PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Flapperon tips/advice and pics!!
  2. What does an auto-pilot device do?
  3. Balancing the Nexstar
  4. What is a closed loop rudder?
  5. Help with 3 needle valves on Magnum required.
  6. what's the point in having the steering wheel up front on a trainer ?!
  7. Here's our trainer! (A work in progress)
  8. BEST NEW GAS TRAINER TO BUY!
  9. Rudder Controls
  10. 1 Day = 3 maidens!
  11. battery charging?
  12. Flaperons on 4*60
  13. Need Advice for Trainer
  14. Gluing foam
  15. Servos
  16. Epoxy Wing
  17. Need Parts Help 4 T/F FW190D9
  18. Buddy box connection
  19. Elevator travel
  20. Elevator travel
  21. LOOK@ Superstar EP electric to gas !!
  22. CA
  23. nexstar simmulator
  24. is my engine possessed
  25. Fuel soaked radio gear
  26. Need Help!fuselage problem
  27. Tips and thoughts:-)
  28. Did you crash on your first flight(s) ?!
  29. Did you crash on your first flyght(s) ?!
  30. Q: Perfect needle setting for flying on the .46 AX engine ?
  31. fuel fittings question
  32. Servo Wire
  33. Landing
  34. My Great Planes PT-40 MKII setup. please check out
  35. Happy New Year RCU
  36. TIP: when zero'ing out your ailerons...
  37. YS 63 Or Saito 82 A
  38. servo
  39. hanger 9 alpha trainer
  40. RTF unable to trim
  41. Happy New Year
  42. Superstar 40 tips
  43. Will My Plane Fly?
  44. Hobbistar 60 (Overpowering)
  45. help me add washout
  46. strengthening U-Can-Do 3D .46 fuse.
  47. Removing Wrinkles
  48. Radio setup for U-Can-DO 46
  49. Too much blue loctite
  50. Is this possible??
  51. Wing mods for nexstar select
  52. Sullivan Electric Fuel Pump any good?
  53. Engine Plumbing for Dummies
  54. AMA Co-Pilot
  55. Lanier Stinger 40
  56. a dumb balancing question
  57. HELP!
  58. 2nd Plane & Radio
  59. Quick question about power panels.
  60. tower voyager
  61. futaba 6exa??
  62. my first rc plane?
  63. fuel pump?
  64. where to find parts
  65. Can I put an ABX 540 on a slow stick?
  66. Most embarrasing moment with CA glue
  67. New ESV , help please.
  68. Take-off advice for a Piper J-3 Cub
  69. First Plane
  70. Super Tiger 45 engine
  71. Firebird outlaw
  72. Pull pull rudder setup question...
  73. Hobbico Superstar EP convert to gas ?
  74. Avistar Engine Help Needed Please??
  75. Sig Kougar
  76. Ultrafly Cessna 182 ARF
  77. Engine Position
  78. Ski Question
  79. My first plane, any tips or advice?
  80. Warplanes
  81. Saito Engines
  82. CA Glue on Fingers
  83. Beginner Airplane
  84. Covering a solid balsa wing (recurring wrinkles)
  85. Ya think these will work on a Nexstar?
  86. instructor in nc
  87. incidence meter question
  88. engine help
  89. Stinger 40
  90. Plane Damage
  91. 2nd plane expectations
  92. Futaba 7UAF vs 7UGF radios
  93. what u guys get for christmass
  94. Q: How can I recharge my 12-volt field battery ?
  95. Wings under the fuselage?
  96. NE Houston, TX Beginners: Instruction
  97. Break in for new OS46 fx
  98. HAPPY HOLIDAYS TO ALL..YOU GUYS ARE THE GREATEST
  99. Here's wishing a special thanks to---
  100. Aerobird Challenger Motor Selection
  101. Four stroke fuel
  102. electric starter
  103. Best 3rd Plane ?
  104. Three blade VS. Two blade
  105. Robinhood 80
  106. What!! no forum for engine ?'s
  107. r/c Christmass carols
  108. Extra Easy Drawings + Cross Sections
  109. Order of building..
  110. First Plane Flight...
  111. Center of Gravity
  112. Radio Ergonomics
  113. Trim on a Plane
  114. Any good gas PT-17's out there?
  115. Question???
  116. Hobbico Superstar EP with brushless
  117. What can you get your trainer to do?
  118. almost done
  119. Fuel soaked Balsa Repair question
  120. Merry Christmas and thanks to all !
  121. First Covering job pics!
  122. Is it important to mount the engine dead center of the firewall
  123. seagull space walker
  124. Hinge slot question?
  125. Prop/Engine marriage?
  126. Kit Building..
  127. Got pretty sweet deal from my uncle!
  128. 4 Channels 5 Servos?
