFLIGHT
- Is "loading up" normal?
- FOAM cutting
- Help...drilled hole into fuel tank
- Balancing
- Any Expercience with Hanger 9 Cessna 182 as a Trainer
- Info needed on starting a new club??
- ultra sport 40 +...good second plane?
- Rudder issues ...
- X-EC Diversion Help needed
- My LT40 wont turn!
- 40 xls compression problem solved THANKS ALL
- Chanel Problem
- spinner out of balance???
- Lost my first plane
- Worries about first build...
- looking for a good starter plane
- Where did CA Hinge article go?
- Maneuvers
- J3-Cub Fabric Recovering
- Newbie
- Third Plane
- How do I make a home Made Starter
- Engine Vibrates at idle
- What type of servos?
- Beginner's 2nd Plane
- rechargeable alkaline batteries
- Sig Senior ARF Suggestions?
- Voltmeter Question?
- 1st low wing?
- 2nd Plane.......
- Setting up servos
- what two stroke engine for my new plane?
- LT-40 Landing woes
- what type of prop for a os 46fx
- new magnum 40 xls seems like no compression help !!!
- My First Plane - alpha trainer
- Does anybody know if it's possible to download a beginner flight simulater?
- RC airplanes
- balancing my scratch built?
- Avistar for G-2 ???
- 1st electric?
- Cap 232 Tip Stall Vs. Snapping
- Opinions On Good Preparation For Bipes
- Old Beginner
- First Flight Jitters
- Moving on to second plane--4 star .60???
- Having trouble getting MDS .40 engine to keep running
- Hobby-Lobby How-to page
- Which Kit?
- What speed will my plane fly??
- Hey guys i have just bought a plane is it any good?????????????????????
- New...have a building question
- can I start with this plane
- Four Star 60 - Do these pictures help
- Wingspan whats the difference in size's?????
- Winter flying?
- battery question
- EPP Wings for new flyer
- Buggy or Truck
- An EPP Wing for a new flyer
- Tx Rx Matching !
- Ultra Stick 60 Balancing problem
- My proposed plane
- I've Finally GOT A PLANE
- Props...
- Connecting Pushrods
- Hey im a beginner witout a plane yet and im gettig places thanks to yous guys
- Apward & Sal_11
- Hey Santa, May I have a model airplane for Christmas?
- TX RX matching
- It's Here....Now What?
- inexpensive plane for my son
- Extreme beginner help please...
- H9 Easy 2 assembled as a taildragger
- I can fly a heli, I want a plane.
- What is ground looping?
- Reminder -READ THIS!
- G&P sales p-38
- RC gear and covering for my Fokker DR1
- Kit errors!
- can i trust this person?