  129. Model hold back devise
  130. Attaching nylon clevises to piano wire
  131. HELP! URGENT!!
  132. Field Box
  133. Pay it forward, the payoff!
  134. wat else do i need?
  135. Monokote
  136. How many planes do you take to the field?
  137. ENGINE SIZE QUESTION
  138. Weighted spinner on 4 stroke?
  139. Glassing question?
  140. Power panel and field charger in one!
  141. Wing building 101(washout?)
  142. Anybody like the Wattage Cessna?
  143. Quick Servo Question...
  144. when did you buy your second plane?
  145. good day turned bad
  146. prop numbers
  147. finally solo
  148. Duraplane Trainer 20/40 vs. Hobbico Sturdy Birdy II
  149. Windy States/Countries:-)
  150. prop flying off
  151. Engine Sizes..
  152. Prophex's first plane
  153. For the battery gurus!!!
  154. How Fast?
  155. Aerofly Professional Deluxe USB
  156. field box
  157. MOVED: AP Hornet .09
  158. Any flyers in NYC?
  159. transmitter question
  160. Muffler screws
  161. Muffler for .40LA
  162. ENGINE/PROP RELATIONSHIP
  163. Another 2nd plane thread
  164. wing balance
  165. Fuel Dots?
  166. starting & priming??
  167. Are sailplanes any good as trainers?
  168. Trainer G-loading
  169. Easy Beginner plane
  170. Best Engine
  171. Evolution 61 Engine
  172. Are Ultimate Combos a good idea?
  173. PLS EXLAIN DUAL CONVERSION RCVR??
  174. Katana Edge540 or Yak54 Please Advise
  175. clever ways of crashing
  176. Home-made starter???
  177. O.S. 50 SX vs .61 FX vs 70 Ultimate for a Fantasy
  178. Battery Question
  179. cant figure out whats wrong with engine
  180. looking for new color scheme!
  181. QUESTION ABOUT RC/U POSTING
  182. One more question Please help!!!
  183. MDS 40 wont start
  184. GP piper 40 wing drops
  185. VMAR PC9 or H9 T34?
  186. futaba radio's
  187. Is one of these three the right engine??????????????????????
  188. Color of Plane???
  189. Maidened my 4 * 40 this weekend
  190. 12 volt power supply?
  191. Great Planes G-2 Sim is GREAT!
  192. World Model Super Sport 40
  193. Returning back after 8 years. Need help.
  194. O.S max 46la engine problems
  195. Engine size on Kadet LT 40
  196. Question about Airtronics Servos
  197. calculating wing area
  198. Plane climbs after trim........
  199. getting back after 20 years...are old planes still flyable?
  200. receiver question?
  201. first time flyer
  202. What would be a good one.
  203. Wing Twist Problem
  204. Nitro helper
  205. everything for beginner
  206. Is it possible.
  207. Transmitter Cases
  208. Engines! So many Types, So many Options.. HELP!
  209. How about this plane.
  210. wingtip washout!
  211. Second radio?
  212. New Plane right one?
  213. Is this plane any good.
  214. Fuel proofing a field box
  215. H9 Ultra Stick 60 & OS FX91
  216. A Beginers Guide to RC.
  217. NEW to FLYING
  218. TT Decathlon as a "Second Plane"?
  219. Cowled engine fueling
  220. bomb release
  221. question about first plane?
  222. I need some help please
  223. top flite contender gold series w/ saito .56
  224. Advise on Radio Programming
  225. Cutting Pitts muffler
  226. Loosing my fear of covering
  227. New to R/C Aircraft
  228. Q: running in an engine on the bench, how ?
  229. prop nut comes off
  230. Diesel engines (Irwin .40) opinions
  231. Advice on FIRST RADIO & PLANE?
  232. TX modules
  233. sig 4* 40
  234. 4 stroke third connection?
  235. Engine question
  236. Use of EZ connectors
  237. Do I have an air leak?
  238. a question
  239. Whats better than an avistar?
  240. Question about Clubs?
  241. Tiger 2 Arrived!
  242. Prop change for Nexstar
  243. Trading?
  244. Thrust angle for Superstar?
  245. Cutting Cowling
  246. trainer flat bottom airfoil
  247. NEW TO R/C
  248. Looking For good Trainer
  249. Flaps mod for nexSTAR ?
  250. 3 blade prop on nexSTAR ?
